N252-012
N252-012
    TRIPPLITE
    PANEL PATCH CAT6 568B 12PORT
N252-012 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 12-Port 1U Rack-Mount Cat6/Cat5 110 Patch Panel 568B, RJ45 Ethernet, TAA MODEL NUMBER: N252-012 Highlights ● 19 in. rackmount ready, 1U ( 1.75" ) ● EIA/TIA 2/32 spacing ● 110 type punchdown termination ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● Description Tripp Lite's Category 6 Patch Panels offer you all the functionality and compatibility as any name brand. Each panel comes with 110-type termination, while meeting and exceeding EIA/TIA TSB-40 Cat6 connecting hardware specifications. Color coded for both EIA/TIA 568A & 568B installations. 12 ports ensure a wide range of plug-n-play options. The clear numbering on both the front and back of each panel gives you a quick and easy way to identify cable runs and the high density 19in panel design will save you valuable space in on the rack. UTP Cat6 22-24 AWG solid cable Features ● Category 6 ● UL approved ● Ports clearly numbered both on front and back ● Labels on front enable each port to be named ● Metal frame ● EIA/TIA 2/32 spacing ● Rack mountable on a 19 rack (1U of space) Specifications OVERVIEW UPC Code 037332120021 Product Type Punchdown Technology Cat5/5e; Cat6 PHYSICAL 1/2 Cat6 Patch Panel 568B-12 Port, 1U 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Shipping Dimensions (hwd / in.) 3.00 x 20.50 x 4.25 Shipping Dimensions (hwd / cm) 7.62 x 52.07 x 10.80 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 CONNECTIONS Number of Ports 12 Side A - Connector 1 110 IDC Side B - Connector 1 RJ45 (FEMALE) PoE Type Type 2 PoE+ (30W, IEEE 802.3at) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N252-012 价格&库存
很抱歉,暂时无法提供与“N252-012”相匹配的价格&库存,您可以联系我们找货
