1000 Eaton Boulevard
Cleveland, OH 44122
United States
13U SmartRack 4-Post Open Frame Rack Organize and Secure Network Rack Equipment
Highlights
13U 4-post open frame rack
Black steel with square,
numbered mounting holes
Toolless button holes to accept
PDUs or cable managers
MODEL NUMBER: SR4POST13
Package Includes
Description
Tripp Lite's 13U 4-Post Open Frame Rack helps IT managers organize their equipment array and provides
fast, easy access to installed IT equipment. The SR4POST13 is a simple solution for housing IT
equipment in secure environments and other areas that don't require a lockable rack solution. This 13U
rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for durability. It
supports stationary loads up to 1000 lbs (453.6 kgs). The SR4POST13 comes with all the hardware
required for assembly and has a self-squaring design with bolt-down provisions. For high-density
applications, multiple units can be bolted together side by side.
The open design of the SR4POST13 provides unobstructed airflow and easy access to equipment and
cabling. It has numbered, square-hole mounting positions for easy installation of standard 19-inch rack
equipment. The SR4POST13 supports equipment depths from 22 to 36 inches. This rack also
accommodates toolless button-hole mounting for vertical PDUs and cable managers.
Features
Supports 1000 lbs (453.6 kgs) of rackmount equipment
Adjustable mounting depth (22 to 36 inches)
Textured powder coat finish
Heavy-duty cold-rolled steel construction
Numbered mounting positions
Bolt down provisions
Self squaring design
Black finish
Easy assembly
Specifications
OVERVIEW
UPC Code
037332144041
1/3
SR4POST13
Installation hardware
16x M6 cagenuts, screws,
washers
6x Cable management hooks
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
13U
Rack Depth
Standard
Maximum Device Depth (cm)
91.44
Maximum Device Depth (in.)
36
Maximum Device Depth (mm)
914
Minimum Device Depth (cm)
55.88
Minimum Device Depth (in.)
22
Minimum Device Depth (mm)
559
Shipping Dimensions (hwd / in.)
6.50 x 4.53 x 55.51
Shipping Dimensions (hwd / cm)
16.51 x 11.51 x 141.00
Shipping Weight (lbs.)
43.40
Shipping Weight (kg)
19.69
Unit Dimensions (hwd / in.)
28.300 x 20.200 x 39.300
Unit Dimensions (hwd / cm)
71.12 x 51.3 x 55.9~91.44 (depth adjustable)
Unit Weight (lbs.)
39
Unit Weight (kg)
17.69
Weight Capacity - Stationary (kg)
454
Weight Capacity - Stationary (lbs.)
1000
Number of Vertical Mounting Rails
4
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Grounding Lug
Includes nuts, bolts, and washers to attach to user-supplied ground wire
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
2/3
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR4POST13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3808.017451+491.26563
