SR48UBDPWD
SR48UBDPWD
    TRIPPLITE
    48U RACK ENCL SERVER CABINET 48"
SR48UBDPWD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 48U SmartRack Deep and Wide Rack Enclosure Cabinet with doors & side panels MODEL NUMBER: SR48UBDPWD Highlights ● 45" (1143mm) depth for extra space need for mounting deep equipment ● 30" (750mm) width for optimizing airflow through cabinet ● Ships fully assembled ● 3000 lbs (1360.8 kgs) stationary / 2250 lbs (1020.6 kgs) rolling load capacity ● Locking, removable, reversible front and rear doors; Locking, removable side panels keyed alike with doors ● Pre-installed casters and leveling feet ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance Package Includes Description The SR48UBDPWD is a DEEP and WIDE version of our standard 48U SmartRack. This enclosure is 1143mm deep (45") compared to the standard 1050mm deep (42"). This extra depth allows for high density equipment installations. It allows extra space for moving the cable management back as well as providing space for mounted equipment that has hot-swap, removable power supplies out the back of the enclosure. It is also 750mm wide (30") compared to the standard 600mm wide (24"). This extra width allows for high density equipment installations. It allows cable management and PDU mounting off to the sides of the rack in order to keep these items out of the airflow for proper cooling. The SR48UBDPWD features a massive front-to rear-ventilation capacity that meets or exceeds server manufacturer requirements. Its integrated baying tabs make it easy to combine multiple enclosures in rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle configurations. With its locking, reversible, removable front and rear doors, and locking, removable side panels, the SR48UBDPWD provides ultimate equipment safety. The side panels are half size for ease of removal and reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The SR48UBDPWD meets all requirements toward PCI DSS compliance. The top panel of the SR48UBDPWD is vented to help remove warm air from the enclosure and draw in cool air by convection. The top panel includes ports for cable routing, and can be quickly removed without tools. To facilitate cable access, the SR48UBDPWD is open-bottom. All components of the SR48UBDPWD are grounded to the enclosure frame. Front and rear threaded grounding points are provided for connection to the facility earth ground. The removable front and rear doors feature quick-release ground wires. It houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 48U. To simplify deployment, the SR48UBDPWD comes with preinstalled casters that enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed for moving the enclosure over long distances. The SR48UBDPWD comes with a 5-year product warranty. As part of the SmartRack family, the SR48UBDPWD is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to meet any requirement. Features ● Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters (casters are removable) ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and 1/4 ● SR48UBDPWD Rack Enclosure ● (4) Side panels ● (4) Side panel locks ● (2) Door & side panel keys ● (50) M6 screws ● (50) M6 cage nuts ● (50) M6 washers ● (1) Allen Wrench ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 42 inches/1050mm (front to rear rail). ● Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling. ● Front door is locking, reversible and removable. ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the front and rear doors. ● Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set at 750mm or 30". ● Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Included stabilizing brackets are used for shipment and can be reattached at the bottom of the enclosure frame on the inside or outside of the rack. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332156808 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color Black Rack Height 48U Rack Depth Deep Factory Preset Rack Depth (in.) 28.125 Factory Preset Rack Depth (cm) 71.4 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Factory Preset Rack Depth (mm) 714 Maximum Device Depth (cm) 106.68 Maximum Device Depth (in.) 42 Maximum Device Depth (mm) 1,067 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 95.00 x 33.50 x 52.75 Shipping Dimensions (hwd / cm) 241.30 x 85.09 x 133.98 Shipping Weight (lbs.) 430.00 Shipping Weight (kg) 195.04 Unit Dimensions (hwd / in.) 89.000 x 29.530 x 48.500 Unit Dimensions (hwd / cm) 226.06 x 75.1 x 123.19 Unit Weight (lbs.) 378 Unit Weight (kg) 171.46 Weight Capacity - Rolling (kg) 1,021 Weight Capacity - Rolling (lbs.) 2250 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management No Extra Wide Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SR48UBDPWD
物料型号:SR48UBDPWD
器件简介: - 这是一个比标准48U SmartRack®机柜更深更宽的版本。 - 深度为1143毫米(45英寸),比标准深度1050毫米深,允许高密度设备安装。 - 宽度为750毫米(30英寸),比标准600毫米宽,允许在机架侧面进行电缆管理和PDU安装,以保持适当的冷却气流。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 前后通风能力巨大,满足或超过服务器制造商的要求。 - 集成的拼装标签使得多个机柜易于组合用于数据中心应用。 - 兼容热通道/冷通道配置。 - 配有锁定、可逆、可拆卸的前后门和锁定、可拆卸的侧板。 - 顶部面板通风,帮助从机柜中排出热空气并通过对流引入冷空气。 - 底部开放,便于电缆访问。 - 所有组件都接地到机柜框架,并提供前后螺纹接地点以连接到设施接地点。
功能详解: - 完全组装发货,便于快速部署和滚动到位。 - 前后设备安装导轨可调节,调整方便快捷。 - 无工具附件安装导轨(每个机柜2条)包括用于快速安装兼容附件的插槽。 - 包含50个M6笼式螺母和50个M6螺丝的安装硬件。 - 纹理粉末涂层,具有强大的抗环境问题能力。
应用信息: - 适用于机架式设备,如配线架、网络交换机、UPS、服务器。 - 机柜类型为外壳,适用于48U机架高度。
封装信息: - 颜色:黑色。 - 机架深度:深。 - 运输尺寸:95.00x33.50x52.75英寸。 - 单位尺寸:89.000x29.530x48.500英寸。 - 单位重量:378磅(171.46千克)。 - 滚动重量容量:2250磅(1020.6千克)。 - 静态重量容量:3000磅(1360.8千克)。 - 垂直安装导轨数量:4。
兼容性和认证: - 产品认证:UL60950-1。 - 产品合规性:RoHS; CE(欧洲); UKCA。 - 保修和支持:提供5年有限保修。
SR48UBDPWD 价格&库存
很抱歉,暂时无法提供与“SR48UBDPWD”相匹配的价格&库存,您可以联系我们找货
