Main Catalog
24th Edition
Main Catalog
Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM
Equipment Protection Solutions
12/2017
39601-641 © 2012 Pentair Equipment Protection
18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1
10.10.2012 11:15:02
DESIGN WITH CONFIDENCE
Pentair, together with its Hoffman®,
McLean® and Schroff® brands, is a
leading manufacturer of products and
solutions for the housing, protection
and cooling of electrical and electronic
assemblies and components.
Under the slogan "Design with
CONFIDENCE®" the company offers
the highest standards across the
industry for quality, performance
and design. Pentair offers a vast
diversity of off-the-shelf products
as well as modified and customized
solutions for applications in the
measurement and instrumentation,
telecommunications and data
processing, energy and industrial,
transport and medical industries
and for electronic systems for
security and defense.
When you enter a partnership
with Pentair you are drawing on
the capabilities of a company that
has all the necessary financial and
other resources at its disposal to
develop, manufacture and assemble
application-critical systems to your
requirements, down to defined
function testing and prompt delivery
of the goods anywhere in the world.
Regional Headquarters
Anoka, MN, USA
Boituva, Brazil
Straubenhardt, Germany
Singapore
Shanghai, China
Manufacturing and
Logistics Locations
Pharr, TX, USA
Anoka, MN, USA
Mt. Sterling, KY, USA
Radford, VA, USA
Warwick, RI, USA
San Diego, CA, USA
Boituva, Brazil
Melbourne, Australia
Reynosa, Mexico
Betschdorf, France
Dzierzoniow, Poland
Bangalore, India
Qingdao, China
Meiwa, Japan
Pentair Equipment Protection brands
pentairequipmentprotection.com
02
18002_Hautpkatalog_Schroff_EN_AK03.indd 2
17.10.2012 11:18:23
INNOVATIVE, SOPHISTICATED,
CUSTOMER-ORIENTED AND WITH GLOBAL
PRESENCE: Schroff
The Schroff® brand stands for
recognized, globally leading
developments in electronics packaging
components and systems for
applications in measurement,
instrumentation and control systems,
infrastructure, security systems, data
communications, telecommunications
and automation. Our customeroriented thinking and mode of working
is an important element of our
business model.
At a glance: what sets Schroff products apart:
- Certified to global standards
- Global availability
- Outstanding quality
- Innovative solutions
- Comprehensive heat management
- Large off-the-shelf product program
- Modifications to your requirements
- Custom new developments
- Customer-oriented thinking and
operations
- Service quality and competence
- Extensive testing
- Best price-performance ratio
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 3
03
17.10.2012 11:20:01
SIX STEPS
TO THE RIGHT PRODUCT
1. APPLICATION
The choice of enclosure often depends
on the field of application and/or
market segment. Does your product
require a door, shelves, slide rails or a
support arm for a monitor? Is ease of
access important? Do you require
cooling for your components,
redundancy or electromagnetic
2. ENVIRONMENT
Environmental conditions are perhaps
the most important factor when
selecting the correct enclosure.
Is it intended for use in, say,
telecommunications, industry,
measurement and control,
infrastructure or security systems,
or as a data communications system?
You should also consider the main
challenges the enclosure will face,
such as:
- electromagnetic radiation
3. STANDARDS
Select an enclosure that satisfies the
required standard of protection for the
environment and application in
question. The evaluation criteria of
protection classes such as NEMA, UL,
cUL, Telcordia GR-487, CSA, DIN, VDE,
GOST, RoHS, CE, IEC, EN, NFF, BN,
IEEE, PICMG and VITA are a measure of
the capability of an enclosure to
shielding? Many details are required to
enable you to select the correct
enclosure. You can find more technical
information about electromagnetic
compatibility on page 12.6.
- shock and vibration
- corrosion
- the required loading capacity
- dust or sand
- fire
- extreme temperatures
- low atmospheric pressure
Deciding these considerations
simplifies the choice of the best
product for your needs. You can
find further information in the
appendix on pages 12.3-12.6
withstand specific environmental
conditions. Note however that these
protection classes differ from one
another in important aspects. Further
technical information is available in the
appendix on pages 12.1-12.7 and in our
Standards Summary brochure, which
you can order from our website
www.schroff.biz/catalogues.
04
18002_Hautpkatalog_Schroff_EN_AK03.indd 4
17.10.2012 11:20:24
4. SIZE
Several factors must be considered
when specifying the size of the
enclosure. What materials should it
be built from? Where in the enclosure
will the assemblies be fitted?
Will you be installing devices on a
mounting plate? Will you be fitting
operating elements to a door? Does your
application have specific requirements
for the location of the enclosure?
5. MATERIAL
Select the most suitable material for
your product, taking into consideration
the potential environmental risks and
possible contamination by harmful
substances against which you must
protect the enclosure.
– steel
– stainless steel
– aluminum
– fiberglass
– ABS
– polycarbonate
– polyester
We will then help you select the most
suitable surface finish:
– electroplating
– hot-dip galvanizing
– passivation
– anodization
– paint (various compositions)
Further technical information is
available in the appendix on pages
12.4-12.5 and in our Standards
Summary brochure (pages 26-33),
which you can order from our website
6. THERMAL MANAGEMENT
Faster and more powerful assemblies
produce ever more waste heat.
Effective thermal management is
therefore important to ensure optimum
efficiency and service life for the
electronic components. While in most
cases the central task is to monitor and
dissipate the heat generated, there are
also circumstances in which heating is
necessary. Some basic questions for
determining the appropriate cooling
method for your application include:
Which enclosure surfaces allow heat
transfer?
How much heat is generated by each
installed component?
What temperature conditions must be
observed?
Will your application be used in a
closed room or out of doors?
Will the cooling device be fitted on the
top, the side or within the enclosure?
With the help of your Schroff contact,
select the most suitable cooling
solution from our wide product range
in section 4. You will also find more
solutions on the Pentair McLean
website www.mcleancoolingtech.com
or in the McLean catalog, in the
"McLean V-Series" and "McLean
Thermoelectric Coolers" brochures
and in the main Pentair Hoffman
catalog, which you can order from
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 5
05
17.10.2012 11:20:40
ServicePLUS
configuration
Simple. Fast. To the ideal product.
We help you to build your ideal product out of off-the-shelf components quickly, competently and simply with interactive
online configurators, our telephone configuration hotline and Power Search, which lets you select standard components fast
www.schroff.co.uk/configuration
assembly
Built by professionals. Double the benefit.
For turnkey products, ServicePLUS assembly lets you keep your attention on your core activity without interruption, while we
carry out the complete assembly of all your system components, competently and on time; competently and on time
www.schroff.co.uk/assembly
modification
Minor modifications. Large impact.
Quality also means 100% accuracy of fit. We therefore also modify off-the-shelf products to your individual needs, for
example, drilled holes, cut-outs, printing and special colors.
www.schroff.co.uk/modification
solution
Simple. Fast. From one source.
If it is not possible to use off-the-shelf products, we will create a special custom solution - from development and design
through to complete, integrated, functioning systems or even highly specific new developments.
www.schroff.co.uk/solution
express
When fast has to be even faster.
In many projects speed is of the essence, and flexibility a decisive criterion. With us you can select your delivery time from a
range of express options.
support
Support. Solution. Availability.
ServicePLUS support is our after-sales service and sets up an ongoing relationship with you. We offer a modular range of
support options that can be tailored to your specific service requirements.
www.schroff.co.uk/support
academy
Know. Share. Become a partner.
With ServicePLUS academy we offer you straightforward access to our specialist knowledge. This includes:
• Seminars and training about our products
• Modern knowledge transfer using webcasts, white papers and webinars
• Technical reports, technical details and CAD drawings available by download
www.schroff.co.uk/academy
lifecycle
We stay with you. For the entire life of the product.
With ServicePLUS lifecycle you profit from our flexibly configurable, comprehensive support over the entire life of your
products and complete solutions. Select options from our range to your exact needs and create your individual Lifecycle
package.
www.schroff.co.uk/lifecycle
06
18002_Hautpkatalog_Schroff_EN_AK03.indd 6
17.10.2012 11:20:41
HOW TO CONTACT US
Your local contact
ALL CONTACT DETAILS
FOR YOUR PERSONAL CONTACT
PARTNER ARE HERE:
Online at www.schroff.biz/contact or
in the address list at the end of this
catalog.
YOUR ONLINE CONTACT
WITH SCHROFF
At www.schroff.biz you can reach us
round the clock.
Use the inquiry basket to inquire
online about the articles you require,
simply and without complication, and
receive a quotation within 24 hours.
For customers who prefer quick and
reliable processing when ordering
stock products by authorized and
qualified business partners, our
distribution partners are the first
choice. If you are looking for
professional support for adapting
our products to your individual needs,
contact our value-added resellers.
These can of course also supply
off-the-shelf products. Decide together
with us whether you would like support
either from our direct sales department
or through our business partners in
various countries.
See www.schroff.biz/contact for the
advantages of the different sales and
distribution options.
WE WILL ANSWER YOUR INQUIRY
WITHIN 24 HOURS
Just send us an inquiry or order by
e-mail to schroff.uk@pentair.com or
to your personal contact. You can
naturally also send us a fax.
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 7
07
17.10.2012 11:20:42
HOW TO OBTAIN OUR PRODUCTS
ONLINE
You will see our oneClick symbol next
to many products in this catalogue.
By entering the order number at
www.schroff.biz/oneclick you can
quickly and easily obtain further
information about the relevant product.
- detailed product description
- scope of delivery information
- detailed drawings
- technical information
- user manuals
- test reports
- downloadable CAD drawings
- certificates
- test reports
You can also use the free text search
available at www.schroff.biz under
"Search" in the function bar:
5. September 2012 6:12 06
Cabinets – VARISTAR Electronics
Apart from the order number, you can
also enter product names or other
terms.
19'' fixed shelf, 75 kg
Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
Mounting height 1 U, for mounting on four panel/slide mounts
With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
Assembly kit incl. GND/earthing
Catalogue
D
c
RAL 7035
For cabinet Usable
xf
depth
surface w x d
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf PU 1 piece
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
Cable ducting with cable ties, see page 1.25
Other sizes, see ServicePLUS, page 1.49
xf
d
c
Order Information
For further information www.schroff.biz/oneclick
To help you get your bearings quickly
and simply, all the ordering tables in
this catalog are uniformly designed:
- The first section contains the
ordering information for the product.
- The next section, indicated by a
separating line, shows suitable
accessories.
- Order numbers printed in bold are
available for shipping in 2 working
days; order numbers in ordinary type
can be shipped within 10 working
days.
- Further information, if available, on
the product or accessories is shown
at the end of the ordering table.
01004067
oneClick search code = Part no.
ounts
sion
08
18002_Hautpkatalog_Schroff_EN_AK03.indd 8
17.10.2012 11:20:46
Cabinets
Overview............................................. 1.0
Varistar Cabinet platform.................. 1.2
Varistar Electronics........................... 1.10
Varistar EMC...................................... 1.54
Varistar Seismic................................ 1.84
Varistar MIL....................................... 1.120
Varistar Data/network systems........ 1.124
Varistar Containment........................ 1.202
LHX 20/40 Air/water heat exchangers..... 1.224
LHX 3 Air/water heat exchangers........... 1.236
Novastar............................................. 1.240
Eurorack............................................ 1.270
Outdoor ............................................. 1.316
Etsirack.............................................. 1.346
19” lab racks...................................... 1.354
PROLINE............................................ 1.362
1
2
Wall mounted case
Overview............................................. 2.0
Epcase................................................ 2.36
LAN wall-mounted distributors........ 2.46
Cabinet and
wall-mounted
case accessories
Overview............................................. 3.0
Mechanics.......................................... 3.2
Telescopic slides............................... 3.24
Electrical............................................ 3.29
Monitors, keyboards, monitoring...... 3.44
Socket strips...................................... 3.50
Power control socket strips.............. 3.72
Climate control
Overview............................................. 4.0
Cooling concepts/service.................. 4.2
19” fan trays....................................... 4.4
Air filtered fans.................................. 4.20
Accessories........................................ 4.58
Desktop enclosures
Overview............................................. 5.0
RatiopacPRO...................................... 5.6
PropacPRO........................................ 5.44
CompacPRO...................................... 5.76
Comptec............................................. 5.100
Accessories........................................ 5.108
Interscale........................................... 5.200
Minipac ............................................. 5.230
5
Subracks/
19” chassis
Overview............................................. 6.0
EuropacPRO...................................... 6.2
EuropacPRO
for railroad applications.......................6.70
EuropacPRO industrial applications.. 6.86
EuropacPRO Rugged......................... 6.92
MultipacPRO...................................... 6.112
Inpac.................................................. 6.128
6
Front panels,
Plug-in-units,
Frame type plug-in-units
Overview............................................. 7.0
Front panels....................................... 7.2
Plug-in units...................................... 7.16
Frame type plug-in units................... 7.64
PCB accessories................................ 7.102
Systems
Overview............................................. 8.0
AdvancedTCA..................................... 8.2
AdvancedMC carriers........................ 8.26
MicroTCA............................................ 8.36
AdvancedMC modules....................... 8.56
CompactPCI, Serial, PlusIO, PSB..... 8.68
VME, VME64x, VXS, VPX..................... 8.88
Accessories........................................ 8.106
8
Power supply systems
Overview............................................. 9.0
19” AC/DC switched-mode PSUs..... 9.2
19” AC/DC linear regulators............. 9.12
19” AC/DC convertors....................... 9.15
19” accessories................................. 9.18
PSUs for MicroTCA............................ 9.20
PSUs for VMEbus.............................. 9.22
PSUs for CompactPCI, VME64x.......... 9.24
9
Backplanes
Overview........................................... 10.0
CompactPCI, Serial, PlusIO............ 10.4
PXI.................................................... 10.11
VXS................................................... 10.14
VME64x, VMEbus............................. 10.15
Power............................................... 10.18
Universal.......................................... 10.19
Test adaptors................................... 10.20
10
Connectors,
Front panel component
systems
Overview........................................... 11.0
Connectors...................................... 11.2
Front panel component system...... 11.12
11
Appendix
Standards abbreviations................. 12.0
Notes on ordering............................ 12.10
Order number index........................ 12.11
Product index................................... 12.62
12
3
4
7
Main Catalogue
Cabinets – Overview
Content
Cabinets . . . . . . 1
VARISTAR
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
쮿 Cabinet platform for many
application areas like electronics,
datacom and networking
technologies
– 19" or metric versions
– EMC shielded
– Earthquake-proof
– Variable cooling concepts
– Air-conditioned cabinets
– Extensive range of innovative cable
routing accessories
쮿 Welded steel frame for static
load-carrying capacity of up to
1200 kg
쮿 Type of protection IP 20 or IP 55
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
NOVASTAR
쮿 19" electronics cabinet for applications
in the measurement and control, audio
and video industries
쮿 Attractive design with visible profile
frame, inset cladding parts and full
glass doors
쮿 Cabinet height from 6 U to 47 U
쮿 Cabinet width only 553 mm
쮿 Screw fixed aluminium rack for static
load-carrying capacity of up to 400 kg
쮿 Type of protection up to IP 40
NEW
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
P
쮿 19" cabinet for electronics applications
쮿 Screw fixed aluminium frame for static
쮿 Type of protection IP 40
Appendix . . . . . 12
36109003 (01006007 01005001 07011036 00105003 )
1.2
SCHROFF Further information: www.varistar.de E 05/2016
ELECTRONICS PROTECTION
Cabinets – Overview
Overview . . . . . . 1.2
Outdoor
VARISTAR . . . . . . 1.2
쮿 Aluminium cabinet for outdoor use
and to accommodate 19", metric or
non-standardized components
쮿 Type of protection IP 55
쮿 Single-wall or double-wall versions
쮿 Static load-carrying capacity up to 400 kg
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
MIL . . . . . . . . . . . . . 1.120
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR
Aisle
Containments . . . . 1.202
VARISTAR
Air/water heat
exchanger . . . . . . . 1.224
Z
쮿 Designed for telecommunications
applications in accordance with
the ETS standard
쮿 Steel construction, 300 mm deep
200 kg
NOVASTAR . . . . . 1.240
eurorack . . . . . . . 1.270
Outdoor . . . . . . . . . 1.316
etsirack . . . . . . . . 1.346
Lab racks . . . . . . . 1.354
Lab Racks
PROLINE . . . . . . . 1.362
쮿 Open 19" frame for lab applications,
stationary or mobile
쮿 Static load-carrying capacity 200 kg
Cabinet
Accessories . . . . 3.0
36109004 (41602001 40012001 05601002 01305003)
SCHROFF.PENTAIR.CO.UK
1.3
VARISTA RMain Catalogue
Cabinets – VARISTAR
Content
Wall mounted
쮿 Open cabinets with decorative
frame
쮿 19" cabinets with IP 20 or IP 55
protection class
Accessories for
cabinets and wall
mounted cases . 3
쮿 Extensive range of innovative
accessories for
electronics cabinets
Climate control . 4
Electronics
VARISTAR EMC
쮿 Shielding up to 60 dB at 1 GHz and 40 dB at 3 GHz
Subracks/
쮿 High shielding also when combined with perforated
doors or fan top covers
쮿 Individual configuration options with ServicePLUS
configuration
Front panels,
VARISTAR Seismic
쮿 Earthquake-resistant cabinets
tested to Bellcore Zone 4
ServicePLUS configuration
Power supply
Backplanes . . . 10
Connectors, front
panel component
VARISTAR MIL
NEW
쮿 Tested and certified to MIL 901D
쮿 With shock absorbers
쮿 Shielded against high-frequency
interference
쮿 IP 55
36108003 (01006007, 01004031, 01007002, 01005018, 01012004)
1.2
SCHROFF Main catalogue
www.schroff.biz E 05/2016
Cabinets – VARISTAR
VARISTAR Data and networking
technology
VARISTAR
Platform . . . . . . . 1.4
쮿 Wide range of network and server cabinet
versions
쮿 Server cabinets with depths up to 1200 mm
쮿 Two standard colors:
light grey (RAL 7035) or
black grey (RAL 7021)
쮿 Extensive, innovative range of cable routing
accessories
VARISTAR
Electronics . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . 1.84
VARISTAR
Aisle containments
NEW
VARISTAR
MIL . . . . . . . . . . . . 1.120
쮿 Cold aisle containments
쮿 Modular standard components
쮿 Extensive range of swing and sliding doors
VARISTAR
Datacom and
Networking
Technology . . . . 1.124
VARISTAR with air/water heat exchangers
VARISTAR Aisle
containment . . . . 1.202
LHX 20/40
VARISTAR
Air/water heat
exchangers . . . . . 1.224
쮿 Versions with single or double
doors and with automatic
door opening
Cabinet
LHX 3
쮿 Electronics cabinets with
LHX 3 air/water heat exchanger
36108004 (01006006, 01006015, 01012006, 01007015, 01006040)
1.3
Cabinets – VARISTAR platform
Two load-carrying classes, one accessory range: The VARISTAR frames
VARISTA R platformMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
VARISTAR is the only cabinet platform that allows identical
accessories to be combined with two basic frames.
The cabinet is available in Slim-Line (narrow) or Heavy-Duty
(robust) profiles.
Slim-Line profile
The Slim-Line version is based on very thin steel profiles in order
to obtain the greatest opening width between the uprights. This
frame can accommodate either 19" equipment or metric
components to ETS 3000-119-3. With a maximum load of 400 kg*
on the 19" plane the frame is still highly robust and suitable for
demanding applications in electronics or data and network
technology.
Heavy-Duty profile
01004035
The Heavy-Duty frame, on the other hand, is designed for use with
heavy loads or in regions susceptible to earthquakes. It offers on
the one hand maximum stability for a load of up to 800 kg* on the
19" plane and, thanks to its high bending stiffness, can meet the
shock and vibration requirements such as occur in railway and
traffic signal installations, in the control of rotating machines, on
commercial ships or in low-level military installations.
In the IEC 61587-2 earthquake test the Heavy-Duty frame qualified
for use in Bellcore Zone 3. Equipped with very simple, low-cost
strengthening brackets, the VARISTAR Seismic version meets the
demands of Bellcore Zone 4.
01006035
Slim-Line profile
capacity
Type of protection
Shock test
01006034
Heavy-Duty profile
01008062
Heavy-duty profile with strengthening bracket
Standard
IEC 61587-1
Slim-Line
400 kg *
Heavy-Duty
800 kg *
IEC 60529
IEC 61587-1
IP 20, IP 55
Maximum acceleration: 5 g
Duration: 11 ms
Frequency: 5 Hz -100 Hz
Acceleration: 1 g
IP 20, IP 55
Duration: 11 ms
Acceleration: 1 g
Standard: up to Bellcore
With strengthening: up to Bellcore
Zone 3, acceleration: 3 g,
Zone 4, acceleration: 5 g,
Frequency: 1 Hz ... 5 Hz
Frequency: 2 Hz ... 5 Hz
60 dB at 1 GHz, 40 dB at 3 GHz
19"
Vibration test
IEC 61587-1
Earthquake test
IEC 61587-2
EMC shielding
Installing options
IEC 61587-3
19" or ETS
* Figures for static load-carrying capacity are based on the IEC 61587-1 test procedure. In this procedure the cabinet is standing on the floor under its equipment load and
lifted up by its lifting eyes; no significant deformations may occur on the frame or at the 19" panel/slide mounts under maximum carrying capacity. The potential load for the
VARISTAR frame is therefore, under normal operating conditions, considerably higher than the test value given under IEC 61587-1.
1.4
SCHROFF PRODUCT CATALOG D 05/2016
Decidedly different: The VARISTAR sealing and shielding concept
VARISTAR platform
Item
1
2
3
4
5
Description
Frame
Conductive EMC
textile gasket with
CuNi coating
Contact/shielding
Rear panel
Side panel
2
3
In most shielding designs currently available, conductive seals or
springs connect the cover parts to the cabinet frame. The points of
contact have thus to be kept conductive and corrosion-free.
With VARISTAR, however, the conductive textile gaskets link the
cover parts with one another directly, which results in two
advantages:
A considerably better shielding performance of 60 dB at 1 GHz
(and 40 dB at 3 GHz) is obtained than with conventional designs.
There is no longer any need for expensive treatment of the frame
surface. The textile EMC gasket is also a protection against dust
and water to IP 55. If no shielding is required, a rubber gasket is
used offering the same protection to IP 55. Both gaskets are fitted
to the 45°-angled surface of the exterior of the frame.
4
5
1
Shielding up to 3 GHz
[dBµV]
100
90
80
70
60
50
40
1
30
2
1000
1500
2000
2500
3000
[Mhz]
1: Cabinet with solid door
01004141 01008061 01008005
2: Cabinet with perforated door
Smooth-running and absolutely tight: The VARISTAR locking system
The latching system also contributes to protection class and
shielding.
The innovative locking bar accepts a variable number of deadbolts,
depending on the cabinet height, to ensure the most even
compression of the gaskets.
And best of all: Activating the locking bar causes the latches to
move in the opposite direction. Thus the frictional forces of the
bolts are balanced out and a resulting lopsided vertical force on
the door is avoided. The doors close easily and with an absolute
seal.
EMC doors are fitted with 4-point locking, IP and server doors with
3-point locking.
01005080
Part number in bold face type: ready for despatch within 2 working days
Part number in normal type: ready for despatch within 10 working days
1.5
Peerless and efficient: The VARISTAR profile (Slim-Line and Heavy-Duty)
VARISTA R platform
Mounting of the 19" bracket
without depth members
The VARISTAR profile has fixing holes in all three axes (height,
width, depth), following a 25 mm grid. This allows for the greatest
variability in the fitting of components and accessories. Thus for
example 19" panel/slide mounts may be installed in a 600 mm
wide cabinet without additional depth members. This saves costs
and provides stability on the 19" plane.
The intricately shaped form of the profile offers further new
assembly possibilities. Cable eyes, for instance, can be plugged
directly into the frame whilst fixing themselves.
01004034 01006105
Self-fixing cable eyes
dummy
New and well thought out: VARISTAR cable management
Schroff has divided the available space in the VARISTAR into zones
and given a simple description of the position and use of these
zones. The coloured arrows show the direction of the cable
ducting.
Zone 1
Zone 2
01006087
쮿 In front of the 19" plane
쮿 In this zone the patch cables are
ducted horizontally between the
distribution fields
1.6
Zone 3
01006088
쮿 On the right and left hand side, next to
the 19" plane
쮿 In this zone patch cables are ducted
vertically in a kind of channel to the
individual components
For each zone a range of accessories has been developed to suit
the conditions in the cabinet, which simplifies cabling and thus
helps to include as many connections as possible in a
distribution cabinet. The VARISTAR profile with its many fixing
options has thus proved a real boon.
Zone 4
01006085
01006086
쮿 Zone 3 is located laterally behind the 쮿 Zone 4 is located in the rear across
the cabinet width
19" plane across the cabinet depth;
mainly for 800 mm wide cabinets
쮿 Alternative to zone 3 for only
600 mm wide cabinets or when cable
쮿 In this zone entering cable bundles
entry is at the rear of the
are fixed in the cabinet, parted and
cabinet
ducted to the rear of the distribution
fields
Heat dissipation to exact requirements: cooling concepts for VARISTAR
Depending on installed heat dissipation and
the surroundings, VARISTAR offers various
cooling options and also good conditions for
problem-free operation of the installed
equipment.
Either top cover fans are used to assist the
heat dissipation or perforated doors with
78 % air throughput are fitted.
Additionally, VARISTAR LHX 20/40 with
assembled air/water heat exchanger
allows to cool especially strained
appliances with water. And that for up to 40
kW per cabinet.
01105057
up to 2 kW
01105056
up to 6 kW
01106027
Fan unit, positioned inside
0100581
up to 40 kW
41003017
78 % air throughput
01005020
Classic and consistent: VARISTAR colour and design
As well as its functional aspects, in the development of VARISTAR
the design of the individual components and their combined effect
on the appearance of the cabinet was always a priority. The cabinet
gains its characteristic, unmistakable look from the high narrow
door with the memorable hinges and the very thin, almost
inconspicuous top cover edge.
While rack, base and cover are offered in black grey (RAL 7021) for
all standard cabinets, a choice of two colour options are available
- even in our standard programme - for side panels, doors and
rear panels:
Either entirely black grey (RAL 7021), as is the contemporary
look in data centres and recording studios. Or in light grey
(RAL 7035), whereby an attractive combination of mainly light
surfaces with a few dark accents is obtained.
Alternatively, VARISTAR can be supplied in many RAL colours
within 15 working days, or even as a combination of two special
colours. The current range of colours can be seen online
at www.schroff.co.uk/modification.
01006037
Colour RAL 7021 (black grey)
01006036
Colour combination RAL 7035/RAL 7021 (light grey/black grey)
1.7
Frame dimensions
Height
Cabinet height
mm
1200
1400
1600
1800
2000
2200
Frame
H
mm
1192
1392
1592
1792
1992
2192
U
24
29
33
38
42
47
h
mm
1102
1302
1502
1702
1902
2102
Width
Cabinet width
mm
600
800
Frame
W
mm
592
792
Slim-Line
w
mm
535
735
Heavy-Duty
w
mm
502
702
Depth
01005087
Adjustable feet
Cabinet depth
mm
300
600
800
900
1000
1100
1200
D
mm
292
592
792
892
992
1092
1192
Frame
d
mm
128.8
428.8
628.8
728.8
828.8
928.8
1028.8
d1
mm
150
450
650
750
850
950
1050
d2
mm
175
475
675
775
875
975
1075
01004081
Castors with adjustable feet
Locking castors
Height of adjustable feet, castors, base/plinth
Adjustable feet
Locking castors
Base/plinth (feet)
Base/plinth, mobile
20 ... 40 mm
85 mm
85 ... 95 mm
112 ... 132 mm
126.5 ... 134.5 mm
01004082 01004156
Base/plinth
Mobile base/plinth
0100411001004111
1.8
Top cover with cut-out zones
D
600
800
900
1000
1100
1200
a
b
W = 600 mm
c
d
e
a
b
W = 800 mm
c
d
e
01006097
Base plate, multi-piece
b
w
a
W
c
200
50
D
600
800
900
1000
1100
1200
Cabinet width
W
mm
600
800
D
50
Depth in mm
a
300
300
300
300
300
300
b
200
300
200
300
300
c
200
200
300
Opening width
w
mm
426
626
01006096
1.9
Varistar ElectronicsMain C atalogue
Cabinets – Varistar Electronics
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01008004
Subracks/
Front panels,
01009002
19" panel mounts integrated in decorative frame
01005014
All-round gasketing to IP 55
Power supply
Backplanes . . . 10
Connectors, front
panel component
01009002
Side panels with quick-release fastener, optionally
lockable
01005014
3-point locking with contradirectional bolts
1.10
SCHROFF E 08/2017
Overview . . . . 1.10
Varistar ElectronicsMain Catalogue
The universal cabinet for electronics
쮿 Selectable stability, static load-carrying capacity up to 800 kg
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
쮿 Professional solutions for cable ducting
쮿 Variable ventilation concepts, active and passive
쮿 Various versions in ServicePLUS configuration
VARISTAR Deco
VARISTAR IP 20
VARISTAR IP 55
VARISTAR Deco . . 1.12
VARISTAR IP 20 . . 1.13
VARISTAR IP 55 . . 1.14
Accessories
Lever handle . . . . . 1.15
Base plate . . . . . . . 1.15
Base/plinth . . . . . . 1.16
Mounting plate . . . 1.17
19" swing
frame . . . . . . . . . . . . 1.18
19 panel/slide
mount . . . . . . . . . . . 1.19
19" fixing
materials kit,
M6 . . . . . . . . . . . . . . 1.19
Slide rails . . . . . . . . 1.20
19" shelves . . . . . . 1.21
Depth members . . 1.24
C horizontal rail . . 1.24
Cable tie,
Velcro . . . . . . . . . . . 1.25
01004001
쮿 Open at front, with deco frame and
integrated 19" panel mounts
01004002
쮿 With glass door and
single point locking
01004003
쮿 With glass or steel door and
3-point locking
ServicePLUS from page 1.26
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
e.g. custom solutions (special sizes)
ServicePLUS . . . 1.26
ServicePLUS
IP 20 . . . . . . . . . . . . 1.27
ServicePLUS
IP 55 . . . . . . . . . . . . 1.39
ServicePLUS
Interior
configuration . . . . . 1.44
VARISTAR EMC . . .1.54
VARISTAR
VARISTAR
Datacom and
Networking
Technology . . . . . .1.124
VARISTAR air/
water heat
www.schroff.biz/ServicePLUS
30407004
1.11
Varistar Deco
Varistar Electronics Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 Open at front (no door)
쮿 19" panel mounts integrated into decoration frame
쮿 Rear door with single point locking, side panels with quick
release fastener
쮿 Static load-carrying capacity 400 kg (Slim-Line)
Delivery comprises (assembled)
Item
1
Qty
1
2
3
4
1
4
1
5
2
6
1
7
8
2
1
Description
Welded basic frame, Slim-Line, St profile,
zinc-plated, powder-coated, RAL 7021
Adjustable foot, assembled
Raised top cover, St, RAL 7021,
with 10 mm air gap all around
Decorative frame, Al, integrated 19" panel mounts at the
front, RAL 7035
Adapter bracket, St, 2 mm, RAL 7035, front,
for assembling shelves and slide rails
Rear door, St, 180° hinge, single point locking and
key with safety lock, RAL 7035
Side panel, St, with quick-release fastener, RAL 7035
GND/earthing kit, supplied loose
Order Information
10
01004001
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1800
600
600
38
1800
600
800
42
2000
600
600
42
2000
600
800
Castors load-carrying capacity 400 kg, PS/St, PU 4
pieces, 2 locking, 2 non locking
Castors with integrated adjustable feet load-carrying
capacity 400 kg, PU 4 pieces
Lever handle for single point locking with push button, 1
piece
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Lifting eye for raised top cover PU 4 pieces
Part no.
10130-001
10130-002
10130-003
10130-004
23130-077
23130-078
23130-067
25127-995
23130-085
Note
W
D
20 - 45
H
쮿 Lever handle can be added to rear door
쮿 For more dimensions and versions see ServicePLUS IP 20,
starting on page 1.27
쮿 Please order base plate separately, see page 1.15
쮿 Please order base/plinth separately, see page 1.16
쮿 For assembly of shelves and slide rails another pair of panel/
slide mounts is necessary, see page 1.19
01004151
ServicePLUS see page 1.26
1.12
SCHROFF PRODUCT CATALOG E 08/2017
Varistar IP 20
Varistar Electronic s
쮿 With glazed front door
쮿 Doors with single point locking, side panels with quick release
fastener
Item
1
Qty
1
2
3
4
1
4
1
5
1
6
2
7
2
8
1
Description
Raised top cover, St, RAL 7021, with 10 mm air gap all
around
Front door, glazed, safety glass, 6 mm, 180° hinge, RAL
7035, single point locking, key lock cover
Rear door, St, 180° hinge, RAL 7035, single point locking,
Side panel, St, quick-release fastener with safety lock,
RAL 7035
19" panel/slide mount with EIA cut-outs, St, RAL 7035,
assembled at front, depth-adjustable in 25 mm
increments
GND/earthing kit, enclosed loose
Order Information
10
01004002
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1800
600
600
38
1800
600
800
42
2000
600
600
42
2000
600
800
piece
Part no.
10130-005
10130-006
10130-007
10130-008
23130-077
23130-078
23130-067
25127-995
23130-085
Note
W
D
20 - 45
H
쮿 Lever handle can be added to the doors
쮿 For other dimensions and versions see ServicePLUS
configuration IP 20, from page 1.27
01004152
1.13
VARISTAR IP 55
쮿 With glazed or steel front door
쮿 Doors with 3-point locking and screw-fixed side panels
Item
1
Qty
1
2
3
4
4
1
1
5
6
7
1
2
1
8
2
9
1
Description
Welded basic frame, Slim-Line, St profile, zinc-plated,
powder-coated, RAL 7021, with all around rubber seals
Flat top cover, St, RAL 7021
Front door, St or glazed, RAL 7035, 180° hinge,
3-point locking, lever handle
Rear panel, screw fixed, St, RAL 7035
Side panel, screw fixed, St, RAL 7035
Base plate, multi-piece, with cover plate, St, RAL 7021,
with gasket
19" panel/slide mount with EIA cut-outs, AlZn,
assembled at front,
depth-adjustable in 25 mm increments
Order Information
01005006
Height Height H Width W
Depth D Description
U
mm
mm
mm
42
2000
600
600
With glazed door
42
2000
600
600
With steel door
Lifting eye for top cover PU 4 pieces
Part no.
10130-021
10130-022
23130-077
23130-078
25127-995
23130-072
Note
configuration IP 55, from page 1.39
01005014
1.14
Lever handle for
쮿 For installation instead of key lock insert
쮿 To open press push-button
쮿 DIN profile half cylinder retrofittable
Delivery comprises
Item
1
2
Qty
1
1
Description
Assembly kit
Order Information
Description
01005016
Part no.
23130-067
25127-995
Note
쮿 Other locks such as ASSA, KABA or RONIS available on request
쮿 The multi-piece base plate is open at the rear
쮿 The opening may be completed
– with a filter mat
– with a brush strip for the cable entry
– with a cover plate
Delivery comprises (kit)
Item
1
5
Qty
1
1
Description
Multi-piece base plate, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01004050
1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter
kit
Width
Depth
mm
mm
600
600
600
800
Item 2 Cover plate for base plate, multi-piece for 600 mm
wide base plate, 200 mm deep, incl. assembly kit, 1 piece
Item 3 Brush strip for base plate for 600 mm width base
Item 4 Filter mat white, class M1 in accordance with
EN 799-G3, for 600 mm wide base plate, 200 mm deep,
Part no.
23130-001
23130-002
23130-076
23130-074
23130-075
Note
쮿 Is assembled from inside
쮿 Please order cover plate, brush strip or filter mat separately
1.15
Stationary base
쮿 Static load-carrying capacity 1000 kg
쮿 Removable covers allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
2a
H
2b
1
2b
2a
W
D = cabinet depth
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
D
4
01004110
01004053
For cabinet width W
Front/rear trim
mm
600
perforated
600
plain
Item 4 Side trim height 100 mm, depth 600 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-169
23130-170
Note
쮿 Please order side trims (item 4) separately
Base/plinth, mobile
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
For cabinet width
mm
600
600
For cabinet depth
mm
600
800
Part no.
23130-208
23130-209
010041110 1006095
1.16
Mounting plate
쮿 For mounting electrical components and sub-assemblies incl.
cabling
쮿 Mounting pitch 25 mm in depth and 50 mm in height for
partial-height mounting
쮿 Depth members are required for partial-height mounting
쮿 Static load
– 450 kg at full height, mounted to rear
– 600 kg at full height, mounted to rear, with additional
Delivery comprises
Item
1
2
Qty
1
1
Description
Mounting plate, St, 3 mm, zinc-plated
Assembly kit
Order Information
Full height
010080520 1008053
For partial-height mounting
For cabinet height
Width
mm
mm
1200 for partial-height mounting 600
1800
600
2000
600
Strengthening bracket for mounting plate PU 2 pieces
Depth member St, 2 mm, for cabinet depth 600 mm,
2 pieces
Depth member St, 2 mm, for cabinet depth 800 mm,
2 pieces
Part no.
23130-413
23130-405
23130-407
23130-418
23130-081
23130-082
1.17
19" swing frame
쮿 Can accommodate 19" chassis and 19" subracks
2
쮿 For full height or partial-height mounting
쮿 Pivot point can be selected right or left
쮿 Load-carrying capacity 150 kg
h2
h1
Delivery includes (kit)
1
ax.
Tm
Qty
1
2
2
2
1
Description
Swing frame, St, 2 mm, RAL 7021
Support bar, St, 3 mm, RAL 7021
Square lock, 8 mm, incl. 2 keys
120° hinge
Assembly kit
Order Information
4
3
01005055
Item
1
2
3
4
5
01005059
Swing frame stop
For cabinet height
Height h1
mm
U
900 for partial-height mounting
16
24
1400 for partial-height mounting
29
1600 for partial-height mounting
33
1800
38
2000
42
2200
47
Accessories
Swing frame stop max. swing angle 120°, St,
zinc-plated, 1 piece
Security lock to replace the square lock,
PU 1 lock incl. 2 keys
Spare key for security lock, 1 piece
Height h2
U
12
21
25
30
34
39
43
Part no.
21130-740
21130-741
21130-742
21130-743
21130-744
21130-745
21130-746
23130-158
60113-267
60220-003
Note
쮿 19" swing frames can be assembled:
– Directly on the cabinet frame
– In 50 mm increments by aid of depth members (depthadjustable)
쮿 For partial-height mounting, depth members are necessary,
see page 1.24
01005061
Security lock
41001517
1.18
19" panel/slide mount with universal pitch (EIA)
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
010041120 1004131
Standard assembly dimension xr = xf = 50 mm
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
RAL 7035 or RAL 7021
Assembly kit, incl. GND/earthing
Order Information
9,6
42,5
Item
1
01005088
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
Partialheight
29
1295
23130-032 23130-022
mounting
Partialheight
33
1495
23130-033 23130-023
mounting
1800
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
쮿 For 19" partial-height mounting depth members are necessary
쮿 Metric panel/slide mounts available on request
19" assembly kit, M6
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.19
Slide rails
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 Wide support surface (48 mm)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Order Information
Static load carrying capacity 25 kg
For cabinet depth
D
mm
600
600
800
800
xf
c
Length L Qty/PU
mm
50
50
50
50
mm
500
500
700
700
mm
456
456
656
656
2
10
2
10
Part no.
23130-096
23130-101
23130-097
23130-102
01005086
Order Information
Static load carrying capacity 100 kg
For cabinet depth
D
mm
600
600
800
800
c
Length L Qty/PU
mm
50
50
50
50
mm
500
500
700
700
mm
458
458
658
658
2
10
2
10
Part no.
23130-118
23130-123
23130-119
23130-124
01004058
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
D
c
xf
c - 130
1.20
xf
01004130
쮿 Static load-carrying capacity 75 kg
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
Item
1
Qty
1
2
1
xr
01004066
Description
c
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
D
d
Order Information
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
xf
w
쮿 Cable ducting with cable ties, see page 1.25
쮿 Other sizes, see ServicePLUS, page 1.49
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
1.21
19'' telescopic shelf, 30 kg
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50 500 22130-343
800
417 x 682
50 700 22130-345
GND/earthing for telescopic 19" shelf PU 1 kit,
for VARISTAR
xf
d
Full depth
RAL 7021
Part no.
21130-343
21130-345
23130-140
Note
01004069
Order Information
Shortened depth
Shortened by 100 mm
w
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50 500 22130-342
800
417 x 582
50 700 22130-344
for VARISTAR
RAL 7021
Part no.
21130-342
21130-344
23130-140
Note
D
c
xr
W
xf
d
c = max. pitch of the 19" panel/slide mounts
1.22
01004070
19'' telescopic shelf, 70 kg
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
Full depth
W
쮿 2 versions
– Full depth
Delivery comprises
xr
w
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 682
50 700 22130-355
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
for VARISTAR
xf
d
Order Information
01004069
c = max. pitch for 19" panel/slidemounts
쮿 Please order T-bar lock (item 4) separately
w
Order Information
21130-355
23130-092
23130-140
Shortened by 100 mm
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 582
50 700 22130-354
for VARISTAR
d
c
Part no.
21130-353
Note
W
xr
Shortened depth
RAL 7021
RAL 7021
Part no.
21130-352
21130-354
23130-092
23130-140
Note
xf
01004070
1.23
Depth member
쮿 For fitting shortened 19" panel/slide mounts and mounting
plates
쮿 Cable ducting by means of cable ties and cable eye
50
Delivery comprises
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
Item
1
2
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
L
Description
010041260 1004079
For cabinet depth
mm
Depth member
600
Depth member
800
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-081
23130-082
21101-151
21101-150
coa43697
Cable eye
C-profile for the cabinet depth
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
,5 x
Ø6
15
- 11
L
50
Part no.
23130-086
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
29,5
L
50
31,5
For cabinet depth
Length L
mm
mm
600
460
800
660
Accessories
Cable retention rail for C-rail Width 75 mm, length 39.5
mm, PU 5 piece
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Slide nut for C-profile, PU 10 piece
쮿 Cable ties and Velcro for cable retention rail see page 1.25
75
01504054
1.24
C-profile
01004132
01006071
C-profile for cabinet width
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
600
550
800
750
Accessories
length 39.5 mm, PU 5 pieces
Slide nut for C-profile, PU 10 pieces
Part no.
23130-333
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable ties, Velcro
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
1.25
Cabinets – Varistar Elektronics ServicePLUS
configuration
Components can be varied and combined
freely
쮿 Configuration tables from page 1.27
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drilling, cut-outs and special colours for
쮿 Download CAD data and send back with modifications
solution
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power supply),
function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
쮿 Further information: www.varistar.co.uk
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
1.26
VARISTAR IP 20 ServicePLUS: configuration and assembly
쮿 Dimensions:
– Height: 29 ... 47 U (1400 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 300, 600 and 800 mm
Page
쮿 2 colour combinations:
– Frame and covers in black grey (RAL 7021)
– Frame, top cover and base in black grey (RAL 7021);
Side panel, door and rear panel in light grey (RAL 7035)
Frames, side-by-side
mounting kits, adjustable
feet, castors
1.28
Side panels, rear panels
1.29
Decorative frames, glazed
1.30
doors
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all
subsequent configuration pages that apply to these dimensions
(see example below)
쮿 The cabinet is assembled by us and
Steel doors
1.31
Double doors
1.32
Flat top covers, lifting
eyes
1.33
Flat top cover assemblies
1.34
with cut-out zones
Fan top covers
1.35
Bases/plinths
1.36
Connecting plates for
short doors/rear panels
1.37
Interior configuration for IP 20 and
IP 55
1.44
ETSI panel/slide mounts
1.45
Swing frames
1.46
Mounting plate, stationary
1.47
shelves, 75 kg
01004077
Example configuration (here: row 10)
Qty
1
1
2
1
1
1
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
Side panel with quick-release fastener, RAL 7021, PU 2 pieces
Safety lock for side panel, PU 4 pieces
Rear panel, screw-fixed, RAL 7021, 1 piece
Glazed door with single point locking, RAL 7021, IP 20, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
21130-051/05
23130-132/05
21130-069/05
21130-129/05
23130-079/05
Telescopic shelves, 70 kg
1.48
19" shelves 1 U, fixed
75 kg, telescopic 30 kg
1.49
19" telescopic shelf, 2 U,
70 kg
1.50
Slide rails, depth
members
1.51
Cable ductings
1.52
Cable ties, Velcro
1.53
1.27
VARISTAR IP 20
Frames, side-by-side mounting kits, adjustable feet, castors
Order Information
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
Side-by-side
mounting kit
IP 20
Side-by-side
mounting kit
IP 55
(with gasketing)
Adjustable feet
Castors
With 2 jacking
feet
With adjustable
feet
Completely in RAL 7021
(black grey)
01004078
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004117
01004081
01004082
01004156
for the frame,
for the frame,
for the frame,
side-by-side
side-by-side
static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: mounting bracket mounting bracket
carrying capacity: carrying capacity: carrying capacity:
(4 pieces), St,
(4 pieces), St;
800 kg,
400 kg,
400 kg,
400 kg,
1000 kg,
RAL 7021, incl.
St, 1.5 mm, zinc- St, 1.5 mm, zinc- RAL 7021, not in
cannot be used
cannot be used
cannot be used
gasketing to
combination with
plated, with
plated, with
with base/plinth with base/plinth with base/plinth
cover the gap
decorative frame
central GND/
central GND/
between two
earthing point;
earthing point;
racks; not in
please order
please order
combination with
adjustable feet or adjustable feet or
decorative frame
castors
castors
separately
separately
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
supplied loose
RAL 7021
RAL 7021
RAL 7021
20130-005
20130-055
20130-006
20130-056
20130-009
20130-059
20130-010
20130-013
20130-060
20130-063
20130-014
20130-064
20130-015
20130-017
20130-065
20130-018
20130-068
20130-019
20130-022
20130-069
20130-072
20130-023
20130-073
20130-026
20130-027
20130-077
20130-028
20130-078
20130-032
20130-082
supplied loose
assembled
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-061
23130-062
23130-062
23130-079
23130-079
23130-077
23130-077
23130-078
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.28
RAL 7021
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-061
23130-062
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-061
23130-062
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-061
23130-062
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-061
23130-062
42 2000 600
300
20130-017
23130-061
23130-062
42 2000 600
600
20130-018
20130-068
23130-061
23130-062
42 2000 600
800
20130-019
20130-069
42 2000 800
600
20130-022
20130-072
23130-061
23130-062
42 2000 800
800
20130-023
20130-073
47 2200 600
300
20130-026
23130-061
23130-062
47 2200 600
600
20130-027
20130-077
23130-061
23130-062
47 2200 600
800
20130-028
20130-078
47 2200 800
800
20130-032
20130-082
23130-061
23130-062
Other dimensions and configurations online (with basket) at www.schroff.biz/conf
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
VARISTAR IP 20
Order Information
Side panel
With quick
release fastener
Screw-fixed side
panel
Lock
Rear panel
With quick
release fastener
Screw-fixed rear
panel
Lock
(black grey)
01004084
7035 (light grey)/
01004072
for quick-release
St, 1 mm, incl.
fasteners of one
GND/earthing,
side panel;
please order lock
4 locks sufficient
separately
for 2 side panels
01004083
St, 1 mm, incl.
GND/earthing
01004087
01004072
for quick-release
St, 1 mm, incl.
fasteners of rear
GND/earthing,
panel
please order lock
separately
01004085
St, 1 mm, incl.
