SR45UBWDVRT
SR45UBWDVRT
    TRIPPLITE
    45U RACK ENCL SERVER CABINET
SR45UBWDVRT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 45U SmartRack Wide Standard-Depth Rack Enclosure Cabinet with Doors and Side Panels, 2 Pre-Installed Cable Managers MODEL NUMBER: SR45UBWDVRT Description SR45UBWDVRT is a WIDE version of our standard 45U SmartRack Enclosure (750mm wide compared to the standard 600mm wide) and includes two SRCABLEVRT3 6-ft. (1.83 m) vertical cable managers. The two pre-installed SRCABLEVRT3 helps eliminate cable stress by organizing the cables within the enclosure. The vertical cable managers are 6-ft. (1.83 m) high and 3" wide. The SR45UBWDVRT houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. Its front and rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch increments from 4 to 37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready reference. With its locking, reversible, removable front and rear doors and locking, removable side panels, the SR45UBWDVRT provides ultimate equipment safety. The side panels are half size for ease of removal and re-installation. The split rear door design allows the enclosure to be placed closer to a wall. The SR45UBWDVRT meets all requirements toward PCI DSS compliance. The top panel of the SR45UBWDVRT is vented to help remove warm air from the enclosure and draw in cool air by convection. the top panel includes ports for cable routing, and can be quickly removed without tools. All components of the SR45UBWDVRT are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. The removable front and rear doors feature quick-release ground wires. To simplify deployment, the SR45UBWDVRT comes with preinstalled casters that enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed for moving enclosures over long distances. The SR45UBWDVRT comes with a 5-year product warranty. As part of the SmartRack family it is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to meet any requirements. Features ● Comes with the two pre-installed SRCABLEVRT3 (6-ft. (1.83 m) vertical cable manager with 3" width) to help eliminate cable stress inside the enclosure ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. 1/4 Highlights ● 45U SmartRack enclosure with doors and side panels ● 30" (750mm) width and 42" (1050mm) depth ● Two pre-installed 6-ft. (1.83 m) vertical cable manager - high capacity for large cable bundles ● 4 interior vertical posts with unthreaded square hole openings ● Massive front to rear ventilation capacity ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors ● Locking, removable side panels keyed alike with doors ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance Package Includes ● SR45UBWDVRT Rack Enclosure ● (4) side panels ● (4) side panel locks ● (2) door & side panel keys ● (50) M6 screws ● (50) M6 washers ● (50) M6 cage nuts ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws. ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 37 inches/940 mm (front to rear rail). ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the front and rear doors. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 750mm or 30" to match standard data center floor tiles. ● SmartRack Enclosure supports up to 3000 lbs (1360.8 kgs) of equipment stationary and 2250 lbs (1020.6 kgs) rolling. ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters (casters are removable) ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332175274 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color Black Rack Height 45U Rack Depth Standard Cable Jacket Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Factory Preset Rack Depth (in.) 21.75 Factory Preset Rack Depth (cm) 55.2 Factory Preset Rack Depth (mm) 552 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 90.25 x 32.00 x 45.00 Shipping Dimensions (hwd / cm) 229.24 x 81.28 x 114.30 Shipping Weight (lbs.) 390.00 Shipping Weight (kg) 176.90 Unit Dimensions (hwd / in.) 83.750 x 29.530 x 43.000 Unit Dimensions (hwd / cm) 212.72 x 75.1 x 109.22 Unit Weight (lbs.) 340 Unit Weight (kg) 154.22 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and rear door frames Built-in Cable Management Yes Extra Wide Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SR45UBWDVRT
物料型号:SR45UBWDVRT
器件简介:SR45UBWDVRT是45U智能机架宽标准深度机柜,宽度为750毫米,比标准宽度600毫米要宽,并包含两个预先安装的SRCABLEVRT3六英尺(1.8米)垂直电缆管理器。
该机柜可以容纳3000磅(1360.8千克)的标准19英寸机架设备。
引脚分配:前后垂直轨配有方形安装孔,可从4英寸到37英寸以四分之一英寸的增量进行调整。
参数特性:包含两个预先安装的SRCABLEVRT3垂直电缆管理器,具有30英寸(750毫米)宽度和42英寸(1050毫米)深度,以及4个内部垂直柱,带有未螺纹的方形孔开口。
功能详解:SR45UBDVRT具有锁定、可逆、可拆卸的前后门和锁定、可拆卸的侧板,提供设备安全性。
顶部面板通风良好,有助于通过对流从机柜中移除热空气并吸入冷空气。
应用信息:该机柜适用于数据中心,需要容纳大型电缆束和19英寸机架设备的环境。
封装信息:机柜的物理尺寸为高90.25英寸、宽32英寸、深45英寸,运输重量为390磅(176.9千克)。
设备兼容性包括配线架、网络交换机、不间断电源(UPS)和服务器。
机柜类型为Enclosure,颜色为黑色,机架高度为45U,机架深度为标准深度。
SR45UBWDVRT 价格&库存
很抱歉,暂时无法提供与“SR45UBWDVRT”相匹配的价格&库存,您可以联系我们找货
