1000 Eaton Boulevard
Cleveland, OH 44122
United States
24-Port 1U Rack-Mount Shielded Blank
Keystone/Multimedia Patch Panel, RJ45
Ethernet, USB, HDMI, Cat5e/6
MODEL NUMBER: N062-024-KJ-SH
Highlights
24 blank cutouts compatible with
all Tripp Lite keystone jacks
Fully shielded, heavy-duty steel
construction
Rear cable manager keeps
cables organized
Numbered ports for easy
connection identification
Mounts into 1U of EIA-standard
19 in. 2-post or wall-mount rack
Package Includes
Manages and organizes input and output cable connections in your network. Customizable solution for a
variety of applications, including Ethernet, voice, audio/video and USB.
Description
The N062-024-KJ-SH 24-Port 1U Rack-Mount Shielded Blank Keystone/Multimedia Patch Panel manages
and organizes the cabling in your network. The 24 blank cutouts accommodate all Tripp Lite keystone
jacks, and some other keystone jacks in the market, including RJ45 Ethernet, HDMI audio/video, voice
and USB applications. The rear cable manager keeps cables neat, tidy and efficiently organized on the
back of the panel. Ports are clearly numbered to help you identify connections. Mounts easily into 1U of
an EIA-standard 19-inch two-post rack or wall-mount rack enclosure. Made from fully shielded, heavy-duty
steel. Grounding wire included.
Features
Manages and Organizes a Wide Variety of Cabling24 blank cutouts accommodate all Tripp Lite
keystone jacks, and some other keystone jacks in the marketFor use with RJ45 Ethernet, HDMI
audio/video, voice, USB and other applicationsPorts are numbered for easy connection identificationFully
shielded, heavy-duty steel construction
Cable Manager on RearKeeps cabling neat, tidy and organized
Quick, Easy InstallationMounts easily into 1U of EIA-standard 19 in. 2-post rack or wall-mount rack
enclosureIncludes grounding wire
Specifications
OVERVIEW
UPC Code
037332193612
Product Type
Blank
Technology
Cat5/5e; Cat6; Cat6a; DisplayPort; HDMI; USB 2.0 (High Speed)
1/2
Panel
Grounding wire
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
2.20 x 6.20 x 19.70
Shipping Dimensions (hwd / cm)
5.59 x 15.75 x 50.04
Shipping Weight (lbs.)
2.40
Shipping Weight (kg)
1.09
CONNECTIONS
Number of Ports
24
Side A - Connector 1
KEYSTONE JACK CUTOUT
Side B - Connector 1
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Warranty Details
LIFETIME LIMITED
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N062-024-KJ-SH”相匹配的价格&库存,您可以联系我们找货
