SR42UBMDEXPND
SR42UBMDEXPND
    TRIPPLITE
    42U 4-POST OPN FRAM RACK CABINET
SR42UBMDEXPND 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U SmartRack 4-Post Mid-Depth Open Frame Rack - no sides or doors MODEL NUMBER: SR42UBMDEXPND Description The SR42UBMDEXPND is part of our new line of mid-depth rack enclosures. Our new line offers 36" (927mm) depth opposed to the standard 42" (1050mm). The SR42UBMDEXPND is a 42U SmartRack enclosure with NO doors and NO side panels. The 'EXP' version is an expansion model used when several cabinets are bayed together. Its integrated baying tabs make it easy to combine multiple enclosures in rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle configurations. The SR42UBMDEXPND houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. Its front and rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch increments from 4 to 28.75 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready reference. Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment and reduces cord clutter. All components of the SR42UBMDEXPND are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. To simplify deployment, the SR42UBMDEXPND comes with preinstalled casters that enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed for moving the enclosure over long distances. The SR42UBMDEXPND comes with a 5-year product warranty. As part of the SmartRack family, the SR42UBMDEXPND is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to meet any requirement. Features ● Ships fully assembled for rapid deployment and roll into place on pre-installed casters, allowing the enclosures to be pre-configured and rolled to the final installation location. Casters are removable. ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. ● Tool-less accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws 1/3 Highlights ● 42U SmartRack Premium open frame rack ● 36" (927mm) depth (with mounting depth increments from 4 to 28.75") and standard 24" (600mm) width ● 4 interior vertical posts with unthreaded square hole openings ● Ships fully assembled ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Preinstalled casters and leveling feet ● Rolls through standard 7-ft. (2.13 m) doorways ● Includes 50 pieces of M6 cage nuts and 50 pieces of M6 screws (equipment mounting hardware) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Maximum usable internal depth of 31 inches ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Built in baying tabs allow premium open frame racks to be combined securely in rows. Center-to-center width can be set at 600mm or 24" to match standard data center floor tiles. ● Leveling feet extend to allow premium open frame racks to be positioned on uneven floors. Levelers are removable. ● Compact design allows the premium open frame racks to roll through standard height commercial doorways. ● Convenient grounding system. All components are grounded to the premium open frame rack structure which includes multiple connections for facility ground. ● Open bottom for cable access. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the premium open frame rack on the inside or outside of the rack. ● Compatibility with all cable management accessories. Specifications OVERVIEW UPC Code 037332175670 Device Compatibility Patch Panel; Network Switch; UPS Rack Type Open-Frame PHYSICAL Color Black Rack Height 42U Rack Depth Mid Maximum Device Depth (cm) 78.74 Maximum Device Depth (in.) 31 Maximum Device Depth (mm) 787 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 85.00 x 26.00 x 37.80 Shipping Dimensions (hwd / cm) 215.90 x 66.04 x 96.01 Shipping Weight (lbs.) 153.00 Shipping Weight (kg) 69.40 Unit Dimensions (hwd / in.) 78.500 x 23.630 x 32.350 Unit Dimensions (hwd / cm) 199.39 x 60.02 x 82.00 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 103 Unit Weight (kg) 46.72 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management No Extra Wide No Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR42UBMDEXPND
1. 物料型号: - 型号编号:SR42UBMDEXPND
2. 器件简介: - SR42UBMDEXPND是一款42U SmartRack®机柜,深度为36英寸(927毫米),与标准42英寸不同。这款机柜没有门和侧板,适用于数据中心应用,可以与多个机柜组合使用。兼容热通道/冷通道配置,可承载3000磅(1360.8公斤)的标准19英寸机架设备。
3. 引脚分配: - 前后各有一对垂直安装轨,这些安装轨上的方形安装孔可以以四分之一英寸的增量从4英寸调整到28.75英寸。
4. 参数特性: - 内部深度最大为31英寸,重量等级为3000磅(1360.8公斤)静态和2250磅(1020.6公斤)滚动。 - 包含50个M6笼式螺母和50个M6螺丝作为安装硬件。
5. 功能详解: - 完全组装发货,便于快速部署和滚动到位。 - 前后装备安装轨可以四分之一英寸增量调整,调整快速方便。 - 无工具配件安装轨(每个机柜2轨),包括用于快速安装兼容PDU和垂直电缆管理器的插槽。 - 所有组件都接地到机柜框架,前后提供螺纹接地点以连接到设施接地。
6. 应用信息: - 适用于数据中心应用,支持热通道/冷通道配置,可以与多个机柜组合使用。
7. 封装信息: - 物理尺寸:高度42U,深度中等,最大设备深度31英寸(787毫米),最小设备深度4英寸(102毫米)。 - 运输尺寸和重量:85.00x 26.00x37.80英寸,153.00磅;199.39x60.02x82.00厘米,69.40公斤。 - 单位尺寸和重量:78.500x 23.630x32.350英寸,103磅;199.39x60.02x82.00厘米,46.72公斤。
SR42UBMDEXPND 价格&库存
很抱歉,暂时无法提供与“SR42UBMDEXPND”相匹配的价格&库存,您可以联系我们找货
