SR42UBZ4
SR42UBZ4
    TRIPPLITE
    42U RACK ENCL SERVER CABINET
SR42UBZ4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 42U SmartRack Seismic-Certified StandardDepth Rack Enclosure Cabinet with doors & side panels MODEL NUMBER: SR42UBZ4 Highlights ● Tested to NEBS Seismic Zone 4 requirements ● 42U SmartRack enclosure with doors and side panels ● 4 interior vertical posts with unthreaded square hole mounting ● Standard 24" width for optimizing floor space ● Ships fully assembled ● Massive front to rear ventilation capacity ● Locking, removable side panels keyed alike with doors ● Includes 50 pieces of M6 cage nuts and 50 pieces of M6 screws (equipment mounting hardware) ● Baying brackets and hardware included ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance Description SR42UBZ has been designed and tested to meet Telcordia GR-63-CORE Network Equipment & Building Systems (NEBS) requirements for Zone 4 Seismic Earthquake Environments. It is designed for secure, high density server and networking applications in IT environments that are earthquake prone or subject to regular vibration, such as an airport or factory. Designed with provisions to integrate cooling, power distribution and cable management, SmartRack enclosures make ideal homes for mission-critical equipment. Vendor-neutral square hole/cage nut mounting for guaranteed compatibility with all EIA-310-E compliant 19" equipment. Enclosures ship fully assembled for rapid deployment. Toolless mounting slots allow quick installation of PDUs and vertical cable managers. Adjustable mounting rails include and easyview depth index to eliminate time-consuming measurements. Lightweight modular doors and side panels provide safe, convenient service access. SmartRack enclosures support cooling, cable management, power distribution and monitoring features that keep critical servers and network equipment operating nonstop. Perforated doors permit massie front to rear airflow that exceeds servers manufacturer requirements. Enclosures are fully compatible with hot-aisle / cold-aisle data center configurations. Package Includes ● SR42UBZ4 Rack Enclosure ● (4) Side panels ● (4) Side panel locks ● (50) M6 screws ● (50) M6 cage nuts ● (50) M6 washers ● (2) Door & side panel keys ● (2) Baying brackets ● (4) M8 Screws Ships fully assembled for rapid deployment ● (4) M8 Washers ● Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements. ● Owner's Manual ● Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable managers side-by-side (four items per enclosure). ● Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws. ● Includes 2 baying brackets and necessary hardware to install ● Textured powder coat finish for tough resistance to environmental concerns such as deployment in warehouses. ● Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or exceeds server manufacturer requirements. ● Maximum usable internal depth of 37 inches/94 cm (front to rear rail). ● Front door is locking, reversible and removable. Features ● 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Rear doors are locking and reversible. Split rear door design reduces clearance requirements for service entry allowing the enclosure to be placed closer to a wall. ● Locking removable side panels are 'half size' to make them smaller and lighter improving ease of installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the front and rear doors. ● Convenient grounding system. All components are grounded to the enclosure frame which includes multiple connections for facility ground. Front and rear doors include quick-release ground wires. ● Open bottom for cable access. ● Top panel has generous cable access holes. Panel can be removed toollessly in seconds without having to disconnect cables first. ● Designed and tested to meet Telcordia GR-63-CORE Network Equipment & Building Systems (NEBS) requirements for Zone 4 Seismic Earthquake Environments. ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) Compliance ● Compatibility with airflow optimization accessories as well as cable management accessories. Specifications OVERVIEW UPC Code 037332160331 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Enclosure PHYSICAL Color Black Rack Height 42U Rack Depth Standard Factory Preset Rack Depth (in.) 27.75 Factory Preset Rack Depth (cm) 70.5 Factory Preset Rack Depth (mm) 705 Maximum Device Depth (cm) 93.98 Maximum Device Depth (in.) 37 Maximum Device Depth (mm) 940 Minimum Device Depth (cm) 10.16 Minimum Device Depth (in.) 4 Minimum Device Depth (mm) 102 Shipping Dimensions (hwd / in.) 78.00 x 25.50 x 44.00 Shipping Dimensions (hwd / cm) 198.12 x 64.77 x 111.76 Shipping Weight (lbs.) 395.00 Shipping Weight (kg) 179.17 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 78.500 x 23.630 x 43.000 Unit Dimensions (hwd / cm) 199,39 x 60,02 x 109,22 Unit Weight (lbs.) 353.00 Unit Weight (kg) 160.12 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management Yes Extra Wide No Pre-Installed Casters No STANDARDS & COMPLIANCE Product Certifications Seismic Zone 4 (NEBS GR-63-CORE) Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR42UBZ4 价格&库存
很抱歉,暂时无法提供与“SR42UBZ4”相匹配的价格&库存,您可以联系我们找货
SR42UBZ4