GND/earthing
Cabinet dimensions
Height
No. U
mm
Width
Depth
PU 2 pieces
PU 4 pieces
PU 2 pieces
1 piece
PU 2 pieces
1 piece
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-043
21130-003
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
21130-044
21130-045
21130-046
21130-047
21130-048
21130-047
23130-132
23130-132
23130-132
21130-004
21130-005
21130-006
21130-007
RAL 7021
21130-093
23130-133
21130-063
21130-095
23130-133
21130-065
21130-097
23130-133
21130-067
23130-132
21130-008
21130-007
21130-098
23130-133
21130-068
21130-049
23130-132
21130-009
21130-099
23130-133
21130-069
21130-050
21130-051
23130-132
21130-010
21130-011
21130-099
23130-133
21130-069
21130-100
23130-133
21130-070
21130-101
23130-133
21130-071
21130-101
23130-133
21130-071
21130-102
23130-133
21130-072
21130-050
21130-051
21130-054
21130-055
21130-056
21130-056
23130-132
23130-132
23130-132
23130-132
21130-010
21130-011
21130-014
21130-015
21130-016
21130-016
RAL 7035
RAL 7035
22130-043
22130-003
22130-044
22130-045
22130-046
22130-047
22130-048
22130-047
23130-132
23130-132
23130-132
22130-004
22130-005
22130-006
22130-007
RAL 7035
RAL 7035
22130-093
23130-133
22130-063
22130-095
23130-133
22130-065
22130-097
23130-133
22130-067
23130-132
22130-008
22130-007
22130-098
23130-133
22130-068
22130-049
23130-132
22130-009
22130-099
23130-133
22130-069
22130-050
22130-051
23130-132
22130-010
22130-011
22130-099
23130-133
22130-069
22130-100
23130-133
22130-070
22130-101
23130-133
22130-071
22130-101
23130-133
22130-071
22130-102
23130-133
22130-072
22130-050
22130-051
22130-054
22130-055
22130-056
22130-056
23130-132
23130-132
23130-132
23130-132
22130-010
22130-011
22130-014
22130-015
22130-016
22130-016
1.29
VARISTAR IP 20
Decorative frames, glazed doors
Order Information
Deco frame
Deco frame
Glazed door
Adapter bracket
Single point
locking
Glazed door
Lever handle
3-point locking
DIN profile half
cylinder
(black grey)
01004086
7035 (light grey)/
Al, 19" plane
integrated,
front open, incl.
GND/earthing,
no door can be
fitted
01004160
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
01004088
St, 1.5 mm,
Sekurit
glass 6 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
01004147
with push button
for doors with
single point
locking
01004091
St, 1.5 mm,
Sekurit
glass, 6 mm,
opening angle
180°, lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.30
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
PU 1 pair
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-232
23130-221
21130-123
23130-067
21130-183
25127-995
21130-233
23130-222
21130-125
23130-067
21130-185
25127-995
21130-234
23130-223
21130-127
23130-067
21130-187
25127-995
RAL 7021
21130-128
23130-067
21130-188
25127-995
21130-235
23130-224
21130-129
23130-067
21130-189
25127-995
21130-235
23130-224
21130-129
23130-067
21130-189
25127-995
21130-130
23130-067
21130-190
25127-995
21130-236
23130-225
21130-131
23130-067
21130-191
25127-995
21130-236
23130-225
21130-131
23130-067
21130-191
25127-995
21130-132
23130-067
21130-192
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-232
23130-231
22130-123
23130-067
22130-183
25127-995
22130-233
23130-232
22130-125
23130-067
22130-185
25127-995
22130-234
23130-233
22130-127
23130-067
22130-187
25127-995
RAL 7035
22130-128
23130-067
22130-188
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-130
23130-067
22130-190
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-132
23130-067
22130-192
25127-995
VARISTAR IP 20
Steel doors
Order Information
Steel door, single point locking
Plain
Solid, inner
surface with
mounting frame
Perforated
Lever handle
Steel door
3-point locking
DIN profile half
cylinder
(black grey)
01004089
7035 (light grey)/
St, 1 mm,
opening angle
180°, key,
incl. GND/
earthing
01008067
St, 1.5 mm,
opening angle
180°, lock cover
incl. GND/
earthing,
designed to carry
extensive cutouts and
assemblies
01004090
St, 1.5 mm,
opening angle
180°, key,
incl. GND/
earthing
01004147
with push button
for doors with
single point
locking
01008085
St, 1.5 mm,
opening angle
180°, inner side
with mounting
frame,
lever handle with
built-in push
button, incl.
GND/earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-108
21130-568
21130-138
23130-067
21130-153
25127-995
21130-110
21130-570
21130-140
23130-067
21130-155
25127-995
21130-112
21130-572
21130-142
23130-067
21130-157
25127-995
21130-113
21130-573
21130-143
23130-067
21130-158
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
25127-995
21130-115
21130-575
21130-145
23130-067
21130-160
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
25127-995
21130-117
21130-577
21130-147
23130-067
21130-162
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-108
22130-568
22130-138
23130-067
22130-153
25127-995
22130-110
22130-570
22130-140
23130-067
22130-155
25127-995
22130-112
22130-572
22130-142
23130-067
22130-157
25127-995
22130-113
22130-573
22130-143
23130-067
22130-158
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
25127-995
22130-115
22130-575
22130-145
23130-067
22130-160
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
25127-995
22130-117
22130-577
22130-147
23130-067
22130-162
25127-995
RAL 7021
RAL 7035
1.31
VARISTAR IP 20
Double doors
Order Information
Double door, 3-point locking
Glazed
Perforated
DIN profile half
cylinder
Plain
(black grey)
01005065
7035 (light grey)/
01005066
01005064
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Securit glass,
lever handle with lever handle with
6 mm,
push button, incl. push button, incl.
opening angle
GND/earthing
GND/earthing
180°,
lever handle with
push button, incl.
GND/earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-454
21130-213
21130-486
25127-995
21130-456
21130-215
21130-488
25127-995
21130-458
21130-217
21130-490
25127-995
21130-459
21130-218
21130-491
25127-995
21130-460
21130-219
21130-492
25127-995
21130-460
21130-219
21130-492
25127-995
21130-461
21130-220
21130-493
25127-995
21130-462
21130-221
21130-494
25127-995
21130-462
21130-221
21130-494
25127-995
21130-463
21130-222
21130-495
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-454
22130-213
22130-486
25127-995
22130-456
22130-215
22130-488
25127-995
22130-458
22130-217
22130-490
25127-995
22130-459
22130-218
22130-491
25127-995
22130-460
22130-219
22130-492
25127-995
22130-460
22130-219
22130-492
25127-995
22130-461
22130-220
22130-493
25127-995
22130-462
22130-221
22130-494
25127-995
22130-462
22130-221
22130-494
25127-995
22130-463
22130-222
22130-495
25127-995
VARISTAR IP 20
Flat top covers, lifting eyes
Order Information
Flat top cover
Plain flush
top cover
Perforated
Spacer
Lifting eye
Spacer
Lifting eye
10
(black grey)
M12
01004096
St, 1.5 mm,
incl. GND/
earthing
7035 (light grey)/
01004097
M12
01004100
01004099
01004100
St, 1.5 mm,
fully perforated,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
St, zinc-plated,
for raising a
top cover by
10 mm
for raised
flat top cover,
application and
in accordance
with DIN 582
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-242
21130-262
21130-243
21130-263
21130-242
21130-243
21130-262
21130-263
21130-242
21130-262
21130-243
21130-246
21130-263
21130-266
23130-072
23130-068
23130-085
21130-241
21130-261
23130-072
23130-068
23130-085
21130-242
21130-243
21130-262
21130-263
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-246
21130-266
21130-247
21130-241
21130-267
21130-261
21130-242
21130-262
21130-243
21130-247
21130-263
21130-267
RAL 7021
RAL 7021
21130-242
21130-262
21130-243
21130-263
21130-242
21130-243
21130-262
21130-263
21130-242
21130-262
21130-243
21130-246
21130-263
21130-266
23130-072
23130-068
23130-085
21130-241
21130-261
23130-072
23130-068
23130-085
21130-242
21130-243
21130-262
21130-263
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-246
21130-266
21130-247
21130-241
21130-267
21130-261
21130-242
21130-262
21130-243
21130-247
21130-263
21130-267
1.33
VARISTAR IP 20
Flat top cover assemblies with cut-out zones
Order Information
Flat top cover
with cut-out
zones
Top cover assemblies
Brush strip
Fan insert
Thermostat
Top cover plate,
perforated
Edge protection
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
M12
300 mm
01004098
7035 (light grey)/
01006092
01004102
W
01108052
D
01009056
230 VAC,
nylon, black, one
with mains cable St, 1.5 mm, 6 mm
St, 1.5 mm,
hole diameter,
brush strip covers with three fans,
230 VAC
incl. GND/
3
incl. GND/
(SCHUKO/UTE
earthing, number a lateral cut-out,
410 m /h,
earthing
two brush strips
plug/
of cut-outs and
completely
cover a center wired, connecting IEC 60320 C13
dimension
cut-out
socket),
drawings
cable IEC 320
adjustment range
see page
0 ... 60°C
1.9
41003065
01004100
PVC, 3 m,
black, for open
cut-out zones
for top cover,
applications
and load in
accordance with
DIN 582
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.34
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
enclosed loose
assembled
RAL 7021
RAL 7021
21130-252
21130-253
21130-252
21130-253
21130-252
21130-253
21130-256
RAL 7021
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-252
21130-253
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-256
21130-257
21130-252
21130-253
21130-257
RAL 7021
21130-252
21130-253
21130-252
21130-253
21130-252
21130-253
21130-256
RAL 7021
RAL 7021
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-252
21130-253
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-256
21130-257
21130-252
21130-253
21130-257
VARISTAR IP 20
Fan top covers
Order Information
Fan top cover
Top cover for
6 fans
Replacement
fan for fan top
Thermostat
Speed control
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
300 mm
01005060
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
kta44844
01108052
01105055
01005085
fully wired,
for fan top cover,
St, 1.5 mm, raised fan with grille for with mains cable
90 ... 264 VAC,
applications and
top assembly,
230 VAC
cover,
static load230 VAC,
(SCHUKO/UTE input SCHUKO/UTE
3 axial fans,
carrying capacity
plug/
plug,
230 VAC,
38x119x119 mm,
3
in accordance
incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 outlet IEC 60320 C1
with DIN 582
socket),
3 socket; external
ND/earthing,
h
adjustment range NTC sensor 1.5 m
connecting cable
0 ... 60°C
2.5 m, SCHUKO/
IEC60320 C12
plug
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
21130-400
21130-401
21130-400
21130-401
21130-400
21130-401
21130-402
23130-165
20118-750
60715-005
23130-090
21130-400
21130-401
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
21130-402
21130-403
21130-400
21130-401
21130-403
RAL 7021
21130-400
21130-401
21130-400
21130-401
21130-400
21130-401
21130-402
23130-165
20118-750
60715-005
23130-090
21130-400
21130-401
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
21130-402
21130-403
21130-400
21130-401
21130-403
1.35
VARISTAR IP 20
Bases/plinths
Order Information
Base plate
Base plate, multipiece
Brush strip
Base/plinth
Dust filter set
Cover plate
Base/plinth,
ventilated
Side covers
Base/plinth,
mobile
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1.36
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004105
01004059
01004106
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm, trim, St,
1.5 mm, static
load-carrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
nylon, black
1 piece
1 piece
1 piece
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-074
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
dimension
drawings
see page 1.9
1 piece
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-074
23130-135
23130-075
23130-136
23130-194
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-074
23130-075
23130-076
23130-187
23130-006
23130-134
23130-135
23130-136
23130-194
RAL 7021
RAL 7021
RAL 7021
RAL 7021
23130-002
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-002
23130-006
23130-074
23130-075
23130-076
23130-187
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-208
23130-170
23130-209
23130-169
23130-166
23130-212
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-170
23130-213
23130-166
23130-169
23130-208
23130-170
23130-209
23130-170
23130-213
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-074
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-166
23130-169
23130-170
23130-208
23130-209
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-169
23130-212
23130-170
23130-166
23130-213
23130-169
23130-208
23130-170
23130-170
23130-209
23130-213
VARISTAR IP 20
Connecting plates for short doors/rear panels
Order Information
Dimensioning
connecting plate
door/rear panel
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01004066 01004056
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
RAL 7021
RAL 7021
21130-472
21130-473
21130-478
21130-479
rack shelves,
19" shelves,
slide rails,
cable ducting
23130-164
23130-164
from page
1.44
from page
1.44
RAL 7035
RAL 7035
22130-472
22130-478
23130-164
22130-473
22130-479
23130-164
1.37
configuration
Simple. Fast. To the ideal product.
freely
쮿 Configuration tables from page 1.39
assembly
modification
off-the-shelf products
solution
Simple. Fast. From one source.
supply), function test
academy
reports
1.38
lifecycle
replacement parts
ELECTRONICS PROTECTION
VARISTAR IP 55 ServicePLUS: configuration and assembly
쮿 Dimensions:
Page
(see example below)
feet, castors
1.40
Side panels, rear panels,
doors, top covers
1.41
eyes
1.42
1.43
IP 55
1.44
1.45
Swing frames
1.46
Mounting plates,
stationary shelves, 75 kg
1.47
1.48
1.49
19" telescopic shelves,
2 U, 70 kg
1.50
Slide rails, depth
members
1.51
Cable ductings
1.52
Cable ties, Velcro
1.53
01004077
Qty
1
1
1
1
1
1
Description
IP 55 gasketing kit, 1 piece
Side panel, screw-fixed, RAL 7021, PU 2 pieces
Glazed door with 3-point locking, RAL 7021, IP 55, 1 piece
SCHROFF.PENTAIR.CO.UK
Part no.
20130-019/05
23130-064/05
21130-011/05
21130-069/05
21130-189/05
23130-079/05
1.39
VARISTAR IP 55
Order Information
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
Gasket kit
IP 55
Side-by-side
mounting kit
IP 55
(with gasketing)
Adjustable feet
Castors
with 2 jacking feet
with adjustable
feet
(black grey)
01004078
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004157
01004120
01004081
01004082
01004158
for the frame,
for the frame,
for the frame,
side-to-side
seals are glued to
static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: the frame, so that mounting bracket
(4 pieces), St,
all cladding parts
800 kg,
400 kg,
400 kg,
400 kg,
1000 kg,
RAL 7021, incl.
conform to
St, 1.5 mm, zinc- St, 1.5 mm, zinccannot be used
cannot be used
cannot be used
gasketing to
protection type
plated, with
plated, with
cover the gap
IP 55
central GND/
central GND/
between two
earthing
earthing
racks; cannot be
point; please
point; please
used with
order adjustable order adjustable
decorative frame
feet or castors
feet or castors
separately
separately
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
RAL 7021
RAL 7021
20130-005
20130-055
20130-006
20130-056
20130-009
20130-059
20130-010
20130-013
20130-060
20130-063
20130-014
20130-064
20130-015
20130-017
20130-065
20130-018
20130-068
20130-019
20130-022
20130-069
20130-072
20130-023
20130-073
20130-026
20130-027
20130-077
20130-028
20130-078
20130-032
20130-082
assembled
supplied loose
assembled
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-064
23130-062
23130-062
23130-079
23130-079
23130-077
23130-077
23130-078
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.40
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-064
23130-062
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-064
23130-062
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-064
23130-062
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-064
23130-062
42 2000 600
300
20130-017
23130-064
23130-062
42 2000 600
600
20130-018
20130-068
23130-064
23130-062
42 2000 600
800
20130-019
20130-069
42 2000 800
600
20130-022
20130-072
23130-064
23130-062
42 2000 800
800
20130-023
20130-073
47 2200 600
300
20130-026
23130-064
23130-062
47 2200 600
600
20130-027
20130-077
23130-064
23130-062
47 2200 600
800
20130-028
20130-078
47 2200 800
800
20130-032
20130-082
23130-064
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
VARISTAR IP 55
Side panels, rear panels, doors, top covers
Order Information
Screw-fixed side
panel
Screw-fixed rear
panel
Glazed door
3-point locking
Steel door
3-point locking
DIN profile half
cylinder
Plain flush top cover
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
Cabinet dimensions
Height
No. U
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load
in compliance
with DIN 582
Depth
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-063
21130-183
21130-153
25127-995
21130-065
21130-185
21130-155
25127-995
21130-067
21130-187
21130-157
25127-995
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
01004148
for lever handle,
common locking
Width
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
01008085
St, 1.5 mm,
opening angle
180°,
inner side with
mounting frame,
lever handle
with built-in
push button,
incl. GND/
earthing
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
21130-003
21130-004
21130-005
21130-006
21130-007
21130-008
21130-007
21130-009
21130-010
21130-011
21130-010
21130-011
21130-014
21130-015
21130-016
21130-016
RAL 7035
22130-003
22130-004
22130-005
22130-006
22130-007
22130-008
22130-007
22130-009
22130-010
22130-011
22130-010
22130-011
22130-014
22130-015
22130-016
22130-016
RAL 7021
21130-242
21130-243
21130-242
21130-243
21130-242
23130-072
23130-072
23130-072
21130-068
21130-188
21130-158
25127-995
21130-243
21130-246
21130-069
21130-189
21130-159
25127-995
21130-241
23130-072
21130-242
21130-243
23130-072
21130-069
21130-189
21130-159
25127-995
21130-070
21130-190
21130-160
25127-995
21130-071
21130-191
21130-161
25127-995
21130-071
21130-191
21130-161
25127-995
21130-072
21130-192
21130-162
25127-995
RAL 7035
RAL 7035
RAL 7035
21130-246
21130-247
21130-241
21130-242
21130-243
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
22130-063
22130-183
22130-153
25127-995
22130-065
22130-185
22130-155
25127-995
22130-067
22130-187
22130-157
25127-995
21130-242
21130-243
21130-242
21130-243
21130-242
23130-072
23130-072
23130-072
22130-068
22130-188
22130-158
25127-995
21130-243
21130-246
22130-069
22130-189
22130-159
25127-995
21130-241
23130-072
21130-242
21130-243
23130-072
22130-069
22130-189
22130-159
25127-995
22130-070
22130-190
22130-160
25127-995
22130-071
22130-191
22130-161
25127-995
22130-071
22130-191
22130-161
25127-995
22130-072
22130-192
22130-162
25127-995
21130-246
21130-247
21130-241
21130-242
21130-243
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
Part number in bold face type: ready for despatch within 2 working days
Part number in normal type: ready for despatch within 10 working days
1.41
VARISTAR IP 55
Order Information
Base plate
Cover plate
Seal IP 55
Base plate,
one-piece,
EMC, IP 55
Base/plinth
Base/plinth,
ventilated
Side cover
Base/plinth,
mobile
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1.42
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004106
01004073
for base plate
with cover
01004051
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimension
drawings see
page 1.9
1 piece
St, 1.5 mm,
please order
gasket IP55
separately
1 piece
1 piece
1 piece
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
AlZn
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-076
23130-073
23130-076
23130-073
23130-076
23130-073
23130-036
23130-073
23130-073
23130-076
23130-073
23130-036
23130-073
23130-073
23130-076
23130-073
23130-006
23130-076
23130-073
RAL 7021
RAL 7021
23130-002
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-002
23130-006
23130-076
23130-073
23130-076
23130-073
23130-076
23130-073
21130-281
21130-282
21130-281
21130-282
21130-281
21130-282
21130-283
21130-285
21130-281
21130-282
21130-283
21130-284
21130-285
21130-281
21130-282
23130-187
23130-194
23130-187
23130-187
RAL 7021
21130-282
21130-281
21130-282
21130-281
23130-073
23130-073
21130-285
23130-076
23130-073
21130-281
21130-282
23130-036
23130-073
23130-073
23130-073
23130-194
23130-187
AlZn
21130-281
23130-076
23130-187
23130-194
23130-036
23130-073
23130-187
21130-284
21130-282
21130-283
23130-076
23130-187
21130-283
21130-284
21130-285
21130-281
21130-282
21130-284
23130-187
23130-187
23130-187
23130-194
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-208
23130-170
23130-209
23130-169
23130-166
23130-212
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-170
23130-213
23130-166
23130-169
23130-208
23130-170
23130-209
23130-170
23130-213
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-187
23130-166
23130-187
23130-169
23130-170
23130-208
23130-209
23130-194
23130-187
23130-187
23130-194
23130-169
23130-212
23130-170
23130-166
23130-213
23130-169
23130-208
23130-170
23130-170
23130-209
23130-213
VARISTAR IP 55
Order Information
Dimensioning
connecting plate
door/rear panel
Connecting plate
Completely in
RAL 7021
(black grey)
01005071
Colour combination
RAL 7035 (light
grey)/
RAL 7021 (black
grey)
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
01005072
St, 1 mm, can
door and rear
also be fitted in
panel must be
upper part,
selected 400 mm
height 400 mm,
shorter than the
cabinet height; with assembly kit
cannot be used
with double door
1 piece
assembled
RAL 7021
21130-504
21130-505
RAL 7035
22130-504
22130-505
1.43
Interior mounting
Order Information
19" panel/slide mounts EIA
Painted RAL 7021
AIZn
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
U height identification
for 19" panel/
slide mount
c
D
Dimension
Standard fitting
xf = distance
from front
c = pitch of
19" panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
reduced-width adapter bracket
required for 800 mm width;
depth members are required for
00505050
sc128
paper strip, white,
assembly kit:
serial numbered item 1: screws,
from 1 ... 47 H item 2: cage nuts,
item 3: washers
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.44
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
AIZn
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AlZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
AlZn
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
Interior mounting
Order Information
Dimensions
Panel/slide
mount
(black grey)
coa43693
7035 (light grey)/
01004114
St, 2 mm,
in accordance
Al-Zn finish,
with ETS 300119suitable only for
3 and
IEC 60917-211; Slim-Line frame;
shelves available
SU = 25 mm
on request
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
Height
SU
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
AIZn
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 1 pair
assembled
23130-052
23130-053
23130-054
23130-054
23130-055
23130-055
23130-055
23130-056
23130-056
23130-056
AlZn
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
23130-052
23130-053
23130-054
23130-054
23130-055
23130-055
23130-055
23130-056
23130-056
23130-056
1.45
Interior mounting
Swing frames for cabinet width 600 mm
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Spare key
01005061
01015060
St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg,
120° hinge, square locks
incl. 2 keys
(Dimension drawings link)
St; for safety reasons a swing
frame stop is recommended
for swing frame, instead of
square lock, incl. 2 keys
01015059
Usable
height
U
Width
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Swing frames for cabinet width 800 mm
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
1.46
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
(item 2) and cutout for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
PU 1 kit
assembled
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
Usable
height
U
mm
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
Width
SCHROFF PRODUCT CATALOG E 08/2017
Interior mounting
Mounting plate, stationary shelves, 75 kg
Order Information
Mounting plate
Full height
Height 1200 mm
Stationary shelf
Full depth
Strengthening
brackets
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01008052
7035 (light grey)/
01008053
St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear
mounted); strengthening bracket
increases static load-carrying
capacity; please order separately
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
01004142
01004142
St, 1.5 mm, static St, 1.5 mm, static
load-carrying
load-carrying
cap. 75 kg, 1 U,
capacity 75 kg,
depth 479 mm,
1 U, incl. GND/
incl. GND/
earthing
earthing,
for recessed
installation order
depth members
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 2 pieces
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
assembled
assembled
assembled
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
23130-413
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
21130-333
21130-332
23130-081
21130-335
21130-334
23130-082
21130-323
21130-322
23130-081
21130-325
21130-335
21130-324
21130-334
23130-082
23130-082
RAL 7035
RAL 7035
AlZn
22130-323
22130-322
23130-081
22130-325
22130-324
23130-082
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-323
22130-322
23130-081
22130-325
22130-333
22130-324
22130-332
23130-082
23130-081
23130-413
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
22130-333
22130-332
23130-081
22130-335
22130-324
23130-082
22130-323
22130-322
23130-081
22130-325
22130-335
22130-324
22130-334
23130-082
23130-082
1.47
Interior mounting
Order Information
Telescopic shelf, 2 U
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
7035 (light grey)/
01004145
load-carrying
load-carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.48
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-373
21130-354
21130-372
23130-274
23130-092
23130-140
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
21130-373
21130-372
21130-375
21130-374
21130-353
21130-352
21130-355
21130-375
21130-354
21130-374
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
AlZn
RAL 7021
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-373
22130-354
22130-372
23130-274
23130-092
23130-140
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-373
22130-372
22130-375
22130-374
22130-353
22130-352
22130-355
22130-375
22130-354
22130-374
Interior mounting
19" shelves 1 U, stationary 75 kg, telescopic 30 kg
Order Information
19'' stationary shelf,
1 U, 75 kg
Full depth
Shortened by
100 mm
W
xf
(black grey)
01004146
7035 (light grey)/
Full depth
1 U, 30 kg
Shortened by
GND/earthing
100 mm
c
D
Dimension
Standard fitting
01004118
01004119
01004123
01004122
St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static
xf = distance
load-carrying
load-carrying
load-carrying
load-carrying
from front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
GND/earthing kit GND/earthing kit
W = cabinet width
separately
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
1.49
Interior mounting
19" telescopic shelf, 2 U, 70 kg
Order Information
Dimension
Standard fitting
Telescopic shelf, 2 U, 70 kg
W
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004123
1.50
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004122
01004125
05904052
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order, T-bar lock
and earthing kit
separately
1 piece
to lock the
telescopic shelf
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
xf
mm
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
22130-353
22130-355
22130-352
22130-354
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
GND/earthing
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order, T-bar lock
and earthing kit
separately
1 piece
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
T-bar lock
xf
(black grey)
7035 (light grey)/
Shortened by
100 mm
c
D
Full depth
for telescopic
shelf
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-352
23130-092
23130-140
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
23130-092
23130-140
21130-353
21130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
21130-353
21130-352
21130-355
21130-354
21130-353
21130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-352
23130-092
23130-140
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
23130-092
23130-140
22130-353
22130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
22130-353
22130-352
22130-355
22130-354
22130-353
22130-352
Interior mounting
Slide rails, depth members
Order Information
Slide rail
25 kg
Depth member,
3 rows
W
xf
(black grey)
01004146
7035 (light grey)/
Short slide rail
100 kg
c
D
Dimension
Standard fitting
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance
finish AlZn, static zinc-plated, static finish AlZn, static
from front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
23130-097
23130-096
23130-119
23130-118
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
23130-097
23130-096
23130-119
23130-118
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-094
23130-081
23130-082
23130-081
23130-096
23130-118
23130-094
23130-099
23130-096
23130-116
23130-118
23130-094
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-099
23130-116
23130-094
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
AlZn
zinc-plated
AlZn
23130-096
23130-118
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
AlZn
23130-081
23130-082
23130-081
23130-082
23130-094
23130-081
23130-082
23130-081
23130-096
23130-118
23130-094
23130-099
23130-096
23130-116
23130-118
23130-094
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-099
23130-116
23130-094
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
23130-094
23130-081
23130-082
23130-081
23130-082
1.51
Cabinets – Varistar Elektronics ServicePLUS
Interior mounting
Cable ductings
Order Information
Cable ducting with C-profile
C-rail for
cabinet depth
C-rail for
cabinet width
Slide nut
Cable shell
Cable support for
C-rail
(black grey)
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
vnt009
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.24
01006110
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.52
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 5 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-087
AlZn
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
AlZn
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
Interior mounting
Cable ties, Velcro
Order Information
Cable tie
Velcro
General
components
Mechanics
Completely in RAL 7021
(black grey)
from page
3.2
01005078
7035 (light grey)/
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.25
01005079
black,
length 300 mm,
further
dimensions
see page
1.25
Electrics
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.29
Power
distribution
from page
3.50
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Climate control
from page
4.0
1.53
VARISTAR EMCMain Catalogue
Cabinets – VARISTAR EMC
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
01008001
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
41003017
Cooling with perforated HF door with high air
throughput (78 % open area)
01007004
Cooling with HF fan top cover for up to 6 fans
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
01007005
Cable entry in rear section of base plate;
sealing by means of sliding plates
01007003
Cable entry by means of HF connection plate
Appendix . . . . . 12
1.54
Overview . . . . . . 1.54
VARISTAR EMC Main Catalogue
Best performance in HF shielding
쮿 Shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz
(tested to IEC 61587-3)
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
쮿 Cable entry to front or rear or via base
쮿 Cooling with perforated front door or with fan top cover
쮿 Standard cabinets available from stock or individually configurable with appropriate accessory range
VARISTAR EMC,
base plate without
cable ducting . . . . 1.55
VARISTAR EMC
with perforated
door . . . . . . . . . . . . . 1.57
VARISTAR EMC
with fan top cover 1.58
VARISTAR EMC
Accessories
01005017
01007017
쮿 Versions with/without
cable entry through base plate
쮿 With perforated HF front and rear
door
쮿 IP 55
쮿 Base plate with cable ducting
01007018
쮿 With fan top cover and perforated
base plate with cable entry
Base/plinth . . . . . . 1.59
19" swing
frame . . . . . . . . . . . 1.60
19" panel/slide
mount . . . . . . . . . . 1.61
19" fixing
materials kit,
M6 . . . . . . . . . . . . . . 1.61
Slide rails . . . . . . . . 1.62
19" shelves . . . . . . 1.63
Depth members . . 1.66
C horizontal rail . . 1.66
Cable tie,
Velcro . . . . . . . . . . . 1.67
ServicePLUS . . 1.68
ServicePLUS
configuration . . . . 1.69
ServicePLUS from page 1.68
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (special sizes)
www.schroff.biz/ServicePLUS
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR air/
water heat
exchanger . . . . . . . 1.224
30407004
1.55
VARISTAR EMC
VARISTA R EMCMain CataloguePart number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
쮿 Shielding 60 dB at 1 GHz, 40 dB at 3 GHz
쮿 Type of protection IP 55
쮿 Doors with 4-point locking and screw-fixed side panels
쮿 Static load-carrying capacity 400 kg (Slim-Line)
쮿 Base plate versions
– without cable ducting
– with cable ducting
Delivery comprises (assembled)
01005017
Item
1
Qty
1
2
3
4
4
1
1
5
1
6
2
7a
7b
1
1
8
2
9
1
Description
Welded basic frame, Slim-Line, St profile, RAL 7021,
with textile gasket all-around
Adjustable foot, assembled
Flat top cover, St, inner surface AlZn, outside RAL 7021
Front door, St, inner surface AlZn, outside RAL 7035,
180° hinge, 4-point locking, lever handle
Rear door, St, inner surface AlZn, outside RAL 7035,
Side panel, screw-fixed, St, inner surface AlZn,
outside RAL 7035
Base plate, one-piece, St, 1.5 mm, finish AlZn
Base plate with cable ducting, St, 1.5 mm, finish AlZn;
cable entry to rear with conductive seal, 359 mm x 60 mm
opening
19" panel/slide mount with EIA cut-outs, AlZn,
assembled at front, depth-adjustable in 25 mm
increments
GND/earthing kit, enclosed loose
Order Information
Height Height
H
U
mm
01005015
120
100
Description
Base plate without
cable entry
42
2000
600
800
entry
Castors load-carrying capacity 400 kg, PS/St,
PU 4 pieces, 2 locking, 2 non locking
Castors with integrated adjustable feet load-carrying
capacity 400 kg, PU 4 pieces
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Lifting eye for top cover PU 4 pieces
42
[dBµV]
Width W Depth
D
mm
mm
2000
600
800
Part no.
10130-020
10130-192
23130-077
23130-078
25127-995
23130-072
80
1
60
2
40
Note
쮿 For more dimensions and versions see ServicePLUS
configuration, from page 1.69
쮿 Please order base/plinth separately, see page 1.59
쮿 For assembly of shelves and slide rails another pair of panel/
slide mounts is necessary, see page 1.61
200
300
400
500
600
700
800
900
1000
[MHz]
1) Shielding without cable ducting
2) Shielding with cable ducting,
tested to IEC 61587-3,
standard dimensions of test objects 2000 x 600 x 600 mm
01007060
ServicePLUS see page 1.68
1.56
VARISTAR EMC
with perforated doors
VARISTAR EMC
쮿 Shielding 40 dB at 1 GHz (tested to IEC 61587-3)
쮿 Air throughput 78 %
Item
1
Qty
1
2
3
4
4
1
1
5
1
6
2
7
1
8
2
9
1
Description
with textile gasket all around
Front door, perforated, St, inner surface AlZn, outside
RAL 7035, 180° hinge, 4-point locking, lever handle
Rear door, perforated, St, inner surface AlZn, outside
outside RAL 7035
Base plate with cable ducting, St, 1.5 mm, finish Al-Zn;
opening
increments
Order Information
01007017
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2000
600
800
Part no.
10130-190
23130-077
23130-078
25127-995
23130-072
Note
01007019
Perforation
[dBµV]
120
100
80
60
40
200
300
400
500
600
700
800
900
1000
[MHz]
Shielding: Tested to IEC 61587-3,
standard dimensions of test object 2000 x 600 x 600 mm
01007059
1.57
VARISTAR EMC with fan top cover
VARISTA R EMC
쮿 Shielding 50 dB at 1 GHz (tested to IEC 61587-3)
쮿 Fan top cover with 3 fans (up to 6 fans can be mounted)
쮿 Perforated base plate with cable ducting
01007018
Item
1
Qty
1
2
3
4
1
4
1
5
1
6
2
7
1
8
2
9
1
Description
with conductive seal all-around
Raised top cover, St, 1.5 mm, RAL 7021; fan top cover with
3 axial fans, 230 VAC, incl. cabling and GND/
earthing; SCHUKO/UTE plug, cable length 2.5 m,
IEC 60320-C13 socket; assembly space for 3 further fans
outside RAL 7035
Base plate with cable ducting, perforated, St, 1.5 mm,
finish AlZn; cable entry to rear with conductive seal,
359 mm x 60 mm opening
increments
Order Information
01007004
Fan top cover
[dBµV]
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2000
600
800
Lifting eye for fan top PU 4 pieces
Part no.
10130-191
23130-077
23130-078
25127-995
23130-090
Note
120
100
80
60
40
200
300
400
500
600
700
800
900
1000
[MHz]
01007057
1.58
Stationary base
VARISTAR EMC
쮿 Static load-carrying capacity 1000 kg
쮿 Removable trims allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
2a
H
2b
1
2b
2a
D = cabinet depth
W
D
4
01004110
01004053
Delivery comprises (kit)
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
For cabinet width W
Front/rear trim
mm
600
perforated
600
solid
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-170
Note
쮿 Please order side trims (item 4) separately
Base/plinth, mobile
VARISTAR EMC
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
For cabinet width
mm
600
01004111
For cabinet depth
mm
800
Part no.
23130-209
01006095
1.59
19" swing frame
VARISTA R EMC
쮿 Can accommodate 19" chassis and 19" subracks
2
쮿 For full height or partial-height mounting within cabinets
쮿 Pivot point can be selected right or left
쮿 Load-carrying capacity 150 kg
h2
h1
1
Tm
ax.
Qty
1
2
2
2
1
Description
Swing frame, St, 2 mm, RAL 7021
Support bar, St, 3 mm, RAL 7021
Square lock, 8 mm, incl. 2 keys
120° hinge
Assembly kit
Order Information
4
3
01005055
Maximum mounting depth for swing frame
Cabinet
Slim-Line
Heavy-Duty
Item
1
2
3
4
5
01005059
Width 600 mm
220 mm
200 mm
For cabinet height
Height h1
mm
U
900 for partial-height mounting 16
1200 for partial-height mounting 24
1400 for partial-height mounting 29
1600 for partial-height mounting 33
1800 for partial-height mounting 38
2000
42
Swing frame stop max. swing angle 120°, St,
zinc-plated, 1 piece
Security lock to replace the square lock,
PU 1 lock incl. 2 keys
Spare key for security lock, 1 piece
Height h2
U
12
21
25
30
34
39
Part no.
21130-740
21130-741
21130-742
21130-743
21130-744
21130-745
23130-158
60113-267
60220-003
Note
Swing frame stop
쮿 19" swing frames can be assembled:
– Directly on the cabinet frame
– In 50 mm increments by aid of depth members
(depth-adjustable)
쮿 For partial-height mounting, depth members are necessary,
see page 1.66
01005061
Security lock
41001517
1.60
19" panel/slide mount with universal pitch (EIA)
VARISTAR EMC
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish
AlZn, RAL 7035 or RAL 7021
Assembly kit, incl. GND/earthing
Order Information
9,6
42,5
Item
1
01004112
01004131
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
8
395
23130-037 23130-027
12
545
23130-038 23130-028
16
745
23130-039 23130-029
Partial20
895
23130-040 23130-030
height
24
1095
23130-031 23130-021
mounting
29
1295
23130-032 23130-022
33
1495
23130-033 23130-023
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
쮿 For 19" partial-height mounting depth members are necessary
쮿 Metric panel/slide mounts available on request
Standard assembly dimension xr = xf = 50 mm
01005088
19" assembly kit, M6
VARISTAR EMC
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.61
Slide rails
VARISTA R EMC
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 Wide support surface (48 mm)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Assembly kit incl. GND/earthing
Order Information
Static load carrying capacity 25 kg
For cabinet depth
D
mm
800
800
01005086
xf
c
Length L Qty/PU
mm
50
50
mm
700
700
mm
656
656
2
10
Part no.
23130-097
23130-102
Order Information
Static load carrying capacity 100 kg
For cabinet depth
D
mm
800
800
c
Length L Qty/PU
mm
50
50
mm
700
700
mm
658
658
2
10
Part no.
23130-119
23130-124
01004058
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
D
c
xf
c - 130
1.62
xf
01004130
19'' stationary shelf, 75 kg
VARISTAR EMC
쮿 Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
c
For cabinet
Usable
xf
c
RAL 7035
depth
surface w x d
mm
mm
mm mm
Part no.
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf PU 1 piece
D
d
Order Information
RAL 7021
Part no.
21130-305
23130-310
Note
w
xf
쮿 Cable ducting with cable ties, see page 1.67
쮿 Other sizes, see ServicePLUS, page 1.80
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
1.63
19'' telescopic shelf, 30 kg
VARISTA R EMC
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
800
417 x 682
50 700 22130-345
GND/earthing for telescopic 19" shelf PU 1 kit,
for VARISTAR
D
c
d
Full depth
RAL 7021
Part no.
21130-345
23130-140
xf
Note
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
800
417 x 582
50 700 22130-344
for VARISTAR
xr
w
RAL 7021
Part no.
21130-344
23130-140
D
xf
d
c
Note
c = max. pitch of the 19" panel/slide mounts
xf, xr = standard assembly pitch
1.64
01004070
19'' telescopic shelf, 70 kg
VARISTAR EMC
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
800
405 x 682
50 700 22130-355
Item 4 T-bar lock for 1 telescopic shelf
(can be mounted right or left), 1 piece
for VARISTAR
xf
d
Order Information
RAL 7021
Part no.
21130-355
23130-092
23130-140
Note
01004069
c = max. pitch for 19" panel/slide mounts
Shortened depth
W
쮿 Please order T-bar lock (item 4) separately
Order Information
w
Shortened by 100 mm
D
d
c
xr
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
800
405 x 582
50 700 22130-354
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
for VARISTAR
RAL 7021
Part no.
21130-354
23130-092
23130-140
Note
xf
01004070
1.65
Depth member
VARISTA R EMC
쮿 For mounting of shortened 19" panel/slide mounts
쮿 Cable ducting by means of cable ties and cable eyes
36,5
11,5
Delivery comprises
50
100
37,5
121,2
25
25
L - 27
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
12
Description
L
01004126
Item
1
2
01004079
Cable eye
For cabinet depth
mm
Depth member
800
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-082
21101-151
21101-150
coa43697
C-profile for the cabinet depth
VARISTA R EMC
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
15
,5
Ø6
50
11
Part no.
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
L
쮿 Cable ties and Velcro for cable retention rail see page 1.67
39,5
29,5
L-
,5
x 31
For cabinet depth
Length L
mm
mm
800
660
Accessories
Cable retention rail for C-rail
width 75 mm, length 39.5 mm, PU 5 pieces
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Slide nut for C-profile, PU 10 pieces
50
75
01504054
1.66
C-profile
01004132
01006071
C-profile for cabinet width
VARISTAR EMC
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
800
750
Accessories
Part no.
