SRWF6U36
SRWF6U36
    TRIPPLITE
    WALL MOUNT RACK ENCL CABINET
SRWF6U36 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartRack 6U Low-Profile Vertical-Mount ServerDepth Wall-Mount Rack Enclosure Cabinet MODEL NUMBER: SRWF6U36 Highlights ● Maximum load capacity of 150 lbs (68 kgs) ● Locking steel cabinet vented to keep equipment cool ● Secures 6U of 19 in. rack equipment up to 36 in. deep ● Includes additional 2U of space for patch panels ● Ships fully assembled for quick installation Package Includes Wall-mount cabinet secures and organizes 6U of 19-inch rack equipment in network wiring closets and other locations with limited floor space. Houses equipment up to 36 inches deep, but extends less than 12 inches from wall. Description The SRWF6U36 SmartRack 6U Low-Profile Vertical-Mount Server-Depth Wall-Mount Rack Enclosure Cabinet is designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail locations, classrooms, back offices and other areas with limited floor space where you need equipment to be secure, organized and out of the way. Constructed from heavy-duty steel with a durable black powdercoated finish, the cabinet has a maximum load capacity of 150 lbs (68 kgs). Because the low-profile cabinet mounts vertically, it extends less than 12 inches from the wall while housing equipment up to 36 inches deep, including 1U servers, UPS systems, battery packs and switches. In addition to 6U of rack space in the primary mounting area, it also includes a slide-out 2U mounting bracket at the top of the enclosure for patch panels up to 2.5 inches deep. The top panel and front door lock securely to help prevent damage, tampering or theft. The cabinet is vented, which allows air to flow freely and keep equipment cool. The reversible front door can open left or right. Convenient top and bottom ports allow easy cable routing. The SRWF6U36 comes fully assembled and ready to mount to the wall. Equipment installation is easy with threaded mounting holes and hardware that support M6 or 12-24 mounting. Features Saves Valuable WorkspacePerfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited floor space where you need equipment to be secure, organized and out of the wayHouses EIA-standard 19 in. rack equipment in 6U of spaceLow-profile vertical-mount cabinet extends less than 12 in. from the wall while housing equipment up to 36 in. deep, including 1U servers, UPS systems, battery packs and switchesAlso includes a slide-out 2U mounting bracket at the top of the enclosure for patch panels up to 2.5 in. deepMaximum load capacity of 150 lbs (68 kgs) Keeps Important Equipment SecureTop panel and reversible front door lock securely to help prevent damage, tampering or theftVented cabinet keeps equipment coolConvenient ports with removable covers allow cable routing through top and bottom Easy Enclosure and Equipment InstallationShips fully assembled for quick installationWall-mounting holes spaced 16 in. apart for standard wall stud placementRails adjust easily—unscrew them, slide them to desired depth, and screw them back inThreaded mounting holes support M6 or 12-24 mountingRack spaces marked for easy reference 1/3 ● SRWF6U36 SmartRack 6U Low-Profile Vertical-Mount Server-Depth Wall-Mount Rack Enclosure Cabinet ● (12) M6 screws ● (12) M6 cup washers ● (12) 12-24 screws ● (2) Keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Meets Payment Card Industry StandardsProvides physical equipment and media security required for PCI DSS (Payment Card Industry Data Security Standard) compliance Specifications OVERVIEW UPC Code 037332190642 Device Compatibility Patch Panel; Network Switch; Server Rack Type Small Enclosure PHYSICAL Color Black Rack Height 6U Rack Depth Standard Maximum Device Depth (cm) 91.44 Maximum Device Depth (in.) 36 Maximum Device Depth (mm) 914 Shipping Dimensions (hwd / in.) 18.00 x 32.00 x 49.00 Shipping Dimensions (hwd / cm) 45.72 x 81.28 x 124.46 Shipping Weight (lbs.) 87.00 Shipping Weight (kg) 39.46 Unit Dimensions (hwd / in.) 43.000 x 25.600 x 11.500 Unit Dimensions (hwd / cm) 109,83 x 67,82 x 30,40 Unit Weight (lbs.) 88.20 Unit Weight (kg) 40.01 Weight Capacity - Stationary (kg) 68 Weight Capacity - Stationary (lbs.) 150 Number of Vertical Mounting Rails 2 FEATURES & SPECIFICATIONS Built-in Cable Management No Extra Wide No Pre-Installed Casters No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SRWF6U36 价格&库存
很抱歉,暂时无法提供与“SRWF6U36”相匹配的价格&库存,您可以联系我们找货
