1000 Eaton Boulevard
Cleveland, OH 44122
United States
Guaranteed compatibility with recommended Tripp Lite cabling, including the N820- and N821-Series
Highlights
cables
40/100Gb Fiber Breakout Patch Panel, 40Gb to 4
x 10Gb, 100Gb to 4 x 25Gb, 15 MTP QSFP to 60
LC Duplex OM4 50/125 Multimode Ports, 1U
Total of 15 12-fiber
MTP/MPO switch ports and 60
LC ports
Base8 wiring uses all LC
ports—no dead ports as in
Base12
Base-8 Fiber compatible with
both QSFP+ 40GBASE-SR4 to
SFP+ 10GBASE-SR and
QSFP28 100GBASE-SR4 to
SFP28 25GBASESR connections
Hardwired cassettes for 30%
improvement in insertion loss
Easily identifiable color-coded
magenta OM4 cables
MODEL NUMBER: N48K-15M8L60-B
System Requirements
Package Includes
High-density 50/125 multimode breakout panel seamlessly and conveniently integrates 10G equipment
with 40G networks or 25Gb equipment with 100Gb networks to meet current connectivity needs and
future-proof your network in a cost-effective manner.
Description
The N48K-15M8L60-B 50/125 Breakout Fiber Patch Panel not only integrates equipment with 10G and
40G speeds, but also provides a simple, flexible path from 25Gb to 100Gb, as well as upcoming 50Gb to
200Gb speeds and beyond. The 1U chassis features five breakout cassettes. Each cassette contains 12
LC duplex ports and three built-in two-meter MTP multimode cables for a total of 15 QSFP fiber switch
ports breaking out to 60 LC ports.
Base8 wiring with built-in MTP trunks maximizes rack space and link performance, while enabling simple
cable deployment and optimized harness mapping. The N48K-15M8L60-B uses all 60 LC ports, meaning
no dead ports as in Base12 wiring, with streamlined 1-to-1 port mapping. Eliminating the need for 12-fiber
conversion modules results in a reduction of up to 50 percent in link attenuation.
Hardwired cassettes offer a 30-percent improvement in insertion loss with no separate MTP connection in
the rear, resulting in longer duplex link distances. Color-coded magenta OM4 cables are easily
distinguished from traditional aqua OM3 multimode fiber. Base-8 Fiber compatible with both QSFP+
40GBASE-SR4 to SFP+ 10GBASE-SR and QSFP28 100GBASE-SR4 to SFP28 25GBASESR connections.
The front panel folds down to protect the LC patch cords, as well as provide wire mapping by matching
each cassette’s labeled MTP cables to the LC clusters. Writing space on the inside panel lets you customlabel each port. Each panel is serialized and insertion loss data is available upon request via the unit’s
serial number.
Features
Integrates Equipment with 10Gb and 40Gb Speeds, or 25Gb and 100Gb, to Meet Current
Connectivity NeedsAlso future-proofs your network for eventual 50Gb and 200Gb speeds and
beyondBase-8 Fiber compatible with both QSFP+ 40GBASE-SR4 to SFP+ 10GBASE-SR and QSFP28
100GBASE-SR4 to SFP28 25GBASE-SR connections.OM4 fiber for highest throughput
5 Breakout Cassettes12 LC duplex ports and 3 built-in 2-meter MTP multimode cables per cassetteTotal
of 15 QSFP fiber switch ports and 60 LC ports100% fiber utilizationStreamlined 1:1 port mappingUp to
50% reduction in link attenuationColor-coded magenta cables easily distinguishable in crowded switch
1/3
Cleveland, OH 44122
United States
Base8 WiringNo unused LC ports as in Base12 wiringSimple patch cable deploymentOptimized harness
mappingHardwired cassette modules offer 30% improvement in insertion loss
Fold-Down Front PanelLC patch cables protectedProvides wire mapping by matching each cassette’s
labeled MTP cables to LC clustersWriting space on inside panel for custom-labeling of portsInsertion loss
data available via unit’s serial number
Mounts in 1U of EIA-Standard 19 in. RackMaximizes rack space and link performance
Specifications
OVERVIEW
UPC Code
037332200846
Product Type
Breakout
Technology
Multimode
Optical Mode
OM4
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
3.80 x 21.30 x 18.80
Shipping Dimensions (hwd / cm)
9.65 x 54.10 x 47.75
Shipping Weight (lbs.)
8.10
Shipping Weight (kg)
3.67
CONNECTIONS
Side A - Connector 1
MTP/MPO (FEMALE)
Side B - Connector 1
LC DUPLEX (FEMALE)
FEATURES & SPECIFICATIONS
All-in-One Kit
Yes
Built-in Cables
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N48K-15M8L60-B”相匹配的价格&库存,您可以联系我们找货
