SRCOOL24K
SRCOOL24K
    TRIPPLITE
    PORTABLEAIRCOND24000BTU
SRCOOL24K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Portable AC Unit for Server Rooms - 24,000 BTU (7 kW), 208/240V MODEL NUMBER: SRCOOL24K Highlights ● 24,000 BTU/h (7 kW) of cooling capacity in 2 x 2-ft. (0.61 m) footprint ● NEMA L6-20P plug connects to standard 208/240V 20A outlet ● Directs cooling through adjustable louvers or ducts ● Restarts automatically after power failures ● Supports network management via preinstalled SRCOOLNET2 Package Includes Portable, self-contained 24,000 BTU server rack cooling system perfect for supplemental or backup cooling in server rooms and data centers, and as primary cooling in wiring closets and other IT environments without facility air conditioning. Description The SRCOOL24K SmartRack 24,000 BTU 208/240V Portable Rack Air Conditioner cools, dehumidifies and filters the air in your server room, data center or other environment with heat-sensitive equipment. The compact, portable unit fits into just 4 square feet of floor space. It is designed for supplemental or backup cooling of IT equipment to prevent shutdowns, malfunctions and costly downtime caused by overheating or fluctuating temperatures. The self-contained SRCOOL24K packs 24,000 BTU/h (7kW) of cooling capacity into a rack-width chassis. A built-in evaporator expels condensation through a directional exhaust duct, eliminating the need for a floor drain or water collection tank. The SRCOOL24K also dehumidifies and filters the air, providing better air quality that can enhance equipment performance. Efficient close-coupled cooling reduces energy use and operating costs. Installation is quick and easy and does not require disruptive construction or the costly expense of hiring a plumber or HVAC specialist. The unit rolls into place on durable built-in casters. The NEMA L6-20P plug connects to a standard 208/240V 20A outlet. The SRCOOL24K restarts automatically after power failures, and a built-in timer supports unattended shutdown and startup. The included SRCOOLNET2LX network management card lets you monitor temperatures, receive alerts, review logs, automate operation and control settings from anywhere via SNMP, web browser, SSH or telnet. The SRCOOLNET2LX includes the ENVIROSENSE remote sensor, which lets you monitor temperature and humidity up to 12-ft. (3.66 m) away from the SRCOOL24K. Features Portable, High-Capacity Cooling PowerProduces 24,000 BTU/h (7 kW) of cooling capacity in a portable, rack-width chassisPrevents equipment shutdowns, malfunctions and failures caused by overheating and temperature fluctuationsFilters and dehumidifies the air to enhance equipment performanceUses environmentally friendly R410A refrigerant, which complies with worldwide standardsEfficient close-coupled cooling reduces energy use and operating costs Convenient OperationAdjustable louvers support area cooling applicationsFlexible dual output ducts aim cold air where it's needed, such as an overheated rack enclosure or equipment hot spotSupports unattended shutdown and startup, including automatic restarts after power failuresEasy-to-read control panel with digital display and diagnostic LEDs for local managementSystem-lock function disables all other buttons to prevent accidental input 1/3 ● SRCOOL24K SmartRack Portable Server Rack Cooling Unit - 24,000 BTU, 