1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 6U Low-Profile Switch-Depth KnockDown Wall-Mount Mini Rack Enclosure
MODEL NUMBER: SRW6UKD
Highlights
Ships unassembled for easy
transport and storage
Maximum load capacity of 200
lbs (90.7 kgs)
Locking steel cabinet vented at
sides, front, top and bottom
Flow-through ventilation keeps
equipment cool
Mounts to wall to save valuable
floor space
Package Includes
Assembly Hardware
(2) Top/bottom panels(2) Side
panelsFront door(2) Vertical
mounting rails(24) M6 screws(4)
M6 cage nuts(4) M6 cup
washers(2) Keys
Equipment Mounting Hardware
(12) 12-24 screws(12) M6 cage
nuts(12) M6 cup washers
● Owner’s manual
Wall-mount cabinet secures and organizes 6U of 19 in. rack equipment in network closets, classrooms
and other locations with limited floor space. Houses network switches and patch panels up to 16.5 in.
deep.
Description
The SRW6UKD SmartRack® 6U Low-Profile Switch-Depth Knock-Down Wall-Mount Rack Enclosure
Cabinet is designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail
locations, classrooms, back offices and other areas with limited floor space where you need equipment to
be secure, organized and out of the way. Constructed from heavy-duty steel with a durable black powdercoated finish, the cabinet has a maximum load capacity of 200 lbs (90.7 kgs).
The front door locks securely to help prevent damage, tampering and theft. The front, top, bottom and side
panels are vented, which allows air to flow freely and keep equipment cool. The reversible front door can
be installed to open left or right. Convenient top and bottom ports allow easy cable routing.
The SRW6UKD comes unassembled for convenient transport and storage in confined spaces. It easily
assembles in minutes using just 12 fasteners, and mounts to the wall to save valuable floor space. Square
and 12-24 threaded mounting holes and numbered rack spaces make equipment installation easy. The
vertical mounting rails adjust in 7/8-inch increments to accommodate equipment up to 16.5 inches deep,
such as network switches and patch panels.
Features
Saves Valuable Workspace
Perfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited
floor space where you need equipment to be secure, organized and out of the wayHouses EIA-standard
19 in. rack equipment in 6U of spaceMaximum load capacity of 200 lbs (90.7 kgs)
Keeps Important Equipment Secure
Front door locks securely to help prevent damage, tampering and theftVented panels allow generous
airflow that keeps equipment coolReversible front door can be installed to open left or rightConvenient
ports with removable covers allow cable routing through top and bottom
Ships Unassembled
Knock-down shipping for convenient transport and storage in confined spacesAssembles in minutes using
just 12 fastenersWall-mounting holes spaced 16 in. apart for standard wall stud placement
Easy Equipment Installation
Vertical mounting rails adjust in 7/8 in. increments to accommodate equipment up to 16.5 in. deep, such
as network switches and patch panelsRails support square-hole or 12-24 threaded-hole mountingRack
1/3
Cleveland, OH 44122
United States
spaces numbered for easy reference
Meets Payment Card Industry Standards
Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332191564
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Small Enclosure
PHYSICAL
Color
Black
Rack Height
6U
Rack Depth
Shallow
Maximum Device Depth (cm)
41.91
Maximum Device Depth (in.)
16.5
Maximum Device Depth (mm)
419
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Cable Access Hole Measurement
(inches)
9.812 x 2.35 (l x w)
Shipping Dimensions (hwd / in.)
25.98 x 20.28 x 7.08
Shipping Dimensions (hwd / cm)
65.99 x 51.51 x 17.98
Shipping Weight (lbs.)
30.00
Shipping Weight (kg)
13.61
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
36.7 x 60.02 x 44.57
Unit Weight (lbs.)
29
Unit Weight (kg)
13.15
Weight Capacity - Stationary (kg)
91
Weight Capacity - Stationary (lbs.)
200
Number of Vertical Mounting Rails
2
Assembly Required
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRW6UKD”相匹配的价格&库存,您可以联系我们找货
