N054-024
N054-024
    TRIPPLITE
    PANEL PATCH CAT5E 24 PORT RACK
N054-024 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 24-Port 1U Rack-Mount Cat5e Feedthrough Patch Panel, RJ45 Ethernet, TAA MODEL NUMBER: N054-024 Highlights ● Cat5e RJ45 Jacks on both sides of the panel ● Installs easily in 19" racks or wall-mounts ● Cable management bar keeps patch cables tidy ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes Description Tripp Lite's 24-Port Cat5e Feed-Through patch panel provides patching without punching down bulk wire to the back of the panel. Fully meets or exceeds Cat5e specifications - works with USOC, T568A, and T568B wiring. 19" width mounts easily in 2-Post Relay Rack, or a Wall-Mount Hinged Rack. Detachable cable management bar keeps patch cables neat and tidy on the back of the panel. IEC 60512-99-001 Compliant PoE Certificate Number: 2018-773 UTP Cat5e Patch Cord (Requires PoE cable if used in PoE setting) Features ● Heavy duty 14ga steel construction ● Meets or exceeds Cat5e specifications ● Easy patching with Cat5e patch cables ● Includes cable management bar ● Rackmountable - 19"W x 1.75"H (1U) Specifications OVERVIEW UPC Code 037332125460 Product Type Feed-Through Technology Cat5/5e PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.75 x 19.70 x 4.60 1/2 ● 24-Port Cat5e Feed-Through 1U Patch Panel ● Detachable Cable Management Bracket ● Package of 24 4" Wire Ties 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 6.98 x 50.04 x 11.68 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 1.700 x 19.000 x 1.250 CONNECTIONS Number of Ports 24 PoE Power Budget (Watts) 30 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) PoE Type Type 4 High-Power (100W, IEEE 802.3bt) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N054-024 价格&库存
很抱歉,暂时无法提供与“N054-024”相匹配的价格&库存,您可以联系我们找货
