FAN80AC230
FAN80AC230
    HAMMONDMANUFACTURING
    FAN AC AXIAL 80MM 32CFM 230V
FAN80AC230 数据手册
Ventilated Panels LOUVERED PANELS • Standard, 19” rack mount • Formed 16 gauge steel construction • Includes a 0.50” fold, top and bottom for added strength • Designed with 3 columns of 4” wide louvers • Smooth powder paint finish to match our standard panels • Louvers face out • Requires mounting hardware Pa r t Nu mb e r Bl ac k Smoot h Bei ge Smoot h PVLL19005BK2 PVLL19005CG2 PVLL19007BK2 PVLL19007CG2 PVLL19008BK2 PVLL19008CG2 PVLL19010BK2 PVLL19010CG2 PVLL19012BK2 PVLL19012CG2 Pa n e l He i g h t Inches Units 5.25 3 7.00 4 8.75 5 10.50 6 12.25 7 Ro ws of Louvers 3 4 6 8 10 SLOTTED STEEL PANELS • Standard, 19” rack mount • 14 gauge steel construction • Slots are 0.25” x 1.0” • Smooth powder paint finish to match our standard panels • Requires mounting hardware Pa r t Nu mb e r Bl ac k Smoot h PVSS19001BK2 PVSS19003BK2 Pa n e l He i g h t Bei ge Smoot h PVSS19001CG2 PVSS19003CG2 Inches 1.75 3.50 Units 1 2 Ro ws of Slots 1 2 Open Space (Cubic In.) 9.7 19.4 SLOTTED ALUMINUM PANELS • Standard, 19” rack mount • 0.13” thick aluminum construction • Slots are 0.25” x 1.0” • Smooth powder paint finish to match our standard panels • Requires mounting hardware Pa r t Nu mb e r Pa n e l He i g h t Bl ac k Smoot h Bei ge Smoot h Inches Units Ro ws of Slots PVSA19001BK2 PVSA19003BK2 PVSA19001CG2 PVSA19003CG2 1.75 3.50 1 2 1 2 Open Space (Cubic In.) 9.7 19.4 PERFORATED ALUMINUM PANELS • Standard, 19” rack mount • Folded (for extra strength) - 0.13” thick aluminum construction • Smooth powder paint finish to match our standard panels • Requires mounting hardware Pa r t Nu mb e r Bl ac k Smoot h Bei ge Smoot h PPFS19001BK2 PPFS19001CG2 PPFS19003BK2 PPFS19003CG2 PPFS19005BK2 PPFS19005CG2 PPFS19007BK2 PPFS19007CG2 PPFS19008BK2 PPFS19008CG2 PPFS19010BK2 PPFS19010CG2 84 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Pa n e l He i g h t Inches Units 1.75 1 3.50 2 5.25 3 7.00 4 8.75 5 10.50 6 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Ventilated Panels BAFFLE PANEL • Standard, 19” rack mount • Rear sloping baffle for directing air flow • 16 gauge steel construction • Shown here, upside down to show construction • Extends apx. 14” behind panel rails • Smooth black powder paint finish to match our standard panels • Requires mounting hardware Par t Number PVBB19001BK2 Panel Height I nches Units 1.75 1 FAN PANELS • Standard, 19” rack mount • Create your own 19" rack mount fan or filter fan panels • Accepts standard square fans (see our cooling accessory section or use your own) • For a filter fan panel use our filter fan grills (see our cooling accessory section) • Perfect as an intake fan panel (when using "push-pull" cooling use the fan grill panel below for exhaust) • Rugged textured black powder paint • Requires mounting hardware • Control your rack temperature with our economical, compact thermostat (see our cooling accessory section) Par t Number PPFP190802BK1 PPFP190803BK1 PPFP191202BK1 Number of Fan Holes 2 3 2 Accepts Fan Size 3.15" 3.15" 4.7" Panel Height I nches Units 5.25 3 5.25 3 7.00 4 FAN GRILL PANELS • Standard, 19” rack mount • Create your own 19" rack mount fan panels • Accepts standard square fans 4.7" (120 mm) see our cooling accessory section or use your own) • Perfect for an exhaust fan panel (when using "push-pull" cooling use the fan panel above with filter grills for intake) • Rugged textured black powder paint • Requires mounting hardware • Control your rack temperature with our economical, compact thermostat (see our cooling accessory section) © Par t Number Number of Fan Holes Accepts Fan Size PPGP191202BK1 2 4.7" Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Panel Height I nches Units 5.25 3 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 85 Cooling - General Selection Specifications All Hammond blowers and filter fans are engineered for performance and built for reliability. This versatile line includes