1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 12U Mid-Depth Small Rack Enclosure
for Harsh Environments
Highlights
Built-In Dust Filter: Protects
against airborne particles and
easily replaced with standard
off-the-shelf furnace filters
Heavy-Duty Construction:
Withstands jolts and vibrations
in harsh working environments
Louvered Door: Keeps out drips,
splashing water and falling
debris
4 High-Performance Fans:
Maintain ample airflow to keep
equipment cool
MODEL NUMBER: SR12UBFFD
Package Includes
Protects sensitive electronic equipment from harsh conditions that would overwhelm a typical rack
enclosure. Ideal for use in factories, construction areas, utility plants, warehouses and other areas with
limited space that are high in moisture, dust and debris.
Description
This SmartRack 12U Mid-Depth Rack Enclosure Cabinet protects sensitive electronic equipment from
harsh conditions that would overwhelm a typical rack enclosure. It is deal for use in factories, construction
areas, utility plants, warehouses and other areas with limited space that are high in moisture, dust and
debris. It can protect your equipment from falling dirt, dust, drips, splashes and accidental contact with
personnel. On the front door there is a built-in dust filter. The filter is removable and can be replaced with
standard furnace filters - they're simple, inexpensive and effective. To compensate for the added air
resistance of the filters, there are 4 large, high performance intake fans in the front door. The fans pull air
through the enclosure, from front to side. Adjustable rack rails with square mounting holes accommodate
up to 12U of standard 19" rackmount equipment. Supports up to 1000 lbs (453.6 kgs) of equipment.
Features
12U floor enclosure
Protection from falling dirt, dust, drips, splashes and accidental contact with personnel
Adjustable mounting depths from 3" to 32.5" inches
Front door has ventilating louvers
Built-in removable dust filter that can be replaced with standard furnace filters (20" x 24" x 1")
4 large, high-performance fans in front door that pull air through the enclosure, from front to rear
2 cable ports allow cable access while maintaining dust and moisture resistance
Locking, reversible front door
Locking, removable solid side panels
Fully assembled for quick installation
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
compliance
Specifications
1/3
(36) M6 cagenuts
(36) M6 screws
(36) Washers
(2) Keys
(1) Removable/Replaceable
dust filter
(4) Casters
(4) Leveling feet
(1) C13 to NEMA 5-15 power
cord, 10-ft. (3.05 m)
Owner's Manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332183439
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Small Enclosure
INPUT
Nominal Input Voltage(s) Supported
120V AC
Nominal Input Voltage Description
120V 50/60 Hz
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
PHYSICAL
Color
Black
Rack Height
12U
Rack Depth
Mid
Factory Preset Rack Depth (in.)
10.42
Factory Preset Rack Depth (cm)
26.5
Factory Preset Rack Depth (mm)
265
Maximum Device Depth (cm)
82.55
Maximum Device Depth (in.)
32.5
Maximum Device Depth (mm)
826
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Shipping Dimensions (hwd / in.)
30.90 x 25.00 x 39.80
Shipping Dimensions (hwd / cm)
78.49 x 63.50 x 101.09
Shipping Weight (lbs.)
134.00
Shipping Weight (kg)
60.78
Unit Dimensions (hwd / in.)
25.200 x 23.600 x 38.500
Unit Dimensions (hwd / cm)
64 x 59.95 x 97.79
Unit Weight (lbs.)
96
Unit Weight (kg)
43.54
Weight Capacity - Rolling (kg)
454
Weight Capacity - Rolling (lbs.)
1000
2/3
Cleveland, OH 44122
United States
Weight Capacity - Stationary (kg)
454
Weight Capacity - Stationary (lbs.)
1000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and back door frames
Built-in Cable Management
Yes
Extra Wide
No
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Protection Rating
IP54
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR12UBFFD”相匹配的价格&库存,您可以联系我们找货
