1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 16U Low-Profile Vertical-Mount WallMount Half-Height Server Rack Enclosure
MODEL NUMBER: SRWF16U38
Highlights
Maximum load capacity of 400
lbs (181.4 kgs)
Locking steel cabinet vented to
keep equipment cool
Secures 12U of 19 in. rack
equipment up to 35 in. deep
Includes additional 4U of space
for patch panels
Modular design for easy
disassembly and assembly
Package Includes
Wall-mount cabinet secures and organizes 16U of 19-in. rack equipment in network wiring closets and
other locations with limited floor space. Houses equipment up to 35 in. deep, but extends just 24 in. from
wall.
Description
The SRWF16U38 SmartRack® 16U Low-Profile Vertical-Mount Server-Depth Wall-Mount Rack Enclosure
Cabinet is designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail
locations, classrooms, back offices, two-post racks and other areas with limited floor space where you
need equipment to be secure, organized and out of the way. Constructed from heavy-duty steel with a
durable black powder-coated finish, the cabinet has a maximum load capacity of 400 lbs (181.4 kgs).
Because the low-profile cabinet mounts vertically, it extends only 24 inches from the wall while housing
equipment up to 35 inches deep, including 1U servers, UPS systems, battery packs and switches. In
addition to 12U of rack space in the primary mounting area, it also includes a 4U mounting space at the
top of the enclosure for patch panels.
The top cover and front panel are removable to allow expedient access to equipment. The cover also
locks securely with the included keys to help prevent damage, tampering or theft. The vented cabinet
allows air to flow freely and keep equipment cool. Convenient top, bottom and side ports allow easy cable
routing.
The SRWF16U38's modular design allows you to disassemble the cabinet in minutes for wall-mounting
with user-supplied hardware. Mounting holes are spaced 16 inches apart to accommodate standard wall
studs. Equipment installation is easy with threaded mounting holes that support 12-24 mounting in twopost racks.
Features
Saves Valuable Workspace
● Recommended for areas with limited floor space where you need equipment to be secure, organized
and out of the way
Houses EIA-standard 19 in. rack equipment in 12U of space
Also includes 4U of mounting space at the top of the enclosure for patch panels
Extends only 24 in. from the wall while housing equipment up to 35 in. deep
Maximum load capacity of 400 lbs (181.4 kgs)
Keeps Important Equipment Secure
● Top cover locks securely to help prevent damage, tampering or theft
1/3
SRWF16U38 SmartRack 16U
Enclosure Cabinet
(2) Keys
Owner’s manual
Cleveland, OH 44122
United States
Vented cabinet keeps equipment cool
Convenient ports with removable covers allow cable routing through top, bottom and sides
Easy Enclosure and Equipment Installation
● Modular design for easy disassembly and assembly
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Threaded mounting holes support 12-24 mounting in 2-post racks
Rack spaces marked for easy reference
Meets Payment Card Industry Standards
● Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332195869
Device Compatibility
Network Switch; Patch Panel; Server
Rack Type
Half-Height Enclosure
PHYSICAL
Color
Black
Rack Height
16U
Rack Depth
Standard
Maximum Device Depth (cm)
88.90
Maximum Device Depth (in.)
35
Maximum Device Depth (mm)
889
Shipping Dimensions (hwd / in.)
42.91 x 22.44 x 26.00
Shipping Dimensions (hwd / cm)
108.99 x 57.00 x 66.04
Shipping Weight (lbs.)
101.00
Shipping Weight (kg)
45.81
Unit Dimensions (hwd / in.)
38.000 x 19.685 x 23.190
Unit Dimensions (hwd / cm)
96.52 x 50.01 x 58.9
Unit Weight (lbs.)
81.5
Unit Weight (kg)
36.97
Weight Capacity - Stationary (kg)
181
Weight Capacity - Stationary (lbs.)
400
Number of Vertical Mounting Rails
2
2/3
Cleveland, OH 44122
United States
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRWF16U38”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9287.070921+1203.78121