208/240V, Network Management Card ● (2) Gray exhaust ducts ● (2) Black cooling ducts ● (2) Exhaust duct adapters ● (2) Adjustable exhaust panels ● (4) Self-tapping screws ● Dual cooling duct adapter ● Louvered vent insert (preinstalled) ● (2) Drainage plugs (preinstalled) ● ENVIROSENSE environmental sensor ● SNMP configuration cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Advanced Network MonitoringIncluded SRCOOLNET2LX accessory allows remote monitoring of temperatures, alerts, logs and control settings from anywhere via SNMP, web browser, SSH or telnetENVIROSENSE remote sensor monitors temperature and humidity up to 12-ft. (3.66 m) away Easy to InstallRolls into place on built-in castersFits into 2 x 2-ft. (0.61 m) section of floor space6.5-ft. (1.98 m) power cord with NEMA L6-20P plug connects to a standard 208/240V 20A AC outletNo external condenser, refrigerant piping or professional maintenance requiredBuilt-in evaporator expels condensation through exhaust tube—no floor drain or water collection tank neededExhaust kit removes hot air from room through drop ceiling, window or return ductIncludes all parts required for setup Specifications OVERVIEW UPC Code 037332184856 INPUT Electrical Consumption (Max) 2560 Watts Nominal Input Voltage(s) Supported 208V AC; 240V AC Input Connection Type NEMA L6-20P Input Plug Features NEMA L6-20P Input Frequency 60 HZ Input Cord Length (ft.) 6.56 Input Cord Length (m) 2.00 COOLING Cooling Type Active Airflow Evaporator = 634 CFM / Condenser = 640 CFM Cooling Capacity (BTUs) 24000 Cooling Capacity (kW) 7.0 Equivalent Room Size 47 sq. m (505.9 sq. ft.) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Touch sensitive control panel with multiple LEDs and numerical temperature readout PHYSICAL Color Black Material of Construction Steel Form Factors Supported Tower Shipping Dimensions (hwd / in.) 46.50 x 25.20 x 29.20 Shipping Dimensions (hwd / cm) 118.11 x 64.01 x 74.17 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 223.00 Shipping Weight (kg) 101.15 Unit Dimensions (hwd / in.) 38.200 x 20.500 x 21.700 Unit Dimensions (hwd / cm) 97.03 x 52.07 x 55.12 Unit Weight (lbs.) 175.37 Unit Weight (kg) 79.55 FEATURES & SPECIFICATIONS Dehumidifier 5 liters / hour Compressor Type Rotary Refrigerant R410a (Environmentally friendly, Non ozone depleting) Refrigerant Amount 42.33 oz. Amp Draw Nominal 13.5A Sound Level (Noise) 65dB Air Supply Tube Length 71 inches Air Exhaust Tube Length 118 inches Air Exhaust Tube Diameter 5.16 inches STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 484 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SRCOOL24K
物料型号: - 型号编号:SRCOOL24K
器件简介: - SRCOOL24K是一款24,000 BTU(7 kW)的便携式服务器机架冷却系统,适合作为服务器房间和数据中心的补充或备份冷却,以及在没有设施空调的其他IT环境中作为主要冷却。
引脚分配: - 输入连接类型:NEMA L6-20P - 电压兼容性:208V AC; 240V AC - 输入频率:60Hz - 输入线长:6.5英尺(约2米)
参数特性: - 电能消耗(最大):2560瓦特 - 制冷类型:主动 - 制冷能力:24000 BTUs(7.0 kW) - 制冷剂:R410a(环保,不破坏臭氧层) - 制冷剂量:42.33盎司 - 等效房间大小:47平方米(505.9平方英尺)
功能详解: - SRCOOL24K具有24,000 BTU/h的冷却能力,内置蒸发器通过方向性排气管排出冷凝水,无需地漏或水箱。 - 还具有除湿和空气过滤功能,提供更好的空气质量,增强设备性能。 - 高效的近耦合冷却减少了能源使用和运营成本。 - 支持通过SNMP、Web浏览器、SSH或Telnet远程监控温度、接收警报、查看日志、自动化操作和控制设置。 - 包括SRCOOLNET2LX网络管理卡和ENVIROSENSE远程传感器,可监测距离SRCOOL24K最远12英尺(3.66米)的温度和湿度。
应用信息: - 适用于需要防止因过热或温度波动导致的设备关闭、故障和昂贵停机的IT设备补充或备份冷却。 - 适用于2 x 2英尺(0.61平方米)的地板空间。
封装信息: - 颜色:黑色 - 材质:钢 - 支持的外形尺寸:塔式
SRCOOL24K 价格&库存
很抱歉,暂时无法提供与“SRCOOL24K”相匹配的价格&库存,您可以联系我们找货
