RCHS1901031LG1
RCHS1901031LG1
    HAMMONDMANUFACTURING
    RACK STEEL 31.5X21X12.5 GRY
RCHS1901031LG1 数据手册
Table Top Rack Cabinets (RCHS Series) - HEAVY DUTY Path: Home > Rack Index > Table Top Rack Cabinets (RCHS Series) Features: z z z z z Textured - Light Gray (RAL7035) click to enlarge z z z z z z z z Heavy duty, 16-gauge steel, 19” rack mount - table top cabinet. For ventilated versions link to our RCHV series. Choice of three depths - 17.5" (444 mm), 24.5" (622 mm) and 31.5" (800 mm). Panel rails are infinitely adjustable (front to back), round hole punched for 10-32 clip-nuts to full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing). Includes two pairs of rails (for rear support of heavier equipment or shelves), rubber feet, black ABS plastic handles, a starter pack of 10-32 clip nuts & matching 1421ABK black screws. Supplied unassembled (four cabinet pieces & four rails), shipped in a flat pack container for handling ease & protection (see photo below). Simple assembly using one bolt in each corner to lock the sides to the top and bottom (hardware included). Overall width 21” (533 mm). Overall height 2” (51 mm) additional over panel height. Front & back lip is .585" (14 mm) so usable depth is reduced by 1.17" (30 mm). Recommended maximum weight (RCHS1902824 tested) - 800 pounds (364 kg). Rugged textured powder paint finish. Stocked in Black & Light Gray (RAL7035). Catalog pages (2) on this series Adobe Reader .pdf format (292K) 17.5" (444 mm) Deep Models Part Number Color RCHS1900817BK1 Black RCHS1900817LG1 Light Gray RCHS1901017BK1 Black 3D AutoCAD Number of Solid Model Panel Height Clip Nuts .dxf File Reader .stp files Included (zipped) File (zipped) Inches Units 8.75 374K 103K 167K 5U 8 Weight 38# (17.3 kg) RCHS1901017LG1 Light Gray 376K 103K 168K RCHS1901417BK1 Black RCHS1901417LG1 Light Gray 390K 105K 172K RCHS1901717BK1 Black RCHS1901717LG1 Light Gray 381K 114K 175K RCHS1902217BK1 Black RCHS1902217LG1 Light Gray 407K 118K 189K RCHS1902817BK1 Black RCHS1902817LG1 Light Gray 409K 121K 193K 10.50 6U 16 40# (18.2 kg) 14.00 8U 16 42# (19.1 kg) 17.50 10U 16 46# (20.9 kg) 22.75 13U 16 54# (24.5 kg) 28.00 16U 16 60# (27.3 kg) 24.5" (622 mm) Deep Models Part Number 3D AutoCAD Number of Solid Model Panel Height .dxf File Clip Nuts Reader .stp files File (zipped) (zipped) Inches Units Included Color RCHS1901024BK1 Black RCHS1901024LG1 Light Gray 395K 158K 169K RCHS1901424BK1 Black RCHS1901424LG1 Light Gray 413K 104K 172K RCHS1901724BK1 Black RCHS1901724LG1 Light Gray 400K 106K 185K RCHS1902224BK1 Black RCHS1902224LG1 Light Gray 424K 107K 186K RCHS1902824BK1 Black RCHS1902824LG1 Light Gray 427K 108K 194K Weight 10.50 6U 16 54# (24.5 kg) 14.00 8U 16 56# (25.5 kg) 17.50 10U 16 60# (27.3 kg) 22.75 13U 16 68# (30.9 kg) 28.00 16U 16 76# (35.5 kg) 31.5" (800 mm) Deep Models Part Number Color 3D AutoCAD Number of Solid Model Panel Height Clip Nuts .dxf File Reader .stp files Included (zipped) File (zipped) Inches Units RCHS1901031BK1 Black RCHS1901031LG1 Light Gray 368K 103K 169K RCHS1901431BK1 Black RCHS1901431LG1 Light Gray 391K 104K 172K RCHS1901731BK1 Black RCHS1901731LG1 Light Gray 380K 104K 175K RCHS1902231BK1 Black RCHS1902231LG1 Light Gray 399K 107K 189K RCHS1902831BK1 Black Weight 10.50 6U 16 64# (29.1 kg) 14.00 8U 16 68# (30.9 kg) 17.50 10U 16 74# (33.6 kg) 22.75 13U 16 82# (37.3 kg) RCHS1902831LG1 Light Gray 28.00 16U 110K 402K 16 92# (41.8 kg) 213K Feature Views: Ships Flat For Handling Ease & Protection Interior View With Infinitely Adjustable Panel Rails click to enlarge click to enlarge Panel Rails (Two Pair Included) With 