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable ties, Velcro
VARISTAR EMC
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
VARISTAR EMC
VARISTAR EMC ServiceP LUS
1.67
Cabinets – VARISTAR EMC ServicePLUS
configuration
Components can be varied and combined
freely
쮿 Configuration tables from page 1.69
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
쮿 Download CAD data and send back with modifications
solution
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
쮿 Further information: www.varistar.co.uk
1.68
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
VARISTAR ServicePLUS: configuration and assembly
쮿 Dimensions:
– Height: 29 ... 47 U (1400 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 600, 800 and 1000 mm
Page
쮿 2 colour combinations:
– Frame and covers in black grey (RAL 7021)
– Frame, top cover and base in black grey (RAL 7021);
Side panel, door and rear panel in light grey (RAL 7035)
Frames, EMC gasketing,
side-by-side mounting
kits, adjustable feet,
castors
1.70
doors
1.71
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
Top covers, fan top covers,
1.72
lifting eyes
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all subsequent
configuration pages that apply to these dimensions (see example below)
Bases, plinths
1.73
1.74
쮿 The cabinet is assembled by us and ready for despatch
Interior configuration
1.75
ETSI panel/slide mounts
1.76
Swing frames
1.77
Stationary shelves
1.78
Telescopic shelves, 70 kg
1.79
1.80
2 U, 70 kg
1.81
Slide rails, depth
members
1.82
Cable ductings
1.83
01004077
Example configuration (here: row 9)
Qty
1
1
1
1
1
1
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
EMC gasketing kit, 1 piece
Side panel screw-fixing, EMC, PU 2 pieces
Screw-fixed rear panel, EMC, 1 piece
Steel door with 4-point locking, EMC, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
23130-065/05
21130-031/05
21130-084/05
21130-174/05
23130-079/05
1.69
VARISTAR EMC
Frames, EMC gasketing, side-by-side mounting kits, adjustable feet, castors
Order Information
Frame
Slim-Line
400 kg
EMC gasketing kit
Heavy-Duty
800 kg
Side-by-side
mounting kit
EMC
Adjustable feet
Castors
With 2 jacking
feet
With adjustable
feet
Completely
in
RAL 7021
(black grey
01004078
gaskets are glued
static loadstatic loadto the frame,
through which all
800 kg,
400 kg,
the following
St, 1.5 mm, zinc- St, 1.5 mm, zinccover parts are
plated, with
plated, with
conductively
central GND/
central GND/
linked
earthing point;
earthing point;
please order
please order
adjustable feet or adjustable feet or
castors
castors
separately
separately
Colour
combinatio
n RAL
7035 (light
grey)/
RAL 7021 (
black grey)
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
01004157
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
01004120
side-by-side
mounting
brackets
(4 pieces), St
01004081
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
assembled
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-055
20130-006
20130-056
20130-009
20130-010
20130-059
20130-060
20130-013
20130-063
20130-014
20130-015
20130-064
20130-065
20130-018
20130-068
20130-019
20130-021
20130-069
20130-071
01004156
for the frame,
for the frame,
for the frame,
static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity:
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
with base/plinth with base/plinth with base/plinth
assembled
20130-005
01004082
PU 4 pieces
PU 4 pieces
RAL 7021
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
20130-022
20130-072
20130-023
20130-027
20130-073
20130-077
20130-028
20130-078
23130-065
23130-063
23130-079
23130-077
23130-078
20130-030
20130-032
20130-080
20130-082
23130-065
23130-063
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.70
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-065
23130-063
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-065
23130-063
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-065
23130-063
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-065
23130-063
42 2000 600
600
20130-018
20130-068
42 2000 600
800
20130-019
20130-069
23130-065
23130-063
42 2000 600
1000
20130-021
20130-071
42 2000 800
600
20130-022
20130-072
23130-065
23130-063
42 2000 800
800
20130-023
20130-073
47 2200 600
600
20130-027
20130-077
47 2200 600
800
20130-028
20130-078
23130-065
23130-063
47 2200 600
1000
20130-030
20130-080
47 2200 800
800
20130-032
20130-082
23130-065
23130-063
Other dimensions and configurations online (with basket) at www.schroff.biz/conf
VARISTAR EMC
Order Information
Side panel,
screw fixed,
EMC,
IP 55
Rear panel,
screw fixed,
EMC,
IP 55
Steel door, 4-point locking
Plain, EMC, IP 55 Perforated, EMC
DIN profile half
cylinder
(black grey)
01004083
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004085
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004092
01004093
St, 1.5 mm,
St, 1.5 mm,
painted outside, painted outside,
AlZn inside,
AlZn inside,
opening angle
opening angle
180°,
180°,
lever handle with lever handle with
push button,
push button,
incl. GND/
incl. GND/
earthing
earthing
01004148
for lever handle,
common locking
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-078
21130-168
21130-198
25127-995
21130-080
21130-170
21130-200
25127-995
21130-027
21130-028
21130-082
21130-172
21130-202
25127-995
21130-027
21130-083
21130-173
21130-203
25127-995
21130-030
21130-031
21130-084
21130-174
21130-204
25127-995
21130-085
21130-175
21130-205
25127-995
21130-036
21130-038
21130-086
21130-176
21130-206
25127-995
21130-036
21130-087
21130-177
21130-207
25127-995
RAL 7035
RAL 7035
RAL 7035
RAL 7035
22130-078
22130-168
22130-198
25127-995
22130-080
22130-170
22130-200
25127-995
22130-027
22130-028
22130-082
22130-172
22130-202
25127-995
22130-027
22130-083
22130-173
22130-203
25127-995
22130-030
22130-031
22130-084
22130-174
22130-204
25127-995
22130-085
22130-175
22130-205
25127-995
22130-036
22130-038
22130-086
22130-176
22130-206
25127-995
22130-036
22130-087
22130-177
22130-207
25127-995
21130-023
21130-024
21130-025
21130-026
21130-033
21130-030
21130-031
21130-035
22130-023
22130-024
22130-025
22130-026
22130-033
22130-030
22130-031
22130-035
1.71
VARISTAR EMC
Top covers, fan top covers, lifting eyes
Order Information
Flat top cover
EMC, IP 55
Fan top cover
Lifting eye
EMC top cover for
6 fans
Replacement
fan for fan top
Thermostat
Speed control
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.72
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
300 mm
M12
01004096
01004090
01008050
kta44844
01108052
01105055
St, 1.5 mm,
fully wired,
fan with grille for with mains cable
RAL 7021;
90 ... 264 VAC,
top assembly,
230 VAC
with 3 axial fans
230 VAC,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
incl. cabling and for 50 Hz, 162 m / IEC 60320 C13
socket),
C13 socket;
GND/earthing,
h
adjustment range
external NTC
connector 2.5m,
0 ... 60°C
sensor 1.5 m
SCHUKO/
IEC 60320 C12
plug
01005085
for fan top cover,
applications and
in accordance
with DIN 582
St, 1,5 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
21130-272
21130-273
21130-272
21130-273
21130-272
21130-273
21130-276
RAL 7021
23130-072
23130-072
23130-072
23130-072
21130-272
21130-273
21130-275
21130-276
21130-277
21130-272
21130-273
21130-275
21130-277
23130-395
23130-396
23130-395
23130-396
23130-395
23130-396
23130-397
23130-395
23130-072
23130-072
23130-396
23130-443
23130-397
23130-398
23130-395
23130-072
23130-396
23130-165
20118-750
60715-005
23130-090
23130-072
23130-443
23130-398
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
RAL 7021
21130-272
23130-395
21130-273
21130-272
21130-273
21130-272
21130-273
21130-276
23130-072
23130-072
23130-072
23130-072
21130-272
21130-273
21130-275
21130-276
21130-277
21130-272
21130-273
21130-275
21130-277
23130-396
23130-395
23130-396
23130-395
23130-396
23130-397
23130-395
23130-072
23130-072
23130-396
23130-443
23130-397
23130-398
23130-395
23130-072
23130-396
23130-165
20118-750
60715-005
23130-090
23130-072
23130-443
23130-398
23130-165
20118-750
60715-005
23130-090
ELECTRONICS PROTECTION
VARISTAR EMC
Bases, plinths
Order Information
Base plate
One-piece,
EMC, IP 55
With cable
ducting, EMC
Base/plinth
Perforated, with
cable ducting,
EMC
Plain base/plinth
Base/plinth,
ventilated
Side covers
Base/plinth,
mobile
(black grey)
01004051
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
SCHROFF.PENTAIR.CO.UK
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004108
AlZn, 1.5 mm,
rear opening
60 mm deep,
incl. GND/
earthing,
assembly from
outside
01008051
01004110
support with
AlZn, 1.5 mm,
adjustable feet
incl. GND/
and 2 trims,
earthing;
loadopening at rear: static
for cabinet width carrying capacity
1000 kg; please
of 600 mm:
order side trims
359 x 60 mm,
separately
for cabinet width
of 800 mm:
559 x 60 mm
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm, trim, St,
1.5 mm, static
load-carrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
1 piece
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
assembled
RAL 7021
23130-169
23130-208
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-281
21130-291
23130-400
21130-282
21130-287
21130-292
21130-296
23130-401
23130-447
23130-387
23130-187
23130-170
23130-209
23130-172
23130-170
23130-211
23130-213
23130-388
23130-194
RAL 7021
RAL 7021
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-281
21130-291
23130-400
21130-282
21130-287
21130-292
21130-296
23130-401
23130-447
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-287
21130-284
21130-296
21130-294
23130-447
23130-403
23130-213
23130-208
23130-187
23130-447
23130-403
23130-400
23130-401
23130-212
23130-170
23130-169
23130-387
23130-401
21130-291
21130-292
23130-169
23130-194
21130-296
21130-294
21130-281
21130-282
23130-209
23130-211
23130-388
21130-292
23130-401
23130-208
23130-170
23130-172
23130-187
21130-287
21130-284
21130-292
23130-169
23130-387
21130-282
21130-282
23130-209
23130-212
23130-194
23130-402
AlZn
23130-208
23130-170
23130-169
23130-388
23130-403
23130-400
23130-400
23130-169
23130-187
21130-293
AlZn
23130-208
23130-209
23130-387
21130-294
21130-291
21130-291
23130-209
23130-187
21130-284
21130-281
AlZn
23130-170
23130-169
23130-170
23130-387
21130-283
21130-281
RAL 7021
23130-387
23130-187
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-169
23130-208
23130-170
23130-172
23130-209
23130-211
23130-169
23130-212
23130-170
23130-169
23130-213
23130-208
23130-387
23130-187
23130-387
23130-187
23130-388
23130-194
23130-387
23130-187
23130-388
23130-194
23130-387
23130-187
23130-170
23130-209
23130-194
23130-172
23130-170
23130-211
23130-213
23130-388
Part number in normal type: ready for despatch within 10 working days
1.73
VARISTAR EMC
Connecting plates for short doors/rear panels
Order Information
Dimensioning
connecting plate
door/rear panel
EMC connecting plate
Flat plate,
EMC, IP 55
Recessed plate,
EMC, IP 55
(black grey)
01005077
7035 (light grey)/
door and rear
panel must be
selected 400 mm
shorter than
cabinet height
01005075
flat plate,
stainless steel,
1 mm,
height 400 mm,
mounting can be
at top or bottom
Cabinet dimensions
Height
Width Depth
U mm mm
mm
400
400
600
800
Colour combinations
400
400
1.74
600
800
01005074
frame,
stainless steel,
1 mm,
mounting can be
at top or bottom,
height 400 mm,
plate recessed
by 40 mm,
stainless steel,
1 mm
1 piece
1 piece
assembled
assembled
RAL 7021
RAL 7021
21130-578
21130-580
21130-579
21130-581
RAL 7035
RAL 7035
22130-578
22130-580
22130-579
22130-581
Interior mounting
Order Information
Dimension
Painted RAL 7021
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
7035 (light grey)/
U height identification for
19" panel/slide
mount
AIZn
c
D
Standard fitting
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
00505050
sc128
paper strip, white,
assembly kit:
from 1 ... 47 H
item 2: cage nuts,
item 3: washers
other kit
quantities
see page
3.17
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
50
50
50
50
50
50
50
70
50
150
50
50
50
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
700
500
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AIZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
AIZn
AIZn
1.75
Interior mounting
ETSI panel/slide mounts, mounting plates
Order Information
Dimensions
Mounting plates
Panel/slide
mount
Full height
Height 1200 mm
Strengthening
brackets
(black grey)
coa43693
7035 (light grey)/
01004114
St, 2 mm,
in accordance
AlZn finish,
with
suitable only for
ETS 300119-3
and IEC 60917- Slim-Line frame;
211; SU = 25 mm shelves available
on request
01008052
01008053
(rear mounted);
strengthening bracket increases
static load-carrying capacity;
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
Height
SU
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.76
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
PU 1 pair
1 piece
1 piece
PU 2 pieces
assembled
assembled
assembled
assembled
AIZn
zinc-plated
zinc-plated
RAL 7021
23130-052
23130-413
23130-418
23130-053
23130-413
23130-418
23130-054
23130-405
23130-413
23130-418
23130-054
23130-406
23130-414
23130-418
23130-055
23130-407
23130-413
23130-418
23130-055
23130-408
23130-414
23130-418
23130-056
23130-413
23130-418
23130-056
23130-414
23130-418
AIZn
verzinkt
verzinkt
RAL 7021
23130-052
23130-413
23130-418
23130-053
23130-413
23130-418
23130-054
23130-405
23130-413
23130-418
23130-054
23130-406
23130-414
23130-418
23130-055
23130-407
23130-413
23130-418
23130-055
23130-408
23130-414
23130-418
23130-056
23130-413
23130-418
23130-056
23130-414
23130-418
Interior mounting
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Width
Spare key
01005061
01015060
incl. 2 keys
01015059
Usable
height
U
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Width
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
Usable
height
U
mm
assembled
PU 1 kit
assembled
PU 2 pieces
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
1.77
Interior mounting
Stationary shelves
Order Information
Stationary shelf
Full depth
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01004142
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
01004142
01004126
St, 1.5 mm, static St, 1.5 mm, static length 460 mm,
St, 1.5 mm, finish
load-carrying
load-carrying
capacity 75 kg, AlZn required for
capacity 75 kg,
recessed shelf
1 U, depth 479
1 U, incl. GND/
mm, incl. GND/
earthing
earthing, for
recessed
installation
please order
depth member
separately
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.78
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-323
21130-324
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-327
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-327
21130-324
23130-082
21130-335
21130-334
23130-082
RAL 7035
RAL 7035
AIZn
22130-323
22130-322
23130-081
22130-325
22130-323
22130-324
22130-322
23130-082
23130-081
22130-325
22130-324
23130-082
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-333
22130-332
23130-081
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-327
22130-333
22130-335
22130-332
22130-334
23130-081
23130-082
22130-323
22130-322
23130-081
22130-325
22130-327
22130-324
23130-082
22130-335
22130-334
23130-082
Interior mounting
Order Information
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
7035 (light grey)/
01004145
load-carrying
load-carrying
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
please order
please order
mounting bracket mounting bracket
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-373
21130-372
23130-274
23130-092
23130-140
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-373
21130-375
21130-372
21130-374
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
21130-353
21130-352
21130-355
21130-354
21130-375
21130-374
23130-274
23130-092
23130-140
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-373
22130-372
23130-274
23130-092
23130-140
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-373
22130-375
22130-372
22130-374
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-354
22130-375
22130-374
23130-274
23130-092
23130-140
1.79
Interior mounting
Order Information
Dimension
19'' stationary shelf, 1 U, 75 kg
Full depth
19'' telescopic shelf, 1 U, 30 kg
Full depth
Shortened by
100 mm
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Standard fitting
01004118
01004119
01004123
01004122
xf = distance from St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static
load-carrying
load-carrying
load-carrying
load-carrying
front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
W = cabinet width
separatelyy
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.80
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
SCHROFF PRODUCT CATALOG E 08/2017
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
23130-140
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-305
21130-309
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
21130-305
21130-304
21130-345
21130-344
21130-309
21130-303
21130-302
21130-343
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-305
22130-309
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
22130-305
22130-304
22130-345
22130-344
22130-309
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
Interior mounting
19" telescopic shelves, 2 U, 70 kg
Order Information
Dimension
Shelf, telescopic, 2 U, 70 kg
Full depth
T-bar lock
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Standard fitting
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004123
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
01004122
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-353
21130-352
21130-355
21130-354
21130-353
21130-352
21130-353
21130-353
21130-352
21130-352
21130-355
21130-354
21130-353
21130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-353
22130-352
22130-355
22130-354
22130-353
22130-352
22130-353
22130-353
22130-352
22130-352
22130-355
22130-354
22130-353
22130-352
23130-092
23130-140
1.81
Interior mounting
Order Information
Dimension
Slide rail
25 kg
Short slide rail
100 kg
Depth member,
3 rows
c
D
Standard fitting
W
xf
(black grey)
01004146
7035 (light grey)/
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance from
front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn
required for
shortened shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.82
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-097
23130-098
23130-119
23130-120
23130-094
23130-094
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-081
23130-094
23130-082
23130-084
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-094
23130-082
23130-098
23130-096
23130-120
23130-118
23130-094
23130-084
23130-082
AIZn
verzinkt
AIZn
23130-096
23130-118
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-097
23130-098
23130-119
23130-120
23130-094
23130-094
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-081
23130-094
23130-082
23130-084
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-094
23130-082
23130-098
23130-096
23130-120
23130-118
23130-094
23130-084
23130-082
23130-094
23130-081
23130-082
23130-081
Interior mounting
Cable ductings
Order Information
C-rail for
cabinet depth
C-rail for
cabinet width
Cable tie
Slide nut
Velcro
General
components
Cable shell
Mechanics
(black grey)
from page
3.2
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
Depth
mm
mm
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm ;
further
dimensions
see page
1.66
01005078
plastic,
92 mm x 2.5 mm;
further
dimensions
see page
1.67
01005079
black,
length 300 mm
Electrics
AlZn
Width
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
vnt009
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-086
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-333
21120-140
20114-731
20118-351
20118-624
23130-089
23130-087
23130-334
21120-140
20114-731
20118-351
20118-624
AIZn
AIZn
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-333
21120-140
20114-731
20118-351
20118-624
23130-089
23130-087
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-086
23130-087
23130-089
23130-086
23130-087
23130-086
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
from page
3.29
Power
distribution
from page
3.50
Climate control
23130-086
23130-087
23130-089
23130-086
23130-087
23130-086
from page
4.0
1.83
VARISTAR Seism icMain Catalogue
Cabinets – VARISTAR Seismic
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01008007
Subracks/
Front panels,
01008062
Welded basic frame with strengthening brackets
01008008
Bellcore test in laboratory
Power supply
Backplanes . . . 10
Connectors, front
panel component
01008063
Seismic base with NEBS fixing
01005083
Test results
1.84
SCHROFF PRODUCT CATALOG E 07/2017
Overview . . . . . . 1.84
The earthquake-resistant cabinet
쮿 Earthquake resistance tested to Bellcore zone 4 with
a dynamic load-carrying capacity of 250 kg
쮿 Customised solutions with higher loading are available
VARISTAR
Platform . . . . . . . . 1.4
Dimensions . . . . . 1.8
쮿 Optional EMC shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz
Seismic cabinets off-the-shelf
VARISTAR Seismic
쮿 Earthquake-resistant up to Bellcore Zone 4
IP 20 . . . . . . . . . . . . 1.86
IP 55 and EMC . . . 1.87
쮿 Versions
- IP 20
- IP 55 with EMC shielding
Accessories
19" panel/slide
mount . . . . . . . . . . 1.88
19" fixing
materials kit,
M6 . . . . . . . . . . . . . 1.88
Slide rails . . . . . . . . 1.89
19" shelves . . . . . . 1.90
Depth members . . 1.93
C horizontal rails . 1.93
Cable ties,
Velcro . . . . . . . . . . . 1.95
01005018
ServicePLUS . . . 1.96
IP 20 . . . . . . . . . . . . 1.98
IP 55 . . . . . . . . . . . . 1.102
EMC . . . . . . . . . . . . . 1.106
Interior
configuration . . . . 1.110
ServicePLUS from page 1.96
VARISTAR
VARISTAR
EMC. . . . . . . . . . . .
VARISTAR
Datacom and
Networking
VARISTAR air/
water heat
1.10
1.54
1.124
1.224
30407004
1.85
VARISTAR Seismic, IP 20
VARISTA R Seis micMain CatalogueP art number in bold face type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days
쮿 Dynamic load-carrying capacity of 250 kg
쮿 Doors with 3-point locking and screw-fixed side panels
쮿 Static load-carrying capacity 800 kg (Heavy-Duty)
Item
1
Qty
1
2
3
4
1
1
1
5
6
7
8
1
2
1
2
9
1
Description
Welded basic frame, Heavy-Duty, St profile, RAL 7021,
Earthquake base, St, RAL 7021
Top cover, raised, St, RAL 7021
Front door, St, RAL 7035, 180° hinge,
3-point locking, lever handle
Rear panel, screw fixed, St, RAL 7035
Side panel, screw fixed, St, RAL 7035
Base plate, multi-piece, St, RAL 7021, open at the rear
increments
Order Information
01005018
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1900
600
800
42
2100
600
600
42
2100
600
800
Lifting eye for raised top cover PU 4 pieces
Part no.
10130-189
10130-023
10130-188
25127-995
23130-085
Note
쮿 Other dimensions and versions available on request
slide mounts is necessary, see page 1.88
Bellcore test
01005084
01005083
ServicePLUS see page 1.96
1.86
VARISTAR Seismic, IP 55 and EMC
VARISTAR Sei smic
쮿 Earthquake secure (up) to Bellcore Zone 4
Item
1
Qty
1
2
3
1
1
4
1
5
1
6
2
7
8
1
2
9
1
Description
EMC, flat top cover, flush, St, finish AlZn,
exterior RAL 7021
Front door, St, finish AlZn, powder-coated RAL 7035, 180°
Rear panel, screw fixed, St, finish AlZn, powdercoated RAL 7035
Side panel, screw fixed, St, finish AlZn, powdercoated RAL 7035
Base plate, one-piece, St, finish AlZn
19" panel/slide mount with EIA perforation, St, finish
AlZn, front mounted, depth-adjustable in 25 mm
increments
Order Information
01008030
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2100
600
800
Part no.
10130-195
25127-995
23130-072
Note
Shielding: Tested to IEC 61587-3, standard dimensions of test
01005084
[dBµV]
120
100
80
60
40
Bellcore test
01005083 01007056
200
300
400
500
600
700
800
900
1000
[MHz]
1.87
VARISTA R Seis mic
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
Order Information
9,6
42,5
Item
1
01004112
01004131
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
1400
29
1295
23130-032 23130-022
1600
33
1495
23130-033 23130-023
1800
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
01005088
VARISTA R Seis mic
Delivery comprises
Item
1
2
3
Description
Order Information
Description
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.88
Slide rails
VARISTAR Sei smic
쮿 2 versions
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Order Information
For cabinet depth D
mm
600
600
800
800
xf
mm
50
50
50
50
c
mm
500
500
700
700
Length L
mm
456
456
656
656
Qty/PU
2
10
2
10
Part no.
23130-096
23130-101
23130-097
23130-102
01005086
Order Information
For cabinet depth D
mm
600
600
800
800
Length L
mm
458
458
658
658
Qty/PU
2
10
2
10
Part no.
23130-118
23130-123
23130-119
23130-124
D
c
xf
c - 130
D = cabinet depth
c
mm
500
500
700
700
01004058
19”
xf
mm
50
50
50
50
01004130
1.89
VARISTA R Seis mic
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
c
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf, PU 1 piece
D
d
Order Information
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
xf
w
쮿 Cable ducting with cable ties, see page 1.95
쮿 Other sizes, see ServicePLUS, page 1.114
W
1.90
01004067
VARISTAR Sei smic
1
mounts
2
쮿 2 versions
– Full depth
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50 500 22130-343
800
417 x 682
50 700 22130-345
for VARISTAR
RAL 7021
Part no.
21130-343
21130-345
23130-140
Note
xf
d
Full depth
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50 500 22130-342
800
417 x 582
50 700 22130-344
for VARISTAR
RAL 7021
Part no.
21130-342
21130-344
23130-140
Note
D
c
xr
w
xf
d
01004070
1.91
VARISTA R Seis mic
1
2
mounts
4
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 682
50 700 22130-355
for VARISTAR
xf
d
Order Information
01004069
Shortened depth
RAL 7021
Part no.
21130-353
21130-355
23130-092
23130-140
Note
W
w
xr
Order Information
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 582
50 700 22130-354
for VARISTAR
d
c
Shortened by 100 mm
RAL 7021
Part no.
21130-352
21130-354
23130-092
23130-140
Note
xf
1.92
01004070
Depth member
VARISTAR Sei smic
쮿 For fitting shortened 19" panel/slide mounts and mounting
plates
50
Delivery comprises
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
Item
1
2
Qty
2
1
Description
Order Information
L
0100412601004079
For cabinet depth
Length L
mm
mm
600
460
800
660
Part no.
23130-081
23130-082
21101-151
21101-150
coa43697
Cable eye
VARISTAR Sei smic
Delivery comprises
Item
1
2
Qty
2
1
Description
Order Information
01004129
Slide nut
31,5
,5 x
Ø6
15
50
11
L
50
Part no.
23130-086
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
29,5
L-
For cabinet depth
Length L
mm
mm
600
460
800
660
Accessories
Cable retention rail for C-rail width 75 mm,
쮿 Cable ties and Velcro for cable retention rail see page 1.95
75
01504054
C-profile
01004132
01006071
Part number in bold face type: ready for despatch within 2 working days
1.93
Delivery comprises
Item
1
2
Qty
2
1
Description
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
600
550
Accessories
Part no.
23130-333
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
1.94
01006064
01504054
Cabinet accessories – VARISTAR Seismic
Cable ties, Velcro
VARISTAR Sei smicMain C ataloguePart number in bold face type: ready for des patch within 2 working daysP art number in normal type: ready for despatch within 10 working days
Order Information
Description
Cable tie, plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, plastic, 360 mm x 5 mm, PU 25 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
VARISTAR EMC
VARISTAR Sei smic ServiceP LUS
1.95
Cabinets – VARISTAR Seismic ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined freely
쮿 Configuration tables from page 1.98
assembly
쮿 Without supplement
modification
for off-the-shelf products
쮿 Download CAD data, modify and send back
solution
Simple. Fast. From one source.
쮿 Climate control, complete construction, cabling
(power supply), function testing
쮿 Ready to despatch within 10 working days
쮿 Special sizes, custom solutions
academy
user reports
1.96
lifecycle
lifecycle
쮿 Delivery to point of use, set-up service, replacement service,
spare parts
VARISTAR Seismic IP 20, IP 50, EMC ServicePLUS: Configuration
Main C atalogue
Page
쮿 Dimensions in catalogue:
– Depth: 600 and 800 mm
Seismic IP 20
Frames, side-by-side
mounting kits, base/plinth
Side panels, rear panels,
doors, top covers
Base plates, brush strips,
filter inserts
쮿 Other dimensions and configurations, sorted by IP 20, IP 55
and EMC online at www.schroff.biz/conf
1.98
1.99
1.100
1.101
Seismic IP 55
Frames, gasketing kits,
kits, base/plinth
doors, top covers
1.102
1.103
Base plates, gasketing
1.104
1.105
Seismic EMC
kits, base/plinth
doors, top covers
1.106
1.107
Base plates
1.108
1.109
Swing frames
1.110
1.111
Mounting plates,
stationary shelves, 75 kg
19" shelves 1 U, stationary
75 kg, telescopic 30 kg
2 U, 70 kg
Slide rails, depth
members
01004077
Example configuration (here: row 12)
Qty
1
1
1
1
1
Description
Frame heavy duty, St profile, with strengthening brackets, height
Side panel, screw fixed, RAL 7021, PU 2 pieces
Rear panel, screw-fixed, RAL 7021, 1 piece
Steel door with 3-point locking, RAL 7021, IP 55, 1 piece
Base/plinth, 1 piece
1.112
1.113
1.114
1.115
1.116
Cable ductings
1.117
Cable ties, Velcro
1.118
ServicePLUS: solution project examples
1.119
Order no.
20130-630/05
21130-011/05
21130-069/05
21130-159/05
23130-455/05
1.97
Seismic IP 20
Frames, side-by-side mounting kits, base/plinth
Seismic frame
Heavy-Duty
800 kg
Side-by-side
mounting kit
IP 20
104,5
Completely in RAL 7021
(black grey)
Base/plinth
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004117
01009062
2 support
side-by-side
St, 1.5 mm, zincmounting bracket profiles, St, 4 mm,
plated, with
lateral; 2 trims,
(4 pieces), St;
8 reinforcing
brackets, central RAL 7021, not in St, 4 mm, front/
rear;
combination with
GND/earthing
point, static load- decorative frame height 104.5 mm;
carrying capacity
800 kg
1000 kg
1 piece
PU 1 kit
1 piece
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-061
23130-454
23130-455
20130-636
23130-061
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-061
23130-454
23130-455
20130-636
23130-061
23130-457
Further dimensions and configurations online at www.schroff.biz/conf
1.98
Seismic IP 20
Side panels, rear panels, doors, top covers
Screw-fixed
side panel
Screw-fixed
rear panel
Steel door
3-point locking
DIN profile half
cylinder
Plain flush top cover
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01008085
01004148
for lever handle,
St, 1.5 mm,
common locking
opening angle
180°,
inner side with
mounting frame,
lever handle with
built-in push
button, incl. GND/
earthing
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
21130-003
RAL 7021
RAL 7021
21130-242
21130-063
21130-153
25127-995
21130-065
21130-155
25127-995
21130-066
21130-156
25127-995
21130-067
21130-157
25127-995
21130-068
21130-158
25127-995
21130-069
21130-159
25127-995
21130-070
21130-160
25127-995
21130-015
21130-016
21130-071
21130-161
25127-995
21130-242
21130-243
23130-072
21130-016
21130-072
21130-162
25127-995
21130-247
23130-072
RAL 7035
RAL 7035
RAL 7035
21130-004
21130-005
21130-006
21130-005
21130-006
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-010
21130-011
22130-003
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-242
22130-063
22130-153
25127-995
22130-065
22130-155
25127-995
22130-066
22130-156
25127-995
22130-067
22130-157
25127-995
22130-068
22130-158
25127-995
22130-069
22130-159
25127-995
22130-070
22130-160
25127-995
22130-015
22130-016
22130-071
22130-161
25127-995
21130-242
21130-243
23130-072
22130-016
22130-072
22130-162
25127-995
21130-247
23130-072
22130-004
22130-005
22130-006
22130-005
22130-006
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-010
22130-011
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.99
Seismic IP 20
Base plates, brush strips, filter inserts
Base plate
Base plate, multipiece
Brush strip
Dust filter set
Cover plate
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U mm
Width
mm
Depth
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.100
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004105
01004059
01004106
nylon, black
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
23130-001
23130-002
23130-074
23130-075
23130-076
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
Dimension
drawings see
page 1.9
1 piece
RAL 7021
RAL 7021
RAL 7021
23130-001
23130-002
23130-074
23130-075
23130-076
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
RAL 7021
Seismic IP 20
Dimensioning
connecting plate
door/rear panel
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01004066 01004056
e.g.
only required if
stationary shelves,
rear panel
19" shelves,
is assembled
slide rails,
above the
cable ducting
connecting plate
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
RAL 7021
RAL 7021
21130-472
21130-473
21130-478
21130-479
23130-164
23130-164
from page
1.110
from page
1.110
RAL 7035
RAL 7035
22130-472
22130-478
23130-164
22130-473
22130-479
23130-164
1.101
Seismic IP 55
Frames, gasketing kits, side-by-side mounting kits, base/plinth
Seismic frame
Heavy-Duty
800 kg
Gasketing kit
IP 55
Base/plinth
Side-by-side
mounting kit
IP 55
(with gasket)
104,5
(black grey)
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004157
01004117
01009062
2 support
side-by-side
St, 1.5 mm, zinc- seals are glued to
the frame, so that mounting bracket profiles, St, 4 mm,
plated, with
lateral; 2 trims,
(4 pieces), St,
8 strengthening all cladding parts
St, 4 mm, front/
RAL 7021, incl.
conform to
brackets, central
rear;
gasket to cover
protection type
GND/earthing
the gap between height 104.5 mm;
IP 55
point, static loadstatic loadtwo racks; not in
carrying capacity
combination with carrying capacity
800 kg
1000 kg
decorative frame
1 piece
PU 1 kit
PU 1 kit
1 piece
assembled
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-064
23130-062
23130-454
23130-455
20130-636
23130-064
23130-062
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-064
23130-062
23130-454
23130-455
20130-636
23130-064
23130-062
23130-457
1.102
Seismic IP 55
Screw-fixed
side panel
Screw-fixed
rear panel
Steel door
3-point locking
DIN profile half
cylinder
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01008085
01004148
for lever handle,
St, 1.5 mm,
common locking
opening angle
180°,
inner side with
mounting frame,
lever handle with
built-in push
button, incl. GND/
earthing
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
21130-003
RAL 7021
RAL 7021
21130-242
21130-063
21130-153
25127-995
21130-065
21130-155
25127-995
21130-066
21130-156
25127-995
21130-067
21130-157
25127-995
21130-068
21130-158
25127-995
21130-069
21130-159
25127-995
21130-070
21130-160
25127-995
21130-015
21130-016
21130-071
21130-161
25127-995
21130-242
21130-243
23130-072
21130-016
21130-072
21130-162
25127-995
21130-247
23130-072
RAL 7035
RAL 7035
RAL 7035
21130-004
21130-005
21130-006
21130-005
21130-006
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-010
21130-011
22130-003
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-242
22130-063
22130-153
25127-995
22130-065
22130-155
25127-995
22130-066
22130-156
25127-995
22130-067
22130-157
25127-995
22130-068
22130-158
25127-995
22130-069
22130-159
25127-995
22130-070
22130-160
25127-995
22130-015
22130-016
22130-071
22130-161
25127-995
21130-242
21130-243
23130-072
22130-016
22130-072
22130-162
25127-995
21130-247
23130-072
22130-004
22130-005
22130-006
22130-005
22130-006
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-010
22130-011
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.103
Seismic IP 55
Base plate
Cover plate
IP 55 gasket
Base plate,
one-piece,
EMC, IP 55
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U mm
Width
mm
Depth
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.104
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004106
01004073
for base plate
with cover
01004051
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
Dimension
drawings see
page 1.9
1 piece
St, 1.5 mm,
please order
IP55 gasket
separately
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
AlZn
23130-076
23130-073
21130-281
21130-282
23130-076
23130-073
23130-036
23130-073
23130-001
23130-002
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-284
RAL 7021
AlZn
23130-076
23130-073
21130-281
21130-282
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-284
Seismic IP 55
Dimensioning
connecting plate
door/rear panel
Connecting plate
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005072
01004066 01004056
e.g.
St, 1 mm,
can also be fitted stationary shelves,
19" shelves,
in upper part,
slide rails,
height 400 mm,
cable ducting
with assembly kit
1 piece
assembled
RAL 7021
21130-504
21130-505
from page
1.110
RAL 7035
22130-504
22130-505
from page
1.110
1.105
Seismic EMC
Seismic frame
EMC gasketing kit
Heavy-Duty
800 kg
Side-by-side
mounting kit
EMC
104,5
(black grey)
Base/plinth
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004157
St, 1.5 mm, zinc- gaskets are glued
to the frame,
plated, with
thus all the
8 strengthening
brackets, central following cover
parts are
GND/earthing
conductively
point, static loadlinked
carrying capacity
800 kg
01004120
side-by-side
mounting
brackets
(4 pieces), St
01009062
2 support
profiles, St, 4 mm,
lateral; 2 trims,
St, 4 mm, front/
rear;
height 104.5 mm;
static loadcarrying capacity
1000 kg
1 piece
PU 1 kit
PU 1 kit
1 piece
assembled
assembled
supplied loose
assembled
RAL 7021
20130-617
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
20130-633
20130-634
20130-636
RAL 7021
RAL 7021
23130-065
23130-063
23130-454
23130-455
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-065
23130-063
23130-454
23130-455
20130-636
23130-065
23130-063
23130-457
1.106
Seismic EMC
Side panel,
Rear panel,
Steel door, 4-point locking
screw fixed, EMC, screw fixed, EMC, Plain, EMC, IP 55 Perforated, EMC DIN profile half
IP 55
IP 55
cylinder
Flat top cover
EMC, IP 55
Lifting eye
(black grey)
M12
01004083
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004085
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004092
01004093
St, 1.5 mm,
St, 1.5 mm,
painted outside, painted outside,
interior AlZn,
interior AlZn,
opening angle
opening angle
180°,
180°,
lever handle with lever handle with
push button, incl. push button, incl.
GND/earthing
GND/earthing
01004148
for lever handle,
common locking
01004096
01004090
St, 1.5 mm,
exterior painted,
interior AlZn,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-023
21130-024
21130-078
21130-168
21130-198
25127-995
21130-080
21130-170
21130-200
25127-995
21130-081
21130-171
21130-201
25127-995
21130-082
21130-172
21130-202
25127-995
21130-083
21130-173
21130-203
25127-995
21130-084
21130-174
21130-204
25127-995
21130-085
21130-175
21130-205
25127-995
21130-086
21130-176
21130-206
25127-995
21130-087
21130-177
21130-207
25127-995
21130-025
21130-026
21130-025
21130-026
21130-027
21130-028
21130-027
21130-028
21130-030
21130-031
21130-030
21130-031
21130-035
21130-036
21130-036
RAL 7035
22130-023
RAL 7035
RAL 7021
RAL 7035
21130-272
21130-273
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-277
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-272
22130-078
22130-168
21130-198
25127-995
22130-080
22130-170
21130-200
25127-995
22130-081
22130-171
21130-201
25127-995
22130-082
22130-172
21130-202
25127-995
22130-083
22130-173
21130-203
25127-995
22130-084
22130-174
21130-204
25127-995
22130-085
22130-175
21130-205
25127-995
22130-035
22130-036
22130-086
22130-176
21130-206
25127-995
21130-272
21130-273
23130-072
22130-036
22130-087
22130-177
21130-207
25127-995
21130-277
23130-072
22130-024
22130-025
22130-026
22130-025
22130-026
22130-027
22130-028
22130-027
22130-028
22130-030
22130-031
22130-030
22130-031
21130-273
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.107
Seismic EMC
Base plates
Base plates
one-piece,
EMC, IP 55
with cable
ducting, EMC
perforated, with
cable ducting,
EMC
(black grey)
01004051
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.108
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004108
AlZn, 1.5 mm,
rear opening
60 mm deep,
incl. GND/
earthing,
assembly from
outside
01008051
AlZn, 1.5 mm,
incl. GND/
earthing;
opening at rear
for cabinet width
of 600 mm:
359 x 60 mm,
for cabinet width
of 800 mm:
559 x 60 mm
1 piece
1 piece
1 piece
assembled
assembled
assembled
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-283
21130-284
21130-293
21130-294
23130-402
23130-403
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-284
21130-294
23130-403
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-284
21130-294
23130-403
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-283
21130-284
21130-293
21130-294
23130-402
23130-403
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-284
21130-294
23130-403
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-284
21130-294
23130-403
ELECTRONICS PROTECTION
Seismic EMC
Dimensioning
connecting plate
door/rear panel
Flat plate,
EMC, IP 55
Shortened plate,
EMC, IP 55
Other VARISTAR
interior mounting
parts
(black grey)
01005077
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
400
400
600
800
Colour combinations
400
400
600
800
SCHROFF.PENTAIR.CO.UK
door and rear
panel must be
selected 400 mm
shorter than
cabinet height
01005075
flat plate,
stainless steel,
1 mm,
height 400 mm,
mounting can be
at top or bottom
01005074
01004066 01004056
e.g.
frame,
stainless steel, stationary shelves,
19" shelves,
1 mm,
slide rails,
mounting at top
cable ducting
or bottom,
height 400 mm,
plate recessed by
40 mm,
stainless steel,
1 mm
1 piece
1 piece
assembled
assembled
RAL 7021
RAL 7021
21130-578
21130-580
21130-579
21130-581
RAL 7035
RAL 7035
22130-578
22130-580
22130-579
22130-581
from page
1.110
from page
1.110
1.109
Interior mounting
Swing frames for cabinet width 600 mm
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Spare key
01005061
01015060
St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg,
120° hinge, square locks
incl. 2 keys
(Dimension drawings link)
St; for safety reasons a swing
frame stop is recommended
for swing frame, instead of
square lock, incl. 2 keys
01015059
Usable
height
U
Width
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Swing frames for cabinet width 800 mm
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
1.110
Width
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
(item 2) and cutout for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
Usable
height
U
mm
assembled
PU 1 kit
assembled
PU 2 pieces
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
Interior mounting
19" panel/slide mounts EIA
Painted RAL 7021
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
7035 (light grey)/
U height
identification
for 19" panel/
slide mount
AIZn
c
D
Dimension
Standard fitting
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
reduced-width adapter bracket
required for 800 mm width;
depth members are required for
partial-height mounting
00505050
sc128
paper strip, white,
assembly kit:
serial numbered item 1: screws,
from 1 ... 47 U
item 2: cage nuts,
item 3: washers
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-091
23130-014
23130-034
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AlZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-091
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
AIZn
Part number in normal type: ready for despatch within 10 working days
1.111
Interior mounting
Mounting plates, stationary shelves, 75 kg
Mounting plate
Full height
Height 1200 mm
Strengthening
brackets
Stationary shelf
Full depth
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01008052
7035 (light grey)/
01008053
St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear
mounted); strengthening bracket
increases static load-carrying
capacity; please order separately
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
01004142
01004142
load-carrying
load-carrying
cap. 75 kg, 1 U,
capacity 75 kg,
depth 479 mm,
1 U, incl. GND/
incl. GND/
earthing
earthing,
for recessed
installation order
depth members
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.112
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
PU 2 pieces
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
assembled
assembled
assembled
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-335
21130-323
21130-334
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
21130-335
21130-334
23130-082
21130-322
21130-324
23130-081
23130-082
21130-334
23130-082
23130-413
23130-418
21130-323
21130-325
23130-414
23130-418
21130-335
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
RAL 7035
RAL 7035
AlZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-335
21130-323
21130-334
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
21130-335
21130-334
23130-082
21130-322
21130-324
23130-081
23130-082
21130-334
23130-082
23130-413
23130-418
21130-323
21130-325
23130-414
23130-418
21130-335
Interior mounting
Telescopic shelves, 70 kg
Telescopic shelf, 2 U
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
01004145
load-carrying
load-carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-373
21130-372
21130-375
21130-353
21130-374
21130-352
21130-355
21130-354
21130-373
21130-375
21130-372
21130-374
21130-353
21130-352
21130-355
21130-373
21130-354
21130-372
21130-375
21130-374
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-375
21130-374
23130-274
23130-092
23130-140
AlZn
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
22130-373
22130-372
22130-375
22130-353
22130-374
22130-352
22130-355
22130-354
22130-373
22130-375
22130-372
22130-374
RAL 7021
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-373
22130-354
22130-372
22130-375
22130-374
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-375
22130-374
23130-274
23130-092
23130-140
1.113
Interior mounting
19" shelves 1 U, stationary 75 kg, telescopic 30 kg
Full depth
Full depth
Shortened by
100 mm
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Dimension
Standard fitting
01004118
01004119
01004123
01004122
xf = distance
load-carrying
load-carrying
load-carrying
load-carrying
from front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
GND/earthing kit GND/earthing kit
W = cabinet width
separately
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.114
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
21130-303
21130-302
21130-343
21130-342
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
23130-140
21130-303
21130-302
21130-343
21130-342
23130-140
22130-303
22130-302
22130-343
22130-342
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
23130-140
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
Interior mounting
W
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004123
GND/earthing
01004122
01004125
05904052
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
1 piece
to lock the
telescopic shelf
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
22130-353
22130-355
22130-352
22130-354
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
T-bar lock
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
1 piece
xf
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Shortened by
100 mm
xf
(black grey)
7035 (light grey)/
Telescopic shelf, 2 U, 70 kg
Full depth
c
D
Dimension
Standard fitting
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-353
22130-352
22130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
for telescopic
shelf
1.115
Interior mounting
Slide rails, depth members
Slide rail
25 kg
Depth member,
3 rows
W
xf
(black grey)
01004146
7035 (light grey)/
Short slide rail
100 kg
c
D
Dimension
Standard fitting
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance
finish AlZn, static zinc-plated, static finish AlZn, static
from front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.116
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-094
23130-094
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
AlZn
zinc-plated
AlZn
23130-096
23130-118
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-094
23130-094
23130-094
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
AlZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
Interior mounting
Cable ductings
Cable ducting with C-profile
C-rail for
cabinet depth
C-rail for
cabinet width
Slide nut
Cable shell
Cable support for
C-rail
(black grey)
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
vnt009
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.93
01006110
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 5 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-087
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-087
AlZn
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
AlZn
1.117
Interior mounting
Cable ties, Velcro
Cable tie
Velcro
General
components
Mechanics
(black grey)
from page
3.2
01005078
7035 (light grey)/
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.95
01005079
black,
length 300 mm,
further
dimensions
see page
1.95
Electrics
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
1.118
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
AlZn
AlZn
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.29
Power
distribution
from page
3.50
Climate control
from page
4.0
ServicePLUS: solution - project examples
Mobile communications technology
쮿 Slim-Line seismic cabinet with ETSI configuration
쮿 NEBS base mounting
쮿 Dynamic loading: 350 kg
쮿 Shielded version (EMC)
쮿 Complete cabling
쮿 Power distribution
쮿 Special cable entry in top cover
쮿 Doors and side panels with ventilation openings
5430301007023
1.119
VARISTAR MILMain Catalogue
Cabinets – VARISTAR MIL
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
01012005
01010017 01010069
Economic and uncompromising - a tailored standard
Schroff offers robust 19" cabinets that meet the specifications of
MIL-S-901D. Their characteristics allow you to meet the most
stringent shock and vibration resistance requirements on the
high seas:
This cabinet was developed on the basis of the VARISTAR platform
and impresses with its high integration capability.
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
쮿 High-performance elastomer or wire cable shock absorbers
for COTS (commercial off-the-shelf) equipment
쮿 19" standard, in accordance with RoHS
쮿 Various dimensions available (height and depth)
Systems . . . . . . . 8
쮿 Wide range of accessories available
쮿 Reduced development and manufacturing costs
쮿 HF shielding
01010068
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
From the qualification ... to the customer solution
A cabinet for your individual requirements can be quickly and
easily developed. It can be validated by numerical simulation
thereby saving lengthy and expensive tests in laboratory. The
elastic suspension is specially adapted to the mechanical
environment and the resilience of the components. At the same
time, the dimensions and weight of the cabinet are tailored to your
specific integration requirements. The design is validated using a
model that has been calibrated in real tests using a finite element
calculation.
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.120
01010070
Finite element model - mesh and stress
analysis
SCHROFF Further information: www.varistar.de E 05/2016
Overview . . . . . . 1.120
VARISTAR MILMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days
The cabinet for the most demanding situations
쮿 Certified: Tested to MIL 901D
쮿 Capable of handling extreme stresses: Robust and secure for mobile use; dynamic loadcarrying capacity of 150 kg
쮿 Reliable: Shielded against high-frequency interference
쮿 Not susceptible: Type of protection IP 55
VARISTAR with shock absorbers
쮿 Two versions:
4 shock absorbers at bottom and 2 at top, for wall mounting
– With wire cable shock absorbers
– with elastomer shock absorbers
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
VARISTAR MIL
VARISTAR
MIL 901D . . . . . . . . 1.122
쮿 Height 38 U (1800 mm), width 600 mm, depth 800 mm
01012002
ServicePLUS . . . 1.123
ServicePLUS from page 1.123
e.g. special colours
e.g. other cabinet dimensions
e.g. higher dynamic load carrying capacity
e.g. custom solutions
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . 1.54
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR Air/
water heat
exchanger . . . . . . 1.224
www.schroff.biz/ServicePLUS
30407004
1.121
MIL 901D cabinets
VARISTA R MILMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Cabinet for extreme mobile situations
쮿 4 shock absorbers at bottom and 2 shock absorbers at top
쮿 Ingress protection IP 55
쮿 EMC protection
쮿 Tested to MIL-STD-901D
쮿 Rear panel horizontally partitioned for fitting of e.g. cable
ducting
Delivery comprises (assembled)
Wire cable shock absorbers
01011001
Elastomer shock absorbers
01012004
Item
1
Qty
1
2
3
1
1
4
1
5
6
7
8
1
1
2
4
9
1
Description
Welded basic frame, heavy duty, St profile, RAL 7032,
with reinforcement brackets welded on floor frame,
10 mm, St, finish AlZn;
base plate, St; 4 shock absorbers; EMC gasket
Flat top cover, flush, St, finish AlZn, exterior RAL 7032
Front door, St, finish AlZn, RAL 7032, 180° hinge,
4-point locking, lever handle
Rear panel, top, screw fixed, St, finish AlZn, RAL 7032;
2 shock absorbers;
Rear panel, centre, screw fixed, St, finish AlZn, RAL 7032
Rear panel, bottom, screw fixed, St, finish AlZn, RAL 7032
Side panel, screw fixed, St, AlZn, RAL 7032
19" panel/slide mount with EIA perforation,
St, finish AlZn, depth-adjustable in 25 mm increments
GND/earthing kit, assembled
Order Information
Height
U
mm
Width
mm
Depth
mm
38
1800
600
800
38
1800
600
800
01011003
Description
absorbers
absorbers
Part no.
10130-198
10130-201
Note
쮿 Other dimensions and versions on request
Rear view
1.122
SCHROFF Main catalogue
01012003
www.schroff.biz E 05/2016
solution
Integration and custom developments
cabling (power supply), function test
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports,
user reports
쮿 Further information: www.varistar.co.uk
lifecycle
We are with you. For the entire product life. the product.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
Mobile applications for marine use
쮿 Heavy-Duty seismic cabinet with shock absorbers for use on
ships
쮿 Special connection plate for shielded cable entry
쮿 Integrated air filtered fan in the door
쮿 Customer-specific testing (vibration, EMC, climate)
32403011
01008022
1.123
Varistar Datacom /NetworkingMain Catalogue
Cabinets – Varistar Datacom/Networking
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01006049
Subracks/
Front panels,
01006023
Professional cable management
01006033
Robust pull-out tilt protection
Power supply
01006084
Universal mounting possibility: With a
mounting space of 740 mm between
front and rear 19" plane in the standard
version, around 90 % of all server types
can be fitted immediately.
Easy installation of servers with special
dimensions by additional partial-height
mounting and further 19" brackets.
Backplanes . . . 10
Connectors, front
panel component
01006024
Large variety of accessories for all
cabling zones
01006032
Heavy load shelves and slide rails
1.124
SCHROFF PRODUCT CATALOG E 05/2016
Cabinets – VARISTAR Datacom/Networking
Overview . . . . . 1.124
VARISTAR Datacom /NetworkingMain Catalogue
Made for datacom and cabling technology
Varistar Platform 1.4
Dimensions . . . . . 1.8
쮿 Two frames with different stability but identical outer appearance
쮿 Two colour schemes for immediate selection with ServicePLUS
쮿 Wide range of versions and dimensions (depths 600 mm to 1200 mm)
쮿 Unique meander profile with multiple mounting options and
new cable management possibilities
Varistar NET
Varistar NET Plus
01006012
Varistar Server
01006011
쮿 Cabling cabinet with one
19" plane
쮿 Datacom cabinet with two
19" planes and base
쮿 Single and side-by-side cabinets
01006014
쮿 Server cabinet with perforated
front and rear door, up
to 1200 mm deep
Varistar NET. . . . .
Varistar NET Plus
Varistar Server . . .
Assembly kit . . . .
Castors. . . . . . . . .
Lifting eye . . . . . .
Top cover fan . . .
Edge protection .
Brush strip . . . . .
Base plate . . . . . .
Base/plinth . . . . .
Tilt protection . . .
19 panel/slide
mounts . . . . . . . . .
Depth members .
Slide rails. . . . . . .
19" shelves . . . . .
Electronic locking
Zone 1,
zone 2 cable
management . . . .
Zone 3 cable
management . . . .
Zone 4 cable
management . . . .
Cable tie,
Velcro . . . . . . . . . .
Tray for excess
cable lengths . . .
1.126
1.130
1.130
1.132
1.132
1.133
1.133
1.136
1.136
1.137
1.139
1.141
1.142
1.143
1.144
1.145
1.148
1.155
1.158
1.161
1.162
1.163
ServicePLUS . . . 1.164
ServicePLUS
RAL 7021 . . . . . . . 1.165
ServicePLUS RAL
7035/RAL 7021 . . . 1.189
ServicePLUS from page 1.156
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
e.g. custom solutions (special sizes)
Varistar
Varistar EMC.
Varistar Seismic .
VARISTAR air/
water heat
exchanger . . . . .
1.10
1.54
1.84
1.224
30407004
SCHROFF.PENTAIR.EN
1.125
Varistar server, 1600 kg
VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Server cabinet with perforated doors, airflow rate 78%
5
쮿 Protection class IP 20
3b
쮿 Static load-carrying capacity up to 1600 kg
3a
쮿 Installation of different servers possible
2
쮿 Available in two color schemes
– Stone gray RAL 7021
– Light gray RAL 7035
1
Delivery includes
Item
1
Qty
1
2
3a
3b
4
1
1
1
1
5
1
6
2
7
4
8
4
9
10
4
1
4
H
6
7
8
W
D
20 - 45
9
01014055
1.126
Description
Welded basic frame (Slim-Line) from steel
profiles, RAL 7021
Flat top cover, St, RAL 7021; with cutouts for brush strips
Brush strip for 600 mm and 800 mm widths
Brush strip for 800 mm width only
Front door, St, with 180° hinges and perforation, 3-point
locking and lever handle (can optionally be expanded with
DIN profile half cylinder), color RAL 7035 or RAL 7021
(see Ordering Information)
Rear double door, St, with 180° hinges and perforation,
3-point locking and lever handle (can optionally be
expanded with DIN profile half cylinder), color RAL 7035
or RAL 7021 (see Ordering Information)
Side panels, screw fixed, St, with inside locking, color
RAL 7035 or RAL 7021 (see Ordering Information)
19" panel/slide mounts, St, mounted in 740 mm intervals,
color RAL 7035 or RAL 7021 (see Ordering Information)
Cross member, St (to accept 19" panel/slide mounts in
800 mm wide cabinets)
Adjustable foot
Earthing kit, fitted
VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days
Order Information
Heig Height Width W Depth Colour
ht
H
D
U
mm
mm
mm
42
2000
600
1200
42
2000
800
1200
Stone gray
RAL 7021
47
2200
600
1200
47
2200
800
1200
42
2000
600
1200
42
2000
800
1200
Light gray
RAL 7035
47
2200
600
1200
47
2200
800
1200
Accessories
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Spare key Handle with locking insert (6) 1 piece
Tip-over protection for floor mounting is screwed to the
floor, PU 2 pieces
Part no.
10130-234
10130-232
10130-235
10130-233
10130-240
10130-238
10130-241
10130-239
25127-995
60127-018
23130-386
01014056
ServicePLUS see page 1.164
SCHROFF.PENTAIR.EN
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.127
Varistar Colocation
VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 Colocation cabinets with 2, 3 or 4 divider units to accommodate
e.g. servers
– Perforated doors (airflow rate 78%)
– Multi-point door locking to prevent unauthorized access
(Iever handle with key and numeric code)
– Access to false floors and cabling only from the appropriate
divider unit
쮿 Flexible cabling, possible from above, below, left or right
(data and power cables can be run separately)
쮿 Color RAL 7021 (black gray)
Delivery includes
Illustration shows cabinet with 3 divider units
01013001
2
Item
1
Qty
1
2
1
3
2 per
divider
unit
2 per
divider
unit
2 per
divider
unit
2 per
divider
unit
4 per
divider
unit
2 per
divider
unit
4
1
4
5
5
6
1
4
7
6
8
3
9
10
7
Description
profiles, RAL 7021
Flat top cover, St, RAL 7021, with brush strip
(left and right)
Front door, rack St, perforated, RAL 7035, 180°
hinge, 2-point locking and lever handle (key and
numeric code)
Rear door, St, perforated, RAL 7021, 180° hinge,
2-point locking and lever handle (key and numeric
code)
Cable channels, left and right
Depth member for fixing false floors and 19" profiles
19" panel, St, RAL 7035, with EIA perforation, depthadjustable in 25 mm increments, standard fitting
position 74 mm recessed
Base plate can be mounted from inside
Adjustable foot
5
8
9
01013050
Detail of a divider unit
1.128
01013002
Varistar Colocation
VARISTAR Datacom/NetworkingPart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Order Information
01013051
Height
mm
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
Width
mm
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
Depth
mm
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
Number of
subdivisions
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
Part no.
