SR42UWEXP
SR42UWEXP
    TRIPPLITE
    42URACKENCLSERVERCABINET
SR42UWEXP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U SmartRack White Standard-Depth Rack Enclosure - side panels not included Highlights ● 42U White SmartRack enclosure with doors and NO side panels. 'EXP' version is an expansion model for when several cabinets are bayed together ● 4 interior vertical posts with unthreaded square hole openings ● Standard 24" (600mm) width and 42" (1050mm) depth for optimizing floor space ● Ships fully assembled ● Massive front to rear ventilation capacity ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors ● Rolls through standard 7-ft. (2.13 m) doorway MODEL NUMBER: SR42UWEXP Description The SR42UWEXP is an expansion model used when several cabinets are bayed together. It has doors and a roof but no side panels. Its integrated baying tabs make it easy to combine multiple enclosures in rows for data center application. The SR42UWEXP is also compatible with hot aisle/cold aisle configurations. The SR42UWEXP houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. Offers vendor-neutral square hole/cage nut mounting for guaranteed compatibility with all EIA-310-E compliant 19" equipment. Its front and rear pairs of vertical rails are adjustable in quarter-inch increments from 4 to 37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready reference. Two of these adjustable vertical mounting rails support toolless button-mount 0U installation of up to four compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment and reduces cord clutter. The top panel of the SR42UWEXP is vented to help remove warm air from the enclosure and draw in cool air by convection. The top panel includes ports for cable routing, and can be quickly removed without tools. To facilitate cable access, the SR42UWEXP is open-bottom. All components of the SR42UWEXP are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. The removable front and rear doors feature quick-release ground wires. To simplify deployment, the SR42UWEXP comes with preinstalled casters that enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed for moving the enclosure over long distances. Features ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters (casters are removable) ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws 1/3 Package Includes ● SR42UWEXP ● Keys ● Mounting Hardware ● Owners Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 37 inches (front to rear rail). ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 600mm or 24" to match standard data center floor tiles. ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Compact design allows the enclosure to roll through standard height commercial doorways. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332178985 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color White Rack Height 42U Rack Depth Standard Factory Preset Rack Depth (in.) 27.75 Factory Preset Rack Depth (cm) 70.5 Factory Preset Rack Depth (mm) 705 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 79.00 x 43.00 x 24.50 Shipping Dimensions (hwd / cm) 200.66 x 109.22 x 62.23 Shipping Weight (lbs.) 245.00 Shipping Weight (kg) 111.13 Unit Dimensions (hwd / in.) 78.500 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 199.39 x 60.02 x 109.22 Unit Weight (lbs.) 209 Unit Weight (kg) 94.80 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR42UWEXP
物料型号:SR42UWEXP
器件简介:SR42UWEXP 是一个用于多个机柜并排时的扩展型号,具有门和顶板,但没有侧板。
它集成了用于数据中心应用的多个机柜组合的安装标签,并且与热通道/冷通道配置兼容。
引脚分配:SR42UWEXP 有 42U 的空间,可以容纳 3000 磅(1360.8 公斤)的标准 19 英寸机架设备。
前后各有一对垂直安装轨,可以以四分之一英寸的增量从 4 到 37 英寸进行调整。
参数特性:SR42UWEXP 的前门和后门可以锁定、可逆和可拆卸。
后门设计为分割式,减少了服务入口的间隙要求,允许机柜更靠近墙壁放置。
功能详解:SR42UWEXP 的顶部面板通风良好,有助于从机柜中排出热空气并通过对流引入冷空气。
顶部面板包括用于电缆布线的端口,并且可以快速移除,无需工具。
应用信息:SR42UWEXP 适用于数据中心应用,可以与热通道/冷通道配置兼容,并且可以与气流优化配件和电缆管理配件兼容。
封装信息:SR42UWEXP 为白色标准深度机架外壳,高度为 42U,深度为标准深度,宽度为 24 英寸(600 毫米),深度为 42 英寸(1050 毫米)。
机柜完全组装好,可以快速部署。
以上信息摘自 Tripp Lite 官方网站提供的 PDF 文档。
SR42UWEXP 价格&库存
很抱歉,暂时无法提供与“SR42UWEXP”相匹配的价格&库存,您可以联系我们找货