10-32 Black Clip Nuts & Mounting Hardware click to enlarge RCHS Accessories Casters - Part Number 1425PHD z z z z z z click to enlarge z SOLD IN A SET OF 4 Base of cabinet is punched to accept this caster set 600# (273 kg) manufacturers specified weight capacity (Set of 4) Features ball bearing swivel and hard composition wheels Small foot print 2.125" (54 mm) x 15/16" (24 mm) hole mounting pattern Wheels are grey & 2" (51 mm) wheel diameter - adds only 2.5" (64 mm) to overall rack height. Includes mounting hardware Locking Doors z z z z (click to enlarge) z z z 16-gauge steel construction Both front & back of "RCHS" rack cabinets are punched to accept these doors Mounts either right or left hand hinge (door & cabinet are symmetrical) Includes installed lock and two keys Finished in rugged textured powder paint to match RCHS/RCHV enclosures Stocked in Black & Light Gray (RAL7035). Includes mounting hardware Part Number RCHD1908BK1 RCHD1908CG1 RCHD1908LG1 RCHD1910BK1 RCHD1910CG1 RCHD1910LG1 RCHD1914BK1 RCHD1914CG1 RCHD1914LG1 RCHD1917BK1 RCHD1917CG1 RCHD1917LG1 RCHD1922BK1 RCHD1922CG1 RCHD1922LG1 RCHD1928BK1 RCHD1928CG1 RCHD1928LG1 AutoCAD Color Reader .dxf File (zipped) File Black Beige Light Gray Black Beige Light Gray Black Beige Light Gray Black Beige Light Gray Black Beige Light Gray Black Beige Light Gray Extra Panel Rails 17K 18K 19K 21K 22K 24K Use With Cabinet Panel Height Weight 8.75" (5U) 5# (2.3 kg) 10.5" (6U) 5# (2.3 kg) 14.0" (8U) 6# (2.7 kg) 17.5" (10U) 7# (3.2 kg) 22.75" (13U) 9# (4.1 kg) 28.0" (16U) 12# (5.5 kg) 17K 18K 20K 22K 24K 27K z z z z RCHS rack cabinets ship with two pair - order below for extra mounting capabilities Sold in pairs Finished in rugged black textured powder paint Includes amhal strut mounting hardware (black clip nuts are not included) click to enlarge Part Number RCHR1908 RCHR1910 RCHR1914 RCHR1917 RCHR1922 RCHR1928 Use With Cabinet Panel Height Weight 8.75" (5U) 1.4# (0.6 kg) 10.5" (6U) 1.7# (0.8 kg) 14.0" (8U) 2.1# (1 kg) 17.5" (10U) 2.5# (1.1 kg) 22.75" (13U) 3.4# (1.5 kg) 28.0" (16U) 4.2# (1.9 kg) Extra Spring Nuts - Part Number 1421SN z z z click to enlarge z 1/4 - 20 Strut nut 1/4 - 20 x 1/2 bolt Used only in our RCHS & RCHV table top rack cabinets - handy for mounting of other equipment to the horizontal struts Sold in packages of 8 (8 spring nuts and 8 bolts) as shown Replacement Rubber Feet - Part Number 1421RC24 z z RCHS rack cabinets ship with four feet included - order these for replacement Sold in package of 20 click to enlarge Universal Accessories z z z z z z z Aluminum rack panels (PBPA series) Steel rack panels (PBPS series) Formed steel rack panels (PBFS series) Ventilated & Access Panels (Louvers, slots, baffles etc.) Doors & Chassis - Panel Mount (Hinged & fixed) Cable Organizing (Panel mount rings, velcro strap panels & guides) Shelves - Panel Mount (Fixed, solid & vented) z z z z z z z z Shelves & Slides - Dual Vertical Rail Mount (Fixed, pull out, solid & vented, drawers, etc.) Keyboard Shelves & Drawers (Vertical rail mount) Rack mount power bars (1582 & 1583 series) Fans (Fans, Fan Kits, Grills & Filters) Cooling Panels (Ventilated Panels, Fan Panels & Baffles) Blowers (HB series) Fan Trays (FT series) Mounting hardware (Hardware) Catalog pages (2) on this series - Adobe Reader .pdf format (292K) Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor Home | Products | Distributors | Technical | Contact Us | Other Options Copyright; © 2004-2010 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RCHS1901031LG1 价格&库存
很抱歉,暂时无法提供与“RCHS1901031LG1”相匹配的价格&库存,您可以联系我们找货
