SR42UBDPWD
SR42UBDPWD
    TRIPPLITE
    42U RACK ENCLOSURE SERVER CAB
SR42UBDPWD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U SmartRack Deep and Wide Rack Enclosure Cabinet with doors & side panels MODEL NUMBER: SR42UBDPWD Highlights ● 45" (1143mm) depth for extra space need for mounting deep equipment ● 30" (750mm) width for optimizing airflow through cabinet ● Ships fully assembled ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors; Locking, removable side panels keyed alike with doors ● Pre-installed casters and leveling feet; Rolls through standard 7-ft. (2.13 m) doorway ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance Package Includes Features ● ● ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters. Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 42 inches/1070mm (front to rear rail). ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the front and rear doors. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 750mm or 30". ● Casters are pre-installed and support a rolling load capacity of 2250 lbs (1020.6 kgs), allowing the enclosures to be pre-configured and rolled to the final installation location. Casters are removable. ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Compact design allows the enclosure to roll through standard height commercial doorways. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. 1/3 ● SR42UBDPWD Rack Enclosure ● (4) Side panels ● (4) Side panel locks ● (2) Door & side panel keys ● (50) M6 screws ● (50) M6 cage nuts ● (50) M6 washers ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332154484 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color Black Rack Height 42U Rack Depth Deep Factory Preset Rack Depth (in.) 28.125 Factory Preset Rack Depth (cm) 71.4 Factory Preset Rack Depth (mm) 714 Maximum Device Depth (cm) 106.68 Maximum Device Depth (in.) 42 Maximum Device Depth (mm) 1,067 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 85.00 x 33.25 x 49.75 Shipping Dimensions (hwd / cm) 215.90 x 84.46 x 126.36 Shipping Weight (lbs.) 404.00 Shipping Weight (kg) 183.25 Unit Dimensions (hwd / in.) 78.500 x 29.630 x 48.500 Unit Dimensions (hwd / cm) 199.39 x 75.2602 x 123.19 Unit Weight (lbs.) 345 Unit Weight (kg) 156.49 Weight Capacity - Rolling (kg) 1,021 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management Yes Extra Wide Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR42UBDPWD 价格&库存
很抱歉,暂时无法提供与“SR42UBDPWD”相匹配的价格&库存,您可以联系我们找货
SR42UBDPWD
