N484-12RJ
N484-12RJ
    TRIPPLITE
    FIBER PATCH PANEL
N484-12RJ 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a Pass-Through Cassette - (x12) RJ45 Highlights ● High Density Copper Cassette for use with the N484-00U and N484-01U chassis' ● Cat6a Pass-through Cassette, with (x12) RJ45 connections ● Rated for 10 Gbps Ethernet data transfer speeds MODEL NUMBER: N484-12RJ Package Includes Description Tripp Lite's N484-12RJ is a High Density Cat6a Pass-through Cassette with (x12) RJ45 connections. Designed specifically for use with Tripp Lite's N484-00U and N484-01U chassis'; up to 4 cassettes per N484-01U, or 1 per N484-00U. Each RJ45 connection is rated for 10 Gbps Ethernet data transfer speeds. Installation is simple, with the cassette being easily installed or removed using screw tabs to lock or unlock it from the panel; no tools required. Furthermore, each cassette features factory terminated connectors that reduce the time and labor required of field connector terminations. Cassette housing is manufactured with heavy duty, 1.0mm Cold Rolled Steel. Features ● High Density Copper Cassette for use with the N484-00U and N484-01U chassis' ● Cat6a Pass-through Cassette, with (x12) RJ45 connections ● Rated for 10 Gbps Ethernet data transfer speeds ● Installation is simple, with the cassette being easily installed or removed using screw tabs to lock or unlock it from the panel; no tools required ● Each cassette features factory terminated connectors that reduce the time and labor required of field connector terminations. ● Housing made of heavy duty, 1.0mm Cold Rolled Steel Specifications OVERVIEW UPC Code 037332187222 Technology Cat6a PHYSICAL Shipping Dimensions (hwd / in.) 2.36 x 7.90 x 1.46 Shipping Dimensions (hwd / cm) 5.99 x 20.07 x 3.71 1/2 ● N484-12RJ Cat6a PassThrough Cassette - (x12) RJ45 ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 0.51 Shipping Weight (kg) 0.23 Unit Dimensions (hwd / in.) 1.200 x 5.120 x 4.700 Unit Dimensions (hwd / cm) 3.65 x 11.35 x 3.43 Unit Dimensions (hwd / mm) 36.5 x 113.5 x 34.3 ENVIRONMENTAL Operating Temperature Range -4° to 122°F (-20° to 50°C) CONNECTIONS Number of Ports 12 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N484-12RJ 价格&库存
很抱歉,暂时无法提供与“N484-12RJ”相匹配的价格&库存,您可以联系我们找货
