1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 4U Low-Profile Vertical-Mount
Switch-Depth Wall-Mount Rack Enclosure
Cabinet
MODEL NUMBER: SRWF4U
Highlights
Maximum load capacity of 150
lbs (68 kgs)
Locking steel cabinet vented to
keep equipment cool
Secures 4U of 19 in. rack
equipment up to 20 in. deep
Includes additional 2U of space
for patch panels
Ships fully assembled for quick
installation
Package Includes
Wall-mount cabinet secures and organizes 4U of 19-inch rack equipment in network wiring closets and
other locations with limited floor space. Houses equipment up to 20 inches deep, but extends just 8 inches
from wall.
Description
The SRWF4U SmartRack 4U Low-Profile Vertical-Mount Switch-Depth Wall-Mount Rack Enclosure
Cabinet is designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail
locations, classrooms, back offices and other areas with limited floor space where you need equipment to
be secure, organized and out of the way. Constructed from heavy-duty steel with a durable black powdercoated finish, the cabinet has a maximum load capacity of 150 lbs (68 kgs).
Because the low-profile cabinet mounts vertically, it extends only eight inches from the wall while housing
equipment up to 20 inches deep, including network switches and patch panels. In addition to 4U of rack
space in the primary mounting area, it also includes a slide-out 2U mounting bracket at the top of the
enclosure for patch panels up to 2.5 inches deep.
The top panel and front door lock securely to help prevent damage, tampering or theft. The cabinet is
vented, which allows air to flow freely and keep equipment cool. The reversible front door can open left or
right. Convenient top and bottom ports allow easy cable routing.
The SRWF4U comes fully assembled and ready to mount to the wall. Equipment installation is easy with
threaded mounting holes and hardware that support M6 or 12-24 mounting.
Features
Saves Valuable WorkspacePerfect for network wiring closets, retail locations, classrooms, back offices
and other areas with limited floor space where you need equipment to be secure, organized and out of the
wayHouses EIA-standard 19 in. rack equipment in 4U of spaceLow-profile vertical-mount cabinet extends
only 8 in. from the wall while housing equipment up to 20 in. deep, including network switches and patch
panelsAlso includes a slide-out 2U mounting bracket at the top of the enclosure for patch panels up to 2.5
in. deepMaximum load capacity of 150 lbs (68 kgs)
Keeps Important Equipment SecureTop panel and reversible front door lock securely to help prevent
damage, tampering or theftVented cabinet keeps equipment coolConvenient ports with removable covers
allow cable routing through top and bottom
Easy Enclosure and Equipment InstallationShips fully assembled for quick installationWall-mounting
holes spaced 16 in. apart for standard wall stud placementRails adjust easily—unscrew them, slide them
to desired depth, and screw them back inThreaded mounting holes support M6 or 12-24 mountingRack
spaces marked for easy reference
1/3
SRWF4U SmartRack 4U LowProfile Vertical-Mount SwitchDepth Wall-Mount Rack
Enclosure Cabinet
(12) M6 screws
(12) M6 cup washers
(12) 12-24 screws
(2) Keys
Owner’s manual
Cleveland, OH 44122
United States
Meets Payment Card Industry StandardsProvides physical equipment and media security required for
PCI DSS (Payment Card Industry Data Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332190611
Device Compatibility
Patch Panel; Network Switch
Rack Type
Small Enclosure
PHYSICAL
Color
Black
Rack Height
4U
Rack Depth
Shallow
Maximum Device Depth (cm)
50.80
Maximum Device Depth (in.)
Maximum Device Depth (mm)
508
Shipping Dimensions (hwd / in.)
13.38 x 31.10 x 34.25
Shipping Dimensions (hwd / cm)
33.99 x 78.99 x 87.00
Shipping Weight (lbs.)
56.00
Shipping Weight (kg)
25.40
Unit Dimensions (hwd / in.)
28.800 x 25.600 x 8.000
Unit Dimensions (hwd / cm)
73.15 x 65.02 x 20.32
Unit Weight (lbs.)
60.18
Unit Weight (kg)
27.30
Weight Capacity - Stationary (kg)
68
Weight Capacity - Stationary (lbs.)
150
Number of Vertical Mounting Rails
2
FEATURES & SPECIFICATIONS
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRWF4U”相匹配的价格&库存,您可以联系我们找货
