SR25UBSP1
SR25UBSP1
    TRIPPLITE
    25URACKENCLSERVERCABINET
SR25UBSP1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 25U SmartRack Standard-Depth Half-Height Rack Enclosure, Doors, Side Panels, Shock Pallet MODEL NUMBER: SR25UBSP1 Highlights ● Standard 25U SmartRack enclosure with additional shock pallet and loading ramps ● 4 interior vertical posts with unthreaded square hole openings ● Standard 24" (600mm) width and 42" (1050mm) depth for optimizing floor space ● Ships fully assembled ● Massive front to rear ventilation capacity ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors ● Locking, removable side panels keyed alike with doors ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) compliance Description 25U SmartRack Enclosure ships mounted on a special pallet that features additional reinforcement and shock-absorbing material. The pallet's protective cushion safeguards the enclosure and the precision components it contains during re-shipping. Reinforced pallets and reusable packaging provide the flexibility to fully configure rack enclosures in a centralized location and safely re-ship them to remote sites, saving significant service costs. They also allow the freedom to custom-configure enclosures with network and server hardware along with UPS systems, PDUs, KVM switches and a variety of other devices prior to final installation. SmartRack enclosures are designed for secure, high density server and networking applications in IT environments. Designed with provisions to integrate cooling, power distribution and cable management, SmartRack enclosures make ideal homes for mission-critical equipment. Vendor-neutral square hole/cage nut mounting for guaranteed compatibility with all EIA-310-D compliant 19" equipment. Enclosures ship fully assembled for rapid deployment and roll into place on heavy-duty casters. Toolless mounting slots allow quick installation of PDUs and vertical cable managers. Adjustable mounting rails include an easyview depth index to eliminate time-consuming measurements. Lightweight modular doors and side panels provide safe, convenient service access. Integrated baying tabs facilitate combining enclosures in rows for standard data center baying applications. SmartRack enclosures hold up to 3000 lbs (1360.8 kgs) and support cooling, cable management, power distribution and monitoring features that keep critical servers and network equipment operating nonstop. Perforated doors permit massive front to rear airflow that exceeds servers manufacturer requirements. Enclosures are fully compatible with hot-aisle / cold-aisle data center configurations. Features ● This special version of Tripp Lite's 25U SmartRack Enclosure ships mounted on a "shock pallet" that features additional reinforcement and shock-absorbing material for safe loading and re-shipping ● Heavy-duty ramps (included) allow enclosure to be rolled on and off the pallet during configuration ● Shipping Capacity: shock-pallet supports up to 1250 lbs (566.9 kgs) (281 lbs (127.5 kgs) SmartRack Enclosure weight + up to 969 lbs (439.5 kgs) of additional equipment), enabling safe loading and reshipping ● Final Installation Capacity: SmartRack Enclosure supports up to 3000 lbs (1360.8 kgs) of equipment stationary and 2250 lbs (1020.6 kgs) rolling. ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters. ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. 1/4 Package Includes ● SR25UBSP1 Rack Enclosure ● (2) Side door panels ● (2) Side door locks ● (2) Door & side panel keys ● (50) M6 screws ● (50) M6 cage nuts ● (50) M6 washers ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosures includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws. ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 37 inches/94 cm (front to rear rail). ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. One side panel per side. Side panels are keyed alike to the front and rear doors. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 600mm or 24" to match standard data center floor tiles. ● Casters are pre-installed and support a rolling load capacity of 2250 lbs (1020.6 kgs), allowing the enclosures to be pre-configured and rolled to the final installation location. Casters are removable. ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Compact shorter design for when a full height enclosure is not needed. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332137395 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Half-Height Enclosure PHYSICAL Color Black Rack Height 25U Rack Depth Standard Factory Preset Rack Depth (in.) 27.75 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Factory Preset Rack Depth (cm) 70.5 Factory Preset Rack Depth (mm) 705 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 56.50 x 43.00 x 25.00 Shipping Dimensions (hwd / cm) 143.51 x 109.22 x 63.50 Shipping Weight (lbs.) 245.00 Shipping Weight (kg) 111.13 Unit Dimensions (hwd / in.) 49.000 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 124.46 x 60.02 x 109.22 Unit Weight (lbs.) 195 Unit Weight (kg) 88.45 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management Yes Extra Wide No Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SR25UBSP1
物料型号:SR25UBSP1
器件简介:25U SmartRack机架式机柜,半高,标准深度,带门和侧板,用于IT环境中安全、高密度的服务器和网络应用。
引脚分配:4个垂直安装轨,带有未螺纹的方形孔。
参数特性: - 颜色:黑色 - 机架高度:25U - 机架深度:标准 - 预设机架深度:27.75英寸(70.5厘米) - 最大设备深度:37英寸(93.98厘米) - 最小设备深度:4英寸(10.16厘米) - 运输尺寸:56.50x43.00x25.00英寸 - 运输重量:245磅(111.13千克) - 单元尺寸:49.00x23.630x43.000英寸 - 单元重量:195磅(88.45千克) - 滚动负载容量:2250磅(1020.6千克) - 静止负载容量:3000磅(1360.8千克) - 垂直安装轨数量:4
功能详解: - 带有额外加固和防震材料的“防震托盘”。
- 重型坡道(包括在内),允许在配置期间将机柜滚上和滚下托盘。
- 运输容量:防震托盘支持高达1250磅(566.9千克)。
- 最终安装容量:SmartRack机柜支持高达3000磅(1360.8千克)的设备静止和2250磅(1020.6千克)滚动。
- 完全组装,快速部署,滚轮重型预装脚轮。
- 前后设备安装轨可调,以1/4英寸增量调整。
- 无工具配件安装轨(每个机柜2轨),包括用于快速安装兼容的PDU和垂直电缆管理器的插槽。
应用信息:适用于需要安全、高密度服务器和网络应用的IT环境。
封装信息:半高机架式机柜,标准深度,带有门和侧板。
兼容性:与气流优化配件和电缆管理配件兼容。
认证和合规性:产品认证为UL60950-1,符合RoHS和CE(欧洲)标准。
保修与支持:提供5年有限保修期。
SR25UBSP1 价格&库存
很抱歉,暂时无法提供与“SR25UBSP1”相匹配的价格&库存,您可以联系我们找货
