SR42UBEXPNDNR3
SR42UBEXPNDNR3
    TRIPPLITE
    42U 4-POST OPEN FRAME RACK CABIN
SR42UBEXPNDNR3 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U Standard-Depth 4-Post Premium Open Frame Rack - No Doors, Side Panels or Top Panel Highlights ● 42U premium open frame rack does not come with sides, doors or roof ● 4 interior vertical posts with unthreaded square hole openings ● Standard 24 in. (600 mm) width and 42 in. (1050 mm) depth for optimizing floor space ● Ships fully assembled for immediate deployment ● 3000 lbs (1360.8 kgs) stationary and rolling load capacity ● Rolls through standard 7-ft. (2.13 m) doorway on preinstalled 3 in. casters ● Comes with equipment mounting hardware (M6 cage nuts and M6 screws) MODEL NUMBER: SR42UBEXPNDNR3 Package Includes Description This SmartRack 42U 4-post rack stores and organizes up to 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. The expansion model comes without sides, doors or roof. Front and rear vertical rails have square mounting holes that are adjustable in quarter-inch increments from 4 to 37 inches. Adjustment is quick with an easy-view depth index that ensures consistent rail placement without requiring time-consuming measurements. Each rack space is numbered for ready reference and supports toolless button-mount 0U installation of four compatible PDUs and cable managers. All components of the SR42UBEXPNDNR3 are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. Heavy-duty pre-installed three-inch casters allow you to roll the open frame rack into the desired location, where you can secure it by adjusting the preinstalled levelers (the casters are intended for minor position adjustments and are not designed for moving the enclosure over long distances). Features ● Ships fully assembled for immediate deployment ● Rolls into place on heavy-duty 3-inch pre-installed (and removable) casters ● Front/rear mounting rails adjust quickly and conveniently in 1/4-inch increments ● Easy-view depth index ensures consistent rail placement without requiring time-consuming measurements ● Toolless accessory mounting rails include slots for quick installation of compatible PDUs and vertical cable managers ● Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Includes mounting hardware: 50 M6 screws and 50 M6 cage nuts ● Textured powder-coat finish for tough resistance to environmental concerns, including deployment in warehouses. ● Maximum usable internal depth of 37 in./94 cm (front to rear rail) ● Weight ratings of 3000 lbs (1360.8 kgs). both stationary and rolling ● Built-in baying tabs allow premium open frame racks to be combined securely in rows with width set center to center at 24 in. or 600 mm to match standard data center floor tiles 1/3 ● SmartRack 42U Standard-Depth 4-Post Premium Open Frame Rack ● (50) M6 screws ● (50) M6 cage nuts ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Heavy-duty leveling feet allow even positioning on uneven floors ● Rolls easily through standard commercial doorways ● All components are grounded to the premium open frame rack structure, which includes multiple connections for facility ground ● Open top, front, sides and bottom for cable access ● Included stabilizing brackets used for shipment and can be reattached on the inside or outside of the rack Specifications OVERVIEW UPC Code 037332166630 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Open-Frame PHYSICAL Color Black Rack Height 42U Rack Depth Standard Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 79.00 x 24.50 x 40.00 Shipping Dimensions (hwd / cm) 200.66 x 62.23 x 101.60 Shipping Weight (lbs.) 200.00 Shipping Weight (kg) 90.72 Unit Dimensions (hwd / in.) 78.500 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 201,93 x 60,02 x 105,41 Unit Weight (lbs.) 150 Unit Weight (kg) 68.04 Weight Capacity - Rolling (kg) 1,361 Weight Capacity - Rolling (lbs.) 3000 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management No Extra Wide No Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications IEC 60297-3; UL 60950-1 Product Compliance RoHS; EIA/ECA-310-E; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR42UBEXPNDNR3
物料型号:SR42UBEXPNDNR3
器件简介:SmartRack 42U 4柱高级开放式机架,无门、侧板或顶板,用于存储和整理高达3000磅(1360.8公斤)的标准19英寸机架设备,共42U。
引脚分配:前/后垂直轨道有方形安装孔,可从4英寸到37英寸以四分之一英寸递增调整。
参数特性:最大可用内部深度为37英寸(94厘米),颜色为黑色,42U机架高度,标准机架深度,设备最大深度为37英寸(940毫米),设备最小深度为4英寸(102毫米),带有50个M6螺丝和50个M6笼式螺母的安装硬件。
功能详解:完全组装发货,可立即部署,重型预安装(可拆卸)3英寸脚轮,前/后安装轨道可快速方便地以1/4英寸递增调整,工具免费配件安装轨道,包括用于兼容PDU和垂直电缆管理器的快速安装槽,每个轨道可容纳两个垂直PDU或电缆管理器并排放置(每个机架四个项目),所有组件均接地至机架框架,前/后螺纹接地点用于连接到设施接地。
应用信息:用于部署机架式设备,如配线架、网络交换机、不间断电源(UPS)和服务器。
封装信息:开放式机架,无侧板、门或顶板,内部有4个垂直立柱,带有非螺纹方形孔开口,标准24英寸(600毫米)宽和42英寸(1050毫米)深,适合优化地板空间。
产品认证:IEC60297-3; UL 60950-1,产品合规性:RoHS; EIAECA-310-E; UKCA,产品保修期:全球5年有限保修。
SR42UBEXPNDNR3 价格&库存
很抱歉,暂时无法提供与“SR42UBEXPNDNR3”相匹配的价格&库存,您可以联系我们找货
