NEMA 12 Frames (C3 Series)
NEMA 12
YL
N
O
E
M
- FRA L RAILS
E
N
ED
A
D
P
U
L
C
N
I
NOT
19” Extra Wide
NEMA 12
Rack Cabinet
Front View
Side View
Rear View
(optional cover
installed)
By using our 24” to 19” rail width
adaptors (page 74) you can convert
our 24” cabinets to 19” Extra Wide
Panel Mount
This additional space allows for large
bundles of wire that would not fit in
standard 19” rack cabinets
70
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
Top View
ww
w.h
am
mo
ndm
fg.c
om
Bottom View
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
FEATURES
• NEMA 12 rated - ideal for use in harsh factory floor situations
• CSA & UL listed
• Oil resistant gaskets are permanently secured on all openings
• Sides and doors are easily removable for easy internal access
• Heavy duty - welded rack (1,500 lb even load rating)
• Choice of standard 19” panel width (23” overall) or 24" panel width (28" overall)
• By using panel width adaptors (page 74) - this system can be converted to 19” rack mount with extra wiring
area on both sides of equipment. Allows space for vertical cable managers (page 96)
• Choice of two depths:
- usable depth of 21.63" (23.63” overall)
- usable depth of 29.50" (31.50” overall)
• Unit is shipped as welded frame only with 4 levelling feet
• Panel rails are NOT included allows maximum flexibility of panel rail quantity & options (ie..tapped or square hole)
• Heavy duty: 14 gauge steel frame
• Frame ships with reinforced lifting eyes
• Finished in a rugged, textured beige powder paint
• See ordering guide (next page)
19” Rack Mount Versions
23.63” Deep (Usable Depth = 21.63”)
Panel Height
Overall Dimensions (I nches)
Strut Center
Par t Number
Panel
Width
I nches
Units
A
B
Depth
H
O
C3F196323CG1
C3F197023CG1
C3F197823CG1
19.00
19.00
19.00
63
70
78
36
40
45
70.31
77.31
86.06
23.00
23.00
23.00
23.63
23.63
23.63
63.06
70.06
78.81
29.50
33.00
37.38
Panel Height
Strut Center
Par t Number
Panel
Width
I nches
Units
A
B
Depth
H
O
C3F196331CG1
C3F197031CG1
C3F197831CG1
19.00
19.00
19.00
63
70
78
36
40
45
70.31
77.31
86.06
23.00
23.00
23.00
31.50
31.50
31.50
63.06
70.06
78.81
29.50
33.00
37.38
NEMA 12
31.5” Deep (Usable Depth = 29.5”)
24” Rack Mount Versions
Panel Height
Strut Center
Par t Number
Panel
Width
I nches
Units
A
B
Depth
H
O
C3F246323CG1
C3F247023CG1
C3F247823CG1
24.00
24.00
24.00
63
70
78
36
40
45
70.31
77.31
86.06
28.00
28.00
28.00
23.63
23.63
23.63
63.06
70.06
78.81
29.50
33.00
37.38
Panel Height
Strut Center
Par t Number
Panel
Width
I nches
Units
A
B
Depth
H
O
C3F246331CG1
C3F247031CG1
C3F247831CG1
24.00
24.00
24.00
63
70
78
36
40
45
70.31
77.31
86.06
28.00
28.00
28.00
31.50
31.50
31.50
63.06
70.06
78.81
29.50
33.00
37.38
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
71
Ordering Guide - NEMA 12 (C3 Series)
Doors
(Page 76)
NEMA 12
Side Panels
(Page 74)
Welded Frame
(Page 70)
Mounting Rails
(Page 73)
72
Caster Assembly
(Page 75)
ww
w.h
am
mo
ndm
fg.c
om
Contempra 3 Accessories
(Page 73)
Universal Accessories
(Page 80)