10130-202
10130-203
10130-204
10130-214
10130-215
10130-216
10130-205
10130-206
10130-207
10130-217
10130-218
10130-219
10130-208
10130-209
10130-210
10130-220
10130-221
10130-222
10130-211
10130-212
10130-213
10130-223
10130-224
10130-225
Note
쮿 Side panel must be ordered separately
쮿 For suitable side panel see page 1.167
쮿 Cable panel, see page 1.160
01013004
Illustration: Cable panel, two-sided through entire cabinet height,
cable entry top/bottom
Detail: Lever handle with
numeric code
01013003
SCHROFF.PENTAIR.EN
Part number in bold face type: ready for despatch within 2 working days
1.129
Varistar NET Plus
쮿 Cabling cabinet with two 19" planes and base/plinth
쮿 Type of protection IP 20
쮿 Load-carrying capacity 400 kg according IEC 61587-1
쮿 Available in two versions
– Single cabinet (with side panels)
– Side-by-side cabinet (with side-by-side mounting kit)
Delivery comprises (Completely assembled and earthed)
Side-by-side cabinet (without side panel)
1.130
Single cabinet
01006011
Item
1
Qty
1
2a
1
2b
1
3
1
4
1
5a
2
5b
6
1
4
7
4
8
1
9
1
10
1
Description
Welded basic frame (Slim-Line) from steel profiles,
RAL 7021
From cabinet height 42 U/47 U:
top cover, St, RAL 7021 with prepunched perforation for
subsequent assembly of brush strip, perforated cover
plate or fan tray
Cabinet height 24 U:
top cover, St, RAL 7021, without cut-out zone
Front door: frame St, RAL 7035, with
safety glass 6 mm and 180° hinge,
single point locking and lever handle
(optionally with DIN profile half cylinder)
Rear door, St, RAL 7035, with 180° hinge,
(optionally retrofittable with DIN profile half cylinder)
Single cabinet: side panels, St, RAL 7035,
with quick-release fastener
Side-by-side cabinet: 1 side-by-side mounting kit
Adaptor bracket for reduced width, St, finish AlZn,
for assembly of 19" panel/slide mounts (only with
19" panel/slide mount, St, RAL 7035, with EIA perforation
(800 mm wide cabinets: assembled on the adaptor
bracket for reduced width),
600 mm cabinet depth: distance to front door 50 mm,
at 800 mm 150 mm,
from 900 mm cabinet depth: 70 mm;
Base plate for lateral cable ducting, St, RAL 7021,
subsequent lateral assembly of brush strip possible
Base/plinth, St, RAL 7021, height 100 mm with front and
rear ventilation trim, mounted base/plinth trims,
integrated feet
Varistar NET Plus
Order Information
Height
01005102
Height Width Depth
Side-by-side
H
W
D
cabinet
U
mm
mm
mm
Part no.
24
1200
600
600
10130-073
24
1200
600
800
10130-075
24
1200
600
900
10130-077
24
1200
600
1000
10130-079
24
1200
800
600
10130-081
24
1200
800
800
10130-083
24
1200
800
900
10130-085
24
1200
800
1000
10130-087
42
2000
600
600
10130-089
42
2000
600
800
10130-091
42
2000
600
900
10130-093
42
2000
600
1000
10130-095
42
2000
800
600
10130-097
42
2000
800
800
10130-099
42
2000
800
900
10130-101
42
2000
800
1000
10130-103
47
2200
600
600
10130-105
47
2200
600
800
10130-107
47
2200
600
900
10130-109
47
2200
600
1000
10130-111
47
2200
800
600
10130-113
47
2200
800
800
10130-115
47
2200
800
900
10130-117
47
2200
800
1000
10130-119
handle (1 key fits all locks) incl. 2 keys
Tilt protection for base mounting is screwed to the
floor, PU 2 pieces
Single cabinet
Part no.
10130-072
10130-074
10130-076
10130-078
10130-080
10130-082
10130-084
10130-086
10130-088
10130-090
10130-092
10130-094
10130-096
10130-098
10130-100
10130-102
10130-104
10130-106
10130-108
10130-110
10130-112
10130-114
10130-116
10130-118
25127-995
23130-386
Note
쮿 The 24 U cabinet has a top cover without prepunched
perforation (not suitable for retrofitting with brush strips,
fan tray, etc.)
쮿 A standard cabinet can be expanded simply with additional
components, see from page 1.189
Single cabinet
01005101
SCHROFF.PENTAIR.EN
1.131
Assembly kit
쮿 For direct assembly of 19" panel/slide mounts, depth members
and further components on Varistar frame
쮿 Assembly by clipping in the cage nut into frame or
depth member
쮿 Mounting of components possible from the inside as well as
from the outside
Delivery comprises (Kit)
Item
1
2
Qty
50
50
Description
Cage nut, St, M5, white zinc-plated
Screw, St, M5 x 10, white zinc-plated
Order Information
Description
Assembly kit, earthed
Part no.
23130-141
01006065
Castors
쮿 For assembly on frame
Delivery comprises
Item
1
2
3
Qty
2
2
1
Description
Locking castor, PA/St
Non-locking castor, PA/St
Assembly kit
Order Information
Description
Castors with 2 locking
01004082
Part no.
23130-077
Note
쮿 Not suitable in connection with base/plinth
Castors with integrated adjustable feet
Delivery comprises
Item
1
2
Qty
4
1
Description
Castor with adjustable feet
Assembly kit
Order Information
Description
Part no.
23130-078
Note
01004156
1.132
Lifting eye, Varistar
쮿 Thread M12
쮿 Application and static load-carrying capacity in accordance with
DIN 582 (see Technical Info Section, chapter 12)
Order Information
Description
Lifting eye for top cover
Qty/PU
4
Part no.
23130-072
Note
쮿 Only suitable with top cover, not usable with raised cover
M12
01004100
Fan unit with 3 fans
쮿 Suitable for flat top cover with cut-out zones
쮿 Mounting position completely in cabinet interior, no protrusion
over top cover
쮿 3 fans fully wired
쮿 Mains connection via SCHUKO/UTE plug IEC 60320 C13 socket
Delivery comprises (completely assembled and wired)
01006027
Item
1
2
Qty
1
3
3
4
3
1
Description
Fan tray, RAL 7021
Axial fan 230 VAC, fully wired,
connects via SCHUKO/UTE plug - IEC 60320-C12 socket
Protective grille
Assembly kit
Order Information
Description
Qty/PU
pieces
1
Part no.
Accessories
Fan with grille, 230 VAC, 38 x 119 x 119 mm, 162 m3/h at 50
Hz, 1 piece
Thermostat with mains cable 230 VAC (SCHUKO/UTE plug/
IEC 60320 C13 socket), adjustment range 0 ... 60°C, 1
piece
23130-070
23130-165
20118-750
Technical data of one fan
Frequency
Voltage
Airflow volume
Noise pressure level
Max. static pressure
Max. ambient temperature
Power consumption
50 Hz
230 VAC
162 m 3/h
37 dB(A)
73 PA
+70 °C
15 W
60 Hz
230 VAC
192 m3/h
41 dB(A)
88 PA
+70 °C
14 W
01004102
SCHROFF.PENTAIR.EN
1.133
Cabinets – VARISTAR
Flat top cover with cut-out zones
VARISTA RMain CatalogPart number i n bold face type: ready for shipping w ithin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Cut-out zones are easy to cut out.
쮿 Cut-outs can be fitted with brush strips, fan units, perforated
cover plates or edge protectors
Delivery includes
Item
1
Qty
1
2
1
Description
Flat top cover, St, 1.5 mm, with cut-out zones for cutouts, RAL 7021
GND/earthing kit
Order Information
01006097
01006092
01004102
01004103
41003065
Width
Depth
mm
mm
600
600
600
800
600
900
600
1000
600
1100
600
1200
800
600
800
800
800
900
800
1000
800
1100
800
1200
Accessories
Brush strip Nylon, black, PU 2 pieces
Fan unit with 3 fans with 3 fans, fully assembled and wired,
1 kit
Perforated cover plate for top cover with
cut-out zones 6 mm perforation, incl. earthing, 1 piece
Edge protection PVC, black, 3 m PVC, black, 3 m, 1 piece
Part no.
RAL 7021
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
23130-069
23130-070
23130-071
28127-281
Flat top cover construction with Flat top cover construction with
brush strips
fan insert
Flat cop cover construction with Flat top cover construction with
cover plate
edge protection
1.134
Cabinets – VARISTAR
Flat top cover with cable through-ducting openings
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Includes earthing
쮿 Color RAL 7021
쮿 St, 1.5 mm
쮿 Cutouts must be covered with brush strips, please order these
separately
Delivery includes
01015052
85
D
449
449
a
Item
1
2
Qty
1
1
Description
Flat top cover, St, 1.5 mm, with cutouts, RAL 7021
GND/earthing kit
Order Information
W
b
a
01015050
Flat top cover construction with brush strips
Width W
Depth D
mm
mm
600
1000
600
1100
600
1200
800
1000
800
1100
800
1200
Accessories
Part no.
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
23130-069
28127-281
Note
쮿 Fan insert with 3 fans (23130-070) cannot be used
01015051
Edge protector
41003065
SCHROFF.PENTAIR.EN
1.135
쮿 To cover the sharp edges of an open cut-out (protects against
injury)
Order Information
Description
Part no.
28127-281
41003065
Brush strip
쮿 For cable ducting with flat top cover (with cut-out zones)
쮿 600 mm wide top cover: two brush strips cover one
centre cut-out
쮿 800 mm wide top cover: brush strip can be used either
lengthways or depthways; one brush strip covers a lateral
cut-out, two brush strips cover a centre cut-out
Order Information
Description
Brush strip
Qty/PU
2
Part no.
23130-069
01006092
Cover plate perforated for top cover with
cut-out zones
쮿 Suitable for flat top cover (with cut-out zones), screwed-fixed
쮿 Provides heat dissipation from cabinet (with 6 mm perforations)
Delivery comprises
Item
1
Qty
1
2
1
Description
Top cover plate, perforated, 6 mm perforation, St, 1 mm,
RAL 7021, incl. GND/earthing
Assembly kit
Order Information
Description
cut-out zones
Qty/PU
1
Part no.
23130-071
01009056
1.136
Base plate, multi-piece
쮿 The multi-piece base plate is open at the rear
쮿 The opening may be completed
– with a filter mat
– with a brush strip for the cable entry
– with a cover plate
Delivery comprises (kit)
Item
1
5
Qty
1
1
Description
Multi-piece base plate, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01004050
1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter
kit
Width
Depth
mm
mm
600
600
600
800
600
900
600
1000
600
1200
800
600
800
800
800
900
800
1000
800
1200
Item 2 Cover plate for multi-piece base plate, for 600 mm
wide cabinets, 200 mm deep, incl. assembly kit, 1 piece
Item 2 Cover plate for multi-piece base plate, for 800 mm
Item 3 Brush strip for base plate, for 600 mm wide
Item 3 Brush strip for base plate, for 800 mm wide
Item 4 Filter mat for base plate, white, class M1 in
accordance with EN 799-G3, for 600 mm wide cabinets,
accordance with EN 799-G3, for 800 mm wide cabinets,
Part no.
23130-001
23130-002
23130-003
23130-004
23130-359
23130-005
23130-006
23130-007
23130-008
23130-361
23130-076
23130-136
23130-074
23130-134
23130-075
23130-135
Note
쮿 Is assembled from inside
쮿 Please order cover plate, brush strip or filter mat separately
SCHROFF.PENTAIR.EN
1.137
쮿 The base plate is open on the side; the opening can be covered
with a brush strip (cabinet width 600 mm) or two brush strips
(cabinet width 800 mm)
쮿 Perforated at front for better heat dissipation
Delivery comprises
Item
1
2
Qty
1
1
Description
Base plate, St, 1.5 mm, width 440 mm, RAL 7021
Assembly kit
Order Information
Cabinet width 600 mm
Cabinet width 800 mm
01006061
01006062
For cabinet width W
Depth D
mm
mm
600 / 800
600
600 / 800
800
600 / 800
900
600 / 800
1000
600 / 800
1200
Item 3 Brush strip for base plate for lateral cable
ducting, cabinet depth 600 mm, 200 mm wide,
ducting, cabinet depth 800 mm, 200 mm wide,
ducting, cabinet depth 900 mm, 200 mm wide,
ducting, cabinet depth 1000 mm, 200 mm wide,
ducting, cabinet depth 1200 mm, 200 mm wide,
Part no.
23130-378
23130-353
23130-354
23130-355
23130-357
23130-074
23130-134
23130-374
23130-375
23130-377
Note
1.138
Stationary base/plinth
쮿 Static load-carrying capacity 1000 kg
쮿 Removable trims allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
Delivery comprises ((kit))
2a
H
2b
1
2b
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
2a
D = cabinet depth
W
D
4
01004110
01004053
For cabinet width W
Front/rear trim
mm
600
perforated
600
plain
800
perforated
800
plain
Item 4 Side trim height 100 mm, depth 600 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 900 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 1000 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 1200 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-194
23130-388
23130-169
23130-170
23130-171
23130-172
23130-363
Note
쮿 Please order side trims (item 4) separately
SCHROFF.PENTAIR.EN
1.139
Mobile base/plinth
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
01004111
1.140
01006095
For cabinet width W
mm
600
600
600
600
600
800
800
800
800
800
For cabinet depth D
mm
600
800
900
1000
1200
600
800
900
1000
1200
Part no.
23130-208
23130-209
23130-210
23130-211
23130-369
23130-212
23130-213
23130-214
23130-215
23130-371
Telescopic tilt protection
쮿 Max. 150 kg at full extension
쮿 Lateral and rear cable entry possible
Delivery comprises
Item
1
2
Qty
1
1
3
4
1
1
Description
Guide plate for tilt protection, St, 2 mm, AlZn
Tilt protection, St, 2 mm, RAL 7021,
with 2 adjustable feet
Bezel, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01006054
For cabinet width W
mm
600
600
600
800
800
800
For cabinet depth D
mm
900
1000
1200
900
1000
1200
Part no.
23130-345
23130-346
23130-348
23130-349
23130-350
23130-352
Note
쮿 Only for use in conjunction with plinth or mobile plinth
01006058
Tilt protection for floor mounting
쮿 For fixing to the floor
쮿 Height adjustable by integrated adjustable feet
쮿 Assembly possible on frame or base/plinth
Delivery comprises
Item
1
2
Qty
2
2
Description
Mounting plate, Al
Adjustable foot with outside thread
Order Information
Description
Part no.
23130-386
01006091
SCHROFF.PENTAIR.EN
1.141
19" panel/slide mounts with universal pitch (EIA)
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
Item
1
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
Assembly kit, incl. GND/earthing
Order Information
15,9
42,5
44,45
44.45
12,75
9,6
65,1
2
76
25
25
49,5
01004112
01004131
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
Partialheight
29
1295
23130-032 23130-022
mounting
Partialheight
33
1495
23130-033 23130-023
mounting
Partialheight
38
1695
23130-034 23130-024
mounting
2000
42
1895
23130-035 23130-025
2200
47
2095
23130-036 23130-026
Accessories
Adaptor bracket for reduced width for mounting of panel/
slide mounts in 800 mm wide cabinets, St, 2 mm, AlZn,
PU 4 pieces
Heavy-load cross member Length 1,000 mm, PU 4 pieces
Heavy-load cross member Length 1100 mm, PU 4 pieces
Heavy-load cross member Length 1,200 mm, PU 4 pieces
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
23130-016
23130-091
23130-544
23130-545
23130-546
25127-997
Note
쮿 Please order adaptor bracket for reduced width for 800 mm
wide cabinets separately
쮿 For 19" partial-height mounting, depth members are required
쮿 Metric panel/slide mounts available on request
1.142
Depth members
쮿 For mounting of shortened 19" panel/slide mounts
쮿 Cable ducting by means of cable ties and cable eyes
Delivery comprises
Item
1
2
50
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
L
01004126
01004079
Cable eye
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Assembly kit incl. GND/earthing
Order Information
For cabinet depth
Length L
mm
mm
600
460
800
660
900
760
1000
860
1200
1060
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-081
23130-082
23130-083
23130-084
23130-365
21101-151
21101-150
Note
쮿 Cable ducting with cable ties see page 1.162
coa43697
19" assembly kit, M6
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
SCHROFF.PENTAIR.EN
1.143
Slide rails
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
D
c
c - 130
쮿 Wide support surface (48 mm)
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
xf
Delivery comprises
01004130
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Order Information
Static load carrying capacity 25 kg
For cabinet depth
mm
600, 800
600, 800
800
800
900, 1000, 1200
900, 1000, 1200
xf
mm
50
50
150
150
70
70
c
mm
500, 700
500, 700
500
500
740
740
Length L
mm
456
456
456
456
699
699
Qty/PU
2
10
2
10
2
10
Part no.
23130-096
23130-101
23130-096
23130-101
23130-098
23130-103
Order Information
01005086
Static load carrying capacity 100 kg
For cabinet depth
mm
600, 800
600, 800
800
800
900, 1000, 1200
900, 1000, 1200
xf
mm
50
50
150
150
70
70
c
mm
500, 700
500, 700
500
500
740
740
Length L
mm
458
458
458
458
699
699
Qty/PU
2
10
2
10
2
10
Part no.
23130-118
23130-123
23130-118
23130-123
23130-120
23130-125
01004058
Short slide rails
쮿 Support for heavy 19" chassis
쮿 To attach on 19" slide mounts
쮿 Static load-carrying capacity max. 15 kg per pair
Delivery comprises
Item
1
2
sc96xxxx
Qty
2 / 10
1
Order Information
Description
Short slide rail
Short slide rail
1.144
Description
Short slide rail, St, 1.5 mm, finish AlZn
Assembly kit
Qty/PU
2
10
Part no.
23130-094
23130-095
19'' fixed shelf, 75 kg
쮿 Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
c
D
For cabinet
Usable
xf
c
RAL 7035
depth
surface w x d
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 442
150
500
22130-303
900
495 x 682
70
740
22130-309
1000
495 x 682
70
740
22130-309
1200
495 x 682
70
740
22130-309
Strengthening rail for stationary 19" shelf PU 1 piece
xf
d
Order Information
w
RAL 7021
Part no.
21130-303
21130-303
21130-309
21130-309
21130-309
23130-310
Note
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
쮿 Other sizes see ServicePLUS page 1.165
19" shelf, stationary, depth-adjustable, 1 U
쮿 Static load-carrying capacity 68 kg
쮿 For mounting on four 19" uprights or four panel/slide mounts
D
쮿 Variable mounting dimensions (depth-adjustable)
쮿 2 Versions
– Mounting dimension 495 ... 851 mm
– Mounting dimension 792 ... 1151 mm
44
441
쮿 2 oval cut-outs for cable ducting
쮿 Colour black, RAL 9005
465
483
Delivery comprises
87928708
Item
1
Qty
1
2
1
Description
Shelf, depth-adjustable, width 19", height 1 U,
RAL 9005 (black)
Fitting materials with user manual
Order Information
Mounting dimension D 495 ... 851 mm
Mounting dimension D 792 ... 1151 mm
Part no.
D19FVT69B
D19FVT912B
Note
쮿 19" assembly kit see page 1.143
SCHROFF.PENTAIR.EN
1.145
19'' telescopic shelf, 30 kg
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50
500
22130-343
800
417 x 482
150 500
22130-343
GND/earthing for telescopic 19" shelf PU 1 kit,
for Varistar
RAL 7021
Part no.
21130-343
21130-343
23130-140
Note
xf
d
Full depth
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50
500
22130-342
800
417 x 382
150 500
22130-342
for Varistar
RAL 7021
Part no.
21130-342
21130-342
23130-140
Note
D
c
xr
w
xf
d
쮿 Cable ducting with cable ties, see page 1.162
c = max. pitch of the 19" panel/slide mounts
1.146
01004070
19'' telescopic shelf, 70 kg
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 482
150 500 22130-353
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
for Varistar
xf
d
Order Information
01004069
Shortened depth
RAL 7021
Part no.
21130-353
21130-353
23130-092
23130-140
Note
쮿 Please order T-bar lock (item 4) separately
W
w
xr
Order Information
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 382
150 500 22130-352
for Varistar
d
c
Shortened by 100 mm
RAL 7021
Part no.
21130-352
21130-352
23130-092
23130-140
Note
xf
SCHROFF.PENTAIR.EN
01004070
1.147
Lever handle for
쮿 For installation instead of key lock insert
쮿 To open press push-button
쮿 DIN profile half cylinder retrofittable
Delivery comprises
Item
1
2
Qty
1
1
Description
Lever handle for single point locking
Assembly kit
Order Information
Description
01005016
Part no.
23130-067
25127-995
Note
쮿 Other locks such as ASSA, KABA or RONIS available on request
Electronic closing (stand-alone)
쮿 Complete package comprising a handle with keyboard (master)
and a handle with opening function (slave) plus all necessary
electrical connection components
쮿 Suitable for all Varistar cabinet doors with single point or
3-point locking and S2100 door handle cut-out
쮿 Front and rear door can be opened together or separately by
means of coding
Item
1
Qty
1
2
1
3
1
4
5
6
1
1
1
41003035
4
3
Description
Electronic lever handle with keyboard (master) for front
door, 4 m connecting cable and ferrules
Electronic lever handle, opener (slave) only, for rear
Plug-in power supply AC/DC with Euro plug,
input voltage 100 VAC ... 230 VAC,
output voltage 12 VDC /700 mA
Central unit with case
Cable ducting
Assembly kit, operating instructions
Order Information
2
Description
Electronic closing
Part no.
20130-598
1
01007054
1.148
ELECTRONICS PROTECTION
Electronic locking (MLR 3000)
쮿 Electronic door handles for Varistar cabinets
쮿 Modular solution with electronic door locking, reader unit,
PSU and administration software
쮿 Integrated visualization, LED display for alarm signals and
operating statuses
쮿 Two locking options: standalone and networked
쮿 Access reporting and user management
쮿 Sabotage and vandalism alarm
Delivery includes
Item
1a
Qty
1
1b
1
1c
1
Description
Electronic door lock MLR 3000 with lever handle and card
reader unit; display with status LEDs;
reader (125 kHz-HDI, 13,56 MH5-MIFARE)
Card reader unit (supply voltage 12 VDC , 40 mA,
(max. 440 mA); Temperature range -20 ... +70 °C
Junction (distribution box)
01013014
Order Information
Qty/PU
piece
Electronic locking (MRL3000), 125 KHz-HDI
1
Electronic locking (MRL3000), 13.56 MHz-MIFARE 1
Accessories
Part no.
23130-513
23130-565
Electronic door lock MLR1000 (slave),
1 piece
23130-512
PSU for electronic locking 1 piece
23130-515
Gateway for electronic door lock 1 piece
23130-523
Administration Suite Software 1 piece
60130-680
Reader cards for electronic locking,
125 KHz-HDI PU 10 pieces
23130-526
13.56 MHz-MILFARE PU 10 pieces
23130-566
Standalone function cards,
125 KHz-HDI PU 4 pieces
60130-678
13.56 MHz- MIFAREPU 4 pieces
60130-832
Battery pack for electronic locking
1 piece
60130-729
Desktop reader, 125 KHz-HDI 1 piece
60130-730
Desktop Reader, 13.56 MHz-MIFARE
1 piece
60130-830
LAN
OUTPUT CONFIG
Description
ff
hro ff
SScchro
ff
chrooff
S
Schrroff
Sch
Sch
S ro
S ch ff
S ch roff
S ch roff
ch ro
ro ff
ff
Schroff
Schroff
Schroff
Schro
ff
SCHROFF.PENTAIR.EN
1.149
Standalone solution:
- Lever handle with HID 125 kHz reader unit (Mifare on request)
- Reader cards are set up and issued directly on handle using the
HID standalone function cards
Standalone solution
Networked solution:
- Access is managed centrally via the network
- Reader cards are issued via the management software
- The Gateway allows up to 32 door handles to be controlled
Networked solution
2
1a
4
3
2a
1a
1a
1b
1c
1b
5
2b
1b
LA
01014051
N
01014052
Required number of components for one cabinet with front and
rear door (standalone solution)
Required number of components for two cabinets with front and
rear door (networked solution)
Item
Description
Item
Description
1a
1b
2
Electronic door lock MLR3000
Stand-alone card reader unit
Power supply unit for door lock
Cards (set of 10)
HID stand-alone function cards
Battery pack (optional)
1a
1b
1c
2a
2b
3
4
5
Card reader unit
Junction
Junction
PSU for door lock/gateway
Access management software, administration
suite via network
Cards (set of 10)
Desktop reader (optional)
1.150
Required
number
Piece
2
2
1
1
1
Order no.
23130-513
23130-515
23130-512
60130-678
60130-729
Required
number
Piece
Order no.
2
23130-513
2
23130-512
5
1
1
23130-515
23130-523
60130-680
1
1
1
23130-526
23130-730
60130-729
operating statuses
쮿 Lever handle opens when switch contacts touch
Delivery includes
Item
1a
Qty
1
1b
1
Description
Electronic door lock MLR1000 with lever handle,
display with multicolor status LED
Junction (distribution box), power supply via 12 VDC
socket, 40 mA (max. 440 mA); temperature range
-20 ... +70 °C
Order Information
Description
01013014
Accessories
Qty/PU
piece
1
Part no.
23130-512
23130-515
VARISTAR Electroni csMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Battery pack allowing emergency opening of lever handle
(MLR 3000) in event of power failure
쮿 Power is supplied to the handle from below, allowing door then
to be opened using an authorized access card
Delivery includes
Item
1
Qty
1
Description
Battery pack, 12 V, width 145 mm, height 72 mm,
depth 34 mm
Order Information
Description
Qty/PU
piece
1
Part no.
60130-729
01014001
SCHROFF.PENTAIR.EN
1.151
쮿 Power adapter to supply lever handle (MLR 3000, MLR1000) and
gateway
Delivery includes
Item
1
Qty
1
Description
Power adapter, 230 VAC (IEC 60320-C13 plug), 12 VDC,
(cable length 1230 mm)
Order Information
Description
01014054
Qty/PU
piece
1
Accessories
Mains cable, IEC IEC 60320 C14 plug,
IEC 60320 C13 socket, 2.5 m, 1 piece
Mains cable, BS British Standard plug,
Mains cable, SCHUKO/UTE SCHUKO/UTE plug,
IEC 60320 socket, 2.5 m, 1 piece
Part no.
23130-515
60197-053
60103-137
62150-191
Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days
쮿 Reader cards for electronic locking (MLR3000)
Delivery includes
ff
hro ff
SScchhro
ff
c hrrooff
S
Scch
ff
ro
S
Item
1
Sch
S ro
S ch ff
Scchrroff
S h off
ch ro
ro ff
ff
Qty
10
Description
Reader card for reader unit
Order Information
Description
125 KHz-HDI
13.56 MHz-MILFARE
Qty/PU
Part no.
PU 10 pieces
23130-526
PU 10 pieces
23130-566
12514051
쮿 Code cards for programming standalone locking
Delivery includes
Item
1
2
3
4
5
Schroff
Schroff
Schroff
Schro
ff
Qty
1
1
1
1
1
Description
Card (unlocking card)
Card (locking card)
Card (group card)
Card (general card)
User manual
Order Information
12514050
1.152
Description
Standalone function cards, 125 KHz-HDI
Standalone function cards, 13.56 MHzMIFARE
Qty/PU
PU 4 pieces
60130-678
Part no.
PU 4 pieces
60130-832
Access management software, Administration Suite
쮿 The Administration Suite enables you to document and protect
all access to indoor cabinets and enclosures. You have
complete control and also have a high level of flexibility
쮿 Alarm management, the possibility of managing systems in
different time zones and managing different installations.
쮿 Flexibility, a clear overview and user-friendly design make this
software easy to use and an effective management system for
data and server cabinets protected with E-LINE by DIRAK
쮿 The integrated web client lets you link any number of users with
the administration suite via a web browser. Any device with a
browser function (iPad®, tablet computers, iPhone®,
Blackberry® etc.) can operate the web client of the
administration suite without additional software installation
Delivery includes
Item
1
Qty
1
Description
CD with software and documentation
Order Information
Description
Qty/PU
piece
1
Part no.
60130-680
01014004
Desktop reader
Elec tricsMain C atalogP art number in bold fac e type: ready for shipping within 2 w orking daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Card reader unit for networked solution
쮿 Centralized allocation of reader cards using administration
suite software
Delivery includes
Item
1
Qty
1
2
1
Description
Desktop reader, width 107.5 mm, depth 108.5 mm,
height 23.75 mm
USB connecting cable, length 1800 mm
Order Information
Description
01014002
SCHROFF.PENTAIR.EN
Desktop reader, 13.56 MHz-MIFARE
Qty/PU
piece
1
1
Part no.
60130-730
60130-830
1.153
Gateway for electronic locking
쮿 Connects to Ethernet network
Delivery includes
OUTPUT CONFIG
Item
1
Qty
1
Description
Gateway, width 75 mm, depth 70 mm, height 29 mm
Order Information
Description
LAN
Accessories
Qty/PU
piece
1
Part no.
23130-523
23130-515
01014053
1.154
Zone 1 cable management
쮿 Cable ducting zone 1 is located in the front area of the cabinet,
in front of the 19" plane
쮿 In this zone the patch cables are ducted horizontally between
the distribution fields
Products
쮿 Cable ducting see chapter Cabinet accessories, from page 3.5
쮿 19'' distribution field, Cat 5/6, see chapter Cabinet accessories,
page 3.14
01006087
Zone 2 cable management
쮿 The cable ducting zone 2 is located on the right and left hand
side in the front area of the cabinet, next to the 19" plane
쮿 The patch cables are ducted in a kind of channel to the
individual distribution fields and components
Products
쮿 Cable eyes see from page 1.156
쮿 Cable brackets for fibre optic cables, see page 1.157
쮿 Shielding panel, see page 1.157
01006088
SCHROFF.PENTAIR.EN
1.155
Cable eye, plastic
쮿 For assembly on cabinet uprights in 800 mm wide cabinets
쮿 Simple and fast assembly by clicking into the cabinet profile
(without assembly kit)
쮿 Cable ducting laterally in front of the 19" panel/slide mounts
쮿 With additional assembly kit also suitable for lateral assembly
on the 19" panel/slide mounts
Delivery comprises
Item
1
Qty
4
Description
Cable eye, PA, UL 94 V-0, black
Order Information
Illustration shows application (W, D = 100 mm)
01006078
43
For cabinet width
W
mm
mm
600
31
800
100
Accessories
Taptite screw M6 Taptite, PU 50 pieces
D
mm
92
100
Part no.
23130-506
23130-336
23130-285
92
31
W = 31 mm, D = 92 mm
01012085
W, D = 100 mm
01006079
Cable eye, steel
쮿 For assembly on cabinet uprights (800 mm cabinet width) or
laterally to the 19" panel/slide mounts
쮿 Cable ducting laterally next to and/or in front of the 19" panel/
slide mounts
Delivery comprises
Item
1
2
3
Qty
4
4
1
Description
Bracket, St, zinc-plated,
Terminal, Al, die-cast
Assembly kit
Order Information
01006080
01006081
1.156
For cabinet width
mm
800
800
W
mm
100
100
D
mm
100
180
Part no.
23130-341
23130-342
01006098
Fibre optic cable ducting
쮿 Assembly on 19" panel/slide mounts
쮿 For secure laying of optical fibre cables
Delivery comprises
Item
1
2
Qty
2
1
Description
Fibre optic cable ducting, PA, UL 94 V-0, black
Assembly kit
Order Information
Description
Part no.
23130-372
01006074
Cover panel, hinged
쮿 For use in 2000 mm high and 800 mm wide cabinets
쮿 For lateral covering of e.g. the patch cables
쮿 Optionally with brush strip
Delivery comprises
Item
1
2
Qty
2
1
Description
Cover panel, St, 1 mm, RAL 7021
Assembly kit
Order Information
Height
Width
Qty/PU
mm
mm
piece
2000
100
2
Brush strip for cover panel height 2000 mm, PU 2 pieces
Part no.
23130-343
23130-379
01006056
SCHROFF.PENTAIR.EN
1.157
Zone 3 cable management
쮿 Is located laterally behind zone 2 across the whole cabinet
depth
쮿 Fibre optic or copper cables are ducted from cable entry in
lateral area of top cover or base plate to rear of distribution
fields
Products
쮿 C-rail or cable support rail for the cabinet depth see from page
1.159
쮿 Or cable ladder from page 1.160
01006085
Cable support rail for cabinet depth
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells (bottom row) and for cable ties, resp. Velcro
(top row)
Delivery comprises
Item
1
2
Qty
2
1
Description
Cable support rail, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01006066
L
60
1
For cabinet depth
Length L
mm
mm
600
466.4
800
666.4
900
766.6
1000
866.4
1200
1066.4
Accessories
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Part no.
23130-326
23130-328
23130-329
23130-330
23130-332
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
Note
쮿 Cable ties and Velcro see page 1.162
01006067
1.158
C-rail for the cabinet depth
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-rail, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
15
Ø
50
11
L
39,5
29,5
L-
,5
x 31
6,5
50
75
01504054
SCHROFF.PENTAIR.EN
C-rail
01004132
For cabinet depth
Length L
mm
mm
600
460
800
660
900
760
1000
860
1200
1060
Accessories
Cable retention rail for C-rail Width 75 mm,
length 39.5 mm, PU 5 piece
Slide nut for C-profile, PU 10 pieces
Part no.
23130-086
23130-087
23130-088
23130-089
23130-367
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
쮿 Cable ties and Velcro for cable retention rail see page 1.162
01006071
1.159
Cable panel
쮿 For fitting directly onto the frame
쮿 Fixing of cables with cable ties or Velcro
쮿 Widths 150 mm and 250 mm
Delivery comprises
Item
1
2
1
Qty
2
1
Description
Cable panel with cut-outs, St, 1 mm, RAL 7021
Assembly kit
H
Order Information
10
W
01006103
For cabinet height
U
8
9
12
14
18
42
47
38
42
47
H
mm
446
496
604
670
917
1019
1700
1900
2100
1700
1900
2100
W
mm
110
110
110
110
110
110
150
150
150
250
250
250
Part no.
23130-501
23130-504
23130-500
23130-503
23130-499
23130-502
23130-420
23130-421
23130-422
23130-149
23130-150
23130-151
Note
Cable ladder
쮿 For mounting in 2000 or 2200 mm high cabinets
쮿 Cables are fixed in place with cable ties or Velcro
Delivery includes
Item
1
2
1
Qty
2
1
Description
Cable ladder, round steel, zinc-plated
Assembly kit
Order Information
H
For cabinet height
mm
2000
2200
Height H
mm
1800
2000
Width
mm
300
300
Depth
mm
30
30
Part no.
23130-554
23130-555
Note
30
300
01014057
1.160
Zone 4 cable management
쮿 Cable ducting on the inside of the cabinet rear panel across the
entire cabinet width
쮿 Top cover openings can be used for cable ducting
Products
쮿 C-rail and cable support rail for the cabinet width see from page
1.161
01006086
Cable support rail for cabinet width
쮿 For cable ducting in rear area of cabinet
(top row)
Delivery comprises
Item
1
2
Qty
2
1
Description
Assembly kit
Order Information
01006077
For cabinet width
Length L
mm
mm
600
550
800
750
Accessories
Part no.
21236-093
23130-312
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
Note
01006076
SCHROFF.PENTAIR.EN
1.161
Cabinets – VARISTAR
C-rail for cabinet width
VARISTA RMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-rail, St, 1.5 mm, finish AlZn
Order Information
01006063
C-rail
Slide nut
For cabinet width
Length
mm
mm
600
550
800
750
Accessories
Slide nut for C-rail, PU 10 pieces
Part no.
23130-333
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable tie, Velcro
MechanicsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
1.162
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
Deposit for excess cable lengths
쮿 For fixing on shelf or depth member
쮿 Height with shelf is 2 U
Delivery comprises
Item
1
Qty
2
2
1
Description
Deposit for excess cable lengths, St, 1.5 mm,
height 55 mm, RAL 7021
Assembly kit
Order Information
Description
Part no.
23130-050
Note
쮿 Velcro see page 1.162
쮿 Shelves see from page 1.145
쮿 Depth members see page 1.143
01006068
01006069
VARISTAR Datacom/Networking ServiceP LUS
SCHROFF.PENTAIR.EN
Part number in normal type: ready for despatch within 10 working days
1.163
Cabinets – VARISTAR Datacom/Networking ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined
freely
쮿 Configuration tables from page 1.165
assembly
Assembled by professionals. Double benefit!
Assembly of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Download CAD data and send back with modifications
solution
Simple. Fast. From one source.
쮿 Climate control, complete assembly, cabling (power supply),
function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
academy
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
1.164
lifecycle
replacement parts
Varistar RAL 7021 ServicePLUS: Configuration and assembly
쮿 Dimensions:
– Height: 24 ... 47 U (1200 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 600, 800, 900, 1000, 1100 and 1200 mm
Page
쮿 Colour: Frame and all covers in black grey (RAL 7021)
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all
subsequent configuration pages that apply to these dimensions
(see example below)
쮿 The cabinet is assembled by us and ready for despatch within 10 working days
Frames, side-by-side
mounting kits, adjustable
feet, castors
1.166
Side panels, lateral cable
ducting
1.167
Decorative frames,
glass doors
1.168
Steel doors
1.169
Double doors, cover
panels
1.170
Rear panels,
connection plates
1.171
Top covers
1.172
Flat top covers with cutout zones
1.173
Fan top covers
1.174
Base plates
1.175
Bases/plinths
1.176
1.177
Swing frames
1.179
Shelves
1.180
19" shelves
1.182
Slide rails
1.184
Cable ducting with C-rails,
1.185
cable support rails
Accessories for cabling
1.186
ServicePLUS RAL 7035/
RAL 7021
1.189
01004077
Example configuration (here: row 20)
Qty
1
1
2
1
1
1
SCHROFF.PENTAIR.EN
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
Side panel with quick release fastener, PU 2 pieces
Safety lock for side panel, PU 4 pieces
Rear panel screw-fixed, 1 piece
Glazed door with single point locking, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
21130-051/05
23130-132/05
21130-069/05
21130-129/05
23130-079/05
1.165
RAL 7021
Frames, side-by-side mounting kits, adjustable feet, castors
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
07004078
Completely in RAL 7021
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.166
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
For dynamic load,
static loadcarrying capacity: St, 1.5 mm, zincplated, with
400 kg,
central GND/
St, 1.5 mm, zincearthing
plated, with
point; please
central GND/
order adjustable
earthing point;
feet or castors
please order
separately
adjustable feet or
castors
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
20130-001
20130-002
20130-035
20130-036
20130-578
20130-579
20130-003
20130-004
20130-037
20130-038
20130-005
20130-006
20130-007
20130-008
20130-013
20130-014
20130-015
20130-016
20130-018
20130-019
20130-020
20130-021
20130-580
20130-581
20130-022
20130-023
20130-024
20130-025
20130-582
20130-583
20130-027
20130-028
20130-029
20130-030
20130-584
20130-585
20130-031
20130-032
20130-033
20130-034
20130-586
20130-587
20130-051
20130-052
20130-085
20130-086
20130-588
20130-589
20130-053
20130-054
20130-087
20130-088
20130-055
20130-056
20130-057
20130-058
20130-063
20130-064
20130-065
20130-066
20130-068
20130-069
20130-070
20130-071
20130-590
20130-591
20130-072
20130-073
20130-074
20130-075
20130-592
20130-593
20130-077
20130-078
20130-079
20130-080
20130-594
20130-595
20130-081
20130-082
20130-083
20130-084
20130-596
20130-597
Side-by-side
mounting kit
IP 20
07004117
side-by-side
mounting
brackets
(4 pieces), St
Adjustable feet
01004081
Castors
With 2 jacking
With adjustable
feet
feet
01004082
01004156
for the frame,
for the frame,
for the frame,
static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity:
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
with base/plinth with base/plinth with base/plinth
RAL 7021
PU 1 kit
supplied loose
PU 4 pieces
assembled
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
RAL 7021
Side panels, lateral cable ducting
Side panel
With quick
Lock
release fastener
Screw-fixed side panel
Side panel
Inside locking
Cable panel
Width 150 mm
Lateral cable ducting
Cable panel
Cable ladder
Width 250 mm
Width 300 mm
H
1
10
01004084
01004072
for quick-release
St, 1 mm, incl.
fasteners of one
GND/earthing,
side panel;
please order lock
4 locks sufficient
separately
for 2 side panels
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
RAL 7021
PU 2 pieces
assembled
21130-041
21130-042
21130-524
21130-525
PU 4 pieces
assembled
23130-132
21130-041
21130-042
21130-524
21130-525
21130-043
21130-044
21130-043
21130-044
21130-047
21130-048
21130-047
21130-048
21130-050
21130-051
21130-052
21130-053
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
21130-050
21130-051
21130-052
21130-053
23130-132
21130-055
21130-056
21130-057
21130-058
23130-132
21130-055
21130-056
21130-057
21130-058
23130-132
01004083
St, 1 mm, incl.
GND/earthing
RAL 7021
PU 2 pieces
assembled
21130-001
21130-002
21130-516
21130-517
21130-532
21130-533
21130-001
21130-002
21130-516
21130-517
21130-003
21130-004
21130-003
21130-004
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-012
21130-013
21130-534
21130-535
21130-010
21130-011
21130-012
21130-013
21130-534
21130-535
21130-015
21130-016
21130-017
21130-017
21130-536
21130-537
21130-015
21130-016
21130-017
21130-017
21130-536
21130-537
W
01006104
bracket, St,
1 mm,
finish AlZn;
with retention
screws
01006103
St, 1 mm, with cut-outs
for cable ties or Velcro
see page
1.186
01006075
round steel,
zinc-plated,
height 1800 mm,
for cable ties or
Velcro
see page
1.186
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
23130-373
23130-373
23130-373
23130-373
23130-373
23130-420
23130-149
23130-373
23130-420
23130-149
23130-373
23130-421
23130-150
23130-554
23130-373
23130-421
23130-150
23130-554
23130-373
23130-422
23130-151
23130-555
23130-373
23130-422
23130-151
23130-555
1.167
RAL 7021
Decorative frames, glass doors
Deco frame
Deco frame
Adaptor bracket
01004086
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.168
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004160
Glazed door
Single point
Lever handle
locking
01004088
Glazed door
3-point locking
01004147
with push button
for doors with
single point
locking
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
DIN profile half
cylinder
01004148
for lever handle,
common locking
Al, 19" plane
integrated,
front open, incl.
GND/earthing,
no door can be
fitted
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lock cover,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
21130-231
23130-230
21130-121
23130-067
21130-181
25127-995
21130-122
23130-067
21130-182
25127-995
21130-232
23130-231
21130-123
23130-067
21130-183
25127-995
21130-124
23130-067
25127-995
21130-234
23130-233
21130-127
23130-067
21130-187
25127-995
21130-128
23130-067
21130-188
25127-995
21130-235
23130-234
21130-129
23130-067
21130-189
25127-995
21130-130
23130-067
21130-190
25127-995
21130-236
23130-235
21130-131
23130-067
21130-191
25127-995
21130-132
23130-067
21130-192
25127-995
RAL 7021
Steel doors
Steel door, single point locking
Plain, with
Perforated
mounting frame
on inner side
Plain
01004089
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004089
Lever handle
01004090
01004147
with push button
for doors with
single point
locking
Steel door, 3-point locking
Plain
Perforated
01004090
DIN profile half
cylinder
01004093
St, 1.5 mm,
St, 1.5 mm,
opening angle
opening angle
180°, lever handle
180°, with
mounting frame with push button,
incl. GND/
on inner side,
earthing
lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
St, 1 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing,
designed to carry
extensive cutouts and
assemblies
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
21130-106
21130-566
21130-136
23130-067
21130-151
21130-700
25127-995
21130-107
21130-567
21130-137
23130-067
21130-152
21130-701
25127-995
21130-108
21130-568
21130-138
23130-067
21130-153
21130-702
25127-995
21130-109
21130-569
21130-139
23130-067
21130-154
21130-703
25127-995
21130-112
21130-572
21130-142
23130-067
21130-157
21130-706
25127-995
21130-113
21130-573
21130-143
23130-067
21130-158
21130-707
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
21130-708
25127-995
21130-115
21130-575
21130-145
23130-067
21130-160
21130-709
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
21130-710
25127-995
21130-117
21130-577
21130-147
23130-067
21130-162
21130-711
25127-995
1.169
RAL 7021
Double doors, cover panels
Glazed
Double door, 3-point locking
Plain
Perforated
DIN profile half
cylinder
Hinged
Cover panel
Brush strip for
cover panel
90°
01005065
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.170
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005064
01005066
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Sekurit glass,
lever handle with lever handle with
6 mm,
push button,
push button,
opening angle
incl. GND/
incl. GND/
180°,
earthing
earthing
lever handle with
push button,
incl. GND/
earthing
01004148
01006056
for lever handle, St, 1 mm, to cover
common locking the cabling space
next to the panel/
slide mounts
01006056
black
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
21130-670
21130-657
21130-683
25127-995
21130-671
21130-658
21130-684
25127-995
21130-672
21130-659
21130-685
25127-995
21130-673
21130-660
21130-686
25127-995
21130-676
21130-663
21130-689
25127-995
21130-677
21130-664
21130-690
25127-995
21130-678
21130-665
21130-691
25127-995
21130-679
21130-666
21130-692
25127-995
23130-343
23130-379
21130-680
21130-667
21130-692
25127-995
21130-681
21130-668
21130-694
25127-995
SCHROFF PRODUCT CATALOG E 05/2016
RAL 7021
Rear panels, connection plates
Rear panel
With quick
Lock
release fastener
01004087
Screw-fixed rear
panel
01004072
for quick-release
St, 1 mm, incl.
fasteners of rear
GND/earthing,
panel
please order lock
separately
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Dimensioning
connecting plate
door/rear panel
01004085
St, 1 mm, incl.
