SR2POST25
SR2POST25
    TRIPPLITE
    25U2-POSTOPENFRAMERACK
SR2POST25 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 25U SmartRack 2-Post Open Frame Rack Organize and Secure Network Rack Equipment Highlights ● 25U 2-post open frame rack ● Black aluminum with 12-24 threaded and numbered mounting holes ● Toolless button holes to accept PDUs or cable managers MODEL NUMBER: SR2POST25 Package Includes Description Tripp Lite's SR2POST25 2-Post SmartRack Open Frame Rack is an economical way to accommodate 25U of rack space for 19-inch rackmount applications in limited spaces that do not require a lockable enclosure. Its heavy-duty, aluminum construction can safely support 800 lbs (362.9 kgs) of rackmount equipment, and its open design provides easy access to equipment and cabling. The black, textured powder coat finish makes it resistant to scratching while giving it a "classic," attractive appearance. The SR2POST25 is easy to install due to a self-squaring design combined with 12-24 threaded and numbered mounting positions, and bolt down provisions. It uses toolless button-hole mounting for vertical PDUs and cable managers. In high-density environments, multiple units can be bolted together side by side for easy expansion or customization. The SR2POST25 2-Post SmartRack Open Frame Rack has been approved by EIA-310-D, IEC 60297-3-100, and RoHS, and is backed by a 5-year warranty. Features ● Supports 800 lbs (362.9 kgs) of rackmount equipment ● Textured powder coat finish ● Heavy Duty Aluminum construction ● 12-24 threaded and numbered mounting positions ● Toolless button holes to accept PDUs or cable managers ● Bolt down provisions ● Self squaring design ● Black finish ● Easy assembly Specifications OVERVIEW UPC Code 037332143143 1/3 ● SR2POST25 ● 28 pieces each of 12-24 screws and washers for equipment mounting ● Installation hardware ● Cable management hooks ● Warranty Information ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Open-Frame PHYSICAL Color Black Rack Height 25U Rack Depth Extra Deep EIA Mounting Rails 12-24 threaded and numbered mounting positions Maximum Device Depth (cm) 121.92 Maximum Device Depth (in.) 48 Maximum Device Depth (mm) 1,219 Shipping Dimensions (hwd / in.) 4.50 x 6.00 x 52.60 Shipping Dimensions (hwd / cm) 11.43 x 15.24 x 133.60 Shipping Weight (lbs.) 26.00 Shipping Weight (kg) 11.79 Unit Dimensions (hwd / in.) 49.010 x 20.300 x 13.500 Unit Dimensions (hwd / cm) 124.46 x 51.56 x 12.06 Unit Weight (lbs.) 23 Unit Weight (kg) 10.43 Weight Capacity - Stationary (kg) 363 Weight Capacity - Stationary (lbs.) 800 Number of Vertical Mounting Rails 2 Assembly Required Yes FEATURES & SPECIFICATIONS Pre-Installed Casters No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR2POST25
物料型号: - 型号:SR2POST25
器件简介: - Tripp Lite品牌的SR2POST25是一款25U的2柱开放式机架,适用于19英寸机架安装应用,适合空间有限且不需要锁闭外壳的环境。其重型铝结构可安全支撑800磅(362.9公斤)的机架设备,开放式设计便于设备和布线的访问。黑色、纹理粉末涂层表面使其抗刮擦,外观经典且吸引人。SR2POST25安装简便,采用自对齐设计,配备12-24个螺纹和编号的安装位置以及螺栓固定装置。它使用无工具按钮孔安装垂直PDU和电缆管理器。在高密度环境中,多个单元可以并排螺栓连接,便于扩展或定制。SR2POST25已通过EIA-310-D、IEC 60297-3-100和RoHS认证。
引脚分配: - 该机架具有12-24个螺纹和编号的安装位置。
参数特性: - 支持800磅(362.9公斤)的机架设备 - 黑色铝结构 - 12-24个螺纹和编号的安装位置 - 无工具按钮孔,可接受PDU或电缆管理器 - 螺栓固定装置 - 自对齐设计 - 黑色外观 - 简易组装
功能详解: - 提供25U的2柱开放式机架 - 黑色铝制结构,带有12-24个螺纹和编号的安装孔 - 无工具按钮孔,可接受PDUs或电缆管理器
应用信息: - 设备兼容性:配线架、网络交换机、UPS、服务器
封装信息: - 机架类型:开放式框架 - 颜色:黑色 - 机架高度:25U - 机架深度:超深 - EIA安装轨:12-24个螺纹和编号的安装位置 - 最大设备深度(厘米):121.92 - 最大设备深度(英寸):48 - 最大设备深度(毫米):1,219 - 发货尺寸(高宽深/英寸):4.50x6.00x52.60 - 发货尺寸(高宽深/厘米):11.43x15.24x133.60 - 发货重量(磅):26.00 - 发货重量(公斤):11.79 - 单位尺寸(高宽深/英寸):49.010x20.300x13.500 - 单位尺寸(高宽深/厘米):124.46x51.56x12.06 - 单位重量(磅):23.1 - 单位重量(公斤):10.43 - 静止状态下的重量容量(公斤):363 - 静止状态下的重量容量(磅):800 - 垂直安装轨数量:2 - 需要组装:是
SR2POST25 价格&库存
很抱歉,暂时无法提供与“SR2POST25”相匹配的价格&库存,您可以联系我们找货
