N48K-15M8L60S-B
N48K-15M8L60S-B
    TRIPPLITE
    8.3/125BREAKOUTFIBERPATCHPAN
N48K-15M8L60S-B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40/100Gb Fiber Breakout Patch Panel, 40Gb to 4 x 10Gb, 100Gb to 4 x 25Gb, 15 MTP QSFP to 60 LC Duplex 9/125 Singlemode Ports, 1U Highlights ● Total of 15 12-fiber MTP/MPO switch ports and 60 LC ports ● Base8 wiring uses all LC ports—no dead ports as in Base12 ● Hardwired cassettes for 30% improvement in insertion loss ● Easily identifiable color-coded yellow singlemode cables MODEL NUMBER: N48K-15M8L60S-B System Requirements Package Includes ● High-density 9/125 singlemode breakout panel seamlessly and conveniently integrates 10Gb equipment with 40Gb networks or 25Gb equipment with 100G networks to meet current connectivity needs and future-proof your network in a cost-effective manner. Description The N48K-15M8L60S-B 9/125 Breakout Fiber Patch Panel not only integrates equipment with 10G and 40G speeds, but also provides a simple, flexible path from 25Gb to 100Gb as well as upcoming 50Gb to 200Gb speeds and beyond. The 1U chassis features five breakout cassettes. Each cassette contains 12 LC duplex ports and three built-in two-meter MTP singlemode cables for a total of 15 QSFP fiber switch ports breaking out to 60 LC ports. Base8 wiring with built-in MTP trunks maximizes rack space and link performance, while enabling simple cable deployment and optimized harness mapping. The N48K-15M8L60S-B uses all 60 LC ports, meaning no dead ports as in Base12 wiring, with streamlined 1-to-1 port mapping. Eliminating the need for 12-fiber conversion modules results in a reduction of up to 50 percent in link attenuation. Hardwired cassettes offer a 30-percent improvement in insertion loss with no separate MTP connection in the rear, resulting in longer duplex link distances. Color-coded yellow singlemode cables are easily distinguished from traditional aqua OM3 multimode fiber. The front panel folds down to protect the LC patch cords, as well as provide wire mapping by matching each cassette’s labeled MTP cables to the LC clusters. Writing space on the inside panel lets you customlabel each port. Each panel is serialized and insertion loss data is available upon request via the unit’s serial number. Features Integrates Equipment with 10Gb and 40Gb Speeds, or 25Gb and 100Gb, to Meet Current Connectivity NeedsAlso future-proofs your network for eventual 50Gb and 200Gb speeds and beyondSinglemode fiber for highest throughput 5 Breakout Cassettes12 LC duplex ports and 3 built-in 2-meter MTP singlemode cables per cassetteTotal of 15 QSFP fiber switch ports and 60 LC ports100% fiber utilizationStreamlined 1:1 port mappingUp to 50% reduction in link attenuationColor-coded yellow cables easily distinguishable in crowded switch Base8 WiringNo unused LC ports as in Base12 wiringSimple patch cable deploymentOptimized harness mappingHardwired cassette modules offer 30% improvement in insertion loss 1/3 N48K-15M8L60S-B 9/125 Breakout Fiber Patch Panel 1000 Eaton Boulevard Cleveland, OH 44122 United States Fold-Down Front PanelLC patch cables protectedProvides wire mapping by matching each cassette’s labeled MTP cables to LC clustersWriting space on inside panel for custom-labeling of portsInsertion loss data available via unit’s serial number Mounts in 1U of EIA-Standard 19 in. RackMaximizes rack space and link performance Specifications OVERVIEW UPC Code 037332200877 Product Type Breakout Technology Singlemode PHYSICAL Color Black Shipping Dimensions (hwd / in.) 3.80 x 21.30 x 18.80 Shipping Dimensions (hwd / cm) 9.65 x 54.10 x 47.75 Shipping Weight (lbs.) 8.00 Shipping Weight (kg) 3.63 CONNECTIONS Side A - Connector 1 MTP/MPO (FEMALE) Side B - Connector 1 LC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS All-in-One Kit Yes Built-in Cables Yes STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N48K-15M8L60S-B
物料型号:N48K-15M8L60S-B
器件简介:这是一个高密度的9/125单模光纤分路面板,可以无缝且方便地将10Gb设备与40Gb网络或25Gb设备与100Gb网络集成,以满足当前的连接需求,并以成本效益的方式为网络的未来做好准备。
引脚分配:每个分路模块包含12个LC双工端口和3根内置的2米MTP单模光纤跳线,总共有15个QSFP光纤交换端口分路到60个LC端口。
参数特性:支持10Gb和40Gb速度的设备集成,或25Gb和100Gb,为当前连接需求提供支持,并为未来的50Gb及以上速度做好准备。使用单模光纤以获得最高吞吐量。Base8布线,无Base12布线中的未使用LC端口,简化了跳线部署和优化了束线映射。
功能详解:面板前盖可折叠,以保护LC跳线,并提供通过将每个模块的标记MTP跳线与LC集群匹配的线缆映射。内部面板上有书写空间,可自定义标记每个端口。每个面板都有序列号,可根据序列号请求插入损耗数据。
应用信息:适用于需要将10Gb设备与40Gb网络或25Gb设备与100Gb网络集成的场景,同时为未来50Gb及以上速度的网络升级做好准备。
封装信息:黑色面板风格,适用于EIA标准19英寸机架安装,最大化机架空间和链路性能。
系统要求:无特殊要求。
包装包含:N48K-15M8L60S-B 9/125分路光纤配线架。
产品合规性:符合RoHS标准。
保修与支持:提供终身有限保修。
N48K-15M8L60S-B 价格&库存
很抱歉,暂时无法提供与“N48K-15M8L60S-B”相匹配的价格&库存,您可以联系我们找货
