SR42UBG
SR42UBG
    TRIPPLITE
    42U RACK ENCLOSURE SERVER CABINE
SR42UBG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartRack 42U Standard-Depth Rack Enclosure Cabinet with Clear Acrylic Window MODEL NUMBER: SR42UBG Highlights ● Maximum stationary load capacity of 3000 lbs (1360.8 kgs) ● Front door includes shatterresistant clear acrylic window ● Locking steel cabinet vented at rear and top ● Secures 42U of 19 in. rack equipment up to 37 in. deep ● Ships assembled for quick and easy deployment Package Includes Cabinet secures and organizes 42U of 19-inch rack equipment in network closets, server rooms, data centers and other locations. Clear acrylic window allows you to monitor equipment without unlocking door. Description The SR42UBG SmartRack 42U Standard-Depth Rack Enclosure Cabinet is ideal for storing EIA-standard 19-inch rack equipment in network closets, server rooms, data centers and other areas with limited floor space where you need equipment to be secure and organized. Constructed from heavy-duty steel with a durable black powder-coated finish, the cabinet has a maximum stationary load capacity of 3000 lbs (1360.8 kgs). The front door features a full-length shatter-resistant clear acrylic window that lets you monitor equipment without unlocking the enclosure. Not only does the window help prevent equipment tampering and reduce acoustic noise, but it also adds visual flair to your IT installation. To ensure your valuable equipment stays secure, the removable side panels, split rear door and reversible front door lock. The rear door and removable top panel are vented, which allows air to flow freely through the cabinet to keep equipment cool. Convenient top ports and an open bottom allow easy cable routing through the cabinet. The SR42UBG comes partially assembled and ready to deploy with preinstalled casters that let you easily maneuver it into position, where it can be secured by adjusting the removable levelers. Square mounting holes and numbered rack spaces make equipment installation easy. The vertical mounting rails adjust in 1/4-inch increments to accommodate equipment up to 37 inches deep, such as servers and networking switches. Features Secures and Organizes Important Equipment ● Perfect for network closets, server rooms, data centers and other areas with limited floor space where you need equipment to be secure and organized ● Houses EIA-standard 19 in. rack equipment in 42U of space ● Maximum stationary load capacity of 3000 lbs (1360.8 kgs). ● Maximum rolling load capacity of 2250 lbs (1020.6 kgs). ● Doors and side panels lock securely ● Vented rear and top panels allow generous airflow that keeps equipment cool Shatter-Resistant Clear Acrylic Front Window 1/4 ● SR42UBG SmartRack 42U Standard-Depth Rack Enclosure Cabinet ● (50) M6 screws ● (50) M6 cage nuts ● (50) M6 washers ● (2) Keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Lets you monitor equipment without unlocking the enclosure ● Prevents equipment tampering ● Reduces acoustic noise ● Provides extra visual flair Convenient Access to Components and Cabling ● Integrated cable management system helps to eliminate unnecessary airflow obstruction and keep the cabinet more organized ● Removable, split side panels provide easy access for inspection and maintenance ● Split rear door reduces clearance requirements for service access, allowing the enclosure to be placed closer to a wall ● Top ports and open bottom allow cable routing through the cabinet ● Top panel removes toollessly to provide access without disconnecting cables Ships Partially Assembled for Quick Deployment ● Preinstalled casters enable the enclosure to be easily maneuvered to desired location ● Removable levelers adjust to stabilize the rack on uneven surfaces Easy Equipment Installation ● Vertical mounting rails adjust in 1/4 in. increments to house equipment up to 37 in. deep ● Rails adjust easily—unscrew them, slide them to desired depth, and screw them back in ● Rails support square-hole mounting ● Rack spaces numbered for easy reference ● 0U mounting slots for quick installation of compatible PDUs and vertical cable managers Meets Payment Card Industry Standards ● Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data Security Standard) compliance Specifications OVERVIEW UPC Code 037332148711 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color Black Rack Height 42U Rack Depth Standard Factory Preset Rack Depth (in.) 27.75 Factory Preset Rack Depth (cm) 70.5 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Factory Preset Rack Depth (mm) 705 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 85.00 x 26.00 x 45.50 Shipping Dimensions (hwd / cm) 215.90 x 66.04 x 115.57 Shipping Weight (lbs.) 336.00 Shipping Weight (kg) 152.41 Unit Dimensions (hwd / in.) 78.500 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 199,39 x 60,02 x 109,22 Unit Weight (lbs.) 286 Unit Weight (kg) 129.73 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SR42UBG 价格&库存
很抱歉,暂时无法提供与“SR42UBG”相匹配的价格&库存,您可以联系我们找货