256 Sonwil Dr.
USA
Panel Rails - NEMA 12 (C3 Series)
TAPPED RAILS
• SOLD IN PAIRS
• Drilled and tapped (10-32)
• Heavy duty construction - formed from 10 gauge steel
• Full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing)
• Bolts vertically in rack to amhal struts
• Includes strut mounting hardware, panel mounting hardware available on
page 119
• Zinc plated finish
• Front of rail allows for 19” or 24” panel rack mounting (depending on the
width of the cabinet frame ordered)
• By using panel width adaptors (next page) - the 24” rack mount frames can
be converted to 19” rack mount with extra wiring area on both sides of
equipment
• Rear of rail flange for rear support or accessory mounting
Pa n e l He i g h t
Pa r t Nu mb e r
( S o l d i n Pa i r s ) I n c h e s Un i t s
CCR35TZPL
35.00
CCR42TZPL
42.00
24
CCR49TZPL
49.00
28
CCR56TZPL
56.00
32
CCR63TZPL
63.00
36
CCR70TZPL
70.00
40
CCR78TZPL
78.75
45
CCR85TZPL
85.75
49
SQUARE HOLE RAILS
Pa n e l He i g h t
Pa r t Nu mb e r
CPR35SZPL
35.00
CPR42SZPL
42.00
24
CPR49SZPL
49.00
28
CPR56SZPL
56.00
32
CPR63SZPL
63.00
36
CPR70SZPL
70.00
40
CPR78SZPL
78.75
45
CPR85SZPL
85.75
49
NEMA 12
• SOLD IN PAIRS
• Square hole punched - allowing choice of hardware for 10-32 or 12-24 or
M6 thread cage nuts), Full EIA hole centers (5/8 - 5/8 - 1/2 inch spacing)
• Includes a starter quantity (25) of 10-32 cage nuts
• Heavy duty construction - formed from 12 gauge steel, zinc plated finish
page 119
• By using panel width adaptors (next page) - the 24” rack frames can be
converted to 19” rack mount with extra wiring area on both sides of equipment
• 23” mount rails ONLY work in 24” rack cabinet frames
• Rear "L" of rail for rear support or accessory mounting
23” Mount Rails
Cage Nut
Installation Tool
• Allows for easy installation of
cage nuts in square rail hole
• Spring steel tool
• Part Number RCNIT
Additional Cage Nuts
Pa r t Nu mb e r
1421CNA25
1421CNA100
1421CNC25
1421CNC100
1421CNB25
1421CNB100
Q t y. P e r
Pa c k a g e
25
100
25
100
25
100
Thread
10-32
10-32
12-24
12-24
M6
M6
ww
w.h
am
mo
ndm
fg.c
om
Pa n e l He i g h t
Pa r t Nu mb e r
C P R 2 3 7 0 S Z P L 70.00
40
C P R 2 3 7 8 S Z P L 78.75
45
256 Sonwil Dr.
USA
73
Width Adaptors & Side Panels (C3 Series)
RAIL WIDTH ADAPTORS
(24” Rack Frames ONLY)
• NOT REQUIRED FOR 19” RACK FRAMES
• SOLD IN SETS OF 6 - ENOUGH FOR ONE PAIR OF RAILS
• Converts 24” rack cabinets to 19” rack mount (extra wide)
• Provides additional wiring space along both sides of 19" rack mounted
equipment
• Allows space for vertical cable managers (page 96)
• Fits between panel rail and three horizontal channels (amhal struts)
• Constructed of black anodized extruded aluminum
• Kit includes six adaptor brackets, extender bolts and washers - required
hardware for one pair of rails
• Part Number CAK1924
SIDE PANELS
• SOLD IN PAIRS
• Constructed of 16 gauge steel
• Panels fit flush with frame
• Features quick release 1/4 turn cam fasteners providing a tight seal
against gasket on the frame
• Finished in beige textured powder paint (matches frame)
For 23.63” Deep Frame
NEMA 12
Pa r t Nu mb e r
C3SP6323CG1
C3SP7023CG1
C3SP7823CG1
Rack
Depth
(Inches)
23.63
23.63
23.63
Pa n e l He i g h t
Inches
Units
U s e Wi t h Fr a me
Pa r t Nu mb e r
63
70
78
36
40
45
C3F196323CG1 or C3F246323CG1
C3F197023CG1 or C3F247023CG1
C3F197823CG1 or C3F247823CG1
For 31.5” Deep Frame
Pa r t Nu mb e r
C3SP6331CG1
C3SP7031CG1
C3SP7831CG1
Rack
Depth
(Inches)
31.50
31.50
31.50
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
C3F196331CG1 or C3F246331CG1
C3F197031CG1 or C3F247031CG1
C3F197831CG1 or C3F247831CG1
• For higher security, the quarter turn fasteners on
the side panels can be replaced with this key
locking version
• Order part number C3SPQTRL
• Kit contains 4 quarter turn locks and 8 keys.