GND/earthing
Intermediate plate for door and rear panel
Plain
With brush strip
Assembly kit
01005071
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
RAL 7021
1 piece
assembled
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
Width
mm
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
PU 1 kit
assembled
21130-091
23130-133
21130-061
21130-092
23130-133
21130-062
21130-093
23130-133
21130-063
21130-094
23130-133
21130-064
21130-097
23130-133
21130-067
600
21130-472
21130-478
23130-164
21130-098
23130-133
21130-068
800
21130-473
21130-479
23130-164
21130-099
23130-133
21130-069
600
21130-472
21130-478
23130-164
21130-100
23130-133
21130-070
800
21130-473
21130-479
23130-164
21130-101
23130-133
21130-071
600
21130-472
21130-478
23130-164
21130-102
23130-133
21130-072
800
21130-473
21130-479
23130-164
1.171
RAL 7021
Top covers
Flat top cover
Perforated
Plain flush
top cover
Lifting eye
Flat top cover, raised
Spacer
Lifting eye
10
M12
01004096
St, 1.5 mm,
incl. GND/
earthing
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.172
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004097
01005064
for flat top cover,
St, 1.5 mm,
applications
fully perforated,
and load in
6 mm perforated,
accordance with
incl. GND/
DIN 582
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
M12
01004099
St, zinc-plated,
for raising a
top cover by
10 mm
01005064
for raised
flat top cover,
applications
and load in
accordance
with DIN 582
PU 4 pieces
assembled
RAL 7021
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
RAL 7021
Flat top covers with cut-out zones
Flat top cover
with cable
through-ducting
openings
Flat top cover
with cut-out
zones
Brush strip
Fan insert
Top cover assemblies
Cover plate for
Edge protection
cut-out zones,
perforated
W
01015052
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006093
St, 1.5 mm,
incl. GND/
earthing, cutout
size 85 mm x
449 mm
St, 1.5 mm,
incl. GND/
earthing, number
of cut-outs and
dimension
drawings
see page
1.9
RAL 7021
1 piece
fitted
RAL 7021
1 piece
assembled
21130-712
21130-713
21130-714
21130-715
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
10106092
01004102
230 VAC,
nylon, black,
one brush strip
with three fans,
covers a
410 m3/h,
lateral cut-out, completely wired,
two brush strips connecting cable
cover a center
IEC 320
cut-out
01009056
St, 1.5 mm,
6 mm hole
diameter,
incl. GND/
earthing
Lifting eye
M12
D
41003065
01005064
PVC, 3 m, black,
for open
cut-out zones
for flat top cover,
applications
and load
in accordance
with DIN 582
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
enclosed loose
PU 4 pieces
assembled
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
Part number in bold face type: ready for despatch within 2 working days
1.173
RAL 7021
Fan top covers
Top cover for
6 fans
Fan for
fan top cover
Fan top cover
Thermostat
Speed control
Lifting eye
30
10
50
°C
1000 mm
300 mm
300 mm
01005060
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.174
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
kta44844
01108052
01105055
fully wired,
St, 1.5 mm, raised fan with grille for with mains cable
90 ... 264 VAC,
top assembly,
230 VAC
cover,
230 VAC,
3 axial fans,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13
socket),
C13 socket;
ND/earthing,
h
adjustment range
external NTC
connecting cable
0 ... 60°C
sensor 1.5 m
2.5 m, SCHUKO/
IEC60320 C12
plug
RAL 7021
1 piece
assembled
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
01005085
for fan top cover,
applications
and load
in accordance
with DIN 582
1 piece
assembled
1 piece
assembled
1 piece
assembled
PU 4 pieces
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
Base plates
Base plate, multipiece
01004104
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimensions
see page
1.9
RAL 7021
1 piece
assembled
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
Brush strip
01004105
Base plate
Dust filter set
Cover plate
01004059
Base plate for lateral cable ducting
For cabinet
For cabinet
Brush strip
width 600 mm
width 800 mm
01004106
01006072
01006094
nylon, black
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm,
one brush strip
opening on
one side,
please order
brush strip
separately
St, 1.5 mm,
brush strip
opening on
both sides,
please order
brush strip
separately
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-074
23130-075
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-134
23130-135
23130-136
23130-378
23130-353
23130-354
23130-355
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-136
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-074
23130-134
23130-074
23130-134
23130-075
23130-135
23130-075
23130-135
23130-136
01006072
nylon, black,
is assembled
laterally,
please order
one brush strip
at cabinet width
of 600 mm, but
two brush strips
at cabinet width
of 800 mm
1 piece
assembled
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
1.175
RAL 7021
Bases/plinths
Base/plinth,
ventilated
01004110
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.176
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Base/plinth
Side trim
Tilt protection,
extractable
01004053
01006055
Base/plinth, mobile
Base/plinth,
Tilt protection,
mobile
extractable
01004111
01006055
support with
adjustable feet
and 2 trims,
perforated,
1000 kg;
please order
side trims
separately
St, 1.5 mm
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
RAL 7021
PU 1 kit
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
RAL 7021
19" panel/slide mounts EIA
Painted RAL 7021
AIZn
U height identification for
19" panel/slide
mounts
19" assembly kit
M6
W
xf
c
D
Dimension
Standard fitting
01004146
01004112
00505050
sc128
assembly kit:
St, 1.75 mm; reduced-width adaptor paper strip, white,
xf = distance
bracket required for 800 mm width; serial numbered item 1: screws,
from front
from 1 ... 47 U
item 2: cage nuts,
depth members are required for
c = pitch of 19"
item 3: washers
panel/slide
mounts
D = cabinet depth
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7021
PU 1 pair
assembled
PU 1 pair
assembled
PU 4 pieces
assembled
PU 50 pieces
supplied loose
23130-021
23130-031
25127-997
21101-809
23130-021
23130-031
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
1.177
RAL 7021
Adapter bracket for reduced width, depth member, cross member
Adapter
bracket for
reduced width
Depth member,
3 rows
Heavy-load cross
member
W
xf
c
D
Dimension
Standard fitting
01004146
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
All RAL 7021 (black grey) RAL
7035 (light grey) on request
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.178
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004128
01004056
01004056
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
St, 1.5 mm,
finish AlZn;
only required for
partial-height
mounting
St, 2.5 mm
PU 4 pieces
assembled
PU 1 pair
assembled
PU 4 pieces
fitted
C
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-091
23130-091
23130-091
23130-091
23130-091
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-544
23130-544
23130-545
23130-546
23130-544
23130-545
23130-546
RAL 7021
Swing frames
Swing frame
Stop 120°
Swing frame trim
Asymmetrical
Symmetrical
assembly
assembly
1
1
2
2
100
200
01005070
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005061
Door opening 160°
Hinge 160°
Stop 160°
Safety lock
100
01005058
01005057
01005061
41001517
is screwed to the St, usable only in for swing frame,
instead of
connection with
swing frame in
square lock,
160° hinge,
place of the
incl. 2 keys
swing frame stop
120° hinge
is recommended
for safety reasons
St, 2 mm,
RAL 7021, loadcarrying capacity:
150 kg,
120° hinge,
square locks incl.
2 keys
St; for safety
reasons a swing
frame stop is
recommended
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
RAL 7021
1 piece
assembled
RAL 7021
PU 1 kit
assembled
RAL 7021
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
RAL 7021
PU 1 kit
assembled
1 piece
assembled
21130-413
23130-158
23130-160
23130-159
60113-267
21130-423
23130-158
21130-432
21130-442
23130-160
23130-159
60113-267
21130-414
23130-158
23130-160
23130-159
60113-267
21130-424
23130-158
21130-433
21130-443
23130-160
23130-159
60113-267
21130-416
23130-158
23130-160
23130-159
60113-267
21130-426
23130-158
21130-435
21130-445
23130-160
23130-159
60113-267
21130-417
23130-158
23130-160
23130-159
60113-267
21130-427
23130-158
21130-436
21130-446
23130-160
23130-159
60113-267
21130-418
23130-158
23130-160
23130-159
60113-267
21130-428
23130-158
21130-437
21130-447
23130-160
23130-159
60113-267
1.179
RAL 7021
Fixed shelves
Full depth
Stationary shelf
Shortened by
100 mm
01004142
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.180
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004142
Depth member,
3 rows
01004056
St, 1.5 mm,
75 kg, 1 U,
incl. GND/
earthing
St, 1.5 mm,
75 kg, 1 U,
depth 479 mm,
incl. GND/
earthing,
for recessed
installation order
depth members
separately
length 660 mm,
St, 1.5 mm,
finish AlZn,
required for
recessed shelf
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
AIZn
PU 1 pair
assembled
21130-323
21130-335
21130-336
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-323
21130-325
21130-333
21130-335
21130-323
21130-325
21130-333
21130-335
21130-323
21130-325
21130-326
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-552
21130-553
21130-323
21130-325
21130-326
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-552
21130-553
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
RAL 7021
Telescopic shelves
Full depth
01004144
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Shortened by 100
mm
Telescopic shelf, 2 U
Mounting
bracket
01004145
St, 1.5 mm,
St, 1.5 mm,
carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
mounting bracket mounting bracket
separately
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
01005054
T-bar lock
01004125
GND/earthing
05904052
St, finish AlZn
to lock the
telescopic shelf
for telescopic
shelf
PU 4 pieces
assembled
1 piece
assembled
1 piece
assembled
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
1.181
RAL 7021
19" shelves, fixed or telescopic, 1 U
19'' telescopic shelf, 1 U, 30 kg
Full depth
Shortened by
GND/earthing
100 mm
01004146
01004118
St, 1.5 mm,
xf = distance
static loadfrom front
carrying capacity
c = pitch of 19"
75 kg,
panel/slide
depth 600 mm,
mounts
incl. GND/
D = cabinet depth
earthing
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.182
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
Xf
Xf
xf
W
Xf
Xf
c
D
C
C
C
19'' stationary shelf, 1 U, 75 kg
Full depth
Shortened by
100 mm
C
Dimension
Standard fitting
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
01004119
St, 1.5 mm,
75 kg,
depth 500 mm,
incl. GND/
earthing
01004123
01004122
St, 1.5 mm, static load-carrying
capacity 30 kg, incl. telescopic slide;
please order GND/earthing kit
separately
05904052
for telescopic
shelf
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
PU 1 kit
assembled
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
ELECTRONICS PROTECTION
RAL 7021
19'' telescopic shelves, 2 U
Full depth
Telescopic shelf, 2 U, 70 kg
Shortened by
T-bar lock
100 mm
GND/earthing
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
01004146
01004123
01004122
St, 1.5 mm, static St, 1.5 mm, static
xf = distance
load-carrying
load-carrying
from front
capacity 70 kg,
capacity 70 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
panel/slide
slide;
slide;
mounts
Please order
Please order
D = cabinet depth
T-bar lock and
W = cabinet width T-bar lock and
earthing kit
earthing kit
separately
separately
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
01004125
05904052
to lock the
telescopic shelf
for telescopic
shelf
1 piece
assembled
PU 1 kit
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
1.183
RAL 7021
Slide rails
Dimension
Standard fitting
Slide rail
Short slide rail
100 kg
St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair
St, 2.5 mm, zinc-plated, static loadcarrying capacity 100 kg/pair
AlZn
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
zinc-plated
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
W
xf
c
D
25 kg
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.184
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004056
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
01004154
St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair
AlZn
PU 2 pieces
supplied loose
PU 10 pieces
supplied loose
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
RAL 7021
Cable ducting with C-rails, cable support rails
C-rail for
cabinet depth
01006109
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
C-rail for
cabinet width
Slide nut
Cable shell
01006107
St, 1.5 mm,
finish AlZn
St, 1.5 mm,
finish AlZn
AIZn
PU 2 pieces
supplied loose
AlZn
PU 2 pieces
supplied loose
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
01504054
vnt009
Cable retention
for C-rail
01006110
for C-rail
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.162
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
PU 10 pieces
supplied loose
PU 10 pieces
supplied loose
PU 5 pieces
supplied loose
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
Cable support rail
For cabinet
For cabinet width
depth
01006108
01006106
St, 1.5 mm,
length 466.4 mm
St, 1.5 mm,
finish AlZn
RAL 7021
PU 2 pieces
supplied loose
RAL 7021
PU 2 pieces
supplied loose
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
1.185
RAL 7021
Plastic
31 x 92 mm
Cable bracket
Plastic
100 x 100 mm
Steel
100 x 100 mm
Steel
100 x 180 mm
43
92
31
01012085
01006079
Plastic, PA6,
plastic, PA6,
black; to slot into
black,
frame
to clip onto frame
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.186
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006081
01006098
St, zinc-plated,
to screw
onto frame or
19" panel/
slide mount
St, zinc-plated,
to screw onto
frame or
19" panel/
slide mount
PU 4 pieces
enclosed loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
RAL 7021
Fibre optic cable
bracket
01006074
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Deposit for
excess cable
lengths
01006113
Cable tie
Velcro
01005078
01005079
St, 1.5 mm,
finish AlZn
for assembly on
shelf or depth
member
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.162
black,
length 300 mm,
further
dimensions
see page
1.162
PU 2 pieces
supplied loose
PU 2 pieces
supplied loose
PU 25 pieces
supplied loose
PU 10 pieces
supplied loose
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
1.187
configuration
freely
쮿 Configuration tables from page 1.189
assembly
Fitting of all mechanical, electrical and
modification
solution
Integration and custom developments
supply), function test
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
reports
쮿 Further information: www.varistar.co.uk
1.188
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
Varistar RAL 7021/RAL 7035 ServicePLUS: Configuration and assembly
쮿 Dimensions:
Page
쮿 Colour: Frame, top cover, base in black grey (RAL 7021),
side panel, door, rear panel in light grey (RAL 7035);
differing colours/finishes are indicated
(see example below)
feet, castors
1.190
Side panels,
1.191
Decorative frames,
glass doors
1.192
Steel doors
1.193
Double doors,
cover panels
1.194
Rear panels,
connection plates
1.195
Top covers
1.196
1.197
Fan top covers
1.198
Base plates
1.199
Bases/plinths
1.200
1.201
Swing frames
1.203
Shelves
1.204
19" shelves
1.206
Slide rails
1.208
Cable ducting with Cprofiles, cable support
rails
1.209
1.210
01006114
Qty
1
1
2
1
1
1
SCHROFF.PENTAIR.EN
Description
800 mm, 1 piece
Order no.
20130-019/05
22130-051/05
23130-132/05
22130-069/05
22130-129/05
23130-079/05
Part number in normal type: ready for despatch within 10 working days
1.189
Cabinets – VARISTAR Datacom/Networking
RAL 7021 / RAL 7035
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
01004078
Colour combination RAL 7035 (light
grey)/RAL 7021 (black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.190
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
For dynamic load,
400 kg,
central GND/
plated, with
point; please
central GND/
order adjustable
earthing
feet or castors
point; please
separately
order adjustable
feet or castors
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
20130-001
20130-002
20130-035
20130-036
20130-578
20130-579
20130-003
20130-004
20130-037
20130-038
20130-005
20130-006
20130-007
20130-008
20130-013
20130-014
20130-015
20130-016
20130-018
20130-019
20130-020
20130-021
20130-580
20130-581
20130-022
20130-023
20130-024
20130-025
20130-582
20130-583
20130-027
20130-028
20130-029
20130-030
20130-584
20130-585
20130-031
20130-032
20130-033
20130-034
20130-586
20130-587
20130-051
20130-052
20130-085
20130-086
20130-588
20130-589
20130-053
20130-054
20130-087
20130-088
20130-055
20130-056
20130-057
20130-058
20130-063
20130-064
20130-065
20130-066
20130-068
20130-069
20130-070
20130-071
20130-590
20130-591
20130-072
20130-073
20130-074
20130-075
20130-592
20130-593
20130-077
20130-078
20130-079
20130-080
20130-594
20130-595
20130-081
20130-082
20130-083
20130-084
20130-596
20130-597
Side-by-side
mounting kit
IP 20
07004120
side-by-side
mounting
brackets
(4 pieces), St
Adjustable feet
01004081
Castors
With 2 jacking
With adjustable
feet
feet
01004082
01004156
for the frame,
for the frame,
for the frame,
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
PU 1 kit
supplied loose
PU 4 pieces
assembled
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
RAL 7021 / RAL 7035
Side panel
With quick
Lock
release fastener
Side panel
Inside locking
Cable panel
Width 150 mm
Cable panel
Cable ladder
Width 250 mm
Width 300 mm
H
1
10
01004084
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004072
St, 1 mm,
incl. GND/
earthing,
please order
lock separately
for quick-release
fasteners of one
side panel;
4 locks sufficient
for 2 side panels
RAL 7035
PU 2 pieces
assembled
PU 4 pieces
assembled
22130-041
22130-042
22130-524
22130-525
22130-041
22130-042
22130-524
22130-525
22130-043
22130-044
22130-043
22130-044
22130-047
22130-048
22130-047
22130-048
22130-050
22130-051
22130-052
22130-053
22130-050
22130-051
22130-052
22130-053
22130-055
22130-056
22130-057
22130-058
22130-055
22130-056
22130-057
22130-058
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
01004083
St, 1 mm,
incl. GND/
earthing
RAL 7035
PU 2 pieces
assembled
22130-001
22130-002
22130-516
22130-517
22130-532
22130-533
22130-001
22130-002
22130-516
22130-517
22130-003
22130-004
22130-003
22130-004
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-012
22130-013
22130-534
22130-535
22130-010
22130-011
22130-012
22130-013
22130-534
22130-535
22130-015
22130-516
22130-517
22130-018
22130-536
22130-537
22130-015
22130-516
22130-517
22130-018
22130-536
22130-537
W
01006104
bracket, St,
1 mm,
finish AlZn;
with retention
screws
01006103
see page
1.210
01006075
round steel,
zinc-plated,
height 1800 mm,
for cable ties or
Velcro
see page
1.210
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
23130-373
23130-373
23130-373
23130-373
23130-373
23130-420
23130-149
23130-373
23130-420
23130-149
23130-373
23130-421
23130-150
23130-554
23130-373
23130-421
23130-150
23130-554
23130-373
23130-422
23130-151
23130-555
23130-373
23130-422
23130-151
23130-555
1.191
RAL 7021 / RAL 7035
Deco frame
Deco frame
Adaptor bracket
01004086
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.192
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004160
Glazed door
Single point
Lever handle
locking
01004088
01004147
with push button
for doors with
single point
locking
Glazed door
3-point locking
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
DIN profile half
cylinder
01004148
for lever handle,
common locking
Al, 19" plane
integrated,
front open,
incl. GND/
earthing,
no door can
be fitted
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lock cover,
incl. GND/
earthing
RAL 7035
1 piece
assembled
RAL 7035
PU 1 pair
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
22130-231
23130-230
22130-121
23130-067
22130-181
25127-995
22130-122
23130-067
22130-182
25127-995
22130-232
23130-231
22130-123
23130-067
22130-183
25127-995
22130-124
23130-067
22130-184
25127-995
22130-234
23130-233
22130-127
23130-067
22130-187
25127-995
22130-128
23130-067
22130-188
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-130
23130-067
22130-190
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-132
23130-067
22130-192
25127-995
RAL 7021 / RAL 7035
Steel doors
Plain, with
Perforated
mounting frame
on inner side
Plain
01004089
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004089
Lever handle
01004090
01004147
with push button
for doors with
single point
locking
Plain
Perforated
01004090
DIN profile half
cylinder
01004093
St, 1.5 mm,
St, 1.5 mm,
opening angle
opening angle
180°, lever handle
180°, with
incl. GND/
on inner side,
earthing
lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
St, 1 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
St, 1,5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing,
designed to carry
assemblies
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
22130-106
22130-566
22130-136
23130-067
22130-151
21130-700
25127-995
22130-107
22130-567
22130-137
23130-067
22130-152
21130-701
25127-995
22130-108
22130-568
22130-138
23130-067
22130-153
21130-702
25127-995
22130-109
22130-569
22130-139
23130-067
22130-154
21130-703
25127-995
22130-112
22130-572
22130-142
23130-067
22130-157
21130-706
25127-995
22130-113
22130-573
22130-143
23130-067
22130-158
21130-707
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
21130-708
25127-995
22130-115
22130-575
22130-145
23130-067
22130-160
21130-709
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
21130-710
25127-995
22130-117
22130-577
22130-147
23130-067
22130-162
21130-711
25127-995
1.193
RAL 7021 / RAL 7035
Glazed
Plain
Perforated
DIN profile half
cylinder
Hinged
Cover panel
Brush strip for
cover panel
90°
01005065
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.194
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005064
01005066
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Sekurit glass,
6 mm,
push button,
push button,
opening angle
incl. GND/
incl. GND/
180°,
earthing
earthing
lever handle with
push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
01006056
St, 1 mm,
to cover the
cabling space
next to the panel/
slide mounts
01006056
black
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
21130-670
21130-657
21130-683
25127-995
21130-671
21130-658
21130-684
25127-995
21130-672
21130-659
21130-685
25127-995
21130-673
21130-660
21130-686
25127-995
21130-676
21130-663
21130-689
25127-995
21130-677
21130-664
21130-690
25127-995
21130-678
21130-665
21130-691
25127-995
21130-679
21130-666
21130-692
25127-995
23130-343
23130-379
21130-680
21130-667
21130-692
25127-995
21130-681
21130-668
21130-694
25127-995
RAL 7021 / RAL 7035
Rear panel
With quick
Lock
release fastener
01004087
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004072
Dimensioning
connecting plate
door/rear panel
01004085
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
01005071
01005063
01005069
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
Width
mm
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
PU 1 kit
assembled
22130-061
23130-133
22130-062
22130-093
23130-133
22130-063
22130-094
23130-133
22130-064
22130-097
23130-133
22130-067
600
22130-472
22130-478
23130-164
22130-098
23130-133
22130-068
800
22130-473
22130-479
23130-164
22130-099
23130-133
22130-069
600
22130-472
22130-478
23130-164
22130-100
23130-133
22130-070
800
22130-473
22130-479
23130-164
22130-101
23130-133
22130-071
600
22130-472
22130-478
23130-164
22130-102
23130-133
22130-072
800
22130-473
22130-479
23130-164
for quick-release
fasteners of
rear panel
St, 1 mm,
incl. GND/
earthing
RAL 7035
1 piece
assembled
PU 2 pieces
assembled
RAL 7035
1 piece
assembled
22130-091
23130-133
22130-092
St, 1 mm,
incl. GND/
earthing,
please order
lock separately
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
Screw-fixed rear
panel
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
1.195
RAL 7021 / RAL 7035
Top covers
Flat top cover
Perforated
Plain flat
top cover
Lifting eye
Spacer
Lifting eye
10
M12
01004096
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.196
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004097
St, 1.5 mm,
incl. GND/
earthing
St, 1.5 mm,
fully perforated,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
SCHROFF PRODUCT CATALOG E 05/2016
01005064
for flat top cover,
applications
and load in
accordance with
DIN 582
M12
01004099
St, zinc-plated,
for raising a
top cover by
10 mm
01005064
for raised
flat top cover,
applications
and load in
accordance
with DIN 582
PU 4 pieces
assembled
RAL 7021
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
RAL 7021 / RAL 7035
Flat top cover
with cable
through-ducting
openings
Flat top cover
with cut-out
zones
Brush strip
Fan insert
Cover plate for
Edge protection
cut-out zones,
perforated
Lifting eye
M12
01015052
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006093
St, 1.5 mm,
incl. GND/
earthing, cutout
size 85 mm x 449
mm
St, 1.5 mm,
incl. GND/
earthing,
number of cutouts and
dimension
drawings
see page
1.9
RAL 7021
1 piece
fitted
RAL 7021
1 piece
assembled
21130-712
21130-713
21130-714
21130-715
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
10106092
01004102
230 VAC,
nylon, black,
one brush strip
with three fans,
covers a
410 m3/h,
cover a center
IEC 320
cut-out
01009056
St, 1.5 mm,
6 mm hole
diameter, incl.
GND/earthing
W
D
41003065
01005064
PVC, 3 m, black,
for open
cut-out zones
for flat top cover,
applications
and load
in accordance
with DIN 582
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
enclosed loose
PU 4 pieces
assembled
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
1.197
RAL 7021 / RAL 7035
Fan top covers
Top cover for
6 fans
Fan for
fan top cover
Fan top cover
Thermostat
Speed control
Lifting eye
30
10
50
°C
1000 mm
300 mm
300 mm
01005060
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.198
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
kta44844
01108052
01105055
fully wired,
90 ... 264 VAC,
top assembly,
230 VAC
cover,
230 VAC,
3 axial fans,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
socket),
C13 socket;
ND/earthing,
h
adjustment range
external NTC
connecting cable
0 ... 60°C
sensor 1.5 m
2.5 m, SCHUKO/
IEC60320 C12
plug
RAL 7021
1 piece
assembled
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
01005085
for fan top cover,
applications
and load
in accordance
with DIN 582
1 piece
assembled
1 piece
assembled
1 piece
assembled
PU 4 pieces
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021 / RAL 7035
Base plates
01004104
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimensions
see page
1.9
RAL 7021
1 piece
assembled
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
Brush strip
01004105
Base plate
Dust filter set
Cover plate
01004059
For cabinet
For cabinet
Brush strip
width 600 mm
width 800 mm
01004106
01006072
01006094
nylon, black
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm,
one brush strip
opening on
one side,
please order
brush strip
separately
St, 1.5 mm,
brush strip
opening on
both sides,
please order
brush strip
separately
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-074
23130-075
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-134
23130-135
23130-136
23130-378
23130-353
23130-354
23130-355
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-136
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-074
23130-134
23130-074
23130-134
23130-075
23130-135
23130-075
23130-135
23130-136
01006072
nylon, black,
is assembled
laterally,
please order
one brush strip
at cabinet width
of 600 mm, but
two brush strips
at cabinet width
of 800 mm
1 piece
assembled
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
Part number in bold face type: ready for despatch within 2 working days
1.199
RAL 7021 / RAL 7035
Bases/plinths
Base/plinth,
ventilated
01004110
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Base/plinth
Side trim
Tilt protection,
extractable
01004053
01006055
Base/plinth, mobile
Base/plinth,
Tilt protection,
mobile
extractable
01004156
01006055
support with
adjustable feet
and 2 trims,
perforated,
1000 kg;
please order
side trims
separately
St, 1.5 mm
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
RAL 7021
PU 1 kit
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
RAL 7021 / RAL 7035
19" panel/slide mount EIA
RAL 7035
AIZn
19" panel/slide
mounts
19" assembly kit
M6
W
xf
c
D
Dimension
Standard fitting
01004146
01004112
00505050
sc128
assembly kit:
St, 1.75 mm, reduced-width adaptor paper strip, white,
xf = distance
from front
from 1 ... 47 U
item 2: cage nuts,
c = pitch of 19"
item 3: washers
partial-height mounting
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7035
PU 1 pair
assembled
PU 1 pair
assembled
PU 4 pieces
assembled
PU 50 pieces
supplied loose
23130-021
23130-031
25127-997
21101-809
23130-021
23130-031
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
1.201
RAL 7021
Adapter
bracket for
reduced width
Depth member,
3 rows
Heavy-load cross
member
W
xf
c
D
Dimension
Standard fitting
01004146
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.202
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004128
01004056
01004056
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
St, 1.5 mm,
finish AlZn;
only required for
partial-height
mounting
St, 2.5 mm
PU 4 pieces
assembled
PU 1 pair
assembled
23130-081
PU 4 pieces
fitted
C
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-082
23130-083
23130-084
23130-364
23130-365
23130-091
23130-091
23130-091
23130-081
23130-082
23130-083
23130-084
23130-544
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-091
23130-365
23130-081
23130-082
23130-083
23130-084
23130-544
23130-364
23130-545
23130-365
23130-546
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-091
23130-083
23130-084
23130-544
23130-364
23130-365
23130-545
23130-546
RAL 7021 / RAL 7035
Swing frames
Swing frame
Stop 120°
Swing frame trim
Asymmetrical
Symmetrical
assembly
assembly
1
1
2
2
100
200
01005070
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005061
Door opening 160°
Hinge 160°
Stop 160°
Safety lock
100
01005058
01005057
01005061
41001517
instead of
connection with
swing frame in
square lock,
160° hinge,
place of the
incl. 2 keys
swing frame stop
120° hinge
is recommended
for safety reasons
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
St; for safety
reasons a swing
frame stop is
recommended
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
RAL 7021
1 piece
assembled
RAL 7021
PU 1 kit
assembled
RAL 7021
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
RAL 7021
PU 1 kit
assembled
1 piece
assembled
21130-413
23130-158
23130-160
23130-159
60113-267
21130-423
23130-158
21130-432
21130-442
23130-160
23130-159
60113-267
21130-414
23130-158
23130-160
23130-159
60113-267
21130-424
23130-158
21130-433
21130-443
23130-160
23130-159
60113-267
21130-416
23130-158
23130-160
23130-159
60113-267
21130-426
23130-158
21130-435
21130-445
23130-160
23130-159
60113-267
21130-417
23130-158
23130-160
23130-159
60113-267
21130-427
23130-158
21130-436
21130-446
23130-160
23130-159
60113-267
21130-418
23130-158
23130-160
23130-159
60113-267
21130-428
23130-158
21130-437
21130-447
23130-160
23130-159
60113-267
1.203
RAL 7021 / RAL 7035
Fixed shelves
Full depth
Stationary shelf
Shortened by
100 mm
01004142
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.204
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004142
Depth member,
3 rows
01004056
St, 1.5 mm,
75 kg, 1 U,
incl. GND/
earthing
St, 1.5 mm,
75 kg, 1 U,
depth 479 mm,
incl. GND/
earthing,
for recessed
installation order
depth members
separately
length 660 mm,
St, 1.5 mm,
finish AlZn,
required for
recessed shelf
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
AIZn
PU 1 pair
assembled
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-323
22130-325
21130-333
21130-335
22130-323
22130-325
21130-333
21130-335
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-552
22130-553
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-552
22130-553
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
RAL 7021 / RAL 7035
Telescopic shelves
Full depth
01004144
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Shortened by
100 mm
Mounting
bracket
01004145
St, 1.5 mm,
St, 1.5 mm,
static loadstatic loadcarrying
carrying
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
please order
please order
separately
separately
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
01005054
T-bar lock
01004125
GND/earthing
05904052
St, finish AlZn
to lock the
telescopic shelf
for telescopic
shelf
PU 4 pieces
assembled
1 piece
assembled
1 piece
assembled
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
1.205
Full depth
Shortened by
100 mm
Full depth
Shortened by
GND/earthing
100 mm
C
Xf
Xf
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
C
RAL 7021 / RAL 7035
01004146
01004118
St, 1.5 mm,
xf = distance
carrying capacity
c = pitch of 19"
75 kg,
panel/slide
depth 600 mm,
mounts
incl. GND/
D = cabinet depth
earthing
W = cabinet width
01004119
St, 1.5 mm,
75 kg,
depth 500 mm,
incl. GND/
earthing
01004123
01004122
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
xf
mm
c
mm
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
PU 1 kit
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.206
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
RAL 7021 / RAL 7035
Full depth
Shortened by
T-bar lock
100 mm
GND/earthing
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
01004146
01004123
01004122
xf = distance
load-carrying
load-carrying
from front
capacity 70 kg,
capacity 70 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
panel/slide
slide; Please
slide; Please
mounts
D = cabinet depth order T-bar lock order T-bar lock
and earthing kit
W = cabinet width and earthing kit
separately
separately
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
01004125
05904052
to lock the
telescopic shelf
for telescopic
shelf
1 piece
assembled
PU 1 kit
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
1.207
RAL 7021 / RAL 7035
Slide rails
Dimension
Standard fitting
Slide rail
Short slide rail
100 kg
AlZn
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
zinc-plated
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
W
xf
c
D
25 kg
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.208
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004056
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
01004154
AlZn
PU 2 pieces
supplied loose
PU 10 pieces
supplied loose
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
ELECTRONICS PROTECTION
RAL 7021 / RAL 7035
C-rail for
cabinet depth
01006109
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
C-rail for
cabinet width
Slide nut
Cable shell
01006107
St, 1.5 mm,
finish AlZn
St, 1.5 mm,
finish AlZn
AIZn
PU 2 pieces
supplied loose
AlZn
PU 2 pieces
supplied loose
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
01504054
vnt009
Cable retention
for C-rail
01006110
for C-rail
for C-rail or for
cable support rail
, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.162
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
PU 10 pieces
supplied loose
PU 10 pieces
supplied loose
PU 5 pieces
supplied loose
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
Cable support rail
For cabinet
For cabinet width
depth
01006108
01006106
St, 1.5 mm,
length 466,4 mm
St, 1.5 mm,
finish AlZn
RAL 7021
PU 2 pieces
supplied loose
RAL 7021
PU 2 pieces
supplied loose
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
1.209
RAL 7021 / RAL 7035
Accessories for cabling
Plastic
31 x 92 mm
Cable bracket
Plastic
Steel
100 x 100 mm
100 x 100 mm
Steel
100 x 180 mm
43
92
31
01012085
01006079
Plastic, PA6,
plastic, PA6,
black; to slot into
black;
frame
to clip onto frame
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.210
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006081
01006098
St, zinc-plated,
to screw
onto frame or
19" panel/
slide mount
St, zinc-plated,
to screw onto
frame or
19" panel/
slide mount
PU 4 pieces
enclosed loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
RAL 7021 / RAL 7035
Fibre optic cable
bracket
01006074
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Deposit for
excess cable
lengths
01006113
Cable tie
Velcro
01005078
01005079
St, 1.5 mm,
finish AlZn
for assembly on
shelf or depth
member
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.162
black,
length 300 mm,
further
dimensions
see page
1.162
PU 2 pieces
supplied loose
PU 2 pieces
supplied loose
PU 25 pieces
supplied loose
PU 10 pieces
supplied loose
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
1.211
Cabinets – VARISTAR Datacom/Networking ServicePLUS
Cooling solutions for beginners and experts
Text
With Schroff's aisle containment you can boost the cooling
efficiency of your data center considerably while simultaneously
cutting the energy costs drastically. Consistently separating cold
supply air and warm exhaust air produces a high degree of
efficiency. Schroff's containment elements can be easily
mounted, also subsequently. The cream of the crop: because they
go with most cabinet types, you always profit from our innovative
solutions.
Schroff's containments - individual applications,
safe investments and future-proof
Based on the Schroff Varistar cabinet platform, cold aisle
containment systems are simple to create This concept may be
adapted or refitted to a location's special room conditions and
cooling requirements.
01008024
Containments
Cold aisle containment
Text
01008074
A high degree of efficiency is reached by the homogeneous
distribution of cold air in front of the servers. Radiation losses are
lower and the existing room climatisation can be used more
efficiently via the double floor. If necessary, the cooling capacity in
the cold aisle can be expanded with LHX air/water heat
exchangers. By relieving the room air-conditioning, redundancy
increases.
VARISTA R Datacom/Networking ServicePLUS
1.212
Requirements and solutions for containments
Requirements
Text
쮿 New data centre for an international bank in a hosting centre
쮿 Constant homogenous cool air for all servers with low energy
consumption
쮿 Future proof in cooling, power and cable management
쮿 User friendly for facility management and IT
The solution
쮿 Cold aisle containment to reduce energy consumption
쮿 Automated fully double-glazed doors minimise cold air loss
쮿 Perforated base plates throughout for maximum passage of air
쮿 Transparent roof elements allow room lighting to be used
01008025
쮿 Higher positioning of roof elements for increased headroom
and sense of space
쮿 Cable duct integrated into roof elements, accessible from cold
aisle
쮿 Separate cable panel on cabinet top covers
01008031
SCHROFF.PENTAIR.EN
1.213
VARISTAR containmentMai n C atalogue
Cabinets – VARISTAR containment
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
01012006
VARISTAR containmentMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days
The Schroff containment system lets you create containment installations without problems.
Increase efficiency and cut energy costs
쮿 Consistent separation of cold and hot air
쮿 Overpressure in the containment: Blow-in temperature of air conditioner is almost the same as the
temperature
쮿 No temperature layering in front of the 19" plane inside the containment
Systems . . . . . . . 8
쮿 No subcooling: possibilities to optimize temperature in data centres
쮿 Higher packing density per cabinet is possible with the same climate control elements
쮿 Low investment with short ROI - no maintenance costs
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.202
SCHROFF PRODUCT CATALOG E 03/2017
Overview . . . . . . 1.202
VARISTAR containmentMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days
Containment of VARISTAR cabinets
쮿
쮿
쮿
쮿
Modular standard components enable flexible adaptation to the requirements of your IT
Base system simple to combine and modify
Minimal investment risk thanks to completely matched climate control system
Short implementation time with minimum outlay
Varistar containment system
쮿 Preconfigured containment solution from modular standard
components (consisting of 6 Varistar server cabinets, RAL
7021, height 2000 mm, width 800 mm, depth 1200 mm)
including containment components; containment aisle width
1200 mm)
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
Containment
system . . . . . . . . 1.204
쮿 Simple to expand or to use as the configuration basis for your
individual containment solution
쮿 Can be delivered in 10 working days
01014007
Doors
Doors
쮿 Sliding doors
– Mechanical
– Electronic
Swing doors . . . . . 1.205
Sliding doors,
mechanical,
Touch variant . . . . 1.205
Sliding door,
electronic . . . . . . . 1.207
Top covers
Top covers
쮿 Standard solutions for aisle width 1200 mm
Top cover
elements . . . . . . . . 1.208
쮿 Standard solutions for 2000 mm and 2200 mm high cabinets
쮿 Swing doors
01012073
쮿 For 600 mm and 800 mm wide cabinets
쮿 Integration of cabinets with other dimensions (heights)
쮿 Free aisle height can be raised by 84 mm
01012074
Air partitioning
Air partitioning . 1.211
쮿 For server and network cabinets
쮿 For cabinets with different widths and recessed 19" planes
쮿 Solid covers with cable ducting or cable routing
(cable fingers, cable channels)
쮿 Halogen-free gasketing UL 94 HF-1
01012055
ServicePLUS from page 1.215
e.g. set-up service and commissioning
e.g. custom modifications and developments
e.g. free combination of components
www.schroff.biz/ServicePLUS
ServicePLUS . . . 1.215
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR
Air/water heat
exchangers . . . . . . 1.224
30407004
SCHROFF.PENTAIR.CO.UK
1.203
Varistar Containment Systems
VARISTA R containmentMain C atalogPart number in bold face type: ready for s hippi ng withi n 2 working daysPart number i n normal type: ready for shipping within 1 0 working days
쮿 Preconfigured containment solutions from modular standard
components
쮿 Consists of 6 Varistar server cabinets (height 2000 mm, width
800 mm, depth 1200 mm) including containment components
쮿 Containment aisle width 1200 mm, all components in RAL 7021
Delivery includes
01014007
Sliding containment door,
mechanical, touch
01012073
Swing containment door
01012070
Item
1
Qty
6
2
3
24
6
4
5
12
6
6
6
7
24
8
24
9
10
11
12
13
12
24
48
4
1
14
1
15
1
16
17
6
2
18
19
1
1
Description
Welded basic frame, Slim-Line, St profile, zincplated, powder-coated, RAL 7021
Adjustable foot
Flat top cover, raised, St, RAL 7021, cutouts for brush
strip mounting
Brush strip for cable entry to flat top cover
Front door, St, RAL 7021, with 180° hinges and
perforation, 3-point locking and lever handle
Rear door, double door, St, RAL 7021, with 180° hinges
and perforation, 3-point locking and lever handle
Cross member, RAL 7021, to accept 19" panel/slide
mounts
19" panel/slide mounts, RAL 7021, mounted at 75 mm
intervals
Air baffle, St, RAL 7021, with brush strip for cable ducting
Central C rail for lateral cable routing in cabinet
Steel cable bracket
Side panel, screw-fixed, for aisle closure, St, RAL 7021
Sliding containment doors, mechanical, Al extruded
frame, 10 mm laminated safety glass, sliding mechanism
and rail, fixing materials kit
Swing containment doors, St frame, 1.5 mm, with 6 mm
single pane safety glass and 180° hinges
Top containment covers, frame St, 2 mm, RAL 7021,
7 mm laminated safety glass, length 1200 mm
Fixing materials for top cover universal profile
Top cover universal profile, Al, length 2400 mm,
RAL 7021
Side-by-side mounting kit for cabinets
Containment gasketing kit
Separator for adjustable cabinet foot
Order Information
Description
1.204
Part no.
10130-250
Swing doors
VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days
쮿 Suitable for 2000 and 2200 mm high cabinets
쮿 Double doors suitable for an aisle width of 1200 mm
쮿 2 colours
– Black grey (RAL 7021)
– Light grey (RAL 7035)
Delivery comprises
Item
1
Qty
2
2
1
Description
Frame St, 1.5 mm; with single pane safety glass 6 mm
and 180° hinge, 2-point magnetic locking on main door,
bolt on side door to lock into the floor
Fixing material kit (for cabinet side)
Order Information
01012070
Accessories
Description
Colour
Swing doors
RAL 7021
Swing doors
RAL 7035
Accessories
Door locking PU 1 pieces
Door cover mask for unequal aisle heights
Part no.
21130-583
22130-583
23130-437
Page 1.216
Note
쮿 Please order suitable door cover masks (above the door)
separately
쮿 Optional lever handle with lock on request
01012068
Door cover mask
Lock
01012060
Part number in normal type: ready for despatch within 10 working days
1.205
Sliding door, mechanical,
Touch variant
Main Catalogue
쮿 Doors open symmetrically (both wings open at same time);
door catch with magnet (door stays open); closes automatically
when lightly tapped
쮿 Colour black grey (RAL 7021)
Delivery comprises
Item
1
Qty
2
2
3
1
1
Description
Sliding door, frame Al extrusion;
laminated safety glass 10 mm, sliding gear
Slide rail with front trim
Order Information
01012073
Accessories
Description
Sliding door, mechanical, Touch variant version
Accessories
Reed contact 1 piece
Door seal cover for various aisle heights
Part no.
21130-060
60130-065
Page 1.217
Note
쮿 Please order suitable door cover maskSs (above the door)
separately
01012067
Door cover mask
Assembly kit
1.206
01012059
Sliding door, electronic
쮿 Door is opened/closed using a button (outside and inside);
manually in case of power failure
쮿 Optional door activation with motion sensor or
operator unit with access control
Delivery comprises
01012072
Item
1
Qty
2
2
3
1
1
Description
laminated safety glass 10 mm, door sliding gear,
connector cable and button to operate door
Order Information
Description
Accessories
Battery pack 1 piece
Motion detector 1 piece
Part no.
21130-073
60130-065
60130-066
60130-067
Page 1.218
Note
separately
쮿 An assembly kit is required for cabinet height 2200 mm with
base/plinth, please order separately
쮿 The door system must be maintained and inspected regularly
Optional door opening with motion sensor
01010066
Accessories
01012069
Door cover mask
Assembly kit
01012059
1.207
Top cover elements
Main Catalogue
쮿 Suitable for an aisle width of 1200 mm
쮿 Top cover with safety glass (VSG)
쮿 For cabinet widths 600 and 800 mm
쮿 A top cover profile can raise the aisle height by 84 mm;
쮿 Top cover can be removed from inside (allows access to lighting
and facilitates maintenance works)
Delivery comprises
01008024
Item
1
Qty
1
2
1
Description
Frame St, 2 mm, RAL 7021; safety glass (VSG) 7 mm,
length 1200 mm
Fixing material kit
Order Information
Description
For cabinet width
mm
600
800
Top cover elements
Top cover elements
Accessories
Top cover profile Length 2400 mm, PU 2 pieces
Assembly kit bracket for top cover raising profile,
PU 6 pieces
Part no.
21130-588
21130-589
21130-594
23130-433
Note
쮿 Where a mechanical sliding door is used, the top cover
directly beside the door must be 100 mm narrower,
see page 1.205
01012074
Universal profile to raise top cover
VARISTA R containmentMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days
쮿 The top cover elements can be raised by 84 mm using a profile
쮿 The profile has a T-groove on the inside that allows lamps,
sensors, etc, to be mounted easily
Delivery comprises
Item
1
Qty
2
Description
Al extrusion, RAL 7021, length 2400 mm
Order Information
Application with raised top covers
01012051
Description
Universal top cover profile,, height 84 mm
Accessories
Assembly kit
Bracket for universal top cover profile, PU 6 pieces
Part no.
21130-594
23130-433
Note
쮿 To mount a profile, an assembly kit (2 pieces) is required;
Accessory: Assembly kit to
mount universal top cover
profile
1.208
01012052
Automatic enclosure top covers
MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days
쮿 Automatic containment top covers open automatically in the
event of fire so that the sprinkler systems installed above the
containment top cover can put out the fire. In normal operation,
the top covers are kept closed by electromagnets and open
when the floating contact of the fire detection system is opened
쮿 For cabinet widths of 600 or 800 mm
쮿 Top cover with safety glass, 7 mm
01017054
쮿 With the universal top cover profile, the aisle height can be
increased by 84 mm; please order separately
쮿 The top cover can be removed from the inside. When opened,
the top cover provides access to lighting and sprinkler systems
above the containment system for maintenance work
쮿 Please order the control unit, which can be used to control up
to 12 automatic top covers, separately
쮿 A 24 VDC power supply unit is required to operate the system.
Please order separately
Delivery includes
01017053
Item
1
Qty.
1
2
3
1
1
Description
Frame, St, 2 mm, RAL 7021; 7 mm laminated safety glass,
length 1200 mm, electromagnet with 1200 mm
connection cable
T-shaped connecting plug
Fixing materials kit
Order Information
Description
Automatic containment top cover, width 600 mm
Automatic containment top cover, width 800 mm
Accessories
Raised top cover Length 2400 mm, PU 2 pieces
Assembly kit
Control unit for automatic top covers 1 set
Power supply for control unit For power distribution of up
to 12 automatic top covers, input 100 to 240 VAC, output:
24 VDC, 40 W, 1 piece
Connecting/extension cable, 1 m
Connecting/extension cable, 2 m
Connecting/extension cable, 5 m
Part no.
21130-592
21130-593
21130-594
23130-433
23130-205
23130-227
23130-206
23130-207
23130-226
쮿 Control unit for up to 12 automatic top covers
쮿 Inputs:
– External 24 VDC power supply unit required, please order
separately
– 2 floating contacts for connecting to a fire detection system
and another opening/test button
01017002
쮿 Output: 24 VDC connection for the control and voltage supply of
up to 12 automatic enclosure top covers, which can be
connected in series
Order Information
Description
Part no.
23130-205
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.209
Adaptors for cable routing
쮿 Suitable for VARISTAR cabinets and all common cable panel
systems
Delivery comprises
Item
1
Qty
2
Description
St profile, RAL 7021
Order Information
Description
For cabinet depth
mm
1000
1200
Cable route adaptor
Cable route adaptor
Accessories
Mounting bracket for cable route adaptor
Bracket, St, PU 2 pieces
01012075
Part no.
21130-596
21130-597
21130-598
Note
쮿 Mounting bracket for cable route adaptor is required for
containment without universal top cover profile
01012076
1.210
Covers
Covers for 800 mm wide cabinets with adapter bracket for
reduced width
쮿 All around the front, covers prevent unwanted air shortcircuits,
i.e. the mixture of warm exhaust air with cold inbound air
쮿 For cabinet width 600 or 800 mm, for cabinet height 42 or 47 U
쮿 Versions for installation with adapter bracket for reduced width
or cross member
– Solid covers
– Covers for 800 mm wide cabinets with cut-outs for cable
routing
– Covers with vertical cable fingers for 800 mm wide cabinets
– Cable routing with cable channel (hinged cover at front) for
800 m wide cabinets
01012055
Covers solid, width
800 mm
01012054
Cover with lateral
cut-outs
01012056
Cover with cable
finger/cable channel
Covers for 800 mm wide cabinets with cross member
Covers, width 800 mm
01015054
Cover with lateral cut-outs
쮿 Suitable divider plates are available for 19" planes mounted
with
recess (70, 145, 220 mm)
쮿 Network and server cabinets can be arranged side by side
쮿 Gaskets, UL 94 HF-1, -20 °C ... 100° C
Delivery comprises
Item
1a
Qty
2
2
3
4
1
1
1
Description
Cover, St, 1 mm, RAL 7021, left/right
(at 600 mm width only gaskets instead of covers)
Cover, top, St, 1 mm, RAL 7021
Cover, bottom, St, 1 mm, RAL 7021
Fixing material kit, gaskets, user manual
01015055
Order Information
Height
Covers for front air separation
For 600 mm For 800 mm wide cabinets with adapter bracket for reduced
wide cabinets
width
Cover with
Cover with
Solid cover
Cover with
cable fingers cable panels
lateral
cut-outs for
cables
Part No.
Part No.
Part No.
Part No.
Part No.
21130-624
21130-627
21130-629
21130-618
21130-631
21130-620
with cross member
Solid cover
Cover with
lateral
cut-outs for
cables
Part No.
Part No.