blowers, fan trays and filter fans. Blowers and fans use forced convection cooling, which means ambient air flows through a filter into the enclosure to cool heated components. Both blowers and fans are sized in CFM (cubic feet per minute). It is recommended that an exhaust filter be used in combination with the blower or filter fan to act both as an exhaust point for the hot internal air plus aid in the pressurization of the enclosure, reducing the chance of unfiltered air entering the enclosure. Whenever possible, the blower or filter fan should be located in the bottom third of the enclosure and the filtered exhaust grill placed as high as possible on the opposing side. Performance levels can be further increased by adding a second exhaust filter. Sizing Blowers and Fans To determine the CFM (cubic feet per minute) required in any standard situation, use the following calculation, (nonstandard situations would consist of high air density – significantly more than 0.075 lbs. per cubic foot.) Power to be dissipated (Watts) x 3.17 C.F.M. = Maximum Allowable Internal Temperature (°F) – Maximum Ambient Temperature(°F) Note: The calculation above is exact, but adding an additional 25% to the CFM level is a standard safety factor. If the air density is high (significantly more than 0.075 lbs. per cubic foot), use the number calculated above in the following formula: CFM x (0.075) Non-standard air Air Density (lbs per cubic foot) Note: Ambient Temperature must be lower than maximum internal temperature for fan/blower to be effective. THERMOSTAT • Designed to provide air temperature control and monitoring in cabinets • Thermostat NO (Normally Open) for control of cooling equipment, or for switching signal transmitters in case of overheating • Thermostatic bi-metal sensor element • Available in Fahrenheit (Part Number SKT011419NO) or in Celsius (Part Number SKT011419NO-C) • Compact 2.4” High x 1.3” Wide x 1.4” Deep, gray ABS flame retardant plastic (UL94VO) • 2 pole terminal for AWG 14 wire • Switching capacity of 15A (120VAC) or 10A (250VAC) • Temperature range from 30-140 degrees F • cUR & UR & CE listed FAN & BLOWER FILTER COAT • Provides a filter adhesive with a grease like consistency which absorbs and traps dust particles • 10 oz. bottle with environmentally friendly trigger spray • Part Number 1475Q © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 97 Cooling FANS (TUBEAXIAL) • Choice of 4.70" (120mm) or 3.15" (80mm) • 1.50" deep • Choice of either 115 or 230 VAC, 50/60 Hz. • Impedance protected motor • Class-B insulated • Ball bearing construction, metal blades • Diecast aluminum body • Rotation is counter clockwise (looking at the rotor - as pictured) • Airflow is over the struts (out the back as pictured) • 4.70" (120 mm) fans have male plug terminations (requires fan cords below) • 3.15" (80 mm) fans have 11" long lead wires • UL recognized, CSA listed, CE certified • With mounting hardware 115 VAC Fans Par t Number FAN80AC115 DNMF100AC115 Size I nches mm 3.15 4.70 80 120 CFM 32 100 Use With Fan Guard Par t Number FAN80FG DNFG Use with Filter Grill Par t Number XPFA80... XPFA120... 230 VAC Fans Par t Number FAN80AC230 DNMF100AC230 Size I nches mm 3.15 4.70 80 120 CFM 32 100 Use With Fan Guard Par t Number FAN80FG DNFG Use with Filter Grill Par t Number XPFA80... XPFA120... FAN CORDS • For 115 VAC wiring • Save time with these stock fan cords • Molded female fan plug (0.91" x 0.68") 98 © Par t Number Description DNMFC DNFC48P DNFC72P DNFCDC2P DNFCDC3P Single Fan Cord Single Fan Cord Single Fan Cord Daisy Chain Daisy Chain Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Lead Length 24" 48" 72" 24" 24" Fan Connector Straight 45 degree 45 degree Qty. 2- 45 degree, 24" apart Qty 3 - 45 degree, 24" apart ww w.h am mo ndm fg.c om 115VAC Plug No Yes Yes Yes Yes Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Cooling FILTER FAN GRILLS • Create your own filter fans or exhaust grills • Mounts easily with 4 screws using template and