FT900HA1220BK
FT900HA1220BK
    HAMMONDMANUFACTURING
    Rack Fan Tray, AC, 9 Fans, 900 CFM 18.58" L x 17.01" W x 1.75" H (471.9mm x 432.1mm x 44.4mm)
FT900HA1220BK 数据手册
Cooling FAN TRAYS • Standard 19" rack mount • Compact and economical rack cooling solution • Fan trays can be positioned at the bottom of a rack to force air through the cabinet, at the top to exhaust air out or below specific pieces of equipment for spot cooling • 115VAC 50/60 Hz., thermally protected, ball bearing fans UR/cUR listed • Circuit breaker protected • Low profile 1.75" (1U) of panel space • 6' 14/3 STJW cord with molded 3 prong plug included • Integral finger guards above and below fans • Case width is 17" • 6 and 9 fan units include an adjustable rear mounting bracket (mounts to rear panel rails) for extra stability • Shipped fully assembled • Available with or without on/off switch • Finished in smooth black powder paint • Control your rack temperature with our economical, compact thermostat FT900HA1BK FT600HA1BK Pa r t Nu mb e r Wi t hout Swi t ch F T 3 0 0 TA 1 B K F T 6 0 0 TA 1 B K F T 9 0 0 TA 1 B K 100 © Wi t h Li ght ed Switch FT300HA1BK FT600HA1BK FT900HA1BK CFM Running Amps 300 600 900 0.5 1.0 1.5 Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 FT300HA1BK Wa t t s Pa n e l Wi dt h Case Wi dt h Case Depth 40 80 120 19 19 19 17 17 17 7.5 13 18.5 ww w.h am mo ndm fg.c om Rear Br acket Depth Mi n. Max. n/a 2.40 7.90 n/a 19.20 24.70 Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
FT900HA1220BK
1. 物料型号:文档中提到了几种型号,例如FT300TA1BK、FT300HA1BK、FT600TA1BK、FT600HA1BK、FT900TA1BK和FT900HA1BK。
2. 器件简介:文档描述了一种标准的19英寸机架安装冷却风扇托盘,它是一种紧凑且经济的机架冷却解决方案。风扇托盘可以放置在机架底部以强制空气通过机柜,在顶部排出空气,或在特定设备下方进行点冷却。
3. 引脚分配:文档中没有明确提到引脚分配,因为它主要描述的是风扇托盘,而不是电子元件。
4. 参数特性: - 风扇:115VAC 50/60 Hz,热保护,滚珠轴承风扇,UR/cUR认证。 - 电路保护:带有熔断器保护。 - 外形尺寸:低轮廓1.75英寸面板空间。 - 电源线:6英尺14/3 STJW线,带成型的三插插头。 - 安全性:风扇上方和下方有集成的手指防护。 - 机箱宽度:17英寸。 - 安装:6和9风扇单元包括可调节的后安装支架(安装到后面板导轨)以增加稳定性。 - 组装:完全组装发货。 - 开关:可选带或不带开关。
5. 功能详解:文档中提到了风扇托盘的功能,包括冷却机架内部、强制空气流通和点冷却。
6. 应用信息:文档中没有详细说明应用信息,但可以推断这些风扇托盘适用于需要机架冷却的场合。
7. 封装信息:文档中提供了风扇托盘的尺寸信息,包括面板宽度、机箱宽度、机箱深度和后支架深度。
FT900HA1220BK 价格&库存
很抱歉,暂时无法提供与“FT900HA1220BK”相匹配的价格&库存,您可以联系我们找货
