SR4POST25
SR4POST25
    TRIPPLITE
    25U 4-POST OPEN FRAME CABINET
SR4POST25 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 25U SmartRack 4-Post Open Frame Rack Organize and Secure Network Rack Equipment Highlights ● 25U 4-post open frame rack ● Black steel with square, numbered mounting holes ● Toolless button holes to accept PDUs or cable managers MODEL NUMBER: SR4POST25 Package Includes Description Tripp Lite's 25U 4-Post Open Frame Rack helps IT managers organize their equipment array and provides fast, easy access to installed IT equipment. The SR4POST25 is a simple solution for housing IT equipment in secure environments and other areas that don't require a lockable rack solution. This 25U rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for durability. It supports stationary loads up to 1000 lbs (453.6 kgs). The SR4POST25 comes with all the hardware required for assembly and has a self-squaring design with bolt-down provisions. For high-density applications, multiple units can be bolted together side by side. The open design of the SR4POST25 provides unobstructed airflow and easy access to equipment and cabling. It has numbered, square-hole mounting positions for easy installation of standard 19-inch rack equipment. The SR4POST25 supports equipment depths from 22 to 36 inches. This rack also accommodates toolless button-hole mounting for vertical PDUs and cable managers. Features ● Supports 1000 lbs (453.6 kgs) of rackmount equipment ● Adjustable mounting depth (22 to 36 inches) ● Textured powder coat finish ● Heavy-duty cold-rolled steel construction ● Numbered mounting positions ● Bolt down provisions ● Self squaring design ● Black finish ● Easy assembly Specifications OVERVIEW UPC Code 037332157942 1/3 ● SR4POST25 ● Installation hardware ● 32x pieces of M6 cage nuts, screws, and washers for equipment mounting ● 18x Cable management hooks ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Open-Frame PHYSICAL Color Black Rack Height 25U Rack Depth Standard Maximum Device Depth (cm) 91.44 Maximum Device Depth (in.) 36 Maximum Device Depth (mm) 914 Minimum Device Depth (cm) 55.88 Minimum Device Depth (in.) 22 Minimum Device Depth (mm) 559 Shipping Dimensions (hwd / in.) 6.50 x 4.53 x 53.70 Shipping Dimensions (hwd / cm) 16.51 x 11.51 x 136.40 Shipping Weight (lbs.) 49.00 Shipping Weight (kg) 22.23 Unit Dimensions (hwd / in.) 49.300 x 20.200 x 39.300 Unit Dimensions (hwd / cm) 125.2 x 51.3 x 55.9~91.44 (depth adjustable) Unit Weight (lbs.) 45 Unit Weight (kg) 20.41 Weight Capacity - Stationary (kg) 454 Weight Capacity - Stationary (lbs.) 1000 Number of Vertical Mounting Rails 4 Assembly Required Yes FEATURES & SPECIFICATIONS Grounding Lug Includes a set of screws, bolts, and washers to secure a user-supplied grounding wire to Front and Back frames Built-in Cable Management No Extra Wide No Pre-Installed Casters No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR4POST25 价格&库存
很抱歉,暂时无法提供与“SR4POST25”相匹配的价格&库存,您可以联系我们找货
