1000 Eaton Boulevard
Cleveland, OH 44122
United States
42U SmartRack 4-Post Mid-Depth Open Frame
Rack, Expansion Version - no sides, doors or
roof
Highlights
42U SmartRack Premium open
frame rack (no sides, doors or
roof)
36" (927mm) depth (with
mounting depth increments from
4 to 28.75") and standard 24"
(600mm) width
4 interior vertical posts with
unthreaded square hole
openings
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 3000 lbs (1360.8 kgs) rolling
load capacity
Preinstalled heavy duty 3"
casters and leveling feet
Rolls through standard 7-ft.
(2.13 m) doorway
Includes 50 pieces of M6 cage
nuts and 50 pieces of M6
screws (equipment mounting
hardware)
MODEL NUMBER: SR42BMDEXPNDNR3
Package Includes
Description
The SR42BMDEXPNDNR3 is part of our new line of mid-depth rack enclosures. Our new line offers 36"
(927mm) depth opposed to the standard 42" (1050mm).
The SR42BMDEXPNDNR3 houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. It is
an expansion model that comes without sides, doors or roof. The front and rear pairs of vertical rails have
square mounting holes that are adjustable in quarter-inch increments from 4 to 28.75 inches. Adjustment
is quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming
measurements. Each rack space within the enclosure is numbered for ready reference and supports toolless button-mount 0U installation of up to four compatible PDUs and cable managers.
All components of the SR42BMDEXPNDNR3 are grounded to the enclosure frame. Front and rear
threaded grounding points are provided for connection to the facility earth ground.
To simplify deployment, the SR42BMDEXPNDNR3 comes with preinstalled 3" casters that enable it to be
easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled
levelers. Note: the casters are intended for minor position adjustments and are not designed for moving
the enclosure over long distances.
The SR42BMDEXPNDNR3 comes with a 5-year product warranty. As part of the SmartRack family, the
SR42BMDEXPNDNR3 is compatible with Tripp Lite's extensive range of rackmount accessories, enabling
you to customize your solution to meet any requirement.
Features
Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed 3" casters
(casters are removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Tool-less accessory mounting rails (2 rails per enclosure) include slots for quick installation of
compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard
pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or
cable managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Maximum usable internal depth of 31 inches/787 mm (front to rear rail).
1/3
SR42BMDEXPNDNR3
Mounting Hardware
Owner's Manual
Cleveland, OH 44122
United States
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 3000 lbs (1360.8 kgs) rolling.
Built in baying tabs allow premium open frame racks to be combined securely in rows. Center-to-center
width can be set at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow premium open frame racks to be positioned on uneven floors. Levelers are
removable.
Compact design allows the premium open frame racks to roll through standard height commercial
doorways.
Convenient grounding system. All components are grounded to the premium open frame rack structure
which includes multiple connections for facility ground.
Open top and bottom for cable access.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the premium
open frame rack on the inside or outside of the rack.
Compatibility with all cable management accessories.
Specifications
OVERVIEW
UPC Code
037332175687
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
42U
Rack Depth
Mid
Maximum Device Depth (cm)
78.74
Maximum Device Depth (in.)
31
Maximum Device Depth (mm)
787
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
85.00 x 26.00 x 37.80
Shipping Dimensions (hwd / cm)
215.90 x 66.04 x 96.01
Shipping Weight (lbs.)
130.00
Shipping Weight (kg)
58.97
Unit Dimensions (hwd / in.)
79.500 x 23.630 x 36.000
Unit Dimensions (hwd / cm)
201.93 x 60.02 x 91.44
Unit Weight (lbs.)
94
Unit Weight (kg)
42.64
2/3
Cleveland, OH 44122
United States
Weight Capacity - Rolling (kg)
1,361
Weight Capacity - Rolling (lbs.)
3000
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR42BMDEXPNDNR3”相匹配的价格&库存,您可以联系我们找货