U mm
42 2000 for 70 mm recessed 19" plane
23130-550
42 2000 for 145 mm recessed 19" plane
23130-550
42 2000 for 220 mm recessed 19" plane
21130-622
21130-633
21130-623
21130-636
21130-638
23130-550
47 2200 for 70 mm recessed 19" plane
21130-625
21130-628
21130-630
23130-551
47 2200 for 145 mm recessed 19" plane
21130-619
21130-632
21130-621
23130-551
47 2200 for 220 mm recessed 19" plane
21130-626
21130-634
21130-635
21130-637
21130-639
23130-551
Accessories
Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece
Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece
Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece
Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece
Brush strip for closing the open cable through-ducting opening, 1 U, black, PU 6 pieces
Clip-on 19" plastic front panels to close the open cable through-ducting opening of the lateral cladding parts , 1 U, black, PU
10 pieces
23130-558
23130-558
23130-558
23130-559
23130-559
23130-559
21130-640
21130-642
21130-641
21130-643
23130-153
D19BPT1RU
1.211
Basic kit for side-to-side-cooled switches
VARISTA R containmentP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Basic kit to divide the 19" plane in the front part of the cabinet
and to accept side trims for switches
쮿 For 800 mm wide VARISTAR cabinets
쮿 with 145 mm recessed 19" plane
쮿 Right front bezel with 5 x air inlets; air inlets that are not
required can be closed with easy-to-cut gasketing material
쮿 Left front bezel for back-to-back cabling with 3 x 19"/1 U cutouts (please order brush strips and filler panels separately)
쮿 Kit can also be retrofitted to cabinets already installed in rows
Delivery includes
Item
1
2
3
4
5
6
7
Qty
2
1
1
1
1
6
1
Description
Front frame, St, 1 mm, RAL 7021 (for top and bottom)
Cover, left, St, 1 mm, RAL 7021 (3 openings)
Cover, right, St, 1 mm, RAL 7021 (5 openings)
Base, St, 1 mm, AlZn, for Cisco side trim
Top cover, St, 1 mm, AlZn, for Cisco side trim
Gasketing (can be cut as required for air inlets)
Fixing materials kit, gasketing, user manual
01013067
Order Information
Cisco switches side trims
01013066
01013060
19" plastic front panels, brush
strips to close cable ducting
openings
For cabinet height
For cabinet width
U
mm
mm
42
2000
800
47
2200
800
Accessories
Side trims for Cisco switches for Cisco Switch 4503, side
trim AlZn, 1 mm, 1 kit
Side trims for Cisco switches for Cisco Switch 4506, side
Side trims for Cisco switches for Cisco Switch 4507, side
Side trims for Cisco switches for Cisco Switch 4510, side
Side trims for Cisco switches for Cisco Switch 6506, side
Side trims for Cisco switches for Cisco Switch 6509, side
Side trims for Cisco switches for Cisco Switch 6510, side
through-ducting opening of the lateral cladding parts 1
U, black, PU 10 pieces
opening 1 U, black, PU 6 pieces
Part no.
21130-646
21130-647
23130-490
23130-491
23130-492
23130-493
23130-494
23130-495
23130-496
D19BPT1RU
23130-153
Note
쮿 Please order appropriate quantity and suitable Cisco switch
side trims separately
쮿 Cover for lateral cable through-ducting openings (please order
brush strip and 19" front panel separately)
1.212
Separating walls
쮿 Where cabinets are arranged in rows the separating wall
replaces the cabinet side wall
쮿 Mounts laterally, prevents unauthorised access
쮿 For cabinet height 42 or 47 U and
cabinet depth 1000 mm or 1200 mm
Delivery comprises
Item
1
2
Qty
1
1
Description
Separating wall, St, 1 mm, finish AlZn
Fixing material kit, user manual
Order Information
For cabinet height
U
42
42
47
47
For cabinet depth
mm
1000
1200
1000
1200
Part no.
23130-480
23130-481
23130-484
23130-485
01012058
1.213
Gasketing
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 Gasketing kits to seal front against air short-circuits
Delivery comprises
Item
1
2
Qty
1
1
Description
Gasket, halogen-free
User manual
Order Information
Description
Vertical gasket for vertical sealing between
10 cabinets
Horizontal gasket for two 600 mm wide
cabinets with adjustable feet
Horizontal gasket for two 800 mm wide
Length
mm
Part no.
3000
23130-475
1200
23130-477
1600
23130-478
Vertical gasket
1.214
01012081
Horizontal gasket
01012082
Cabinets – Varistar ServicePLUS containment
Configuration aid for aisle containment
Varistar ServicePLUS c ontainmentMain Catalogue
쮿 For cabinet rows
– Cabinet height 2000 and 2200 mm
– Aisle width 1200 mm
– Cabinet width 600 mm and 800 mm
Page
Folding doors
1.216
쮿 Once you have selected the desires cabinet containment height,
the row number (first column of the configuration tables) guides you
through all subsequent configutations pages that apply to these
dimensions (see example below)
Sliding door (touch),
mechanical
1.217
쮿 Assembly on request
Automatic sliding doors
1.218
Top covers
1.219
Cable panel adapter,
covers beside 19" plane,
solid
1.221
쮿 Colour RAL 7021, swing door also in RAL 7035
쮿 Configure your containment system from individual components
Covers beside 19" plane,
800 mm, with adapter
1.222
Covers with cable ducting,
cable finger, cable
1.223
channel
01012065
Cover for various 19"
installation depth,
separating wall
1.224
Airflow for side-to-sidecooled switches
1.224
Separating wall,
gasketing kits
1.226
Configuration of SHX 30
air/water heat exchanger
1.227
Example 6 cabinet containment cells (here: row 6)
Qty
6
2
1
1
3
1
1
5
5
2
Description
Side-to-side cabinet, 47 U, 2200 mm high, 800 mm wide, 1200 mm deep,
with front and rear door, RAL 7021, 1 piece
(see chapter VARISTAR data/network systems)
Side panel screw fixed, height 47 U - 2200 mm, for cabinet depth 1200 mm,
RAL 7021, PU 2 pieces (see chapter VARISTAR data/network systems)
Sliding door, mechanical, for cabinet height 2200 mm, aisle height 2102 mm,
with adjustable foot + top cover raising element, 1 piece
Door cover mask to equalize aisle height, 1 piece
Top cover, for cabinet width 800 mm, aisle width 1200 mm, 1 piece
Universal top cover profile, length 2400 mm, height 84 mm, PU 2 pieces
Assembly kit for universal top cover profile, PU 6 pieces
Cover, for lateral termination, 70 mm recessed, PU 1 kit
Cover with lateral cutouts, by 145 mm recessed 19" plane, PU 1 kit
Cover for lateral termination, depth-offset 70 mm, 1 piece
Order no.
10130-233
22130-537
21130-060
21130-612
21130-589
21130-594
23130-433
21130-638
21130-632
21130-643
1.215
Swing doors
Main Catalogue
Order Information
Swing door
RAL 7021
RAL 7035
01012064
Cover
01012063
Frame, St, with single pane safety
glass 6 mm and 180° hinge,
3-point loking and lever handle
(please order lock separately),
door cover mask to equalise
aisle height,
1 piece
Door locking
01012068
01012060
St, 1.5 mm,
RAL 7021;
cover to equalise
aisle height
Door locking
mechanism
01012070
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
3
7
42
47
8
1.216
2000
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
1 piece
21130-583
22130-583
23130-437
21130-611
21130-612
21130-583
22130-583
23130-437
21130-612
21130-613
Sliding doors (touch), mechanical
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Order Information
Hand operated sliding door, touch
RAL 7021
Cover
01012062
Reed contact
01012067
01015001
Door cover mask
Prepared for
Sliding door,
to equalise aisle
integration into
frame St, with
height, 1 piece
door boxes,
single pane safety
magnet detects
glass 6 mm,
when door is
closes
opened; connects
automatically
to door plate
01012062
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
3
7
8
42
47
2000
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
21130-060
60130-065
21130-040
21130-060
60130-065
21130-040
21130-059
1.217
Main Catalogue
Order Information
RAL 7021
Cover
01012061
Reed contact
01012069
Motion detector
01015001
Battery pack
01015003
Prepared for
Door cover mask
Prepared for
Sliding door,
to equalise aisle
integration into mounting on door
frame, St,
box, power supply
height, 1 piece
door boxes,
with single pane
magnet detects via connector on
safety glass
door plate
when door is
6 mm,
opened; connects
closes electrically
to door plate
by pushbutton
01015002
Prepared for
integration into
door boxes
01012073
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2
3
7
42
47
8
1.218
2000
2200
Raising elements
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
21130-073
60130-065
60130-067
60130-066
60130-065
60130-067
60130-066
21130-040
21130-073
21130-040
21130-059
Top covers
Main Catalogue
Order Information
Top cover
600 mm width
Universal profile
to raise
top cover
800 mm width
01012050
Frame, St; with single pane safety
glass 7 mm,
aisle width 1200 mm
Assembly kit
01012051
01012052
Bracket to mount
Al extrusion,
the universal top
RAL 7021,
cover profile
length 2400 mm,
height 84 mm
01012074
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
3
42
2000
1 piece
21130-588
1 piece
21130-589
PU 2 pieces
PU 6 pieces
21130-594
23130-433
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
21130-594
23130-433
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
21130-594
23130-433
21130-594
23130-433
7
8
47
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
21130-588
21130-589
1.219
Automatic fan top covers
MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days
Order Information
Automatic top cover
600 mm width
800 mm width
Control unit for
top covers
01017053
Frame St, 2 mm, RAL 7021; 7
length 1200 mm,
connection cable,
T-shaped connecting plug and
01012074
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
47
8
1.220
2200
Power supply for
control unit
01017002
Connection/
extension
cable
Length 1 m
Connection/
extension
cable
Length 2 m
Connection/
extension
cable
Length 5 m
01617001
01017056
Control unit for
up to 12
automatic top
covers, inputs: 24 VDC and
2 floating
contacts; output:
24 VDC
For power
distribution of up
to 12 automatic
top covers,
input 100 to
240 VAC,
output: 24 VDC,
40 W
Cable with
plug, 1 m
Cable with
plug, 2 m
Cable with
plug, 5 m
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
21130-592
21130-593
23130-205
23130-227
23130-206 23130-207 23130-226
21130-592
21130-593
23130-205
23130-227
Cable panel adapter, covers beside 19" plane, solid
Main Catalogue
Order Information
for 1000 mm
cabinet depth
for 1200 mm
cabinet depth
Covers beside 19" plane, solid, 600 mm cabinet width
Mounting
bracket for
cable route
adaptor
for 70 mm
recessed 19"
plane
for 145 mm
recessed 19"
plane
for 220 mm
recessed 19"
plane
Tex
t
01012075
01012076
01012053
St profile, RAL 7021;
fits to cabinet with a mounting
bracket
and has drilled holes
to bolt on cable panel
Bracket, St,
1.5 mm
Gasketing on left and right; Cover at top and bottom
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 kit
PU 1 kit
21130-596
21130-597
21130-598
21130-624
21130-618
21130-622
21130-596
21130-597
21130-598
21130-625
21130-619
21130-626
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
8
42
47
2000
2200
1.221
Covers beside 19" plane, 800 mm, with adapter bracket for reduced width
Main Catalogue
Order Information
Cover, beside 19" plane,
800 mm cabinet width
for 70 mm
for 145 mm
for 220 mm
recessed
recessed
recessed
19" plane
19" plane
19" plane
for 70 mm
recessed
19" plane
for 145 mm
recessed
19" plane
for 220 mm
recessed
19" plane
Tex
t
01012055
Cover left, right, at top and bottom
01012054
Cover with cable routes left and right;
cover closed top and bottom
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
2
3
7
42
47
8
1.222
2000
2200
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
21130-627
21130-631
21130-633
21130-629
21130-620
21130-623
21130-628
21130-632
21130-634
21130-630
21130-621
21130-635
Covers with cable ducting, cable finger, cable channel
Main Catalogue
Order Information
Covers beside 19" plane, 800 mm cabinet width, with
cross member
Cover, solid
Cover with cable ducting
openings
Cover with
cable fingers
for 220 mm
recessed
19" plane
Cover with
cable channels
Cable panel
Lateral cable
ducting
Tex
t
01015054
01015055
Cover with cable ducting left and right; cover at top,
bottom solid, for 19" planes recessed to different depths
(25 mm increments)
01012056
Support with
cable fingers
and front covers
01012077
01012078
St, 1 mm,
St,
width 150 mm;
with cable
with perforations
channel and
hinged front cover for cable ties or
Velcro-type tape
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
8
47
2200
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 2 pieces
23130-550
23130-558
21130-636
21130-638
23130-421
23130-551
23130-559
21130-637
21130-639
23130-422
1.223
19" plastic front panels, lateral panels
Main Catalogue
Order Information
Closure for cut-outs in covers
19" plastic
panels
19" brush strip
Lateral panel
Depth offset
70 mm
Depth offset
145 mm
Tex
t
01012079
ABS, UL 94 V-0,
clips in
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
42
47
8
1.224
2000
2200
01012080
To close the open
for sealing the
cable routes
open cable
in lateral
ducting openings
panels
of the lateral trim;
6 brushes,
sufficient for
3 cutouts
01012057
Al, 2 mm
Plastic
Lateral panel for
unequal 19" mounting depths
PU 10 pieces
PU 6 pieces
1 piece
1 piece
D19BPT1RU
23130-153
21130-640
21130-642
D19BPT1RU
23130-153
21130-641
21130-643
Airflow for side-to-side-cooled switches
Order Information
Basic kit for Cisco
switches
Air circulation
from right to left
Switch 4503
Switch 4506
Switch 4507
Switch 4510
Switch 6506
Switch 6509
Switch 6513
Te
xt
01013060
01012051
AlZn, 1 mm; multiple side plates can be fitted one above another;
in all cases only one basic kit is required
Bezels, top cover
and base plate for
Cisco side trims
01013006
Aisle
height
(lower
edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
For cabinet
height H
No. U
3
7
8
42
47
mm
2000
2200
PU 1 kit
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
21130-646
23130-490 23130-491 23130-492 23130-493 23130-494 23130-495 23130-496
21130-647
1.225
Separating walls, gasketing kits
Order Information
Separating wall
Cabinet depth
1000 mm
Vertical gasket
Horizontal gasket
Cabinet depth
1200 mm
For 600 mm
wide cabinets
For 800 mm
wide cabinets
Tex
t
01012058
St, 1 mm;
lateral cabinet mounting,
01012081
PUR flexible foam,
colour similar to RAL 7021,
UL 94-HF1;
10 cabinets,
also suitable for base/plinth and
to raise top cover
01012082
2 x bracket, St, RAL 7021;
PUR flexible foam seal,
UL 94-HF1;
suitable for horizontal sealing
of 2 cabinets to bottom,
when adjustable feet are used
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
42
47
8
1.226
2000
2200
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 kit
23130-480
23130-481
23130-475
23130-477
23130-478
23130-484
23130-485
23130-475
23130-477
23130-478
Configuration of SHX 30 air/water heat exchanger
Order Information
Frame
1000 mm deep
SHX 30 air/water heat exchanger, 30 kW
1200 mm deep
Water connection at bottom
01013068
Water connection at top and bottom
(with condensate pump)
01013076
Rack (VARISTAR Slim-Line), St,
RAL 7021; top cover and base plate,
front and rear panel; prepared to
accommodate SHX 30 air/water heat
exchanger
01013077
2 PSUs,
redundant power
supply
1 PSU
2 PSUs,
redundant power
supply
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
8
47
2200
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
10130-226
10130-227
60714-067
60714-068
60714-077
60714-078
10130-228
10130-229
60714-067
60714-068
60714-077
60714-078
1.227
Order Information
Gasketing for
adjustable feet
Base/plinth
Side trim for base/plinth
Depth 1000 mm
Depth 1200 mm
min. 2
max. 22
Adjustable feet
D
01013069
St, black, for the
rack, static loadcarrying capacity
1000 kg. Please
order gasketing
separately
01013070
100
100
D
300
01013071
Base plinth, St,
Polyurethane
cover, St, 1.5 mm,
gasketing,
suitable for front height 100 mm,
width 300 mm,
and rear, RAL
7021; for closing RAL 7021; please
order cover
the air gap at the
separately
front
01013072
St, 1.5 mm, height 100 mm,
RAL 7021
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
2
3
7
42
47
8
1.228
2000
2200
PU 4 pieces
PU 2 pieces
PU 1 kit
PU 2 pieces
PU 2 pieces
23130-511
23130-538
23130-507
23130-172
23130-363
23130-511
23130-538
23130-507
23130-172
23130-363
Order Information
Screw-fixed side panel
Depth 1000 mm
Separating wall
Depth 1200 mm
Cabinet depth
1000 mm
Cabinet depth
1200 mm
01013073
St, 1 mm, incl. GND/earthing
01013074
St, 1 mm, AlZn; lateral cabinet
mounting prevents unauthorized
access
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
8
42
47
2000
2200
PU 2 pieces
PU 2 pieces
1 piece
1 piece
21130-013
21130-535
23130-480
23130-481
21130-018
21130-537
23130-484
23130-485
1.229
Order Information
Top cover
300 mm width
Raised top cover
01013079
Assembly kit
01012051
01012052
St, 2 mm,
RAL 7021, aisle
width 1200 mm
Al extrusion,
RAL 7021,
length 2400 mm,
height 84 mm
Mounting of top
cover raising
profile
1 piece
PU 2 pieces
PU 6 pieces
21130-594
23130-433
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
3
42
2000
21130-648
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
21130-594
23130-433
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
21130-594
23130-433
21130-594
23130-433
7
8
47
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
21130-648
1.230
1.231
Varistar cabinet-based and row-bas ed coolingMai n C atalogue
Cabinets – Varistar cabinet-based and row-based cooling
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01017025
Front panels,
Power supply
Backplanes . . . 10
01013005
Front bottom or bottom/top water
connection, easy access and
greatest possible safety
Applications
The future for data centers
The SHX 30 heat exchanger is
especially suitable for use in the
following areas:
쮿 Data centers
쮿 19" and blade-server
applications
Connectors, front
panel component
쮿 Systems with extremely high
heat dissipation
1.224
01017015
Electronic monitoring unit with
display and interfaces
SCHROFF PRODUCT CATALOG E 06/2016
01013005
Six powerful, temperaturecontrolled fans. Easy access for
maintenance purposes during
operation
VARISTAR LHX+, the space-independent
complete cabinet system for dissipating
up to 34 kW of heat.
The air/water heat exchanger is installed in the
cabinet as complete unit on the left or right side.
The horizontal air flow provides for
uniform air dissipation over the entire
cabinet height.
01017060
Overview . . . . . . 1.224
Varistar cabinet-based and row-based coolingMain Catalogue
VARISTAR LHX+ with air/water heat exchanger
for data centers
쮿 Cooling capacity up to 34 kW
VARISTAR
쮿 Complete cabinet solution, static load capacity up to 1600 kg
쮿 Space-independent cooling, high energy efficiency
쮿 Water and air circuits are temperature controlled
쮿 Low noise level
쮿 Fans may be changed individually while the unit is operating
With single door
VARISTAR SHX+,
single door . . . . . . 1.230
VARISTAR SHX+,
double door . . . . . 1.231
With double door
01017003
(heat exchanger on left or right)
01017007
Accessories
쮿 Management system for monitoring LHX+ and other cabinet
parameters
Accessories
Heat exchangers . 1.232
Rack for heat
exchanger . . . . . . . 1.234
Adjustable feet . . . 1.235
Base/plinth . . . . . . 1.236
00711020
ServicePLUS
e.g. other cabinet dimensions
e.g. side-by-side mounting solutions
e.g. containment (cold aisle)
e.g. custom solutions (special sizes)
30407004
VARISTAR
VARISTAR
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
1.225
Varistar cabinet-based and row-based coolingMAIN CATALOG P art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days
Optimum temperature for air/water heat exchanger
Since the thermal load continues to increase, conventional cooling methods eventually
reach their physical limits. It can happen that thermal load limits within a cabinet are
such that some height units must go unused.
ADVANTAGES
The solution:
Air/water heat exchangers installed close to the heat source not only increase the
cooling capacity per cabinet, but also improve the redundancy of the data center.
With intelligent control systems, air conditioners can quickly respond to the working
load of the equipment, thereby enabling additional savings.
쮿 Highest cooling capacity in the smallest
of spaces
Text
cooling capacity per cabinet, but also improve the redundancy of the data center. With
intelligent control systems, air conditioners can quickly respond to the working load of
쮿 Integrated solutions with spaceindependent thermal transfer
쮿 A wide variety of dimensions are
supported, short implementation time
and low planning effort
Thanks to the Ethernet and Modbus connection, Schroff air/water heat exchangers
can be monitored and configured. Operating parameters are easy to specify, and
temperature, fan speed and error protocols can be managed remotely.
Text
01015011
1.226
Varistar cabinet-bas ed and row-based coolingMAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days
Integrated heat exchanger
Heat exchanger mounted side-by-side
In this combination, an active heat exchanger integrated
into an 800 mm wide cabinet has the lowest space
requirement on the market. The closed system reduces
the noise level and controls itself by means of the thermal
load. With a cooling capacity of up to 34 kW1), the heat
exchanger is suitable for HPC applications. Multiple
cabinets can be mounted side-by-side to create a closed
system. Thanks to the low space requirement, reduced
noise level and ease of creating redundancy, this heat
exchanger is well suited also for medium-sized data
centers.
Active heat exchanger for containment systems with a cooling capacity of
up to 34 kW1). This in-row heat exchanger is mounted side-by-side to
cabinets within the aisle containment. This enables optimal scalability
with regard to planning for the cooling capacity and the redundancy of the
system.
Text
01017009
LHX+ cabinets mounted side-by-side with integrated heat
exchangers
01013005
SHX 30 in-row heat exchanger
Integrated heat exchanger:
Cooling capacity
Dimensions
Functions
In-row heat exchanger:
Cooling capacity
Dimensions
Functions
Up to 34 kW1)
Width 800 mm
Height 2100 mm
Depth 1000 to 1200 mm
IP 55 protection on request EMC
design on request 1600 kg static
load capacity Bottom/top water
connections Control system options
with an external temperature
sensor (Display in four languages)
Up to 34 kW
Width 300 mm
Height 2000 to 2200 mm
Water connections from bottom/top
Control system options with an
external temperature sensor
1) Cooling capacity 34 kW at +12 °C water flow temperature,
+24 °C cold air temperature, 4.5 m³/h water flow rate;
for other conditions refer to the diagram for the cooling capacity
1.227
Space-saving, low-noise and energy-efficient
Highly efficient and noise-optimized
Text
The Varistar heat exchanger range impresses customers with its high
energy efficiency and cooling capacity. Failure safety and ease of
servicing play a special role. The unit itself is designed for long life.
Sensitive components with a low MTBF have been consistently
dispensed with and necessary wear parts are treated carefully during
operation. Fans are positioned in the cold area to significantly increase
the service life of the bearings compared to operation in a warm-air
area. Additionally, the heat exchanger is equipped as standard with a
droplet separator and a condensate management system to prevent the
formation of water droplets in the air entry area to the server.
Compelling use of space
Since the heat exchanger is inserted on one side as a
complete module, in a cabinet only 800 mm wide, the 19"
plane can be used over its full height, with 42 U
(max. 52 U). This saves valuable space in the data center!
01017061
01017060
IN-ROW heat exchanger to cool your indoor aisle
containment
This in-row heat exchanger is specially designed to cool cabinets with
high thermal loads within an aisle containment structure and is
included in the row as a modular unit. Depending on the packaging
density, you can scale the units optimally and implement redundancy.
26°
C
01012083
1.228
One heat exchanger for multiple cabinets
Redundancy from side-by-side mounting
The option of mounting the cooling unit to the left or right of the
19" plane means it is easy to build very variable cooling systems
from multiple cabinets. If the full cooling capacity is not needed
initially, one unit can supply cold air to multiple cabinets mounted
side-by-side. In cabinets mounted side-by-side, the space for the
cooling unit is closed with an air baffle. If the necessary cooling
capacity increases, the air baffle is removed and an additional
cooling unit is inserted.
Redundant systems are also very easy to implement. If two
cabinets are mounted side-by-side with one heat exchanger each,
one unit can take over the cooling of both cabinets up to half of the
max. cooling capacity per cabinet.
Text
01017015
01017015
For installation and maintenance, the air conditioners of the Varistar series have a very service-friendly design. The water connections
are easy to access. Fans can be changed individually and very quickly while the unit is operating. However, if a defined threshold value
does arise, either in the cabinet or in the unit itself, each heat exchanger will provide valuable information for maintenance and service
work. Fan speeds and temperatures at various positions in the cooling circuit are measured via integrated communication interfaces
and can be shown on a display. However, all information (measured values, threshold values, etc) can also be transferred directly into
the network management system.
Text
쮿 Display
쮿 Bottom or top and bottom
water connections
쮿 Hot-swap-capable fans
쮿 Power supplies
쮿 Communication interface
쮿 External temperature sensor
쮿 Interlog interface
01017015
01013005
1.229
VARISTAR LHX+, cabinet with single door, integrated
air conditioner
쮿 Cabinet with air/water heat exchanger with cooling capacity of
34 kW
쮿 Max. static load capacity 1600 kg
쮿 Gasket all around reduces noise and suction of room air
Delivery includes (Fully assembled and grounded)
Item
1
Qty.
1
2
1
3
1
4
1
5
6
2
1
7
1
8
4
9
2
10
11
4
1
12
13
14
1
1
1
01017003
Description
Welded basic frame, Slim-Line, St profile, zinc-plated,
RAL 7021, with gasket all around
Flat roof, St, RAL 7021 with cable entry point in rear with
brush, entry point for water connection in rear, entry
points can be sealed with a gasket/cover plate
Front door glazed, St frame, RAL 7021, single-pane
safety glass 6 mm, 3 x 180° hinge, three-point closure,
pivoting lever handle for optional DIN profile half cylinder
Rear door, St, RAL 7021, 3 x 180° hinge, three-point
closure, pivoting lever handle for optional DIN profile half
cylinder
Side panel, screwed, St, RAL 7021
Baseplate, St, RAL 7021 with cable entry point in rear
with brush, entry point for water connection in rear,
entry points can be sealed with a gasket/cover plate
Base/plinth 100 mm, with additional center
crossmember, St, RAL 7021, removable covers,
integrated adjustable feet
19" panel/slide mount with EIA cut-outs, St, RAL 7021,
225 mm recessed in front, c dimension 740 mm distance
between front and rear 19" plane
Support rail for connecting the air/water heat exchanger
and 19" panel/slide mounts, St, RAL 7021
SHX 30 air/water heat exchanger, RAL 7021, 100
to 240 VAC, may be mounted on the left or right, see Order
Information
Power cable, length 1.5 m
Connecting cable for management unit
User manual (for online download)
Order Information
Height
U mm
42 2100
42 2100
Width
mm
800
800
Depth
mm
1200
1200
Heat
Water
Power
exchanger connection supply
Left
Right
Top
Top
Top and
bottom
Top and
bottom
42 2100 800
1200
Left
42 2100 800
1200
Right
Part no.
1
1
10130-300
2 redundant
10130-302
2 redundant
10130-303
Accessories
Lifting eye for top cover PU 4 pieces
Electronic closing (MLR3000),
13.56 MHz-MIFARE With reader, 1 set
Electronic locking (MRL3000), Mifare With reader, 1 set
10130-301
23130-072
23130-513
23130-565
Note
01017059
1.230
쮿 34 kW cooling capacity at +12 °C water flow temperature,
쮿 Other dimensions on request
VARISTAR LHX+, cabinet with double door, integrated air
conditioner
34 kW
쮿 Separate front and rear access doors for air/water heat
exchanger
Item Qty.
1
1
01017007
2
1
3
1
4
1
5
6
2
1
7
1
8
4
9
2
10
11
4
1
12
13
14
1
1
1
Description
brush, entry point for water connection in rear, entry points
Front door, divided asymmetrically, RAL 7021, 3 x
180° hinges, three-point closure, pivoting lever for optional
DIN profile half cylinder;
in front of the 19" plane, 600 mm, St frame, glazed, singlepane safety glass 6 mm, in front of the heat exchanger,
200 mm, St, with viewing window, single-pane safety glass
6 mm
Back door, divided asymmetrically, St, RAL7021, 3 x 180°
hinges, three-point closure, pivoting lever for optional DINprofile half cylinder; in front of the 19" plane, 600 mm,
in front of the heat exchanger, 200 mm
Baseplate, St, RAL 7021, cable entry point in rear, entry
point for water connection, entry points can be sealed with
gasket/cover plate
crossmember, St, RAL 7021, removable covers, integrated
adjustable feet
SHX 30 air/water heat exchanger, RAL 7021, 100 to 240 VAC,
may be mounted on the left or right, see Order Information
Order Information
Height
U mm
42 2100
42 2100
01017058
Width
mm
800
800
Depth
mm
1200
1200
Heat
Water
Power
Left
Right
Top
Top
Top and
bottom
Top and
bottom
42 2100 800
1200
Left
42 2100 800
1200
Right
Part no.
1
1
10130-304
2 redundant
10130-306
2 redundant
10130-307
Accessories
10130-305
23130-072
23130-513
23130-565
Note
1.231
쮿 Air/water heat exchanger with cooling capacity of 34 kW1)
Main CatalogueMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Water connection at bottom or bottom/top (with condensate
pump)
쮿 1 PSU or 2 PSUs (redundant)
쮿 Drop collector and condensate management
Delivery includes
Item
1
Qty
1
2
3
4
1
1
Description
100 ... 240 VAC
Mains cable, 1.5 m
Order Information
01017026
SHX 30 air/water heat exchanger, 34 kW1)
1 PSU
Water connection at
2 PSUs, redundant power
bottom
supply
1 PSU
and bottom (with
condensate pump)
supply
Accessories
Cabinet management basic units Height 44 mm, width
251 mm, depth 53 mm, for monitoring one air/water heat
exchanger, max. 16 sensor values, 1 piece
440 mm, depth 134 mm, for monitoring up to max. 8 air/
water heat exchangers, max 128 sensor values, 1 piece
Capteur de température à raccorder directement au
SHX 30, longueur du câble 2 m, 1 pièce
Part No.
60714-067
60714-068
60714-077
60714-078
EMX111
EMX888
60130-724
Note
Please order optional management unit separately
Rear connections at bottom
01013020
Rear connections at top
01013021
쮿 Cabinet management base unit connects via RJ 45 interface
쮿 Web interface
– Automatic detection of connected Varistar SHX 30 air/water
heat exchanger
– Inlet temperature of servers (parameter can be set via web
interface)
– Switch on/off of cooler
– Adjustment of set temperature and fan speed
– Air temperature monitoring at front/rear, fan speed and
water inlet temperature
– Temperature monitoring/control using an external
temperature sensor (please order separately)
쮿 1) Cooling capacity 34 kW at +12 °C water flow temperature, +24 °C cold
air temperature, 4.5 m³/h water flow rate; for other conditions refer to
Management browser representation
1.232
00711017
Graph: cold air temperature against cooling capacity
Technical data
Cooling capacity
Useful cooling capacity
Normal temperature
1) Cold air temperature
2) Cooling capacity at different cold water temperatures
Fan speed 100%
Maximum water flow rate 4.5 m3/h
3) Water inlet temperature
01017062
34 kW1)
18 to 50 °C (adjustable in 0.1 °C
increments)
Max. control deviation of emergency 4 (factory-preset)
cooling can be set to 0–8 K relative to
the set value
Water circuit
Cooling medium 2)
Water, water-glycol mix
(max. 33%)
Water inlet temperature 3)
6 to 18 °C
Water flow volume
up to 4.5 m 3/h
Pressure loss in device at
3.0 m3/h, max. 1.3 bar; 4.5 m3/h,
max. 3.1 bar
Water conduit
Copper
Water connection inlet/outlet
Rp 1"
Condensate drain connection
Rp 1/2"
Air circuit
Max. airflow volume, temperature- 5000 m3/h
dependent control
Electrical data AC
Supply voltage (single phase)
100 to 240 VAC (50 / 60 Hz)
Max. current consumption
6 A / 12 A (230 V / 115 V)
1100 W / 750 W
Max. power consumption
fan speed 100% / Normal
operation (fan speed 80%)
Pre-fuse (on building side)
D 10 A / D 16 A (230 V / 115 V)
Interface
RS 485 Modbus interface
Connection option for external
monitoring system
RS 232 (SUB-D 9-pin)
Serial access
Input, terminal block with
10 potential-free contacts
connection
General data
Ambient temperature: Transport,
-25 to 70 °C / 5 to 70 °C
storage when fully emptied / when
containing 35% glycol / in operation
outside of the cabinet
Relative humidity for transport and 5 to 95%
storage (non-condensing)
Heat exchanger dimensions
Height 1849 mm, width 189.5 mm,
depth 850 mm
Heat exchanger weight
110 kg
Weight of cabinet with cooling
370 kg
module approx.
2) To ensure problem-free operation of the air/water heat exchanger the quality
requirements of the water must be maintained; the appropriate anti-corrosion and
frost protection agents are dependent on the environment in which the unit is used
and on the external chiller (VDI 3803, see also user manual).
3) At water inlet temperatures of < 6 °C und > 15 °C, the control accuracy can no
longer be guaranteed. There is also a risk of condensation if the water temperature
falls short of the given limits.
1.233
Rack for SHX 30 air/water heat exchanger
쮿 Rack (VARISTAR Slim-Line) to accommodate a SHX 30 air/
쮿 Height 2000 or 2200 mm
쮿 Depth 1000 or 1200 mm
쮿 Width 300 mm
쮿 Covers top, bottom, front and rear
Delivery includes
Item
1
Qty
1
2
1
3
4
5
1
1
1
2
1
3
Description
Welded basic rack (Slim-Line) from steel
profiles, RAL 7021; earthing stud
Flat top cover, St, RAL 7021; with brush strip cut-out
(for water) and on the side for cable ducting
Front frame, St, RAL 7021
Rear cover, perforated, lockable
Base plate, St, RAL 7021; with brush strip cut-out (for
Order Information
4
5
01013068
01013080
01013022
Water enters via brush strips; lateral cable ducting for power/data
cables
1.234
Height
Width
Depth
mm
mm
mm
2000
300
1000
2000
300
1200
2200
300
1000
2200
300
1200
Accessories
Adjustable feet for the frame, RAL 7021, static loadcarrying capacity 1000 kg, PU 4 pieces
Gasketing for adjustable feet Polyurethane foam
gasketing, color similar to RAL 7021, length 300 mm, for
sealing front and rear, PU 2 pieces
Base/plinth Base plinth, St, width 300 mm, height 100 mm;
bolts on to rack, PU 2 pieces
Side trim St, 1.5 mm, height 100 mm, depth 1000 mm,
PU 2 pieces
Side trim St, 1.5 mm, height 100 mm, depth 1200 mm,
PU 2 pieces
Side panel, screw-fixed for IP 55 St, 1 mm,
height 2000 mm, depth 1000 mm, 2 pieces
height 2000 mm, depth 1200 mm, 2 pieces
height 2200 mm, depth 1200 mm, 2 pieces
Separating wall St, 1 mm, AlZn, height 2000 mm,
for depth 1000 mm, 1 piece
for depth 1200 mm, 1 piece
Separating wall St, 1 mm, AlZn, height 2200 mm,
Part no.
10130-226
10130-227
10130-228
10130-229
23130-511
23130-538
23130-507
23130-172
23130-363
21130-013
21130-535
21130-018
21130-537
23130-480
23130-481
23130-484
23130-485
ELECTRONICS PROTECTION
Adjustable feet
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Adjustable feet for direct mounting onto frame
쮿 Static load-carrying capacity 1000 kg
Delivery includes
Item
1
2
Qty
4
1
Description
Adjustable feet, St, polyamide, black
Order Information
MRA44483
Description
Adjustable feet
Accessories
Part no.
23130-511
23130-538
쮿 For horizontal sealing at bottom in containments (front and
rear) where adjustable feet are used
Delivery includes
Item
1
Qty
2
Description
Gasketing, flexible polyurethane, length 300 mm, color
similar to RAL 7021, conforms to UL 94-HF1
Order Information
Description
Part no.
23130-538
01013070
1.235
Base/plinth
Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days
쮿 Base for 300 mm wide frame (air/water heat exchanger)
쮿 Base is bolted to the frame at front and rear; please order side
trims separately
Delivery includes
D
Item
1
Qty
2
2
1
Description
Base, St, 1.5 mm; with built-in feet, width 300 mm, color
RAL 7021
100
Order Information
300
01013071
Base/plinth
Height
Width
mm
mm
100
300
Accessories
Side trim RAL 7021, St, 1.5 mm, height 100 mm,
depth 1000 mm, PU 2 pieces
depth 1200 mm, PU 2 pieces
Part no.
23130-507
23130-172
23130-363
100
D
Accessories: Side covers
01013072
Top cover element for aisle containment (SHX 30 air/
쮿 Width 300 mm (when fitting directly beside the "Sliding door,
mechanical" a 200 mm width must be used)
쮿 The universal top cover profile enables the aisle height to be
raised by 84 mm and cabinets with other heights can also be
integrated. Please order separately
Width 300 mm
01013079
Delivery includes
Item
1
2
Qty
1
1
Description
Top cover, St, 2 mm, RAL 7021, plate length 1200 mm
Order Information
Width Description
mm
300
For cabinet width 300 mm (aisle width 1200 mm)
Accessories
Raised top cover Al extrusion, RAL 7021, length 2400 mm,
height 84 mm, PU 2 pieces; raises top cover elements by
84 mm and allows integration of cabinets with other
heights
Assembly kit Mounting of top cover raising profile,
PU 6 pieces
1.236
Part no.
21130-648
21130-594
23130-433
Management for SHX 30
쮿 Connection of cabinet management basic unit with RJ 45
interface
쮿 Automatic detection of the connected LHX 20/40 air/water heat
exchangers
쮿 Monitored parameters:
interface
– Air temperature front (2 parameters)
– Air temperature rear (2 parameters)
– Fan speed
(6 parameters for LHX 20, 7 parameters for LHX 40)
– Water inflow temperature (1 parameter)
Note
00711017
Browser display
쮿 For cabinet management base unit see page 3.46
쮿 Sensors (temperature, humidity, differential pressure,
airflow...) and hub for connecting multiple sensors see from
page 3.47
1
LA
N
4
2
3
EMX -111
00711020
01011051
5
1
4
LA
N
2
3
EMX -888
Item
1
2
3
4
5
01011050
01011050
Description
Real-time monitoring of web graphical user interface (GUI)
EMX
LHX 20/40
Telemonitored temperature and humidity sensors
Part number in bold face type: ready for despatch within 2 working days
1.237
VARISTAR LHX 3 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
Cabinets – VARISTAR LHX 3
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01008029
Front panels,
01007010
Air/water heat exchanger in base/
plinth
- Extractable
- Water connection from rear,
optionally from front
- Cable ducting to rear, can be
sealed with slide covers
Advantages:
By separating the heat exchanger
(in the base/plinth) from the fan
(in the top cover), the cold air flows
evenly through the cabinet.
Reflowing of the warm air to the
heat exchanger through channels
in the side panels.
Applications:
Measuring and test devices in
industrial areas, e.g.:
- Temperature sensitive precision
measurements
- Engine and transmission test
bench
Power supply
Backplanes . . . 10
Connectors, front
panel component
01007014
Top cover with fan
- Fan unit in top cover
- Airflow through channels in side
panel
- Easy maintenance and exchange
01007055
1.236
SCHROFF PRODUCT CATALOG E 05/2016
Overview . . . . . . 1.236
VARISTAR LHX 3Mai n C atalogue
Air/water heat exchanger for measuring and test equipment
쮿 Complete cabinet to protection class IP 55 with heat exchanger
in base/plinth and fan tray in top cover
쮿 Even circulation of cold air within the cabinet, no air short circuits as with
side-by-side mounted units
VARISTAR
쮿 Cooling capacity up to 3 kW
쮿 Very low noise level of 45 dB(A)
VARISTAR LHX 3
VARISTAR LHX 3 . 1.238
쮿 Air/water heat exchanger in base/plinth
쮿 Airflow through channels in side panel
쮿 Leakage safety
01007015
VARISTAR LHX 19" chassis, available on request
쮿 Air/water heat exchanger as 19" chassis
쮿 Airflow through channels in rear door (cabinets may be
mounted side-by-side)
쮿 Devices with different airflows may be used (e.g. from left to
right or from front to rear)
쮿 Variable air outlet in 19" chassis, thus selective direction of
cold air
01008088
ServicePLUS
e.g. climate control, complete assembly,
cabling (power supply), function test
e.g. delivery to point of use, erection service,
commissioning, replacement service,
maintenance, repairs, replacement parts
30407004
VARISTAR
VARISTAR
EMC. . . . . . . . . . . . . 1.54
VARISTAR
VARISTAR
Datacom and
Networking
1.237
VARISTAR LHX 3
VARISTA R LHX 3 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Cabinet in accordance with protection class IP 55, RAL 7021,
with glass front door
쮿 Air/water heat exchanger (3 kW) in base/plinth (extractable)
쮿 Static load-carrying capacity 800 kg (Heavy-Duty frame)
Delivery comprises (completely assembled and earthed)
Item
1
Qty
1
2
3
1
1
4
1
5
1
6
7
2
1
8
4
9
1
10
1
01007015
2
3
Description
Welded basic frame, Heavy-Duty, St profile, zinc-plated,
RAL 7021, IP 55, with all-round gasket
Radial fan, 230 VAC, assembled on cross member,
SCHUKO/UTE connector, cable length 1.5 m
Front door, glass, frame RAL 7021, 180° hinge,
multi-point locking, lever handle for optional
Rear door, St, RAL 7021, 180° hinge, multi-point
interlocking, lever handle for optional DIN profile half
cylinder
Side panel, screwed, St, RAL 7021, with ventilation duct
Base/plinth with base plate, St, RAL 7021, height
200 mm, removable covers at front and rear, integrated
feet; cable ducting to rear, can be sealed with slide
covers
175 mm recessed at front, 500 mm distance between
Air/water heat exchanger, 3 kW, RAL 7021; integrated
in base/plinth, extractable
User manual
Order Information
5
Height
Usable height
Width
Depth
mm
U
mm
mm
2000
34
600
800
2200
38
600
800
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Thermostat with mains/line connector, 230 VAC, SCHUKO/
UTE connector, IEC-320 female connector, 1 piece
1
8
4
Part no.
10130-193
10130-194
25127-995
20118-750
Note
쮿 Further dimensions and versions available on request (e.g. with
heat exchanger as 19" chassis or with airflow in the rear panel)
쮿 Technical data see page 1.239
6
7
9
01007061
1.238
Technical data LHX 3
Cooling capacity
Usable cooling capacity
(cooling water inlet temperature 10° C,
air exit temperature 20° C)
01007055
A fan sucks in the warm air at the top and leads it downwards
through the lateral air channels in the side panels to the air/water
heat exchanger. The cold air is let into the cabinet at the bottom.
Water circuit
Cooling medium 1)
Water inlet temperature 2)
Water flow volume
Max. water pressure
Static pressure loss in device at 0.5 m3/h
Water conduit
Connection condensat drain
Water
6 ... 16 °C
up to 2.0 m3/h
6 bar
0.1 bar
Copper
Rp 1/2"
Ø 10 mm
Air circuit
Airflow volume
900 m 3/h
Electrical data
Supply voltage, single phase
Current consumption
Power consumption
Apparent power at full load
Protection fuse
230 VAC, 50/60 Hz
0.38 A
85 W
120 VA
2A
General Data
Cabinet type of protection
Ambient temperature during transport
Ambient temperature outside of cabinet
(during operation)
Relative humidity level
Noise level at 100 % fan performance
Weight: cabinet/heat exchanger
Dimensions of air/water heat exchanger
Height
Width
Depth
Diagram of LHX 3 characteristics
Usable cooling capacity in kW
3 KW
IP 55
-25 ... 70 °C
5 ... 70 °C
5 ... 95 %
45.2 dB(A)
approx. 115 kg/35 kg
199 mm
464 mm
425 mm
(465 mm with handles)
1) For an optimal operation of the air/water heat exchanger the demands on the
water quality have to be fulfilled (VDE 3803, please see user manual)
2) If the water inlet temperature falls short of 16 °C the formation of condensation
should be anticipated
kW
3,0
l
VH2O = 400 /h
2,9
2,8
2,7
2,6
2,5
2,4
8
10
12
Incoming water temperature
14
16
18
°C
01007076
1.239
N ovastarMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
Cabinets – Novastar
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
07011036
Light - slim - robust
The base frame, made in lightweight aluminium, is the
basis for your individual NOVASTAR. And now you
decide: small or large, in standard depth or with
extended space for cabling and heat dissipation,
whether as a stand-alone solution or stacked one on
top of another and bolted together.
The NOVASTAR platform concept leaves no wish
neglected. And regardless of how you put your
NOVASTAR together, the internal dimensions remain
consistently compatible with 19" technology. Unwanted
spaces in either height or width are now a thing of the
past.
With a cabinet width of only 553 mm, NOVASTAR is the
slimmest of all 19" cabinets. It has a slender, filigreed
look, almost like a piece of designer furniture. This
impression is further reinforced by the different finishes
of the frame and cover trim and the plain, modern fullglass doors.
Because of this, NOVASTAR is not only used in offices
and laboratories but also in sound and TV studios. And
indeed as a collector's item in the occasional home!
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
07011023
Backplanes . . . 10
Simple fitting of side panel
without tools
07011025
07011020
07011022
07011007
Door with 180° opening angle thanks to new hinge concept;
can be mounted left or right
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
07011028
Extensive selection of castors
1.240
SCHROFF PRODUCT CATALOG E 06/2017
Heavy-Duty frame with lateral groove
for mounting e.g. of carrier arm systems
Cabinets – Novastar
Overview . . . . . . 1.240
Novastar
Main CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
The inNOVAtive 19" electronics cabinet
쮿
쮿
쮿
쮿
쮿
Type of protection up to IP 40
Bolted, die-cast frame with Al extrusions
Cabinet width only 553 mm
Static load-carrying capacity up to 400 kg
Colours: RAL 7021 or colour combination RAL 7021/ RAL 7035
19" cabinet,
with glass door (smoke grey) and rear panel
Dimensions . . . . . . 1.243
19" cabinet,
door and rear panel combination freely selectable
NOVASTAR
19" cabinet with
smoke tintend
glass door and
rear panel . . . . . . . 1.246
Selectable
combination of 19"
cabinet, door and
rear panel . . . . . . . 1.247
Accessories
07011010
07011013
쮿 Height of Slim-Line 12 ... 20 U (load-carrying
capacity 200 kg)
쮿 Height of Slim-Line 9 ... 25 U (load-carrying
capacity 200 kg)
쮿 Height of Heavy-Duty 38 ... 43 U (load-carrying
capacity 400 kg)
쮿 Height of Heavy-Duty 34 ... 47 U (load-carrying
capacity 400 kg)
쮿 Depth 600, 800 mm
쮿 Depth 500, 600, 800 mm
쮿 Door and rear panel can be equipped individually
Doors and
cable ducting
systems . . . . . . . . . 1.247
Rear panels and
cable ducting
systems . . . . . . . . . 1.251
Base plates . . . . . . 1.252
Castors . . . . . . . . . . 1.253
Bases/plinths . . . . 1.254
19" panel/slide
mounts . . . . . . . . . . 1.255
Depth members . . 1.255
Slide rails . . . . . . . . 1.256
Shelves . . . . . . . . . 1.258
Support arm
system . . . . . . . . . . 1.260
Slide nut . . . . . . . . . 1.260
Standards/Approvals
쮿 External and internal dimensions in accordance with IEC 60297-3-100
쮿 Type of protection IP 40 in accordance with IE 60529
쮿 Earth connections in accordance with DIN EN 50178 / VDE 0160
ServicePLUS from page 1.261
ServicePLUS . . . 1.261
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (cut-outs)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
30407004
SCHROFF.PENTAIR.CO.UK
www.schroff.biz/ServicePLUS
1.241
Cabinets – Novastar
Novastar configurator
NovastarMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shipping within 10 working days
With the Schroff brand, Pentair offers a wide range of electronics
cabinets and other electronic protection products. Instead of
restricting the range to a few standard products, Schroff offers
bespoke solutions which fulfill the specific requirements of the
application. Schroff configurations are easy-to-operate tools
which make it possible to configure and modify products quickly
and easily: Design Your Standard.
The Novastar configurator is a web-based tool with an intuitive
graphical user interface and multilingual menus in English,
German, and French. These make configuring Novastar cabinets
quick and easy.
