SR4POST1224
SR4POST1224
    TRIPPLITE
    45U 4-POST OPEN FRAME CABINET
SR4POST1224 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 45U SmartRack 4-Post Open Frame Rack Threaded 12-24 Mounting Holes Highlights ● 45U 4-post open frame rack ● Black steel with threaded (1224) mounted holes ● Toolless button holes to accept PDUs or cable managers MODEL NUMBER: SR4POST1224 Package Includes Description Tripp Lite's 45U 4-Post Open Frame Rack with Threaded Mounting Holes helps IT managers organize their equipment array and provides fast, easy access to installed IT equipment. The SR4POST1224 is a simple solution for housing IT equipment in secure environments and other areas that don't require a lockable rack solution. This 45U rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for durability. It supports stationary loads up to 1000 lbs (453.6 kgs). The SR4POST1224 comes with all the hardware required for assembly and has a self-squaring design with bolt-down provisions. For high-density applications, multiple units can be bolted together side by side. The open design of the SR4POST1224 provides unobstructed airflow and easy access to equipment and cabling. It has threaded (12-24) mounting holes for easy installation of standard 19-inch rack equipment. The SR4POST1224 supports equipment depths from 22 to 36 inches. This rack also accommodates toolless button-hole mounting for vertical PDUs and cable managers. Features ● Supports 1000 lbs (453.6 kgs) of rackmount equipment ● Adjustable mounting depth (22 to 36 inches) ● Textured powder coat finish ● Heavy-duty cold-rolled steel construction ● Numbered mounting positions ● Bolt down provisions ● Threaded 12-24 holes ● Black finish ● Easy assembly Specifications OVERVIEW UPC Code 037332159830 1/3 ● SR4POST1224 ● Installation hardware ● 50x pieces of 12-24 screws and washers ● Cable management hooks ● Owner's Manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Open-Frame PHYSICAL Color Black Rack Height 45U Rack Depth Standard Maximum Device Depth (cm) 91.44 Maximum Device Depth (in.) 36 Maximum Device Depth (mm) 914 Minimum Device Depth (cm) 55.88 Minimum Device Depth (in.) 22 Minimum Device Depth (mm) 559 Shipping Dimensions (hwd / in.) 4.40 x 6.60 x 88.40 Shipping Dimensions (hwd / cm) 11.18 x 16.76 x 224.54 Shipping Weight (lbs.) 74.00 Shipping Weight (kg) 33.57 Unit Dimensions (hwd / in.) 84.300 x 20.300 x 39.400 Unit Dimensions (hwd / cm) 214.122 x 51.56 x 55.88 - 91.44 Unit Weight (lbs.) 69 Unit Weight (kg) 31.30 Weight Capacity - Stationary (kg) 454 Weight Capacity - Stationary (lbs.) 1000 Number of Vertical Mounting Rails 4 Assembly Required Yes FEATURES & SPECIFICATIONS Grounding Lug Includes a set of screws, bolts, and washers to secure a user-supplied grounding wire to Front and Back frames Pre-Installed Casters No STANDARDS & COMPLIANCE Product Certifications IEC 60297-3 Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR4POST1224
物料型号: - 型号编号:SR4POST1224
器件简介: - 这是一款45U的4柱开放式机架,具有螺纹(12-24)安装孔,旨在帮助IT经理组织设备并提供快速、便捷的安装IT设备的访问。SR4POST1224适用于安全环境和其他不需要可锁定机架解决方案的场合。这款45U机架采用重型冷轧钢构造,表面有黑色粉末涂层,耐用性强,支持高达1000磅(453.6公斤)的静态负载。
引脚分配: - 该机架具有编号的安装位置,并且有4个垂直安装轨。
参数特性: - 支持1000磅(453.6公斤)的机架安装设备。 - 可调节的安装深度(22至36英寸)。 - 纹理粉末涂层。 - 重型冷轧钢构造。 - 带有螺纹(12-24)孔,便于安装标准19英寸机架设备。 - 支持设备深度从22到36英寸。 - 黑色表面处理。 - 易于组装。
功能详解: - 该机架具有自对齐设计和螺栓固定装置,适用于高密度应用,可以并排螺栓固定多个单元。开放式设计提供无阻碍的气流和方便的设备及布线访问。还支持工具式按钮孔安装,适用于垂直PDU和电缆管理器。
应用信息: - 设备兼容性:配线架、网络交换机、不间断电源(UPS)、服务器。
封装信息: - 颜色:黑色。 - 机架高度:45U。 - 标准机架深度。 - 最大设备深度:36英寸(914毫米)。 - 最小设备深度:22英寸(559毫米)。 - 发货尺寸:4.40x6.60x88.40英寸(11.18x16.76x224.54厘米)。 - 发货重量:74.00磅(33.57公斤)。 - 单位尺寸:84.300x20.300x39.400英寸(214.122x51.56x55.88-91.44厘米)。 - 单位重量:69磅(31.30公斤)。 - 固定重量容量:1000磅(454公斤)。 - 需要组装。
SR4POST1224 价格&库存
很抱歉,暂时无法提供与“SR4POST1224”相匹配的价格&库存,您可以联系我们找货
