1000 Eaton Boulevard
Cleveland, OH 44122
United States
Enclosure for 5 High-Density Fiber Cassettes, 1U
Highlights
Space saving 1U design, 19"
rackmountable
Supports up to 5 Tripp Lite High
allowing for up to 60 Duplex LC
Ports (120 fiber connections),
making the most of your rack
space
Includes optional rear-mounting
cable management bracket for
proper routing of cabling
Features a fold-down door panel
on the front of the unit that
protects your connections, while
rotating out of the way to
provide full access. Door panel
can also be removed altogether.
MODEL NUMBER: N482-01U
Package Includes
Description
Tripp Lite's N482-01U is a High Density Fiber Cassette solution that supports up to 5 High Density Fiber
Cassettes, maximizing rack space and allowing for up to 60 Duplex LC Ports (120 fiber connections) in
just 1U of space. Tripp Lite's High Density Fiber Cassettes come in multiple variations, allowing you to
connect different generations of equipment (10Gb, 40Gb, 100/120Gb), and giving you the flexibility to
adapt as your technology changes. Installation is simple, with the cassettes being easily installed or
removed using push / pull tabs to lock or unlock them from the panel; no tools required. Management is a
breeze with an optional rear-mounting cable management bracket that allows you to rout your cabling
neatly and safely. A fold-down door panel is featured on the front of the unit, and protects your
connections, while rotating out of the way to provide full access. The door panel can also be removed
altogether for installations where constant access is preferred. Constructed of heavy-duty steel housing.
Features
Space saving 1U design, 19" rackmountable
Supports up to 5 Tripp Lite High Density Fiber Cassettes, allowing for up to 60 Duplex LC Ports (120
fiber connections), making the most of your rack space
Cassettes come in multiple variations, allowing you to connect different generations of equipment
(10Gb, 40Gb, 100/120Gb), and giving you the flexibility to adapt as your technology changes.
Includes optional rear-mounting cable management bracket for proper routing of cabling
Features a fold-down door panel on the front of the unit that protects your connections, while rotating
out of the way to provide full access. Door panel can also be removed altogether.
Specifications
OVERVIEW
UPC Code
037332184511
Technology
Singlemode; Multimode
PHYSICAL
1/2
N482-01U High Density Fiber
Enclosure Panel, 1U, 5Cassette Capacity
Quick Start Guide
Cleveland, OH 44122
United States
Color
Black
Shipping Dimensions (hwd / in.)
3.50 x 15.00 x 21.10
Shipping Dimensions (hwd / cm)
8.89 x 38.10 x 53.59
Shipping Weight (lbs.)
6.60
Shipping Weight (kg)
2.99
Unit Dimensions (hwd / in.)
1.750 x 19.000 x 13.000
Unit Dimensions (hwd / cm)
4.445 x 48.26 x 33.02
Unit Weight (lbs.)
4.5
Unit Weight (kg)
2.04
ENVIRONMENTAL
Operating Temperature
-4 to 140 F (-20 to 60 C)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N482-01U”相匹配的价格&库存,您可以联系我们找货
