SR42UW
SR42UW
    TRIPPLITE
    42URACKENCLSERVERCABINET
SR42UW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U SmartRack White Standard-Depth Rack Enclosure Cabinet with doors & side panels MODEL NUMBER: SR42UW Highlights ● Standard 24" (600mm) width and 42" (1050mm) depth for optimizing floor space ● Ships fully assembled ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors ● Locking, removable side panels keyed alike with doors ● Pre-installed casters and leveling feet; Rolls through standard 7-ft. (2.13 m) doorway ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance Package Includes Description The SR42UW features a massive front-to rear-ventilation capacity that meets or exceeds server manufacturer requirements. Its integrated baying tabs make it easy to combine multiple enclosures in rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle configurations. The SR42UW houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. Its front and rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch increments from 4 to 37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready reference. Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment and reduces cord clutter. With its locking, reversible, removable front and rear doors, and locking, removable side panels, the SR42UW provides ultimate equipment safety. The side panels are half size for ease of removal and reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The SR42UW meets all requirements toward PCI DSS compliance. The top panel of the SR42UW is vented to help remove warm air from the enclosure and draw in cool air by convection. The top panel includes ports for cable routing, and can be quickly removed without tools. To facilitate cable access, the SR42UW is open-bottom. All components of the SR42UW are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. The removable front and rear doors feature quick-release ground wires. To simplify deployment, the SR42UW comes with preinstalled casters that enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed for moving the enclosure over long distances. The SR42UW comes with a 5-year product warranty. As part of the SmartRack family, the SR42UW is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to meet any requirement. Features ● White version of our standard 42U rack enclosure offers easier visibility of installed equipment ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters (casters are removable) ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and 1/4 ● SR42UW Rack Enclosure ● (4) side panels ● (4) side panel locks ● (2) door & side panel keys ● (50) M6 screws ● (50) M6 washers ● (50) M6 cage nuts ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 37 inches/94 cm (front to rear rail). ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the front and rear doors. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 600mm or 24" to match standard data center floor tiles. ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Compact design allows the enclosure to roll through standard height commercial doorways. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332175519 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color White Rack Height 42U Rack Depth Standard Factory Preset Rack Depth (in.) 27.75 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Factory Preset Rack Depth (cm) 70.5 Factory Preset Rack Depth (mm) 705 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 78.00 x 43.00 x 24.00 Shipping Dimensions (hwd / cm) 198.12 x 109.22 x 60.96 Shipping Weight (lbs.) 336.00 Shipping Weight (kg) 152.41 Unit Dimensions (hwd / in.) 78.500 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 199.39 x 60.02 x 109.22 Unit Weight (lbs.) 286 Unit Weight (kg) 129.73 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and back door frames Built-in Cable Management Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SR42UW
1. 物料型号: - 型号编号:SR42UW
2. 器件简介: - SR42UW是一个42U的智能机架式机柜,具有出色的前后通风能力,满足或超过服务器制造商的要求。它集成了组合标签,可以轻松组合多个机柜以用于数据中心应用,并且兼容热通道/冷通道配置。
3. 引脚分配: - 前后各有一对垂直安装轨,这些安装轨上的方形安装孔可以以四分之一英寸的增量从4英寸调整到37英寸。
4. 参数特性: - 内部深度最大可达37英寸(94厘米),门上开孔模式的开放空间超过65%,满足服务器制造商的要求。 - 静态承重能力为3000磅(1360.8公斤),滚动承重能力为2250磅(1020.6公斤)。
5. 功能详解: - 带有锁定、可逆、可拆卸的前后门和锁定、可拆卸的侧板,提供设备安全。 - 顶部面板通风良好,有助于从机柜中排出热空气,并通过对流引入冷空气。 - 底部开放,便于电缆访问,顶部面板有大量的电缆通道孔,无需断开电缆即可快速拆卸。
6. 应用信息: - 适用于数据中心,服务器房等需要高承重和良好通风的场合。
7. 封装信息: - 机柜高度为42U,标准深度,颜色为白色。 - 包装包括机柜、4个侧板、4个侧板锁、2个门和侧板钥匙、50个M6螺钉、50个M6垫圈、50个M6笼式螺母以及用户手册。
SR42UW 价格&库存
很抱歉,暂时无法提供与“SR42UW”相匹配的价格&库存,您可以联系我们找货
