SR4POSTAA
SR4POSTAA
    TRIPPLITE
    45U 4-POST OPEN FRAME CABINET
SR4POSTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant 45U SmartRack 4-Post Open Frame Rack MODEL NUMBER: SR4POSTAA Description Tripp Lite's TAA-Compliant 45U 4-Post Open Frame Rack helps IT managers organize their equipment array and provides fast, easy access to installed IT equipment. The SR4POSTAA is a simple solution for housing IT equipment in secure environments and other areas that don’t require a lockable rack solution. This 45U rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for durability. It supports stationary loads up to 1000 lb. The SR4POSTAA comes with all the hardware required for assembly and has a self-squaring design with bolt-down provisions. For high-density applications, multiple units can be bolted together side by side. The SR4POSTAA is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. The open design of the SR4POSTAA provides unobstructed airflow and easy access to equipment and cabling. It has numbered, square-hole mounting positions for easy installation of standard 19-inch rack equipment. The SR4POSTAA supports equipment depths from 22 to 36 inches. This rack also accommodates toolless button-hole mounting for vertical PDUs and cable managers. Features ● Supports 1000lbs of rackmount equipment ● Adjustable mounting depth (22 to 36 inches) ● Textured powder coat finish ● Heavy-duty cold-rolled steel construction ● Numbered mounting positions ● Bolt down provisions ● Self squaring design ● Black finish ● Easy assembly 1/2 Highlights ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● 45U 4-post open frame rack ● Black steel with square, numbered mounting holes ● Toolless button holes to accept PDUs or cable managers 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332154057 Rack Type Open-Frame PHYSICAL Color Black Rack Height 45U Maximum Device Depth (cm) 91.44 Maximum Device Depth (in.) 36 Maximum Device Depth (mm) 914 Shipping Dimensions (hwd / in.) 4.53 x 6.50 x 87.99 Shipping Dimensions (hwd / cm) 11.51 x 16.51 x 223.49 Shipping Weight (lbs.) 58.40 Shipping Weight (kg) 26.49 Unit Dimensions (hwd / in.) 84.020 x 20.200 x 34.300 Unit Dimensions (hwd / cm) 214.122 x 51.44 x 55.88-91.44 Unit Weight (lbs.) 73 Unit Weight (kg) 33.11 Weight Capacity - Stationary (kg) 454 Weight Capacity - Stationary (lbs.) 1000 FEATURES & SPECIFICATIONS Pre-Installed Casters No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SR4POSTAA
物料型号:SR4POSTAA
器件简介:Tripp Lite的TAA合规45U 4柱开放式机架帮助IT经理组织他们的设备阵列,并提供快速、便捷的安装IT设备的访问。该机架适用于安全环境和其他不需要可锁定机架解决方案的区域。
引脚分配:机架具有编号的、方形孔位安装位置,便于安装标准19英寸机架设备。
参数特性: - 支持1000磅的机架安装设备 - 可调节的安装深度(22至36英寸) - 纹理粉末涂层表面 - 重型冷轧钢构造 - 编号的安装位置 - 螺栓固定装置 - 自我校正设计 - 黑色表面处理 - 易于组装
功能详解:开放式设计提供无阻碍的气流和对设备及布线的便捷访问。支持设备深度从22到36英寸,也支持工具式按钮孔位安装垂直PDU和电缆管理器。
应用信息:适用于高密度应用,多个单元可以并排螺栓固定。
封装信息:重型冷轧钢构造,黑色粉末涂层表面,支持固定负载高达1000磅。
SR4POSTAA 价格&库存
很抱歉,暂时无法提供与“SR4POSTAA”相匹配的价格&库存,您可以联系我们找货