Individual solutions are just a click away
쮿 Configurations can start with the frame or by modifying readyconfigured or previously configured Novastar cabinets
쮿 Large selection of dimensions, frame types, door types, side panels,
top covers, and base plates
쮿 Accessories such as shelves and slide rails can be mounted
쮿 Selection of special cabinet colors
쮿 Cutouts incorporated for switches and connectors or logos, text, and
other graphics printed
07017001
Real-time 3D CAD model generation
쮿 Real-time display of configured cabinets with all modifications in
several views and adjustable transparency
쮿 The configuration adjusts in real time and offers different mounting
options
쮿 Real-time generation of 3D CAD models and/or 2D native CAD files in
more than 30 CAD file formats for downloading or for immediate
further processing and integration into the user's CAD software
쮿 Real-time generation of a bill of materials with all components of the
configured cabinet
쮿 Quotes issued quickly for customized Novastar cabinets and an inquiry
is simply a click away
Ease of use
쮿 Graphical user interface with drag-and-drop functionality and
immediate display of the selected configuration
쮿 Available components are listed as illustrations in the menu for quick
access and easy identification
쮿 Intelligent configurator logic indicates where components can be
installed, ensures compatibility and shows relevant optional
components
쮿 The "U" height scale helps you to position the components correctly
쮿 Components identified with mouse-over functionality
쮿 Components exchanged using simple drag-and-drop functionality or
deleted in the bill of materials
쮿 Non-assembled accessories can be added to the bill of materials
쮿 No need to download any programs or apps, or install any software or
plug-ins No registration required
쮿 The optional, free user account registration provides access to
additional functions
1.242
Cabinets – Novastar
Dimension drawings Slim-Line frames
Frame
451
451
10
465
84,
5
8
h
H
465
553
D
07011094
Frame (top view)
07011093
Main Catalogue
쮿 Lightweight aluminium die-cast frame and lightweight vertical
profile
553
467
쮿 Static load-carrying capacity 200 kg, tested in accordance with
IEC 61587-1
d
Cabinet height
U
6
9
12
16
34
38
43
47
Foot height 8 mm
d1
56
33
64
c
56
d1
D
106
60
Frame dimensions
Ø8
451
465
w
451
465
w
H
mm
357
456
589
767
945
1167
1567
1745
1967
2145
h
mm
268
401
535
713
890
1112
1513
1690
1913
2090
07011098
Upright at front/rear
50,5
Upright at rear
50,5
30
Frame dimensions
Cabinet
depth
7
M8
12
19" to
19" plane
Floor mounting
c
mm
407
507
707
807
907
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
12
07011096
D
mm
500
600
800
900
1000
Adjustable feet,
castors, lifting eye,
top cover fixing
d
mm
405
505
705
805
905
19,5
36
33
19,5
36
60
7
84,5
M8
84,5
10
10
30
07011097
1.243
Cabinets – Novastar
Dimension drawings Heavy-Duty frames
Frame
19" upright
451
451
465
h
H
75
84,
8
465
10
553
D
07011095
Frame (top view)
07011092
쮿 Light aluminium die-cast frame and robust vertical profile
553
쮿 Static load-carrying capacity 400 kg, tested in accordance with
IEC 61587-1
467
쮿 Lateral groove for mounting accessories
Cabinet height
U
12
16
34
38
43
47
Foot height 8 mm
d1
d
d1
56
60
64
56
c
D
106
60
Frame dimensions
Ø8
451
465
H
mm
589
767
945
1167
1567
1745
1967
2145
h
mm
535
713
890
1112
1513
1690
1913
2090
451
465
w
07011100
Frame dimensions
19" front / rear upright
Cabinet
depth
50,5
30
D
mm
500
600
800
900
1000
10
M8
19" to
19" plane
Floor mounting
c
mm
380
480
680
780
880
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
19,5
60
64
84,5
7
Adjustable feet,
top cover fixing
d
mm
405
505
705
805
905
12
07011099
1.244
Cabinets – Novastar
Dimensional drawings Heavy-Duty Universal frames
Frame
Universal upright
07016081
Frame (top view)
07016002
MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days
쮿 Light aluminum die-cast frame and robust vertical profile
쮿 Static load-carrying capacity 400 kg, tested to IEC 61587-1
쮿 Lateral groove for mounting built-on accessories
Rack dimensions
Cabinet height
U
12
16
34
38
43
47
Foot height 8 mm
Universal front upright / 19" rear upright
07016082
H
mm
589
767
945
1167
1567
1745
1967
2145
H
mm
535
713
890
1112
1513
1690
1913
2090
Rack dimensions
Cabinet
depth
D
mm
500
600
800
900
1000
Adjustable feet,
casters, lift lug, top
cover fixing
d
mm
405
505
705
805
905
19" to 19"
plane
Base mounting
c
mm
380
480
680
780
880
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
07016083
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.245
Cabinets – Novastar
19" cabinet with glass door (smoke grey) and rear panel
쮿 All uprights (front and rear) with 19" cut-outs
쮿 Flush cladding parts
쮿 Type of protection IP 20
쮿 2 cabinet depths (600 mm, 800 mm), cabinet width 553 mm
– Slim-Line 200 kg (12, 16, 20 U)
– Heavy-Duty 400 kg (38, 43 U)
쮿 2 colours
– RAL 7021 (black grey) throughout
– Colour combination: side panels, rear panel RAL 7035 (light
grey); frame, top cover RAL 7021 (black grey)
Delivery comprises (assembled)
07011010
3
Item
1
Qty
1
2
2
3
4
1
1
5
1
6
7
4
1
Description
Frame, uprights Al extrusion with 19" cut-outs,
Al die-cast frame, RAL 7021
Side panel, St, 1 mm; light grey (RAL 7035) or
black grey (RAL 7021), see Order information;
twist-locking catch (Torx T30)
Flush top cover, St, 1 mm, RAL 7021
Glazed door, single pane safety glass (ESG) 6 mm, smoke
grey, with DIN cylinder safety lock and 2 keys (2233x)
Rear panel, St, 1 mm, light grey (RAL 7035) or
Foot
GND/earthing kit
Order Information
2
1
H
8
5
Width
W
Depth
D
U
mm
mm
mm
Colour
RAL 7021
Part no.
Colour
RAL 7035/RAL
7021
Part no.
16230-019
16230-020
16230-021
16230-022
16230-023
16230-024
16230-025
27230-066
Note
D
6
Spacing to 19" plane:
Slim-Line: front 33 mm, rear 60 mm;
Heavy-Duty: front and rear 60 mm
Height
H
Slim-Line
12
589
553
600
15230-019
16
767
553
600
15230-020
553
600
15230-021
Heavy-Duty
38
1745
553
600
15230-022
38
1745
553
800
15230-023
43
1967
553
600
15230-024
43
1967
553
800
15230-025
Accessories
Lifting eye for flush cover M12 thread, application and load
to DIN 582 PU 4 pieces
4
W
Usable
height
07011050
쮿 Please order base plate, base/plinth, slide rails and shelves
separately, see from page 1.254
쮿 Castors see page 1.253
쮿 Other accessories/components see ServicePLUS,
from page 1.261
쮿 Dimension drawings see from page 1.243
ServicePLUS see page 1.261
1.246
Cabinets – Novastar
19" cabinet, door and rear panel combination freely
selectable
쮿 3 cabinet depths (500, 600 and 800 mm), cabinet width 553 mm
– Slim-Line 200 kg (9 U to 25 U)
– Heavy-Duty 400 kg (34 U to 47 U)
쮿 2 colours
– Colour combination: side panels RAL 7035 (light grey);
07011013
2
8
H
1
D
4
Qty
1
2
2
3
4
5
1
4
1
Description
Foot
GND/earthing kit
Order Information
3
W
Item
1
07011051
Usable height Height H Width
W
Depth
D
U
mm
mm
mm
Part no.
Colour
RAL 7035/RAL
7021
Part no.
Slim-Line
9
12
12
16
16
25
456
589
589
767
767
945
945
945
1167
1167
553
553
553
553
553
553
553
553
553
553
600
500
600
500
600
500
600
800
600
800
15230-001
16230-001
15230-002
16230-002
15230-003
15230-004
16230-003
16230-004
15230-005
16230-005
15230-006
15230-007
16230-006
16230-007
15230-008
16230-008
15230-009
15230-010
16230-009
16230-010
Colour
RAL 7021
Heavy-Duty
34
1567
553
600
15230-011
34
1567
553
800
15230-012
38
1745
553
600
15230-013
38
1745
553
800
15230-014
43
1967
553
600
15230-015
43
1967
553
800
15230-016
47
2145
553
600
15230-017
47
2145
553
800
15230-018
Accessories
16230-011
16230-012
16230-013
16230-014
16230-015
16230-016
16230-017
16230-018
27230-066
쮿 Please order doors, rear panel, base plate, base/plinth, slide
rails and shelves separately, see from page 1.248
from page 1.261
Part number in normal type: ready for despatch within 10 working days
1.247
Cabinets – Novastar
Glass door (smoke grey)
쮿 Can be assembled at front and rear
쮿 Opening angle 180°
Delivery comprises
Item
1
Qty
1
2
1
Description
Glass door, single pane safety glass (ESG) 6 mm, smoke
grey; safety lock with DIN cylinder and 1 key (2233x);
hinges, plastic, black
Assembly kit
Order Information
For cabinet height
U
9
12
16
29
34
38
43
47
Height
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Part no.
27230-002
27230-003
27230-004
27230-005
27230-006
27230-028
27230-007
27230-008
27230-009
27230-010
07011059
Glazed acrylic glass door
쮿 Mounting front or rear
쮿 Lock with key
쮿 Frame color black gray (RAL 7021) or light gray (RAL 7035)
Delivery includes
Item
1
2
3
4
Qty.
1
1
1
1
Description
Door frame, St, 1.5 mm
Acrylic sheet, 2 mm, clear
Lock (2233x) with 1 key
Fixing materials kit including GND
Order Information
07016054
1.248
07016053
For cabinet height
For cabinet height
U
6
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
322
456
589
767
945
1167
1345
1567
1745
1967
2145
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-092
26230-092
25230-093
26230-093
25230-094
25230-095
26230-094
26230-095
25230-096
26230-096
25230-097
25230-102
26230-097
26230-102
25230-098
26230-098
25230-099
25230-100
26230-099
26230-100
25230-101
26230-101
60127-018
Cabinets – Novastar
Steel door
쮿 Colour black grey (RAL 7021) or light grey (RAL 7035)
Delivery comprises
Item
1
Qty
1
2
1
Description
Steel door, St, 1.5 mm; safety lock with DIN cylinder and
1 key (2233x); hinges, plastic, black
Fixing material kit and GND/earthing kit
Order Information
07011060
For cabinet height
Height
U
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-021
25230-022
26230-021
26230-022
25230-023
26230-023
25230-024
25230-025
26230-024
26230-025
25230-030
26230-030
25230-026
25230-027
26230-026
26230-027
25230-028
26230-028
25230-029
26230-029
60127-018
Perforated door
쮿 Can be mounted at front and rear
쮿 Perforated (60 % ventilation opening)
쮿 Lock with key (2233X)
쮿 Colors RAL 7035 and RAL 7021
Delivery includes
Item
1
Qty.
1
2
3
2
2
1
1
Description
Door, perforated, St, 1.5 mm, width 553 mm, 60 %
ventilation opening, see order information for color
Hinge, 180° opening angle
Lock with single key (2233X)
Earthing (GND) kit
Order Information
07016078
07016055
For cabinet height
Height
U
6
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
288.4
421.75
555.1
732.9
910.7
1132.95
1310.75
1533
1710.8
1933.05
2110.85
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-081
26230-081
25230-082
25230-083
26230-082
26230-083
25230-084
26230-084
25230-085
25230-086
26230-085
26230-086
25230-091
26230-091
25230-087
25230-088
26230-087
26230-088
25230-089
26230-089
25230-090
26230-090
60127-018
1.249
Cabinets – Novastar
Cable ducting combination for steel door
쮿 For a cable ducting combination a steel door, a door hinge
bracket and a frame for cable ducting are required
쮿 Cable ducting can be at top or bottom
쮿 Frame with brush strip for cable ducting is either 3 U or 4 U,
depending on cabinet/door height
Delivery comprises
2
Item
1
Qty
1
1
2
1
3
1
Description
Door hinge bracket, St, 2 mm, RAL 7021
requires 1 U fitting space,
mounts above or below the steel door
Steel door, St, 1.5 mm, lock (2233x) with 1 key,
opening angle 180°, GND/earthing
Frame for cable ducting, St, 2.5 mm,
with black brush strip,
3 U (for cabinet heights 16, 20, 38, 47 U)
4 U (for cabinet heights 25, 34, 43 U)
3
07011061
Order Information
Steel door
RAL 7035
RAL 7021
1 key, openingangle 180,
incl. GND/earthing
Height
(U)
16
34
38
43
47
Steel door
Perforated
RAL 7035
RAL 7021
St, 1.5 mm, perforated, opening
angle 180°, lock with key
(2233X), incl. grounding
Glass door
Door hinge bracket for doors
smoke grey
Slim-Line
Slim-Line
Heavy-Duty
19" plane for
front
rear
front/rear
universal upright
33 mm
60 mm
60 mm
door hinge bracket, St, 2 mm, RAL 7021
St, 2 mm, RAL 7021; 1) Height 3 U
RAL 7021;
mounts above or 2) Height 4 U
mounts above or below the door;
below the door;
requires 1 U assembly space
requires 1 U
assembly space
opening angle
180°,
lock with key,
glass type:
ESG 6 mm,
EN 12150
26230-022
26230-023
25230-022
25230-023
26230-084
26230-085
25230-084
25230-085
27230-004
27230-005
27230-060
27230-060
27230-061
27230-061
27230-098
27230-098
26230-024
25230-024
26230-086
25230-086
27230-006
27230-060
27230-061
27230-098
26230-030
26230-026
25230-030
25230-026
26230-087
26230-088
25230-087
25230-088
27230-007
27230-008
27230-060
27230-060
27230-061
27230-061
27230-098
27230-098
26230-027
25230-027
26230-089
25230-089
27230-009
27230-060
27230-061
27230-098
26230-028
25230-028
26230-090
25230-090
27230-010
27230-060
27230-061
27230-098
1)
1)
2)
2)
1)
2)
1)
27230-162
27230-162
27230-163
27230-163
27230-162
27230-163
27230-162
Cable ducting
RAL 7035
Screw fixed
Height
(U)
16
34
38
43
47
1.250
RAL 7021
RAL 7021
Screw fixed
clipped
St, 2.5 mm,
1) Height 3 U
2) Height 4 U
1)
1)
2)
2)
1)
2)
1)
20118-391 1) 20118-796 1) 27230-160
20118-390 2) 20118-797 2) 27230-161
Cabinets – Novastar
Rear panel
쮿 Twist-locking catch (Torx T30, with 1/4 turn)
쮿 Rear panel: colour black grey (RAL 7021) or
Delivery comprises
Item
1
Qty
1
2
1
Description
Rear panel, St, 1 mm, twist-locking catch (Torx T30,
with 1/4 turn)
Assembly kit
Order Information
For cabinet height
Height
U
9
12
16
29
34
38
43
47
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-371
25230-372
26230-371
26230-372
25230-373
26230-373
25230-374
25230-375
26230-374
26230-375
25230-147
26230-147
25230-376
25230-377
26230-376
26230-377
25230-378
26230-378
25230-379
26230-379
07011057
Rear panel with cable ducting frame
쮿 Cable ducting frame 3 or 4 U
Delivery comprises
Item
1
Qty
1
2
1
3
1
4
1
1
2
Order Information
3
07011058
Description
Rear panel, St, 1 mm, colour see Order information;
twist-locking catch (Torx T30, with 1/4 turn)
Door hinge bracket, St, 2 mm, colour see Order
information
Frame for cable ducting, St, 1.5 mm, colour see Order
information; brush strip;
3 U frame for cable ducting for cabinet heights
16, 20, 38, 47 U;
4 U frame for cable ducting for cabinet heights
25, 34, 43 U
Assembly kit and GND/earthing kit
For cabinet
height
U
16
34
38
43
47
Height
mm
733
911
1133
1534
1711
1933
2111
For cabinet
width
mm
553
553
553
553
553
553
553
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-430
26230-430
25230-434
26230-434
25230-439
25230-448
26230-439
26230-448
25230-452
26230-452
25230-457
25230-461
26230-457
26230-461
1.251
Cabinets – Novastar
Base plate, multi-piece
쮿 Floor is open at rear; Opening can be closed with a cover plate
or brush strip
Delivery includes
Item
1
Qty
1
2
1
Description
Base plate, St, 1.5 mm, RAL 7021; cable through-ducting
opening, width 440 mm, depth 70 mm
Assembly kit
Order Information
07011073
Accessories
07016050
For cabinet depth
For cabinet width
mm
mm
500
553
600
553
800
553
1000
553
1200
553
Accessories
Brush strip Nylon, black, 440 mm x 98 mm, PU 1 piece
Solid cover plate for floor, multi-piece, St, 1 mm,
485 mm x 92 mm, RAL 7021, 1 piece
Perforated cover plate for floor, multi-piece St, 1 mm,
Filter mat cover plate for floor, multi-piece St, 1 mm,
Part no.
27230-188
27230-189
27230-190
27230-191
27230-192
27230-079
27230-114
27230-254
27230-255
Note
쮿 Please order cover plate or brush strip separately
Base plate, single piece, reinforced, with cutouts for
cable ducting
쮿 Heavy-load floor panel
쮿 Load-carrying capacity 50 kg (110 lbs)
쮿 Cutout for cable ducting
Delivery includes
Item
1
Qty.
1
2
1
Description
Base plate, St, 2,5 mm, RAL 7021;
cable ducting opening, perforated, width 370 mm,
depth 50 mm
Order Information
07016059
Reinforced brush strip for floor
For cabinet depth
For cabinet width
Qty/PU
mm
mm
piece
500
553
1
600
553
1
800
553
1
900
553
1
1000
553
1
Accessories
Brush strip for heavy-load floor panel Nylon, black, width
370 mm, depth 50 mm 1 piece
Part no.
RAL 7021
25230-149
25230-150
25230-151
25230-152
25230-153
27230-055
Note
07016060
1.252
SCHROFF PRODUCT CATALOG E 07/2017
쮿 Please order brush strip separately
Cabinets – Novastar
Castors
쮿 Castors are fitted to the frame
쮿 Static load-carrying capacity 200 kg, 300 kg or 400 kg
depending on version
쮿 Height dependent on version 73 mm, 80 mm, 131 mm or
155 mm
쮿 2 castors without jacking foot, 2 castors with jacking foot
Delivery comprises
07011065
Load-carrying capacity 200 kg
07011066
Load-carrying capacity 300 kg,
conductive,
ESD resistance < 10 kΩ
Item
1
2
3
Qty
2
2
1
Description
Locking castor, PA/St
Non-locking castor, PA/St
Assembly kit
Order Information
Description
Loadcarrying
capacity
kg
200
Castors
Castors, conductive,
ESD resistance < 10 kΩ 300
to EN 12528
Castors with
400
adjustable feet
Castors
400
07011067
Height H Castor
diameter
mm
mm
Part no.
73
Ø 50
27230-067
131
Ø 100
27230-110
80
Ø 60
27230-068
155
Ø 125
27230-069
07011068
Load-carrying capacity 400 kg, Load-carrying capacity 400 kg
with adjustable feet
1.253
Cabinets – Novastar
Base/plinth with cable ducting
쮿 Height adjustable 57 .... 67 mm
쮿 Cable ducting (110 x 76 mm) with cover
Item
1
Qty
1
2
3
4
1
Description
Base/plinth, St, 1.5 mm, height 55 mm, RAL 7021;
cable ducting 110 mm x 76 mm, with plastic cover
Adjustable foot
Order Information
07011075
For cabinet width
For cabinet depth
mm
mm
553
500
553
600
553
800
553
900
553
1000
Accessories
Brush strip Nylon, black, 110 mm x 76 mm; to cover cable
through-ducting opening , 1 piece
Part no.
27230-070
27230-071
27230-072
27230-076
27230-080
27230-111
Mobile base/plinth
쮿 Base/plinth height H = 100 mm
Delivery comprises
Item
1
Qty
1
2
1
3
4
4
1
Description
Base/plinth, St, 2 mm, black (RAL 7021), with perforation,
height = 100 mm
Fine-grooved mat, natural rubber, anthracite, 3 mm
thick, self-adhesive
Castors, St, Ø 55 mm, load-carrying capacity 200 kg
Assembly kit
Order Information
D
mm
592
692
892
Part no.
27230-146
27230-147
27230-148
96
37
48
For cabinet depth
mm
500
600
800
546
D
07011113
1.254
Cabinets – Novastar
Depth members
쮿 For assembly on cabinet uprights
쮿 Adjustable in 1 U increments
Delivery includes
Item
1
Qty
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
56
13,5
For cabinet depth
mm
500
600
800
900
1000
D
mm
366
466
666
766
866
Part no.
27230-167
27230-168
27230-169
27230-170
27230-171
D
07016067
07011114
19" panel/slide mounts with universal perforation grid
(EIA)
쮿 For fitting to depth members (25 mm grid)
쮿 For recessed installation of 19" components
쮿 Load-carrying capacity 400 kg
쮿 Slide rails can be fitted
쮿 A partial-height 19" mounting is possible with short 19" panel/
slide mounts
Delivery includes
Item
1
2
Qty
2
1
Description
19" panel/slide mount, St, 2 mm, RAL 7021
Assembly kit
Order Information
07011111
19" panel/slide mount mounted
on depth members
07016080
For cabinet height
U
mm
Partial-height
6
mounting
9
456
12 589
16 767
20 945
25 1167
34 1567
38 1745
43 1967
47 2145
Usable height
U
H
mm
Part no.
6
267
27230-172
9
12
16
34
38
43
47
400
534
712
889
1112
1512
1690
1912
2090
27230-173
27230-174
27230-175
27230-176
27230-177
27230-178
27230-179
27230-180
27230-181
쮿 Slide rails see page 1.256
쮿 Depth members are required for fitting, see page 1.255
1.255
Cabinets – Novastar
19" plane for universal upright
쮿 Panel/slide mount for installing on the universal profile
쮿 A 19" plane can be implemented using the panel/slide mount
Delivery includes
Item
1
2
Qty.
4
1
Description
Order Information
Height
U
3
4
3U
07016070
Height
mm
130
170
Qty/PU
piece
2
2
Part no.
27230-162
27230-163
07016071
4U
Slide rail
쮿 For mounting on the vertical cabinet uprights or 19" panel/slide
mounts
쮿 Static load-carrying capacity 25 kg per pair
D
Delivery comprises
Qty
2
1
Description
Slide rail, St, 1.5 mm, finish AlZn
Assembly kit
82
Order Information
39
W
07011078
Item
1
2
07011104
For cabinet depth D
mm
500
600
800
900
1000
L
mm
370
470
670
770
970
x
mm
322
422
622
822
922
Part no.
27230-102
27230-103
27230-104
27230-105
27230-106
00205051
1.256
Cabinets – Novastar
Heavy-load slide rail
mounts
쮿 Static load-carrying capacity 50 kg per pair
쮿 900, 1000 mm depth for server applications
Delivery includes
Item
1
2
Qty.
2
1
Description
Slide rail, St, 2 mm, finish AlZn
Order Information
07016066
For cabinet depth D
L
x
mm
mm
mm
500
272
322
600
370
422
800
470
522
900
670
722
1000
870
822
900, 1000 mm for server
740
692
applications
Accessories
Fixing materials kit for heavy-load slide rail 1 set (4 x
M5x12 screws, 4 x M5 cage nuts, screwed in from the
inside)
Part no.
25230-013
25230-014
25230-015
25230-145
25230-146
25230-148
27230-056
07016084
Short slide rail
쮿 For mounting on the cabinet uprights or 19" panel/slide mounts
쮿 Static load-carrying capacity max. 15 kg per pair
Delivery comprises
Item
1
2
Qty
2 / 10
1
Description
Short slide rail, St, 1.5 mm, finish AlZn
Assembly kit
Order Information
Description
Short slide rail
Short slide rail
Qty/PU
piece
2
10
Part no.
27230-184
27230-185
07016065
1.257
Cabinets – Novastar
Shelf, stationary
쮿 Static load-carrying capacity 75 kg
쮿 Mounting height 1 U, for fitting on the vertical cabinet uprights
쮿 Hammer head perforation for fixing cables using cable ties or
Velcro-type tape
쮿 900, 1000 mm Tiefe für Server Anwendungen
Delivery includes
Item
1
2
Qty
1
1
Description
Shelf with perforation, St, 1.5 mm, RAL 7021
Assembly kit
07011077
Order Information
W
W = 553 mm
1.258
D
d
w
07011105
For cabinet depth D
Usable surface w x d
mm
mm
500
488 x 350
600
488 x 450
800
488 x 650
900
488 x 750
1000
488 x 850
900, 1000 mm für
488 x 740
Serveranwendungen
Accessories
Cable ties 92 mm x 2.5 mm, PU 25 pieces
Cable ties 186 mm x 5 mm, PU 25 pieces
Cable ties 360 mm x 5 mm, PU 25 pieces
Velcro strip Polyethylen/Polyamide, black,
length 300 mm, PU 10 pieces
Part no.
27230-051
27230-052
27230-053
27230-088
27230-089
27230-165
20118-351
20118-352
20118-353
20118-624
Cabinets – Novastar
Telescopic shelf, 70 kg
Main Catalogue
쮿 Static load-carrying capacity at full extension 70 kg
쮿 Mounting height 2 U, for fitting to the four vertical uprights
쮿 Incl. telescopic slides
1
쮿 Locking possible with T-bar lock
2
Velcro-type tape
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
4
Delivery comprises
Item
1
2
3
Qty
1
2
1
Description
Telescopic slide
Assembly kit
07011089
Full depth
Order Information
w
Full depth
D
c
Cabinet dimensions W x Usable surface xf
xf1 c
D
wxd
mm
mm
mm mm mm
553 x 500
405 x 382
33 60 407
553 x 600
405 x 482
33 60 507
553 x 800
405 x 682
33 60 687
533 x 900, 740 mm für
405 x 582
33 60 787
Serveranwendungen
533 x 1000
405 x 682
33 60 887
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
GND/earthing for telescopic shelf PU 1 piece
xf
xf 1
d
60
W
Full depth
Part no.
21130-357
21130-353
21130-355
27230-108
27230-109
23130-092
21120-189
07011101
Order Information
Shortened depth
Shortened by 100 mm
W
xf1 c
Shortened by
D
wxd
100 mm
mm
mm
mm mm mm
Part no.
553 x 500
405 x 282
33 60 407 21130-358
553 x 600
405 x 382
33 60 507 21130-352
553 x 800
405 x 582
33 60 687 21130-354
405 x 582
33 60 787 27230-108
Serveranwendungen
533 x 1000
405 x 682
33 60 887 27230-109
23130-092
21120-189
D
xf
xf 1
d
c
60
w
07011102
c = pitch of 19" profiles; xf, = Slim-Line assembly dimensions;
xf1 = Heavy-Duty assembly dimensions
1.259
Cabinets – NOVASTAR
Support arm for monitor and keyboard (SysPend®)
쮿 Support arm for mounting of monitor, keyboard and mouse on
cabinet
쮿 Fixing is to the side of the Heavy-Duty frame (height adjustable)
쮿 Static load-carrying capacity 3 ... 7 kg
쮿 Support arm:
– Height-adjustable 300 mm
– Angle of rotation on cabinet 180 °
– Monitor rotation angle 340° (fitted on cabinet 270°)
– Monitor tilt angle 60°
– Integrated cable routing
쮿 Suitable for industrial applications
Delivery comprises
00511006
Item
1
Qty
1
2
1
3
1
4
1
Description
Support arm frame, Al extrusion, RAL 7035, rotatable,
height adjustable
Wall-mounting bracket, for mounting on cabinet or wall,
hinged sideways through 180°
Keyboard storage point, tiltable upward through 95°,
width 480 mm, depth 170 mm;
mouse pad: width 150 mm, depth 190 mm
Monitor holder for flat-screen units, hinged through
340°, tiltable through 60° (15° forwards, 45° to rear)
Order Information
Description
Qty/PU
pieces
1
(SysPend® )
Accessories
Mounting material for cabinet exterior PU 4 pieces
00511004
Support arm fitted with monitor Cable ducting
and keyboard
Part no.
VAMONITOR
27230-144
00511003
NOVASTARMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 For mounting accessories to cabinet exterior (e.g. support arm)
쮿 Slide nut (M6) is simply inserted into the side T-groove of the
Heavy-Duty frame
Delivery comprises
Item
1
2
3
Qty
1
1
1
Description
Slide nut M6
Pan head screw M6 x 16 (Torx T30)
Nomel washer 6.1
Order Information
06712050
Description
1.260
Qty/PU
pieces
4
Part no.
27230-144
Cabinets – Novastar Service Plus
ServicePLUS: configuration and assembly
Novastar Servi ce Plus Main Catalogue
쮿 Dimensions:
– Height: 6 ... 47 U (357 ... 2145 mm)
– Width: 553 mm
– Depth: 500, 600, 800, 900, 1000 mm
Page
Frames, gasketing kit,
side-by-side mounting kit, 1.262
stacking kit
쮿 3 frame versions:
– Slim-Line, static load-carrying capacity 200 kg, height 6 ... 47 U
– Heavy-Duty, static load-carrying capacity 400 kg,
19" + Universal, height 16 ... 47 U
Castors, adjustable feet
1.263
쮿 Configure your cabinet from individual parts (to have them assembled
please add the suffix /05 to each part number)
Side panels
1.264
쮿 Once you have selected your cabinet dimensions, the row number
(first column of the configuration tables) guides you through all the pages
of the configurations possible for these dimensions (see example below)
Glass doors, steel doors
1.265
Cable ducting for steel
doors
1.266
Rear panels
1.267
Top covers
1.268
Fan top covers, lifting eye,
thermostat, speed
controller
1.269
Floors
1.270
Base/plinth
1.271
depth members, shelves
1.272
Shelves
1.273
Slide rails
1.274
Cable ties, Velcro-type
tape
1.275
쮿 The configured cabinet is assembled and is ready for despatch
07011052
Configuration example, assembled (here: row no. 11)
Qty
1
1
1
1
1
Description
Order no.
Frame, Slim-Line, usable height 20 U, height 945 mm,
28230-015/05
width 553 mm, depth 500 mm, 1 piece
Side panel, Slim-Line, height 20 U, depth 500 mm, RAL 7035, PU 26230-074/05
2 pieces
Glass door (smoke grey), height 20 U, opening angle 180°, width 27230-005/05
553 mm, 1 piece
Rear panel, height 20 U, width 553 mm, RAL 7035, PU 1 piece
26230-374/05
Top cover, raised, width 553 mm, depth 500 mm, RAL 7021,
25230-010/05
1 piece
1.261
Frames, gasketing kit, side-by-side mounting kit, stacking kit
Frame
Slim-Line
200 kg
Heavy-Duty
400 kg,
19"
07011053
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.262
07011054
static loadstatic loadcarrying capacity: carrying capacity:
400 kg,
200 kg,
Al extrusion,
Al extrusion,
RAL 7021, incl.
RAL 7021, incl.
GND/earthing;
GND/earthing;
19" plane 33 mm 19" plane 60 mm
at front,
at front,
60 mm at rear;
60 mm at rear;
please order
please order
castors or
castors or
adjustable feet
adjustable feet
separately
separately
Heavy-Duty,
400 kg,
Universal
07016056
Static loadcarrying
capacity: 400 kg,
Al profile,
RAL 7021,
incl. grounding;
19" plane
rear 60 mm,
castors or
adjustable feet
ordered
separately
Gasketing kit
for IP 40
07012050
TPE, black;
raises ingress
protection from
IP 20 to IP 40;
gaskets are
affixed onto the
frame
Side-by-side
mounting kit
07011080
gasket, foam
adhesive tape: PU
foam anthracite;
for joining
two adjacent
cabinets
Stacking kit
07011070
for joining two
cabinets
positioned one
above the other
Slide nut
for T-groove
aza43431
St, M6, for lateral
mounting of
accessories on
the T-groove of
the Heavy-Duty
frame
1 piece
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 kit
PU 4 pieces
assembled
assembled
assembled
assembled
enclosed loose
enclosed loose
enclosed loose
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
28230-056
28230-189
28230-310
28230-370
28230-430
28230-192
28230-193
28230-314
28230-374
28230-434
28230-196
28230-197
28230-319
28230-379
28230-439
28230-200
28230-201
28230-328
28230-388
28230-448
28230-204
28230-205
28230-332
28230-392
28230-452
28230-208
28230-209
28230-337
28230-397
28230-457
28230-212
28230-213
28230-341
28230-401
28230-461
28230-216
28230-217
28230-057
28230-058
28230-059
28230-107
28230-108
28230-109
28230-110
28230-111
28230-112
28230-113
28230-114
28230-115
28230-116
28230-117
28230-118
28230-119
28230-167
28230-168
28230-169
28230-170
28230-171
28230-172
28230-173
28230-174
28230-175
28230-176
28230-177
28230-178
28230-179
28230-180
28230-181
28230-182
28230-183
28230-184
28230-185
28230-186
28230-187
28230-188
28230-052
28230-053
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
28230-001
28230-060
28230-004
28230-063
28230-007
28230-066
28230-126
28230-054
28230-055
28230-011
28230-070
28230-130
28230-190
28230-191
28230-015
28230-074
28230-134
28230-194
28230-195
28230-020
28230-079
28230-139
28230-198
28230-199
28230-029
28230-088
28230-148
28230-202
28230-203
28230-033
28230-092
28230-152
28230-206
28230-207
28230-048
28230-097
28230-157
28230-210
28230-211
28230-042
28230-101
28230-162
28230-214
28230-215
Castors
Load-carrying
capacity 200 kg
07011065
Load-carrying
capacity 300 kg,
conductive
07011066
Adjustable foot
Load-carrying
capacity 400 kg,
Ø 60 mm
07011067
Load-carrying
capacity 400 kg,
Ø 125 mm
07011068
static loadstatic loadstatic loadstatic loadcarrying capacity carrying capacity carrying capacity carrying capacity
400 kg,
400 kg,
300 kg, height 131
200 kg,
height 155 mm,
height 80 mm,
mm, Ø 100 mm,
height 73 mm,
Ø 125 mm,
Ø 60 mm,
2 castors without
Ø 50 mm,
2 castors without 2 castors without
jacking foot,
2 castors without
jacking foot,
jacking foot,
2 castors with
jacking foot,
2 castors with
2 castors with
jacking foot;
2 castors with
jacking foot
jacking foot,
EN 12528
jacking foot
incl. 4 adjustable
(resistance
feet
< 10 kΩ)
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07011069
400 kg,
St, polyamide,
black
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
assembled
assembled
assembled
assembled
assembled
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
1.263
Side panels
Side panel
Slim-Line
07011055
Heavy-Duty
07011084
Side panel lock
07011056
07011085
St, 1 mm, with quarter-turn fastener; St, 1 mm, with quarter-turn fastener;
incl. GND/earthing
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.264
07011108
2 locks
(2233x locking),
2 keys;
suitable for
2 side panels
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 1 kit
assembled
assembled
assembled
assembled
assembled
26230-070
26230-120
26230-071
26230-121
26230-072
26230-122
26230-172
26230-113
26230-114
26230-073
26230-123
26230-173
26230-115
26230-116
26230-074
26230-124
26230-174
26230-117
26230-118
26230-075
26230-125
26230-175
26230-119
26230-130
26230-076
26230-126
26230-176
26230-131
26230-132
26230-077
26230-127
26230-177
26230-133
26230-134
26230-078
26230-128
26230-178
26230-135
26230-136
26230-079
26230-129
26230-179
26230-137
26230-138
25230-070
25230-120
25230-071
25230-121
25230-072
25230-122
25230-172
25230-113
25230-114
25230-073
25230-123
25230-173
25230-115
25230-116
25230-074
25230-124
25230-174
25230-117
25230-118
25230-075
25230-125
25230-175
25230-119
25230-130
25230-076
25230-126
25230-176
25230-131
25230-132
25230-077
25230-127
25230-177
25230-133
25230-134
25230-078
25230-128
25230-178
25230-135
25230-136
25230-079
25230-129
25230-179
25230-137
25230-138
27230-115
27230-115
26230-222
26230-272
26230-322
26230-067
26230-068
26230-223
26230-273
26230-323
26230-069
26230-080
26230-224
26230-274
26230-324
26230-103
26230-104
26230-225
26230-275
26230-325
26230-105
26230-106
26230-226
26230-276
26230-326
26230-107
26230-108
26230-227
26230-277
26230-327
26230-109
26230-110
26230-228
26230-278
26230-328
26230-111
26230-112
26230-229
26230-279
26230-329
26230-040
26230-041
25230-222
25230-272
25230-322
25230-067
25230-068
25230-223
25230-273
25230-323
25230-069
25230-080
25230-224
25230-274
25230-324
25230-103
25230-104
25230-225
25230-275
25230-325
25230-105
25230-106
25230-226
25230-276
25230-326
25230-107
25230-108
25230-227
25230-277
25230-327
25230-109
25230-110
25230-228
25230-278
25230-328
25230-111
25230-112
25230-229
25230-279
25230-329
25230-040
25230-041
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
Steel door
Steel door
Glazed door
Glass door
Perforated
07011060
07011088
opening angle 180,
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07016078
angle 180°, lock with key (2233X),
incl. grounding
07011060
Door frame, St, 1.5 mm;
acrylic glass, 2 mm;
safety lock with 2 keys
07016054
07011059
opening angle
180°,
lock with key,
glass type:
ESG 6 mm,
EN 12150
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
smoke grey
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
26230-020
25230-020
26230-081
25230-081
26230-092
25230-092
27230-001
26230-021
25230-021
26230-082
25230-082
26230-093
25230-093
27230-002
26230-022
25230-022
26230-083
25230-083
26230-094
25230-094
27230-003
26230-023
25230-023
26230-084
25230-084
26230-095
25230-095
27230-004
26230-024
25230-024
26230-085
25230-085
26230-096
25230-096
27230-005
26230-025
25230-025
26230-086
25230-086
26230-097
25230-097
27230-006
26230-026
25230-026
26230-087
25230-087
26230-098
25230-098
27230-007
26230-027
25230-027
26230-088
25230-088
26230-099
25230-099
27230-008
26230-028
25230-028
26230-089
25230-089
26230-100
25230-100
27230-009
26230-029
25230-029
26230-090
25230-090
26230-101
25230-101
27230-010
1.265
Cable ducting for steel doors
Cable ducting for steel door with door hinge bracket and frame
Steel door
RAL 7035
RAL 7021
07011060
07011088
key, opening angle 180,
incl. GND/earthing
Slim-Line
front
Slim-Line
rear,
Heavy-Duty
front/rear,
Universal rear
Cable ducting frame
Heavy-Duty
Universal
front
RAL 7035
screw fixed
07011061
RAL 7021
screw fixed
RAL 7021
clipped
07011061
07016073
St, 2.5 mm,
1) Height 3 U
2) Height 4 U
door hinge bracket, St, 2 mm, RAL 7021;
Heavy-Duty Universal: Short 19" planes
are required to mount the door hinge bracket,
see page 1.272
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.266
RAL 7035
RAL 7021
33 mm
60 mm
60 mm
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
assembled
26230-022
25230-022
27230-060
27230-061
27230-098
20118-391
26230-023
25230-023
27230-060
27230-061
27230-098
20118-391
26230-024
25230-024
27230-060
27230-061
27230-098
20118-390
26230-030
25230-030
27230-060
27230-061
27230-098
20118-390
26230-026
25230-026
27230-060
27230-061
27230-098
20118-391
26230-027
25230-027
27230-060
27230-061
27230-098
20118-390
26230-028
25230-028
27230-060
27230-061
27230-098
20118-391
1)
1)
2)
2)
1)
2)
1)
1)
20118-796
1)
20118-796
2)
20118-797
2)
20118-797
1)
20118-796
2)
20118-797
1)
20118-796
RAL 7021
1)
27230-160
1)
27230-160
2)
27230-161
2)
27230-161
1)
27230-160
2)
27230-161
1)
27230-160
Rear panels
Rear panel
07011057
07011086
St, 1 mm; 2 twist-locking catches
(Torx T30,with1/4 turn);
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07011058
07011087
Rear panel lock
07011107
2 rear panel
catches with lock
(Torx T30, with 1/4 turn),
(2233x locking),
incl. GND/earthing, cable ducting
2 keys;
and door hinge bracket;
suitable for a
cable ducting can be fitted at top or
rear panel
bottom, 3 U cable ducting for cabinet
height 16, 20, 38, 47 U; 4 U cable
ducting for cabinet height 25, 34, 43 U
RAL 7035
RAL 7021
RAL 7035
1 piece
1 piece
PU 1 kit
RAL 7021
PU 1 kit
PU 1 kit
assembled
assembled
assembled
assembled
assembled
26230-370
25230-370
27230-116
26230-371
25230-371
27230-116
26230-372
25230-372
27230-116
26230-373
25230-373
26230-430
25230-430
27230-116
26230-374
25230-374
26230-434
25230-434
27230-116
26230-375
25230-375
26230-439
25230-439
27230-116
26230-376
25230-376
26230-448
25230-448
27230-116
26230-377
25230-377
26230-452
25230-452
27230-116
26230-378
25230-378
26230-457
25230-457
27230-116
26230-379
25230-379
26230-461
25230-461
27230-116
1.267
Top covers
Top cover flush
Flush
07011063
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.268
Top cover raised
Lifting eye
07011071
St, 1 mm,
RAL 7021,
incl. GND/
earthing
for flush cover;
M12, application
and load to
DIN 582
1 piece
assembled
25230-001
25230-002
25230-001
25230-002
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
Raised
07011064
Lifting eye
07011072
Raised top cover,
load-carrying
capacity 50 kg
07016077
St, 1 mm,
RAL 7021,
incl. GND/
earthing,
height 31 mm,
air gap 10 mm
for raised cover
or fan top cover;
M12, application
and load to
DIN 582
PU 4 pieces
1 piece
PU 4 pieces
1 piece
assembled
assembled
assembled
assembled
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
25230-010
25230-011
25230-010
25230-011
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
St, 1 mm,
RAL 7021,
incl. GND/
earthing,
height 31 mm,
air gap 10 mm,
roof mounting
from the inside
(outside no
screws)
25230-039
25230-038
25230-039
25230-038
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
Fan top covers, lifting eye, thermostat, speed controller
Fan top cover
(fan height 25 mm)
Fan top cover
Fan
with fans
84 ... 90 m³
Fan top cover
(fan height 38 mm)
Fan top cover
Fan
with fans
162 ... 172 m³
Lifting eye
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
07011082
kta44844
07011082
axial fan with
St, RAL 7021, incl.
St, RAL 7021, incl.
protective grille,
GND/earthing
GND/earthing
230 VAC, 8 W,
and cabling;
and cabling;
2 fans for 500 mm
2 fans for 500 mm
84 ... 90 m³/h
depth, 1 cover
depth, 4 cover
29 ... 30 dB(A),
cap;3 fans for
caps;
height 25 mm;
600/800 mm
3 fans for
600/
please order
depth, 3 cover
800 mm depth,
separately if
caps; 0.5 m
3 cover caps;
additional fans
connector cable,
0.5 m
are required
IEC C14 plug
connector cable,
IEC C14 plug
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
kta44844
07011072
axial fan with
protective grille,
230 VAC, 15 W,
162 ... 172 m³/h,
37 ... 41 dB(A),
height 38 mm;
please order
separately if
additional fans
are required
for raised cover
or fan top cover;
M12, application
and load to
DIN 582
01108052
01105055
with mains cable
fully wired,
230 VAC
90 ... 264 VAC,
(SCHUKO/UTE
input SCHUKO/
plug/IEC 60320
UTE plug,
C13 socket),
outlet IEC 60320
adjustment range
C13 socket;
0 ... 60°C
external NTC
sensor 1.5 m
PU 1 kit
1 piece
PU 1 kit
1 piece
PU 4 pieces
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-081
27230-082
27230-081
27230-082
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-085
27230-086
27230-085
27230-086
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
1.269
Floors
Base plates
Base plate,
rear open
07011073
St, 1.5 mm,
RAL 7021,
incl. GND/
earthing;
cable ducting in
rear area of
cabinet; please
order cover or
brush strip
separately
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.270
Cover plate
07011073
St, 1.5 mm,
485 x 92 mm;
to cover the rear
floor opening
Cover plate
Perforated
07016052
St, 1.5 mm,
485 x 92 mm;
to cover the rear
floor opening
Cover plate
Filter mat
07016052
St, 1 mm,
485 x 92 mm; to
cover the rear
floor opening
Brush strip
07011073
Nylon, black,
440 x 98 mm;
to cover the rear
floor opening
Base plate, reinforced,
with cable ducting
Base plate
Brush strip
07016059
St, 1.5 mm,
RAL 7021;
fully closed with
pre-cut area for
cable ducting
opening,
width 370 mm,
depth 50 mm
07016060
Nylon, black,
width 370 mm,
depth 50 mm; for
covering the rear
floor opening
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
montiert
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-188
27230-189
27230-188
27230-189
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
25230-149
25230-150
25230-149
25230-150
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
ELECTRONICS PROTECTION
Base/plinth
Bases/plinths
Mobile bases/
plinths
Brush strip
96
37
48
With cable
ducting
546
07011075
07011077
D
07011113
St, 2 mm,
Nylon, black,
St, 1.5 mm,
110 mm x 76 mm; fine-grooved mat,
RAL 7021,
3 mm, 4 castors,
to cover cable
height 55 mm;
load-carrying
through-ducting
incl. GND/
capacity 200 kg
opening
earthing;
cable ducting
110 x 76 mm;
adjustable feet,
adjustable height
range
57 mm ... 67 mm
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1 piece
1 piece
1 piece
assembled
assembled
assembled
27230-070
27230-071
27230-070
27230-071
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-146
27230-147
27230-146
27230-147
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
Part number in bold face type: ready for despatch within 2 working days
1.271
19" panel/slide mounts, depth members, shelves
Depth members
07011114
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.272
19" panel/slide
mounts
07011111
3U
4U
07016070
St, 2 mm, RAL 7021
07011114
St, 1.5 mm,
finish AlZn;
for mounting
19" pitch profiles
19" panel/slide
mounts with
universal
perforation grid
(EIA)
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
27230-172
27230-162
27230-163
27230-173
27230-162
27230-163
27230-174
27230-162
27230-163
27230-175
27230-162
27230-163
27230-176
27230-162
27230-163
27230-177
27230-162
27230-163
27230-178
27230-162
27230-163
27230-179
27230-162
27230-163
27230-180
27230-162
27230-163
27230-181
27230-162
27230-163
27230-167
27230-168
27230-167
27230-168
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
Shelves
Stationary shelf
07011077
St, 1.5 mm,
RAL 7021,
with perforation,
75 kg
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
Shelf, stationary
for server
Telescopic shelf, 2 U, 70 kg
Full depth
07011077
Shortened by
100 mm
07011101
07011102
St, 1.5 mm, RAL 7021,
static loadSt, 1.5 mm,
carrying capacity when fully extended
RAL 7021,
70 kg, incl. telescopic slide;
with perforation,
please order T-bar lock
and GND/
static loadearthing kit separately
carrying capacity
75 kg
T-bar lock
01004125
to lock the
telescopic shelf
GND/earthing
aza43284
for telescopic
shelf
1 piece
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
assembled
27230-051
27230-052
27230-051
27230-052
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
21130-357
21130-353
21130-357
21130-353
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-358
21130-352
21130-358
21130-352
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
1.273
Slide rails
Slide rail
Slide rail
07011078
St, 1.5 mm,
finish AlZn,
25 kg/pair
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.274
Heavy-load
slide rail
07011078
Heavy-load
slide rail
for server
07011078
St, 1.5 mm, finish AlZn,
50 kg/pair
Short slide rail
ERA46348
sc96xxxx
15 kg/pair
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
assembled
assembled
assembled
enclosed loose
enclosed loose
27230-102
27230-103
27230-102
27230-103
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
25230-013
25230-014
25230-013
25230-014
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
SCHROFF PRODUCT CATALOG E 06/2017
Cable ties, Velcro-type tape
Cable tie
Velcro
General
components
Mechanics
01005078
plastic,
92 mm x 2.5 mm;
01005079
black,
length 300 mm,
from page
3.2
Electrics
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
SCHROFF.PENTAIR.CO.UK
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.30
Power
distribution
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.35
Climate control
20118-351
20118-624
from page
4.0
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
1.275
P Main CataloguePart num ber in bold face type: ready for despatch w ithin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Cabinets – P
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
00105003
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
19" grid integrated in upright
00105004
Simple solution for shortened
doors
00105005
Doors can also be assembled
laterally
00105066
Standards/certifications
쮿 External and internal dimensions in accordance
with
IEC 60297-3-100
쮿 Type of ingress protection: IP 40, in accordance with
IEC 60529
쮿 Protective GND/earthing connections in accordance
with DIN EN 50178/VDE 0160
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.270
SCHROFF PRODUCT CATALOG E 11/2017
Cabinets – P
Overview . . . . . . 1.270
PMain C atalogue
19" electronic cabinet
쮿 Type of ingress protection up to IP 40
Introduction . . . . . 1.272
Dimensions . . . . . 1.274
쮿 Bolted frame, die-castings and aluminium profiles,
with inset covers
쮿 Static load-carrying capacity 400 kg
쮿 New colours: RAL 7021 (black grey) or
RAL 7021/RAL 7035 (black grey/light grey) colour combination
Cabinet with
front and rear door
Cabinet without
front and rear door
00108002
쮿 38 and 43 U
쮿 Depth 600 and 800 mm
쮿 34, 38, 43 and 47 U
ServicePLUS from page 1.288
e.g. individual configuration and assembly
e.g. modifications (special colours or sizes)
e.g. variants of uprights
e.g. custom solutions (electromagnetically shielded
applications)
eurorack
00108004
19" cabinets with
front and rear
door . . . . . . . . . . . . 1.276
19" cabinets
without front and
rear door . . . . . . . . 1.277
Front/
rear doors . . . . . . 1.278
Door hinge
bracket for
shortened
doors . . . . . . . . . . . 1.279
Base plates . . . . . . 1.280
Bases/plinths . . . . 1.280
Cable ducting with
C-profiles . . . . . . . . 1.282
Cable eyes for
C-profile . . . . . . . . 1.283
Slide rails . . . . . . . 1.284
Cable ties . . . . . . . 1.283
Fixed/telescopic
shelves . . . . . . . . . 1.285
Cable trays . . . . . . 1.287
Cable ties . . . . . . . 1.287
Velcro . . . . . . . . . . 1.287
ServicePLUS
1.288
ServicePLUS
configuration 19"
1.289
eurorack . . . .
