N492-036-LCLC-E
N492-036-LCLC-E
    TRIPPLITE
    FIBERPATCHPANEL
N492-036-LCLC-E 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 36-Port Fiber Patch Panel Enclosure, 1U RackMount (LC/LC) MODEL NUMBER: N492-036-LCLC-E Highlights ● Supports up to 36 LC/LC patch connections ● Multimode and most Singlemode applications supported ● Space saving 1U design, 19" rackmountable Package Includes Description Tripp Lite N492-036-LCLC-E is a pre-loaded, 36-port, LC/LC fiber patch enclosure that supports either Multimode or most Singlemode LC Fiber cable patching. Features rugged heavy steel construction, with multiple rear entry points for trunk cable feeding into the panel, providing protection as well as internal management. 1U design takes up minimal space while allowing for maximum patching. Features ● 36 port LC/LC Feed Through couplers in a 1U panel ( 3 x 12port modules ) ● Supports most Singlemode and Multimode Fiber connections ● 19" Wide x 8" Deep x 1.75" High ● Pull-out locking tray for easy access to internal connections ● Heavy Cold-Rolled steel construction, Black Powder Coated finish ● Six rear cable entry ports ● Adjustable depth mounting Specifications OVERVIEW UPC Code 037332181824 Product Type Feed-Through Technology Singlemode; Multimode PHYSICAL Color Black Shipping Dimensions (hwd / in.) 20.90 x 1.80 x 9.80 1/2 ● 1U Chassis ● 3 x 12-port LC Feed-Through Adapter plate ● Mounting Brackets ● Mounting Screws 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 53.09 x 4.57 x 24.89 Shipping Weight (lbs.) 6.00 Shipping Weight (kg) 2.72 Unit Dimensions (hwd / in.) 1.700 x 19.000 x 1.250 Unit Dimensions (hwd / cm) 4.445 x 48.26 x 20.32 CONNECTIONS Number of Ports 36 Side A - Connector 1 LC DUPLEX (FEMALE) Side B - Connector 1 LC DUPLEX (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N492-036-LCLC-E
物料型号:N492-036-LCLC-E
器件简介: - 该产品为36端口LC/LC光纤配线架,支持多模态和大多数单模态LC光纤电缆配线。 - 采用1U机架式设计,节省空间,同时允许最大配线。 - 具有36个LC/LC直通耦合器,分布在1U面板上(3个12端口模块)。 - 支持大多数单模和多模光纤连接。 - 产品采用重型冷轧钢构造,黑色粉末涂层表面处理。 - 包含后拉式锁定托盘,方便访问内部连接。 - 有六个后部电缆入口。
引脚分配: - 每个模块包含12个LC双工(女头)连接器,面板的一侧(A侧)和另一侧(B侧)各有一个。
参数特性: - UPC代码:037332181824 - 产品类型:直通型 - 技术:支持单模和多模光纤技术 - 端口数量:36个 - 连接器类型:LC双工(女头)
功能详解: - 提供了36个LC/LC直通耦合器,支持多模和单模光纤连接。 - 1U设计,节省空间,同时允许最大配线。 - 重型冷轧钢构造,提供保护和内部管理。 - 六个后部电缆入口,方便布线。 - 可调节深度安装。
应用信息: - 适用于需要大量光纤连接的数据中心、网络中心等环境。 - 适用于多模和单模光纤网络的部署和管理。
封装信息: - 颜色:黑色 - 运输尺寸(高宽深/英寸):20.90x1.80x9.80 - 运输尺寸(高宽深/厘米):53.09x4.57x24.89 - 运输重量(磅):6.00 - 运输重量(千克):2.72 - 单元尺寸(高宽深/英寸):1.700x19.000x1.250 - 单元尺寸(高宽深/厘米):4.445x48.26x20.32 - 面板样式:直通型
N492-036-LCLC-E 价格&库存
很抱歉,暂时无法提供与“N492-036-LCLC-E”相匹配的价格&库存,您可以联系我们找货