• Good for 1 rack (ie...2 locks per side panel)
74
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
Casters & Plinths - NEMA 12 (C3 Series)
CASTER BASE ASSEMBLY
• Casters and adaptor base provide heavy duty
caster capability
• Complete assembly with four casters, mounts to rack
frame without drilling
• 3” non-static rockite caster wheels with ball bearing
pivots
• 1,080 lb. Mfg's specified weight capacity
• Not compatible with plinth (below)
• Hardware included
For 19” Rack Mount Frames
For 24” Rack Mount Frames
Pa r t Nu mb e r
A
Pa r t Nu mb e r
A
C3CRS19
19.88
C3CRS24
24.88
LOCKING CASTERS
• These are exterior mount casters that mount outside of rack frame perimeter to allow foot access of locking pedals
• Medium Duty - 560# Mfg's specified weight capacity (Set of 4)
• Available in either locking or non-locking format
• Sold in pairs allowing for mix of locking and nonlocking on same cabinet
• 3.5” diameter wheels add 4.88” to cabinet height
• No drilling required as casters fit into built-in caster mounts
• Part Number CCSTL for a PAIR of locking casters
• Part Number CCSTN for a PAIR of non-locking casters
PLINTH
NEMA 12
• Adds 4” to overall rack height
• 14 gauge steel construction
• Features 4 corner units and 4 removable fill panels
• By removing both front & rear panels, easy access to bottom cabling and
forklift lifting/transport are achieved
• Not compatible with levelling feet or casters
Pa r t Nu mb e r
B l a c k Te x t u r e d
B e i g e Te x t u r e d
CPL19423BK1
CPL19423CG1
CPL19431BK1
CPL19431CG1
Pa n e l
Wi dt h
19"
19"
Use with
Fr a me D e p t h
23.63"
31.50"
Pa r t Nu mb e r
CPL24423BK1
CPL24423CG1
CPL24431BK1
CPL24431CG1
Pa n e l
Wi dt h
24"
24"
Use with
Fr a me D e p t h
23.63"
31.50"
BOLT DOWN KIT
• Fixes rack to floor
• Kit includes set of four - 3/8” x 5 1/2” bolts with flat washers and nuts
• Can be used with or without plinths
• Part Number: CBDK4
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
75
Doors - NEMA 12 (C3 Series)
SOLID DOOR
• Heavy Duty 14 gauge steel construction
• Smooth action handle provides solid NEMA 12 seal
• Quick release hinge design allows for easy removal
• Can be used on front or rear of frame
• Allows full access to space between panel rails when open
• Finish matches “C3” type rack frame in the same rugged beige textured powder paint
Pa r t Nu mb e r
C3DS1963HCG1
C3DS1970HCG1
C3DS1978HCG1
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
C3F196323CG1 or C3F196331CG1
C3F197023CG1 or C3F197031CG1
C3F197823CG1 or C3F197831CG1
Pa r t Nu mb e r
C3DS2463HCG1
C3DS2470HCG1
C3DS2478HCG1
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
C3F246323CG1 or C3F246331CG1
C3F247023CG1 or C3F247031CG1
C3F247823CG1 or C3F247831CG1
PLEXI - GLASS DOOR
NEMA 12
• Surface mount
• UL/CSA listed polycarbonate window
• Heavy Duty 14 gauge steel frame construction
• Slimline handle design allows maximum window viewing area & provides a solid NEMA 12 seal
• Frame matches “C3” type rack frame in the same rugged beige textured powder paint finish
Pa r t Nu mb e r
C3DS1963PCG1
C3DS1970PCG1
C3DS1978PCG1
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
Pa r t Nu mb e r
C3DS2463PCG1
C3DS2470PCG1
C3DS2478PCG1
76
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
QUARTER TURN - LATCHING SOLID DOOR
• Surface mount
• 3 quarter turn latches provide solid NEMA 12 seal
• Latches are close to door edge allowing for maximum door mounting area
Pa n e l He i g h t
Pa r t Nu mb e r
C3DS1963QCG1
C3DS1970QCG1
C3DS1978QCG1
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
Pa n e l He i g h t
Pa r t Nu mb e r
C3DS2463QCG1
C3DS2470QCG1
C3DS2478QCG1
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
SOLID SURFACE COVER
NEMA 12
• Surface mount
• 16 gauge steel construction
• Screws to frame to provide a solid NEMA 12 seal
• Normally used to cover & seal the rear of the rack
Pa r t Nu mb e r
C3CS1963SCG1
C3CS1970SCG1
C3CS1978SCG1
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
Pa r t Nu mb e r
C3CS2463SCG1
C3CS2470SCG1
C3CS2478SCG1
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
77
Exclusive Accessories For NEMA 12 (C3 Series)
RACK JOINING KIT
• Easily installed joining kit provides alignment and strength for
modular multi-bay installations
• When installed properly, this kit maintains UL/CSA NEMA 12 listing
Pa r t Nu mb e r
NEMA 12
C3JK6323
C3JK7023
C3JK7823
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
Pa r t Nu mb e r
C3JK6331
C3JK7031
C3JK7831
Pa n e l He i g h t
Inches
Units
Pa r t Nu mb e r
63
70
78
36
40
45
DON’T FORGET TO CHECK OUT OUR UNIVERSAL
ACCESSORY SECTION - NEXT PAGE
78
ww
w.h
am
mo
ndm
fg.c
om
256 Sonwil Dr.
USA
很抱歉,暂时无法提供与“C3F246323CG1”相匹配的价格&库存,您可以联系我们找货
