1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 24U Mid-Depth Half-Height Rack
Enclosure
MODEL NUMBER: SR24UB
Highlights
24U rack cabinet with adjustable
front and rear vertical rackmount
rails
Extended depth of 33" allow for
standard server installation
Locking, reversible front/rear
doors and locking, removable
side panels
Fully assembled for quick
installation
Casters and leveling feet
included
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) compliance
Package Includes
Description
Tripp Lite's SmartRack 24U Mid-Depth Rack Enclosure Cabinet is packed with features designed to
simplify rack equipment installations and rack equipment maintenance: top and bottom cable routing
ports, perforated front and rear doors and solid side panels promote efficient airflow, adjustable vertical
mounting rails and more. And as part of the SmartRack family, the SR24UB is compatible with Tripp Lite's
extensive range of rackmount accessories, enabling you to customize your solution to meet any
requirement. The SR24UB ships fully assembled for quick installation and comes with a 5-year warranty.
The SR24UB is compatible with all standard 19-inch rack equipment and features front and rear pairs of
vertical rails with square mounting holes. The rails are adjustable in quarter-inch increments to
accommodate equipment depths from 3 to 32.5 inches, ideal for standard server installation. Adjustment
is quick and convenient: simply unscrew the rails, slide them to the desired depth and restore the screws.
The rails feature square mounting holes and are capable of supporting up to 1000 lbs (453.6 kgs) of
equipment with included installation hardware. Each rack space within the enclosure is numbered for easy
reference.
With a locking, reversible front/rear doors and locking, removable side panels, the SR24UB provides safe,
secure installation for all equipment. This prevents unauthorized access to installed equipment while
making it easy for authorized personnel to perform inspections, maintenance and equipment replacement.
The enclosure meets all requirements toward PCI DSS compliance.
The top and bottom panels of the SR24UB are furnished with vents designed to help remove warm air
from the enclosure and draw in cool air by convection. They also support installation of standard usersupplied case fans (Tripp Lite SRFANWM). The top and bottom panels are also provided with ports for
cable routing.
To simplify deployment, the SR24UB comes with an accessory caster kit consisting of 4 casters and all
required installation hardware. With the casters installed, the SR24UB can easily be maneuvered into the
desired location, and then secured in place by adjusting the unit's levelers. Note: the casters are intended
for minor position adjustments within the final installation area only and are not designed for moving the
enclosure over long distances.
Features
24U extra deep enclosure
Adjustable mounting depths from 3" to 32.5" inches
Locking, reversible front and rear doors
Locking, removable side panels
Top and bottom panel cable access openings
1/3
(50) M6 screws
(50) M6 cage nuts
(50) M6 washers
(4) Casters
(4) Levelers
(2) keys
Owner's Manual
Cleveland, OH 44122
United States
Fully assembled for quick installation
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
compliance
Specifications
OVERVIEW
UPC Code
037332185228
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Half-Height Enclosure
PHYSICAL
Color
Black
Rack Height
24U
Rack Depth
Mid
Factory Preset Rack Depth (in.)
28.31
Factory Preset Rack Depth (cm)
71.9
Factory Preset Rack Depth (mm)
719
Maximum Device Depth (cm)
82.55
Maximum Device Depth (in.)
32.5
Maximum Device Depth (mm)
826
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Cable Access Hole Measurement
(inches)
9.812 x 2.35 (l x w)
Shipping Dimensions (hwd / in.)
52.00 x 26.00 x 35.00
Shipping Dimensions (hwd / cm)
132.08 x 66.04 x 88.90
Shipping Weight (lbs.)
152.00
Shipping Weight (kg)
68.95
Unit Dimensions (hwd / in.)
46.060 x 24.200 x 34.060
Unit Dimensions (hwd / cm)
115.82 x 60 x 85.09
Unit Weight (lbs.)
123
Unit Weight (kg)
55.79
Weight Capacity - Rolling (kg)
454
Weight Capacity - Rolling (lbs.)
1000
2/3
Cleveland, OH 44122
United States
Weight Capacity - Stationary (kg)
454
Weight Capacity - Stationary (lbs.)
1000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
Yes
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR24UB”相匹配的价格&库存,您可以联系我们找货
