FAN10A220
FAN10A220
    HAMMONDMANUFACTURING
    FANACAXIAL10"550CFM230V
FAN10A220 数据手册
Tops (C2 Series) SOLID TOP • 14 gauge steel construction • Supplied with mounting hardware • Should be used on all racks where protection from dust or falling objects is required Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923SBK1 C2T1923SCG1 C2T1931SBK1 C2T1931SCG1 C2T1936SBK1 C2T1936SCG1 Pa n e l Wi dt h 19 19 19 R a ck Dept h 23.63 31.50 36.00 VENTED TOP • 14 gauge steel construction • Supplied with mounting hardware • Provides a practical and economical solution to convection cooling requirements • Available either with or without 3.5” cable access holes and covers Without Cable Access Holes Pa n e l Wi dt h 19 19 19 R a ck Dept h 23.63 31.50 36.00 19” Rack Mount Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923VBK1 C2T1923VCG1 C2T1931VBK1 C2T1931VCG1 C2T1936VBK1 C2T1936VCG1 With 3.5” Cable Access Holes & Covers Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923VCEBK1 C2T1923VCECG1 C2T1931VCEBK1 C2T1931VCECG1 C2T1936VCEBK1 C2T1936VCECG1 Pa n e l Wi dt h 19 19 19 R a ck Dept h 23.63 31.50 36.00 RAISED VENT TOP • 14 gauge steel construction • Supplied with mounting hardware • Simple up or down adjustment permits either raised installation for venting or flush mounting for smooth decorative look • Allows for protection from falling objects or liquids • When raised, permits convection cooling as gap between top & frame allows warm air to escape on all four sides Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923RBK1 C2T1923RCG1 C2T1931RBK1 C2T1931RCG1 C2T1936RBK1 C2T1936RCG1 © Pa n e l Wi dt h 19 19 19 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 R a ck Dept h 23.63 31.50 36.00 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 49 Fan Tops (C2 Series) 4.7” FAN TOP PANEL • 14 gauge steel construction • 4.7" fan top panel - fans not included (see next page) • Quantity 4 or 6 openings depending on depth of rack • Maximum flexibility - add fans, leave holes open (for cable access) or use covers (see next page) Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923FBK1 C2T1923FCG1 C2T1931FBK1 C2T1931FCG1 C2T1936FBK1 C2T1936FCG1 Pa n e l Wi dt h 19 19 19 Rack Depth 23.63 31.50 36.00 Fa n Holes 4 6 6 PRE-WIRED 4.7” EXHAUST FAN TOP • Includes a quantity of 4 - long life, ball bearing, 4.7", 115 volt, 50/60 Hz. AC, 100 CFM fans (230 VAC fan tops available on special order) • Available with or without thermostat • Finger guards are punched into top panel and bottom of fan top • Fans are pre-wired, installed and complete with 3 foot cord & plug 19” Rack Mount Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923F4BK1 C2T1923F4CG1 C2T1931F4BK1 C2T1931F4CG1 C2T1936F4BK1 C2T1936F4CG1 C2T1923F4TBK1 C2T1923F4TCG1 C2T1931F4TBK1 C2T1931F4TCG1 C2T1936F4TBK1 C2T1936F4TCG1 Pa n e l Wi dt h 19 19 19 19 19 19 Rack Depth 23.63 31.50 36.00 23.63 31.50 36.00 Ther most at No No No Ye s Ye s Ye s PRE-WIRED 10” EXHAUST FAN TOP PANEL Without Cable Access • Includes quantity 1 - 10", 550 CFM, 115 V 50/60 Hz. AC fan 35 watt motor (230 VAC fan tops available on special order) • Thermal protected motor • Ball bearing construction, plastic blades (3) • Diecast aluminum body fan • Rotation is clockwise (looking down at the rotor - as pictured on the left) • Airflow exhausts the rack (out the top as pictured on the left) • C UL & UL recognized • 5' cord and molded on plug • Top & bottom finger guards included • Pre-wired and assembled as shown • Available either with or without 4 cable access holes (3.5”) and covers Without Cable Access Holes Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923F10BK1 C2T1923F10CG1 C2T1931F10BK1 C2T1931F10CG1 C2T1936F10BK1 C2T1936F10CG1 Pa n e l Wi dt h 19 19 19 R a ck Dept h 23.63 31.50 36.00 With Cable Access 3.5” Holes & Covers With Cable Access 50 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 Pa r t Nu mb e r B l a c k Te x t u r e d B e i g e Te x t u r e d C2T1923F10CEBK1 C2T1923F10CECG1 C2T1931F10CEBK1 C2T1931F10CECG1 C2T1936F10CEBK1 C2T1936F10CECG1 ww w.h am mo ndm fg.c om Pa n e l Wi dt h 19 19 19 Rack Depth 23.63 31.50 36.00 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Fan Top Accessories (C2 Series) 4” FANS • 4.70" (120mm), 1.50" deep - Tubeaxial type • Choice of either 115 or 230 VAC, 50/60 Hz. • Impedance protected motor Class-B insulated • Ball bearing construction, metal blades • Diecast aluminum body • Rotation is counter clockwise (looking at the rotor - as pictured) • Airflow is over the struts (out the back as pictured) • Male plug terminated (requires fan cords below) • UL recognized, CSA listed, CE certified • With mounting hardware Size Par t Number DNMF100AC115 DNMF100AC230 I nches mm 4.70 4.70 120 120 VAC CFM Wattage 115 230 105 105 22 22 Use With Fan Guard Par t Number DNFG DNFG METAL FAN GUARDS • Constructed of steel • For covering unused fan top openings or as 4.7” fan guards • Hardware included Color DNFG Wire mesh, nickel plated Use with Fan Size 4.7" 19” Rack Mount Par t Number 4.7” FAN HOLE COVER • Constructed of 14 gauge steel • For covering unused fan top openings on 4.7” fan tops • Hardware included Pa r t Nu mb e r DNFPBK1 DNFPCG1 Color B l a ck G r ey - B e i g e Pa i n t F i n i s h Tex t u r e d Tex t u r e d FAN CORD • For 115 VAC wiring • Standard molded female fan plug (0.91” x 0.68”) Pa r t Nu mb e r Descr iption DNMFC DNFC48P DNFC72P DNFCDC2P DNFCDC3P Si n g l e Fa n Co r d Si n g l e Fa n Co r d Si n g l e Fa n Co r d Dai sy Chai n Dai sy Chai n © Lead Length 24" 48" 72" 24" 24" Fa n C o n n e c t o r St rai ght 4 5 d e gr e e 4 5 d e gr e e Qt y. 2 - 4 5 d e gr e e, 2 4 " a p a r t Q t y 3 - 4 5 d e gr e e, 2 4 " a p a r t Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 1 1 5 VA C Plug No Ye s Ye s Ye s Ye s ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 51
FAN10A220 价格&库存
很抱歉,暂时无法提供与“FAN10A220”相匹配的价格&库存,您可以联系我们找货
