FAN150AC230
FAN150AC230
    HAMMONDMANUFACTURING
    插件
    FAN AC AXIAL 150MM 210CFM 230V
FAN150AC230 数据手册
www.hammfg.com Fan Kits Filter Fan Grills Accessories Mounts easily with 4 screws using the template provided. All mounting hardware included. Standard 80mm/3.15" and 120mm/ 4.00" fans can be attached with hardware provided to make a filter fan. Can be used alone as an enclosure exhaust. Moulded in flame retardant ABS. Flame retardant synthetic filter supplied. Integral gasket on reverse of grill seals against enclosure surface. Available in black, RAL7032 beige and ASA61/RAL7011 gray to match enclosures. Black Part No. Filterfs/Fans Climate Control Products XPFA80BK XPFA120BK Beige Part No. Gray Part No. H W XPFA80CG XPFA120CG XPFA80GY XPFA120GY 4.13 5.91 4.13 5.91 Part No. Optional Compatible Fan Size CFM FAN80AC115 80mm/3.15" DNMF100AC115 120mm/4.70" 32 102 Repl. Filter (pkg. 5) PFF1000 PFF2000 AC Fans and Guards Fan Cords and Daisy Chains (10 amp, 115V) Part No. FAN80AC115 FAN80AC230 DNMF100AC115 DNMF100AC230 FAN150AC115 FAN150AC230 FAN10A115 FAN10A220 1 Part No. Description Lead Length (In) Connector Fan End Termination DNMFC DNFC48P DNFC72P DNFCDC2P DNFCDC3P Fan Cord Fan Cord Fan Cord Daisy Chain Daisy Chain 24" 48" 72" 24" 24" Straight 45° 45° 2x45°, 24" apart 3x45°, 24" apart none 2 pin 115V plug 2 pin 115V plug 2 pin 115V plug 2 pin 115V plug Size(mm) Size (In.) CFM AC Voltage 80 80 120 120 150 150 255 255 3.15 3.15 4.70 4.70 6.00 6.00 10.00 10.00 32 32 100 100 210 210 550 550 115 230 115 230 115 230 115 230 Use Fan Guard Use Filter Fan Grill FAN80FG FAN80FG DNFG DNFG FAN150FG FAN150FG FAN10FG FAN10FG XPFA80...1 XPFA80...1 XPFA120...1 XPFA120...1 n/a n/a n/a n/a "..." specify color - BK (black), CG (RAL 7032) or GY (ASA61 gray) Technical references and DXF downloads available at www.hammfg.com 364 Spare hardware kit, Part No. 1421F4 All dimensions in inches unless specified otherwise Quality Enclosures. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 USA: 716.651.0086 Data Subject to change without notice www.hammfg.com Fan Kits Fan Panels Create your own rack mount fan or filter fan from these panels. Black powder coated steel. Also available in 24" and other widths or custom configurations. Fans sold separately...see page 364. 19" Fan Panel 19" Grill Panel Punched 19" Fan Panels Panel Size # Holes Optional Fan Part No. (115V) Optional Fan Guard Grill Optional Filter Grill (Black) Optional Replacement Filter (pkg. 5) PPFP190802BK1 3U 80mm/3.15" 2 FAN80AC115 FAN80FG XPFA80BK PFF1000 PPFP190803BK1 PPFP191202BK1 3U 4U 80mm/3.15" 120mm/4.70" 3 2 FAN80AC115 DNMF100AC115 FAN80FG DNFG XPFA80BK XPFA120BK PFF1000 PFF2000 DNFG - - Punched 19" Grill Panels (with integral front finger guard) PPGP191202BK1 3U 120mm/4.70" 2 DNMF100AC115 Filterfs/Fans Technical references and DXF downloads available at www.hammfg.com All dimensions in inches unless specified otherwise Quality Enclosures. Service Excellence. © Hammond Manufacturing Canada: 519.822.2960 or 905.456.3770 Climate Control Products Part No. Cutouts for Stnd. Fans USA: 716.651.0086 Data Subject to change without notice 365
FAN150AC230 价格&库存
很抱歉,暂时无法提供与“FAN150AC230”相匹配的价格&库存,您可以联系我们找货