hardware provided • Complete with flame retardant ABS plastic grill and flame retardant synthetic filter • Integral gasket on rear of grill (see photo below), seals against mounting surface • Can be used with standard 3.15" (80 mm) or 4.7" (120 mm) square fans (available opposite page or use your own) or alone as an exhaust grill • Molded in a choice of 3 colors to match our racks & accessories Two Sizes Assembled (fan not included) Open View Par t Number Grill Size Black Beige Grey H W XPFA80BK XPFA120BK XPFA80CG XPFA120CG XPFA80GY XPFA120GY 4.13" 5.91" 4.13" 5.91" Use with Square Fan Size 3.15" 4.70" Rear View REPLACEMENT FILTERS • Flame retardant synthetic filter (as supplied with above) • Five per pack Par t Number Use with Square Fan Size PFF1000 PFF2000 3.15" (XPFA80 series) 4.7" (XPFA120 series) FAN FINGER GUARDS • Mounts to either the 3.15” (80 mm) or 4.7” (120 mm) fans • Steel construction • Chrome plated finish • Includes mounting hardware © Pa r t Nu mb e r Descr iption FA N 8 0 F G DNFG W i r e m e s h , n i cke l p l a t e d W i r e m e s h , n i cke l p l a t e d Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Use with Fa n S i z e 3.15" 4.70" ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 99 Cooling FAN TRAYS • Standard 19" rack mount • Compact and economical rack cooling solution • Fan trays can be positioned at the bottom of a rack to force air through the cabinet, at the top to exhaust air out or below specific pieces of equipment for spot cooling • 115VAC 50/60 Hz., thermally protected, ball bearing fans UR/cUR listed • Circuit breaker protected • Low profile 1.75" (1U) of panel space • 6' 14/3 STJW cord with molded 3 prong plug included • Integral finger guards above and below fans • Case width is 17" • 6 and 9 fan units include an adjustable rear mounting bracket (mounts to rear panel rails) for extra stability • Shipped fully assembled • Available with or without on/off switch • Finished in smooth black powder paint • Control your rack temperature with our economical, compact thermostat FT900HA1BK FT600HA1BK Pa r t Nu mb e r Wi t hout Swi t ch F T 3 0 0 TA 1 B K F T 6 0 0 TA 1 B K F T 9 0 0 TA 1 B K 100 © Wi t h Li ght ed Switch FT300HA1BK FT600HA1BK FT900HA1BK CFM Running Amps 300 600 900 0.5 1.0 1.5 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 FT300HA1BK Wa t t s Pa n e l Wi dt h Case Wi dt h Case Depth 40 80 120 19 19 19 17 17 17 7.5 13 18.5 ww w.h am mo ndm fg.c om Rear Br acket Depth Mi n. Max. n/a 2.40 7.90 n/a 19.20 24.70 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Cooling PACKAGED TWIN BLOWERS • Standard 19" rack mount • All blowers contain a quadruplex centrifugal blower powered by a single precision ball-bearing motor • These widely used packaged twin blowers deliver air from more than 50% of their 17” width • 115VAC 50/60 Hz., UR/CSA listed ball bearing motor • Internal neoprene isolation mounts reduce transmission of vibration to the enclosure • Heavy duty steel enclosure • Includes permanent filter & attractive stainless steel grill • Inlet air (front of unit) cools motor for long life • Exhaust guards included • Six foot (minimum) SJTW 3-wire cord Static Pressure KP350A KP350A Air Flow C.F.M. Static Pressure KP529A H J Air Flow C.F.M. L KP729A Static Pressure F KP350A & KP729A M N G Air Flow C.F.M. Pa r t Number KP350A KP529A KP729A © Fr e e F l o w A m b i e n t Te m p . P a n e l H e i g h t RPM Air Deliver y Nomi nal Mi n. °F Max. °F E Units ( CFM) 150 1500 -20 250 3.50 2 300 3000 -20 250 5.25 3 470 3250 -20 250 7.00 4 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Di mensi ons ( I nches) F G H J L M N 8.75 6.25 8.25 10.50 7.69 10.25 4.50 4.63 7.50 4.50 4.75 2.25 1.88 2.50 2.25 3.00 4.00 1.19 1.44 ww w.h am mo ndm fg.c om 101 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
FAN80AC230 价格&库存
很抱歉,暂时无法提供与“FAN80AC230”相匹配的价格&库存,您可以联系我们找货
FAN80AC230
  • 1+551.072331+71.42947
  • 10+440.4059610+57.08500
  • 25+400.4384325+51.90445
  • 50+372.7037450+48.30950
库存:1
