N052-048
N052-048
    TRIPPLITE
    PANEL PATCH CAT5E 48 PORT RACK
N052-048 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 48-Port 2U Rack-Mount Cat5e 110 Patch Panel, 568B, RJ45 Ethernet, TAA MODEL NUMBER: N052-048 Highlights ● 19-in. rackmount ready, 2U Height ( 3.50in ) ● EIA/TIA 2/32 spacing ● 110 type punchdown termination ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● Description Tripp Lite's Enhanced Category 5 Patch Panels offer you all the functionality and compatibility as any name brand. Each panel comes with 110-type termination, while meeting and exceeding EIA/TIA TSB-40 Cat5e connecting hardware specifications. Color coded for both EIA/TIA 568A & 568B installations. 48 ports ensure a wide range of plug-n-play options. The clear numbering on both the front and back of each panel gives you a quick and easy way to identify cable runs and the high density 19in panel design will save you valuable space in on the rack. UTP Cat5e 22-24 AWG solid cable Features ● Cat5e ● UL approved ● Ports clearly numbered both on front and back ● Labels on front enable each port to be named ● Color coded label on back offers both EIA/TIA 568A & 568B wiring ● Metal frame ● EIA/TIA 2/32 spacing ● Rack mountable on a 19 rack ( 2U Height, 3.50in ) Specifications OVERVIEW UPC Code 037332013200 Product Type Punchdown Technology Cat5/5e 1/2 Cat5e Patch Panel 568B-48 Port, 2U 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 2.80 x 19.70 x 4.70 Shipping Dimensions (hwd / cm) 7.11 x 50.04 x 11.94 Shipping Weight (lbs.) 2.30 Shipping Weight (kg) 1.04 CONNECTIONS Number of Ports 48 Side A - Connector 1 110 IDC Side B - Connector 1 RJ45 (FEMALE) PoE Type Type 2 PoE+ (30W, IEEE 802.3at) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N052-048 价格&库存
很抱歉,暂时无法提供与“N052-048”相匹配的价格&库存,您可以联系我们找货