ServicePLUS
configuration
Universal
eurorack . . . . . . . 1.300
www.schroff.biz/ServicePLUS
30407004
1.271
Cabinets – P
eurorack - the "classic"
Text
00108005
Handsome to behold is this classic among electronics cabinets,
and with good reason. Its load-bearing frame consists of a
die-cast aluminium frame and aluminium uprights whose fluting
gives the impression of classical pillars. Thus in eurorack - and
also in NOVASTAR - the cladding parts are not fitted externally on
the frame but rather inside between the frame and uprights. Thus
they remain visible and give the cabinet its unmistakable look.
The cabinet is available in two colour schemes.
The basic frame and top cover are always in black grey
(RAL 7021). With black grey claddings (side panels, doors and rear
panels) you get an entirely black cabinet, as it is the
contemporary look in recording studios and data centres.
Alternatively, select the cladding components in light grey
(RAL 7035). The different colours of the frame and lateral parts
give particular emphasis to the aluminium profile.
Wholly classical yet timelessly modern!
PMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 working days
1.272
Cabinets – P
eurorack - frames
19" frame
Universal frame
Text
00108058
Unlike with other cabinet concepts, where the height of a cabinet
is determined by common mm intervals in its exterior
dimen-sions, eurorack is systematically oriented along the
interior dimensions, using the height units of the 19" system.
19" components are thus flush in height with the frame and
without disruptive gaps.
So that likewise no gaps occur in the width there is the 19" frame,
with the 19" plane already integrated in the vertical cabinet
uprights. When fully equipped with 19" components, the cabinet
therefore looks superb without any cover trims, decorative
frames or doors.
Nevertheless, if a door is required, the eurorack glazed door is a
clear design option, with 60 mm space in front of the 19" mounting
for assembly.
01008059
If more space is required in front of the 19" plane, the user can fall
back on the Universal frame and fit separate 19" panel/slide
mounts. These can then be positioned at 25 mm intervals on the
depth members.
However, 800 mm wide cabinets can also be realised using the
Universal frame. For example, equipped with shelves for the
greatest possible surface or with components that require more
flexibility than 19" technology.
Further features
Text
00108060
Die-cast frame and frame are bolted;
the cabinet can thus be dismantled
00105066
Because of their symmetrical upright
dimensions, doors can also be used
on the sides.
00108052
Mobility with mobile base
Part number in normal type: ready for despatch within 10 working days
1.273
Cabinets – P
Dimensions 19" frame
Height
w
h
H
H with feet
mm
998
1220
1398
1620
1798
2020
2198
d
w
d
w1
d1
W
Usable height h
U
29
34
38
43
47
mm
890.5
1112.5
1290.5
1512.5
1690.5
1912.5
2090.5
d1
Width
Cabinet
width
W
mm
600
9
w1
H without feet
mm
989
1211
1389
1611
1789
2011
2189
Ø3
Upright
distance
w
mm
451
Bolt-on
dimension
w1
mm
465
Upright
distance
d
mm
382
582
682
Bolt-on
dimension
d1
mm
396
596
696
Distance
between feet
w2
mm
502
D
00105057
Depth
Cabinet
depth
D
mm
600
800
900
Cdimension
c
mm
480
680
780
Distance
between feet
d2
mm
444
644
744
00105058
Upright 60 mm recessed
00106051
1.274
Cabinets – P
Dimensions Universal frame
Height
H with feet
mm
998
1220
1398
1620
1798
2020
2198
h
H
d
d
H without feet
mm
989
1211
1389
1611
1789
2011
2189
Usable height h
U
29
34
38
43
47
mm
890.5
1112.5
1290.5
1512.5
1690.5
1912.5
2090.5
d1
d1
Width
9
Cabinet width
W
mm
600
800
w
W
Ø3
Upright distance
w
mm
528
728
Distance between feet
w2
mm
502
702
D
00105056
Depth
Cabinet depth
D
mm
600
800
900
Upright distance Bolt-on
dimension
d
d1
mm
mm
426
440
626
640
726
740
Distance
between feet
d2
mm
444
644
744
00105059
00106052
1.275
Cabinets – P
19" cabinet with front and rear door
쮿 Front: smoked glass door, rear: steel door
쮿 19" cut-outs in front and rear uprights
쮿 Inset covers
쮿 Type of protection IP 40
쮿 Available in two colour combinations:
– Frame, side panels, door and top cover in black grey
(RAL 7021)
– Frame and top cover in black grey (RAL 7021),
side panels and door in light grey (RAL 7035)
Delivery comprises (assembled)
00108002
Item
1
Qty
1
2
2
3
4
1
2
5
1
6
1
7
4
Description
19" frame, consisting of 2 Al die-cast frames, RAL 7021,
4 Al extrusion uprights with 19" cut-outs
Side panel, St, 1 mm, fixes with 2 side panel catches per
panel, colour RAL 7021 (black grey) or RAL 7035 (light
grey) see Order information
Top cover with vents, St, 1.5 mm, RAL 7021
Trims, St, 1 mm, RAL 7021 (for decorative finishing at the
top and at the bottom of the front assembly area)
Rear door, St, 1 mm, opening angle 120°,
safety lock with 2 keys Colour RAL 7021
Glass door, Sekurit, 6 mm, smoke grey, opening angle
120°, safety lock with 2 keys
Foot, Al
Order Information
Usable Height
height H
Width W Depth D C
Colour
RAL 7021
U
mm
mm
mm
mm
Part no.
38
1798
600
600
480
10117-537
38
1798
600
800
680
10117-538
43
2020
600
600
480
10117-539
43
2020
600
800
680
10117-540
GND/earthing for frame, doors, side panels, top cover and
base plate, PU 1 kit
Lifting eyes St, zinc-plated, M10, PU 4 pieces
Adjustable feet Load-carrying capacity 100 kg/foot, St and
PA, black, PU 4 pieces
Castors Load-carrying capacity 100 kg/castor, PU 4 pcs
Castors Load-carrying capacity 60 kg/castor, PU 4 pcs
00105060
Colour
RAL 7021/
RAL 7035
Part no.
10117-533
10117-535
10117-534
10117-536
21101-539
20117-080
21101-201
20117-024
20117-757
Note
쮿 Please order base/plinth separately, see page 1.280
쮿 Other sizes available on ServicePLUS configuration,
see from page 1.289
쮿 Please find the new generation of 19" aluminium electronics
cabinets under NOVASTAR, page 1.240
00105067
ServicePLUS see page 1.288
1.276
Cabinets – P
19" cabinet without front and rear door
쮿 Door combination freely selectable
쮿 Inset covers
– frame, side panels and top cover in black grey (RAL 7021)
– frame and top cover in black grey (RAL 7021) side panels
Item Qty
1
1
2
2
3
4
1
2
5
4
Description
Trim, St, 1 mm, RAL 7021 (for decorative finishing at top
and bottom of front assembly area)
Foot, Al
Order Information
00108004
2
H
4
1
15
2
W
Height
H
Width W Depth D C
Colour
RAL 7021
U
mm
mm
mm
mm
Part no.
34
1567
600
600
480
10117-541
34
1567
600
800
680
10117-544
38
1798
600
600
480
10117-542
38
1798
600
800
680
10117-545
43
2020
600
600
480
10117-543
43
2020
600
800
680
10117-546
47
2198
600
800
680
10117-547
3
4
Usable
height
Colour
RAL 7021/
RAL 7035
Part no.
10117-527
10117-530
10117-528
10117-531
10117-529
10117-532
10117-548
21101-539
20117-080
21101-201
20117-024
20117-757
Note
D
5
00105061
쮿 Please order front and rear door separately, see page 1.278
see from page 1.289
00105067
1.277
Cabinets – P
Glass door, 120° opening angle
Main Catalogue
쮿 Can be assembled on all four sides
75
쮿 Opening angle 120°
Delivery comprises
35
Item
1
2
3
4
Description
Safety lock with 2 keys
Hinge, St, 3 mm, black (RAL 9005)
Assembly kit
Order Information
H
era44522
Qty
1
1
2
1
mra45967
For cabinet
height
mm
782
945
1167
1290
1567
1798
2020
2198
Usable
height
U
16
29
34
38
43
47
H
mm
733
911
1133
1311
1534
1711
1934
2111
For cabinet
width
mm
553
553
553
553
553
553
553
553
Part no.
20117-744
20117-745
20117-746
20117-747
20117-748
20117-749
20117-751
20117-752
쮿 Doors with opening angle 180° see page 1.291
쮿 Further dimensions available on ServicePLUS, see from page
1.291
Steel door, 120° opening angle
쮿 Colour black grey (RAL 7021) or light grey (RAL 7035)
g
.6
un
ist . . .
e
l
e
c
rvi
Se . . . .
e
pp
ite
ma
Se
s
ng
ibu ware 7
e
r
h ft
ssc so
Au ungs . . . .
n
Pla . . . .
ite
Se
Delivery comprises
Item
1
2
3
H
21
523
00105053 a4491c
1.278
Qty
1
1
1
Description
Steel door, St, 1 mm
Assembly kit
Order Information
For cabinet
height
Usable
height
H
mm
767
945
1167
1290
1567
1798
2020
2198
U
16
29
34
38
43
47
mm
733
911
1133
1311
1534
1711
1934
2111
For
cabinet
width
mm
600
600
600
600
600
600
600
600
Colour
RAL 7021
Colour
RAL 7035
Part no.
Part no.
22117-934
21117-184
22117-935
22117-936
21117-185
21117-186
23117-012
21117-187
22117-937
22117-938
21117-188
21117-189
22117-940
21117-190
22117-942
21117-191
see from page 1.292
쮿 180° steel door with lever handle see ServicePLUS
configuration, page 1.292
Cabinets – P
Glazed door, 120° opening angle
PMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
523
29
46
쮿 Frame colour: black grey (RAL 7021) or light grey (RAL 7035)
Delivery comprises
Item
1
2
3
4
era44522
mra49568
Description
Door frame, Al, 2 mm, RAL 7035
Plexiglass pane, 2 mm, clear
Assembly kit
Order Information
For
cabinet
height
mm
782
945
1167
1290
1567
1798
2020
2198
H
21
Qty
1
1
1
1
Usable
height
H
U
16
29
34
38
43
47
mm
733
911
1133
1311
1534
1711
1934
2111
For
cabinet
width
mm
600
600
600
600
600
600
600
600
Colour
RAL 7021
Colour
RAL 7035
Part no.
Part no.
22117-943
20117-769
22117-944
22117-945
20117-770
20117-771
23117-011
20117-772
22117-946
22117-947
20117-765
20117-766
22117-949
20117-767
22117-951
20117-768
쮿 Further dimensions available on ServicePLUS configuration,
see page 1.292
Door hinge bracket for shortened doors
P
쮿 For doors which do not cover the full cabinet height
2
쮿 1 U space required (may be mounted above and below the door)
쮿 The clearance can be covered with 19" filler panels or with
cable ducting plates 3 U/4 U
Delivery comprises (kit)
1HE
Item
1
2
3
Qty
1
1
1
Description
Door hinge bracket, 19", St, 1.5 mm, RAL 7021
Trim, St, 1 mm, RAL 7021, cover for frame
Assembly kit
Order Information
1
4
00105068
4
Description
Item 4 Cable ducting 3 U, RAL 7021, with brush strip and
fixing materials kit, 1 piece
Item 4 Cable ducting 4 U, RAL 7021, with brush strip and
Part no.
22117-798
20118-796
20118-797
37
55
쮿 19" front panels see chapter Cabinet Accessories, page 3.2
Cable ducting plate
00201507
1.279
Cabinets – P
Base plates
P
쮿 For covering the base opening, two parts
쮿 Mounting on frame, overlaying
Delivery comprises
Item
1
Qty
2
2
1
Description
Base plate, St, 1.5 mm, RAL 7021, width 469 mm,
depth 234 mm (at cabinet depth 600 mm),
depth 334 mm (at cabinet depth 800 mm)
Assembly kit
Order Information
For cabinet width
mm
600
600
For cabinet depth
mm
600
800
Part no.
22117-826
22117-827
00108051
Plain bases/plinths
P
쮿 Height 100 mm
쮿 Covers removable from all sides
Delivery comprises
3
Item
1
2
4
4
Ø 15
1
2
Qty
4
2
2
1
Description
Corner piece, AI die-cast
Cover, St, 2.5 mm, RAL 7021, for front and rear
Cover, St, 2.5 mm, RAL 7021, for sides
Assembly kit
Order Information
w
d
ERA44532
00108057
For cabinet width
For cabinet depth
mm
mm
600
600
600
800
St and PA, black, PU 4 pieces
Part no.
22117-830
22117-831
21101-201
Note
쮿 Castors cannot be used with a base/plinth
era44553
1.280
Cabinets – P
Bases/plinths with ventilation
P
쮿 Height 100 mm
쮿 Covers removable on all sides
쮿 Can be assembled with filter
Delivery comprises (Kit)
4
6
Item
1
2
Qty
4
2
3
4
5
2
2
1
Description
Cover, St, 2.5 mm, RAL 7021, for front and rear, with vent
slots
Filter retention
Assembly kit
Order Information
2
3
1
ERTP0057
For cabinet width
For cabinet depth
mm
mm
600
600
600
800
Filter mat Item 6 for cabinet depth 600 mm,
width 600 mm, PU 3 pieces
Filter mat Item 6 for cabinet depth 800 mm,
Part no.
22117-864
22117-865
60114-514
60114-515
Note
쮿 Filter mat not included, please order separately
1.281
Cabinets – P
Mounting system with C-profiles
Mounting system
P
쮿 The mounting system serves for assembly of horizontal and
vertical mounting planes; C-profiles can be positioned freely by
using combination and L-brackets in conjunction with slide
nuts
쮿 Slide nuts, cable eyes or cable shells can be inserted directly
into the C-profiles
Delivery comprises
Item
1
Qty
see Order
Information
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
ertp0020
C-profile/slide nut
25
9
Ø 5,25
30
10
L
15
5
1
ertp0021
Mounting bracket
For cabinet For cabinet For
Length L Qty/PU
width
depth
cabinet
height
mm
mm
mm
mm
piece
600
450
4
600
800
650
4
900
750
4
600
650
4
800
800
650
4
1600
1500
2
1800
1650
2
2000
1900
2
Item 2 Mounting bracket for cabinet upright or depth
member assembly, St, 2.5 mm, zinc-plated, PU 4 pieces,
incl. assembly kit
Item 3 Combination bracket for connection of
two C-profiles, St, 2.5 mm, zinc-plated, PU 4 pieces,
incl. assembly kit
Item 4 L-bracket for edge-to-edge or corner
connection of two C-profiles, St, 2.5 mm, zinc-plated, 2
right hand brackets and 2 left hand brackets, incl.
assembly kit
Item 5 Slide nut for C-profiles, PU 10 pieces
Item 5 Slide nut for C-profiles, PU 100 pieces
Delivery: supplied loose with cabinet or frame
Part no.
22114-455
22114-457
22114-458
22114-457
22114-457
22114-460
22114-461
22114-462
21120-145
21120-146
21120-147
21120-140
21101-127
Part no./35
Note
ertp0022
쮿 Please order mounting brackets separately
Combination bracket
ertp0024
L-bracket
ertp024a
1.282
Cabinets – P
Cable eyes for C-profiles
P
Delivery comprises
Item
1
D=
W
95
=9
5
75
D=
W
=4
D=
Qty
4
45
Description
Cable eye, round steel, 6 mm, zinc-plated, with
integrated anti-rotation protection
Order Information
W
Description
W
mm
Cable eye for C-profile
120
40
95
Assembly kit for 4 cable eyes, PU 1 kit
=1
00507051
00507052
D
mm
45
75
95
Part no.
20118-339
20118-554
20118-340
21101-596
Note
쮿 Please order assembly kit separately
Cable shells
P
쮿 For mounting of cables on C-profiles and cable support rails
Delivery comprises
Item
1
Qty
10
Description
Cable shell, St, 2 mm, tin-plated, with plastic half shells
Order Information
For cable bundle d
mm
18 ... 22mm
22 ... 26mm
26 ... 30mm
30 ... 34mm
34 ... 38mm
38 ... 42mm
42 ... 46mm
46 ... 50mm
b
mm
26
30
34
38
45
48
51
54
Part no.
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
vnt009
1.283
Cabinets – P
Slide rail
P
쮿 For safe and simple installation of heavy
19" subracks
쮿 Can be hung into the upright at 1 U increments
쮿 Load-carrying capacity max. 25 kg per pair
Delivery comprises
c
D
Item
1
2
1
Qty
10
1
Description
Slide rail for insertion, St, 1.5 mm, surface AlZn
Assembly kit
Order Information
c = pitch of the 19" uprights
xf
W
For cabinet depth
mm
600
800
00205059
00205069
Length L
mm
420
620
c
mm
480
680
xf
mm
60
60
Part no.
21127-197
21127-198
Note
쮿 Can only be fitted to 19" upright
see from page 1.298
L = length
41003080
Short slide rail
P
쮿 For mounting on the vertical cabinet uprights
쮿 Can be hung at 1 U increments
쮿 Static load-carrying capacity 15 kg max per pair
Delivery comprises
Item
1
2
Qty
2 / 10
1
Description
Short slide rail, St, 1,5 mm, finish AlZn
Assembly kit
Order Information
sc96xxxx
1.284
Description
Short slide rail
Short slide rail
Qty/PU
2
10
Part no.
20118-592
20118-593
Cabinets – P
19'' fixed shelf, 75 kg
P
쮿 Mounting height 1 U, for mounting on cabinet uprights,
full depth
쮿 With hammer head perforation to fix cable ties
Delivery comprises
Item
1
2
1
Qty
1
1
Description
Shelf, St, 1.5 mm, RAL 7021
Assembly kit incl. GND/earthing kit
Order Information
00105054
Cabinet dimensions
WxD
mm
600 x 600
600 x 800
Usable surface
wxd
mm
477 x 443
477 x 643
xf
xr
c
mm mm mm
60
60
480
60
60
680
Part no.
22117-842
22117-843
Note
see from page 1.299
00105050
1.285
Cabinets – P
19'' telescopic shelf, 70 kg
P
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
1
쮿 Locking with T-bar lock possible
2
쮿 Hammer head perforation to fix cable ties
4
쮿 2 versions
– Full depth
Delivery comprises
00105052
Full depth
Item
1
2
3
Qty
1
2
1
Description
Telescopic slide, 2 U
Assembly kit
Order Information
Full depth
Cabinet dimensions
Usable surface
c
WxD
wxd
mm
mm
mm
600 x 600
405 x 482
480
600 x 800
405 x 682
680
GND/earthing for telescopic shelf PU 1 kit, for
NOVASTAR, eurorack
Full depth
Part no.
21130-353
21130-355
23130-092
21120-189
00105069
Shortened depth
Order Information
Shortened by 100 mm
Cabinet dimensions
Usable surface
c
Shortened by
WxD
wxd
100 mm
mm
mm
mm
Part no.
600 x 600
405 x 382
480
21130-352
600 x 800
405 x 582
680
21130-354
23130-092
GND/earthing for telescopic shelf PU 1 kit, for NOVASTAR,
21120-189
eurorack
c = max. pitch of the slide mounts
1.286
00105070
Cabinets – P
Cable panels
P
쮿 For mounting direct onto the frame, can be recessed with depth
members
쮿 Fixing of cables with cable ties or Velcro
쮿 Colour RAL 7021 (black grey) or RAL 7035 (light grey)
쮿 Widths 150 mm and 250 mm
1
Delivery comprises
Item
1
2
Qty
2
1
Description
Cable panel with cut-outs, St, 1 mm
Assembly kit
Order Information
H
For cabinet height H
D
RAL 7021
U
mm
mm
Part no.
38
1798
150
23117-020
43
1934
150
23117-021
47
2020
150
23117-022
38
1798
250
23117-023
43
1934
250
23117-024
47
2020
250
23117-025
Depth member for 19" eurorack 600 mm cabinet depth,
St, 1.5 mm, AlZn, PU 2 pieces
Depth member for 19" eurorack 800 mm cabinet depth,
St, 1.5 mm, AIZn, PU 2 pieces
10
D
00108050
RAL 7035
Part no.
23117-026
23117-027
23117-028
23117-029
23117-030
23117-031
22117-376
22117-377
Note
쮿 Cable ties, see page 1.287
쮿 Velcro, see page 1.287
Cable ties
P
Delivery comprises
Item
1
Qty
25
Description
Cable tie, plastic
Order Information
Description
Cable tie
Cable tie
Cable tie
Part no.
92 mm x 2.5 mm
186 mm x 5 mm
360 mm x 5 mm
20118-351
20118-352
20118-353
01005078
Velcro
P
쮿 Length 300 mm (for cable bundles of max. 90 mm diameter)
Delivery comprises
Item
1
Qty
10
Description
Velcro strip, PE/PA, black, length 300 mm
Order Information
Description
Velcro strip
Part no.
20118-624
01005079
1.287
Cabinets – P19" ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined
freely
쮿 Configuration tables from page 1.289
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Download CAD data and send back with modifications
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power
supply), function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Ready for despatch within 15 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
19" Servic ePLUS
1.288
Cabinets – P 19" ServicePLUS
eurorack 19" ServicePLUS: configuration and assembly
1 9" ServicePLUSP
쮿 Dimensions:
– Height: 20 ... 47 U (998 ... 2198 mm)
– Width: 600 mm
– Depth: 600, 800 mm
Page
Frames, side-by-side
mounting kit, GND/
earthing, adjustable feet,
castors
1.290
Side panels, glass doors
1.291
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
Doors
1.292
쮿 Once you have selected the desired cabinet dimensions, the row
number (first column of the configuration tables) will guide you
through all subsequent configuration pages that apply to these
Door hinge bracket, cable
1.293
ducting
쮿 Colours:
– Frame, top cover and plinth in black grey (RAL 7021);
– Side panels and doors in light grey (RAL 7035)
or black grey (RAL 7021)
쮿 The cabinet is assembled by us and
Flush top covers
1.294
Raised top covers
1.295
Base plates, plinths
1.296
Third 19" plane, lateral
cable ducting
1.297
19" slide rails
1.298
19" fixed or telescopic
shelves
1.299
1.274
ServicePLUS
configuration
eurorack Universal
1.300
00101534
Example configuration (here: row 14)
Qty
1
1
1
1
1
1
Description
19" frame, RAL 7021, height 2020 mm, width 600 mm, depth 800 mm, 1 piece
Adjustable foot, PU 4 pieces
Side panel, screw fixed, RAL 7035, PU 2 pieces
Front glass door, RAL 7035, opening angle 120°, 1 piece
Rear steel door, RAL 7035, opening angle 120°, 1 piece
DIN profile half cylinder, 1 piece
Order no.
22117-779/05
21101-201/05
21117-172/05
20117-751/05
21117-190/05
60114-121/05
1.289
eurorack 19"
Frames, side-by-side mounting kit, GND/earthing, adjustable feet, castors
Order Information
19" frame
19" plane to front
and rear
era45341
Side-by-side
mounting kit
GND/earthing
Castors
Load-carrying
capacity 180 kg
per kit
ERTP0070
serves to bolt
19" frame,
together
frame Al die-cast,
two cabinets;
uprights
sealing strips are
Al extrusion,
PU foam
RAL 7021, defined
pitch between
front and rear 19"
plane
Adjustable feet
aza43284
era44553
for frame, door,
side panel, top
cover, base plate
St, PA, black,
load-carrying
capacity 100 kg
per foot
Load-carrying
capacity 300 kg
per kit
era44556
assembly directly assembly directly
onto frame,
onto frame,
height H =
height H =
110 mm,
93 mm, 2 locking,
2 locking, 2 non2 non-locking
lockingcastors
castors
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
assembled
supplied loose
assembled
assembled
enclosed loose
enclosed loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-977
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
22117-978
22117-979
22117-980
22117-981
22117-982
22117-772
22117-773
22117-774
22117-775
22117-776
22117-977
22117-978
22117-979
22117-980
22117-983
22117-981
22117-984
Frame dimensions, see page 1.274
1.290
eurorack 19"
Order Information
Side panel
with side-panel catches
Side panel
with safety lock
Glass door
Opening angle
120°
ERA44517
St, 1 mm,
RAL 7035,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
ERA44517
St, 1 mm,
RAL 7035,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
St, 1 mm,
RAL 7021,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
mra45967
glazing
smoke grey,
Sekurit, 6 mm,
safety lock with
2 keys
DIN profile half
cylinder
00101506
glazing
smoke grey,
Sekurit, 6 mm,
lever handle
(incl. blank
insert)
SZA44484
DIN profile half
cylinder for lever
handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
Width
Depth
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
20117-745
20117-746
20117-747
22117-239
60114-121
20117-748
22117-227
60114-121
20117-749
22117-228
60114-121
20117-751
22117-229
60114-121
20117-752
22117-230
60114-121
No. U
mm
mm
mm
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
21117-158
22117-993
21117-167
21117-159
22117-994
22117-995
21117-168
22117-996
21117-160
21117-169
22117-997
22117-998
22117-185
22117-186
23117-002
23117-003
21117-161
22117-958
22117-173
23117-004
21117-170
21117-179
22117-959
22117-960
22117-177
22117-181
23117-005
23117-006
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
Glass door
Opening angle
180°
21117-162
22117-961
22117-174
23117-007
21117-171
21117-180
22117-962
22117-963
22117-178
22117-182
23117-008
23117-009
21117-163
22117-964
22117-175
22117-968
21117-172
21117-181
22117-965
22117-966
22117-179
22117-592
22117-969
22117-970
21117-164
22117-999
22117-176
23117-010
21117-173
21117-182
22117-967
23117-001
22117-180
22117-593
22117-971
22117-972
Note: Doors can also be assembled laterally, in place of side panels
1.291
eurorack 19"
Doors
Order Information
Glazed acrylic glass door
Steel door
Opening angle 120°
Opening angle 120°
Steel door
a4491b
frame, Al, 2 mm, frame, Al, 2 mm,
RAL 7021;
RAL 7021;
acrylic glass,
acrylic glass,
2 mm,
2 mm,
safety lock with
safety lock with
2 keys
2 keys
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.292
Opening angle 180°
00101506
DIN profile half
cylinder
00101504
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
St, 1 mm,
RAL 7021,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
RAL 7021
SZA44484
DIN profile half
cylinder for
lever handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
20117-770
22117-944
21117-185
22117-935
20117-771
22117-945
21117-186
22117-936
20117-772
23117-011
21117-187
23117-012
22117-201
23117-013
60114-121
20117-765
22117-946
21117-188
22117-937
22117-189
23117-014
60114-121
20117-766
22117-947
21117-189
22117-938
22117-190
23117-015
60114-121
20117-767
22117-949
21117-190
22117-940
22117-191
22117-973
60114-121
20117-768
22117-951
21117-191
22117-942
22117-192
22117-975
60114-121
eurorack 19"
Door hinge bracket, cable ducting
Order Information
Door hinge
bracket for
19" frame
Cable ducting frame
3U
4U
00105068
07011081
St, 1.5 mm,
with black brush strip for short doors
RAL 7021,
or rear panels
mounting to front
or rear,
above or below
the short door,
1U
assembly area,
please order
19" cable ducting
separately
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1 piece
1 piece
1 piece
assembled
assembled
assembled
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
1.293
eurorack 19"
Flush top covers
Order Information
Flush top cover
Plain
Louvered
Top cover fan for flush louvered top cover
Lifting eyes
Fan trays without
fans
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44525
St, 1 mm, RAL
7021
ERA45344
ERA44560
St, 1 mm, RAL
7030
lifting eye for
flush cover,
application and
static loadcarrying capacity
in accordance
with DIN 582
ertp0055
St, 1.5 mm,
RAL 7021,
all 6 openings
closed with PE
blank plugs,
terminal
clamp with
connecting
cable, 2 m, IEC60320 C14 plug
KTA44844
axial fan 230 VAC,
8 W, 90 m3/h,
height 25 mm,
protective grille,
plastic, black,
flammability
UL 94 V-0
01108052
01105055
for air barrier,
fully wired,
with mains cable
90 ... 264 VAC,
230 VAC
input SCHUKO/
UTE plug,
(SCHUKO/UTE
outlet IEC 60320
plug/
C13 socket;
IEC 60320 C13
external NTC
socket),
sensor 1.5 m
adjustment range
0 ... 60°C
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-801
22117-806
22117-802
22117-807
20713-048
20118-750
60715-005
22117-801
22117-802
22117-806
22117-807
20713-048
20118-750
60715-005
22117-801
22117-806
22117-802
22117-801
22117-807
22117-806
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.294
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-808
20117-080
20117-080
20117-080
20117-080
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
eurorack 19"
Raised top covers
Order Information
Raised top cover
Raised
Fan for raised top cover
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44526
ERA44560
St, 1.5 mm,
RAL 7021,
air gap all round
8 mm, IP 20
lifting eye for
raised top cover,
application and
in accordance
with DIN 582
ertp0055
KTA44844
KTA44844
01108052
01105055
axial fan 230 VAC, axial fan 230 VAC,
St, 1.5 mm,
fully wired,
for air barrier,
RAL 7021,
90 ... 264 VAC,
with mains cable
15 W, 162 m3/h,
8 W, 90 m3/h,
all 6 openings
230 VAC
height 38 mm,
height 25 mm,
input SCHUKO/
closed with PE
plastic, black,
plastic, black,
UTE plug,
(SCHUKO/UTE
blank plugs,
flammability
flammability
outlet IEC 60320
plug/IEC 60320
terminal
UL 94 V-0
UL 94 V-0
C13 socket;
C13 socket),
clamp with
external NTC
adjustment range
connecting cable,
sensor 1.5 m
0 ... 60°C
2 m, IEC-60320
C14 plug
Cabinet dimensions
Width
Depth
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-811
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
22117-812
22117-811
22117-812
22117-811
22117-812
22117-811
22117-812
20150-011
20150-011
20150-011
20150-011
22117-813
22117-811
22117-812
20150-011
22117-813
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-822
22117-823
22117-821
20150-011
22117-813
22117-811
22117-812
22117-822
22117-823
22117-821
22117-813
22117-811
22117-812
22117-821
22117-822
22117-823
22117-821
20150-011
22117-822
22117-823
1.295
eurorack 19"
Order Information
Base plate
Fixed base/plinth , height 100 mm
Plain
00108051
St, 1.5 mm,
RAL 7021,
two parts,
mounting on
frame
With ventilation
ERA44532
base, Al die-cast,
covers, St,
2.5 mm,
RAL 7021
Filter mat
ERTP0057
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021,
front and rear
with ventilation
openings;
please order
filter mat
separately
ERTP0057
Adjustable feet
era44553
filter mat for fixed
base/plinth,
with ventilation
St, PA, black,
load-carrying
capacity 100 kg
per foot
Cabinet dimensions
Width
Depth
PU 2 pieces
1 piece
1 piece
PU 3 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
enclosed loose
assembled
assembled
enclosed loose
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-826
22117-830
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
22117-826
22117-830
22117-864
60114-514
22117-827
22117-826
22117-831
22117-830
22117-865
22117-864
60114-515
60114-514
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.296
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-832
22117-866
21101-201
21101-201
21101-201
21101-201
21101-201
21101-201
21101-201
eurorack 19"
Third 19" plane, lateral cable ducting
Order Information
RAL 7021
Depth member
AlZn
SZA45958
St, 1.5 mm, with 19" cut-outs;
to mount a third 19" plane,
1 pair of 19" panel/slide mounts
and 2 pairs of depth members are
required
Width
Cable panel
Width 250 mm
ertp0043
St, 1.5 mm, AlZn,
for assembly of
the third 19"
plane or other
components
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
RAL 7021
AlZn
AlZn
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
23117-026
23117-020
23117-029
23117-023
23117-027
23117-021
23117-030
23117-024
23117-028
23117-022
23117-031
23117-025
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
Cable panel
Width 150 mm
Depth
Cabinet dimensions
Height
Lateral cable ducting
For 19" eurorack
23117-017
22117-352
23117-018
22117-353
23117-019
22117-354
22117-835
22117-355
22117-376
22117-377
22117-376
22117-377
22117-376
22117-377
22117-376
22117-377
22117-378
22117-376
22117-836
22117-356
22117-377
22117-378
22117-376
22117-837
22117-357
22117-377
22117-378
22117-376
22117-838
22117-358
22117-377
22117-378
1.297
eurorack 19"
19" slide rails
Order Information
Dimensions
standard
assembly
Slide rail
Short slide rail
40 kg, depthadjustable
W
xf
c
D
25 kg
00205066
xf = distance from
front
c = pitch of 19"
plane
D = cabinet depth
W = cabinet width
00108056
St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair
41003081
St, 1,5 mm,
finish AlZn,
40 kg/pair,
depth-adjustable
(c: 675 - 850 mm)
sc96xxxx
St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.298
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
480
680
780
480
680
780
PU 2 pieces
PU 10 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
enclosed loose
enclosed loose
enclosed loose
enclosed loose
enclosed loose
22127-094
21127-197
22127-095
21127-199
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-199
28127-001
20118-592
20118-593
22127-094
21127-197
22127-095
22127-094
21127-199
21127-197
28127-001
20118-592
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
21127-199
28127-001
eurorack 19"
19" fixed or telescopic shelves
Order Information
Fixed shelf, 1 U, 75 kg
Full depth
Shelf, telescopic, 2 U, 70 kg
Recessed by c 100 mm
Full depth
Shortened by
100 mm
T-bar lock
GND/earthing
W
xf
c
D
Dimensions
standard
assembly
00205066
00105050
St, 1.5 mm,
xf = distance from
RAL 7021, with
front c = pitch of
perforation,
19" plane
static loadD = cabinet depth
carrying capacity
W = cabinet
75 kg, incl. GND/
width
earthing
00105051
St, 1.5 mm,
RAL 7021, with
perforation,
75 kg, incl. GND/
earthing,
third 19" plane
necessary,
please order
separately
00105069
00105070
St, 1.5 mm, staic load-carrying
capacity 70 kg, incl. telescopic slide;
please order T-bar lock and GND/
earthing separately
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
480
680
780
480
680
780
1 piece
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
assembled
22117-842
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-842
22117-843
22117-845
22117-871
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
22117-842
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-842
22117-871
22117-845
21130-355
21130-353
21130-354
21130-352
23130-092
23130-092
21120-189
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-843
1.299
Cabinets – PUniversal ServicePLUS
configuration
freely
쮿 Configuration tables from page 1.301
assembly
Assembly of all mechanical, electrical and
modification
solution
academy
reports
lifecycle
maintenance, repair, replacement parts, recycling
Universal ServicePLUSP
1.300
Cabinets – P Universal ServicePLUS
eurorack Universal ServicePLUS: configuration and assembly
쮿 Dimensions:
– Width: 600, 800 mm
– Depth: 600, 800, 900 mm
Page
쮿 Colours:
mounting kit, GND/
castors
1.302
Doors
1.303
1.305
ducting
dimensions (see example below)
Flush top covers
1.306
Raised top covers
1.307
1.308
1.309
19" slide rails
1.311
Fixed 19" shelves
1.312
Telescopic 19" shelves
1.313
Fixed shelves on
Universal
cabinet uprights
Telescopic shelves on
Universal
cabinet uprights
Dimensions
Universal frame
1.314
1.315
1.275
00101534
Example configuration (here: row 17)
Qty
1
1
2
2
1
Description
Universal frame, RAL 7021, height 2020 mm, width 600 mm, depth 900 mm, 1
piece
Lateral steel door, opening angle 120°, RAL 7035, 1 piece
Front, rear glass door, RAL 7035, opening angle 180°, 1 piece
Order no.
22117-792/05
21101-201/05
21117-190/05
22117-229/05
60114-121/05
1.301
eurorack Universal
Order Information
Universal frame
(without 19"
plane)
Side-by-side
mounting kit
era44489
Universal frame,
rack Al die-cast,
uprights
Al extrusion,
19" plane can be
built in 25 mm
increments with
depth members
and depthadjustable
19" panel/slide
mounts
GND/earthing
Castors
Load-carrying
capacity 180 kg
per kit
ERTP0070
serves to screw
together
two cabinets
Adjustable feet
aza43284
era44553
for frame,
door, side panel,
top cover,
base plate
St, PA, black,
load-carrying
capacity
100 kg per foot
Load-carrying
capacity 300 kg
per kit
era44556
onto frame,
onto frame,
height
height
H = 110 mm,
H = 93 mm,
2 locking, 2 non- 2 locking, 2 nonlocking castors
locking castors
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
assembled
supplied loose
assembled
assembled
enclosed loose
enclosed loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-985
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
22117-796
22117-992
20117-515
21101-539
21101-201
20117-757
20117-024
22117-797
20117-515
21101-539
21101-201
20117-757
20117-024
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
22117-986
22117-987
22117-988
22117-989
22117-990
22117-782
22117-783
22117-784
22117-985
22117-986
22117-787
22117-788
22117-789
22117-790
22117-791
22117-792
22117-793
22117-794
22117-991
Frame dimensions, see page 1.275
1.302
eurorack Universal
Order Information
Side panel
Side panel
with safety lock
Glass door
Opening angle
120°
ERA44517
St, 1 mm,
RAL 7035,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
ERA44517
St, 1 mm,
RAL 7035,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
St, 1 mm,
RAL 7021,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
mra45967
glazing
smoke grey,
Sekurit, 6 mm,
safety lock with
2 keys
DIN profile half
cylinder
00101506
glazing
smoke grey,
Sekurit, 6 mm,
lever handle
(incl. blank
insert)
SZA44484
DIN profile half
cylinder for lever
handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
Width
Depth
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
20117-745
20117-746
20117-747
22117-239
60114-121
20117-748
22117-227
60114-121
20117-749
22117-228
60114-121
20117-754
22117-236
60114-121
20117-751
22117-229
60114-121
20117-753
22117-237
60114-121
20117-752
22117-230
60114-121
20117-756
22117-238
60114-121
No. U
mm
mm
mm
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
21117-158
22117-993
21117-167
21117-159
22117-994
22117-995
21117-168
22117-996
21117-160
21117-169
22117-997
22117-998
22117-185
22117-186
23117-002
23117-003
21117-161
22117-958
22117-173
23117-004
21117-170
21117-179
22117-959
22117-960
22117-177
22117-181
23117-005
23117-006
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
Glass door
Opening angle
180°
21117-162
22117-961
22117-174
23117-007
21117-171
21117-180
22117-962
22117-963
22117-178
22117-182
23117-008
23117-009
21117-162
22117-961
22117-174
23117-007
21117-171
21117-163
22117-962
22117-964
22117-178
22117-175
23117-008
22117-968
21117-172
22117-965
22117-179
22117-969
21117-181
21117-163
22117-966
22117-964
22117-592
22117-175
22117-970
22117-968
21117-172
22117-965
22117-179
22117-969
21117-164
21117-173
22117-999
22117-967
22117-176
22117-180
23117-010
22117-971
21117-182
23117-001
22117-593
22117-972
21117-173
22117-967
22117-180
22117-971
1.303
eurorack Universal
Doors
Order Information
Steel door
Opening angle 120°
Opening angle 120°
Steel door
a4491b
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.304
Opening angle 180°
00101506
DIN profile half
cylinder
00101504
SZA44484
DIN profile half
cylinder for
lever handle
frame, Al, 2 mm,
RAL 7035;
acrylic glass,
2 mm,
safety lock with
2 keys
frame, Al, 2 mm,
RAL 7021,
acrylic glass,
2 mm,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7021,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
St, 1 mm,
RAL 7021,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
20117-770
22117-944
21117-185
22117-935
20117-771
22117-945
21117-186
22117-936
20117-772
23117-011
21117-187
23117-012
22117-201
23117-013
60114-121
20117-765
22117-946
21117-188
22117-937
22117-189
23117-014
60114-121
20117-766
22117-947
21117-189
22117-938
22117-190
23117-015
60114-121
20117-775
22117-948
21117-198
22117-939
22117-198
23117-016
60114-121
20117-767
22117-949
21117-190
22117-940
22117-191
22117-973
60114-121
20117-776
22117-950
21117-199
22117-941
22117-199
22117-974
60114-121
20117-768
22117-951
21117-191
22117-942
22117-192
22117-975
60114-121
20117-777
22117-952
21117-200
22117-957
22117-200
22117-976
60114-121
ELECTRONICS PROTECTION
eurorack Universal
Order Information
Door hinge
bracket for
Universal frame
Cable ducting frame
3U
4U
00105068
St, 1.5 mm,
RAL 7021,
assembly above
or below
shortened door,
1 U assembly
area, please
order 19" panel/
slide mount and
cable ducting
plate separately
SZA45958
short doors or rear panels
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1 piece
1 piece
1 piece
assembled
assembled
assembled
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
1.305
eurorack Universal
Flush top covers
Order Information
Flush top cover
Plain
Louvered
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44525
St, 1 mm,
RAL 7021
ERA45344
ERA44560
St, 1 mm,
RAL 7030
lifting eye for
flush cover,
application and
in accordance
with DIN 582
ertp0055
St, 1.5 mm,
RAL 7021,
all 6 openings
closed with PE
blank plugs,
terminal clamp
with connecting
cable, 2 m,
IEC 60320
C14 plug
KTA44844
01108052
01105055
axial fan 230 VAC,
for fan tray,
fully wired,
with mains cable
90 ... 264 VAC,
8 W, 90 m3/h,
230 VAC
height 25 mm,
input SCHUKO/
protective grille,
UTE plug,
(SCHUKO/UTE
plastic, black,
outlet IEC 60320
plug/IEC 60320
flammability
C13 socket;
C13 socket),
UL 94 V-0
external NTC
adjustment range
sensor 1.5 m
0 ... 60 °C
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-801
22117-806
22117-802
22117-807
20713-048
20118-750
60715-005
22117-801
22117-802
22117-806
22117-807
20713-048
20118-750
60715-005
22117-801
22117-806
22117-802
22117-801
22117-807
22117-806
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.306
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-802
22117-808
22117-807
22117-804
22117-809
22117-801
22117-802
22117-806
22117-807
22117-803
22117-808
22117-802
22117-804
22117-807
22117-809
20117-080
20117-080
20117-080
20117-080
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20117-080
20117-080
20117-080
22117-822
22117-823
22117-824
22117-825
22117-821
22117-822
22117-823
20117-080
22117-824
22117-825
22117-801
22117-806
22117-802
22117-803
22117-807
22117-808
20117-080
22117-822
22117-823
20713-048
20118-750
60715-005
22117-804
22117-809
20117-080
22117-825
20713-048
20118-750
60715-005
22117-821
eurorack Universal
Raised top covers
Order Information
Raised top cover
Raised
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44526
ERA44560
St, 1.5 mm,
RAL 7021,
air gap all round
8 mm, IP 20
lifting eye for
raised top cover,
application and
in accordance
with DIN 582
ertp0055
KTA44844
01108052
01105055
St, 1.5 mm,
for fan tray,
fully wired,
RAL 7021,
with mains cable
90 ... 264 VAC,
15 W, 162 m3/h,
8 W, 90 m3/h,
all 6 openings
230 VAC
height 38 mm,
height 25 mm,
input SCHUKO/
closed with PE
protective grille, protective grille,
UTE plug,
(SCHUKO/UTE
blank plugs,
plastic, black,
plastic, black,
outlet IEC 60320
plug/IEC 60320
terminal clamp
flammability
flammability
C13 socket;
C13 socket),
with connecting
UL 94 V-0
UL 94 V-0
external NTC
adjustment range
cable, 2 m, IECsensor 1.5 m
0 ... 60°C
60320 C14 plug
Cabinet dimensions
Width
Depth
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-811
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
22117-812
22117-811
22117-812
22117-811
22117-812
22117-811
22117-812
20150-011
20150-011
20150-011
20150-011
22117-813
22117-811
22117-812
22117-813
22117-812
22117-814
22117-811
22117-812
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20150-011
20150-011
20150-011
22117-813
22117-812
22117-814
22117-821
22117-822
22117-823
22117-824
22117-825
22117-821
22117-822
22117-823
20150-011
22117-811
22117-824
22117-825
22117-821
22117-812
22117-813
20150-011
22117-824
22117-823
20713-243
20713-048
20118-750
60715-005
22117-814
20150-011
22117-825
20713-243
20713-048
20118-750
60715-005
Part number in bold face type: ready for despatch within 2 working days
1.307
eurorack Universal
Order Information
Base plate
Plain
00108051
St, 1.5 mm,
RAL 7021,
two parts,
mounting on
frame
With ventilation
ERA44532
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021
Filter mat
ERTP0057
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021,
front and rear
with ventilation
openings
ERTP0057
Mobile base/plinth
Adjustable feet
Base/plinth
era44553
base/plinth,
with ventilation
St, PA, black,
load-carrying
capacity 100 kg
per foot
Jacking foot
era45323
ERA44532
Al die-cast,
RAL 7021,
300 kg,
with rubber mat,
4 castors, PA
for mobile base,
mounted below
front,
adjustment from
above
Cabinet dimensions
Width
Depth
PU 2 pieces
1 piece
1 piece
PU 3 pieces
PU 4 pieces
1 piece
PU 2 pieces
No. U
Height
mm
mm
mm
enclosed loose
assembled
assembled
enclosed loose
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-826
22117-830
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
21101-201
22117-869
20117-503
22117-826
22117-830
22117-864
60114-514
22117-827
22117-826
22117-831
22117-830
22117-865
22117-864
60114-515
60114-514
21101-201
22117-869
20117-503
21101-201
22117-869
20117-503
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
21101-201
21101-201
22117-869
20117-503
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-828
22117-827
22117-832
22117-833
22117-866
22117-867
21101-201
60114-517
22117-829
22117-834
22117-868
60114-518
21101-201
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
21101-201
21101-201
22117-869
22117-869
20117-503
20117-503
22117-828
22117-832
22117-866
21101-201
22117-827
22117-829
22117-833
22117-834
22117-867
22117-868
60114-517
60114-518
21101-201
22117-827
22117-830
22117-864
60114-514
21101-201
22117-869
20117-503
22117-829
22117-827
22117-831
22117-832
22117-865
22117-866
60114-515
22117-869
20117-503
21101-201
21101-201
22117-829
22117-834
22117-868
60114-518
21101-201
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.308
eurorack Universal
Order Information
RAL 7021
Depth member
AlZn
for 600 mm width
SZA45958
St, 1.5 mm, for depth-adjustable
fitting:
cabinet depth 600 mm:
please order depth members,
cabinet depth 800 mm: please order
reduced-width depth members
Width
ertp0044
St, 1.5 mm, AIZn St, 2.5 mm, zincplated, RAL 7021,
19" plane at least
110 mm from
front edge of
cabinet;
please order
panel/slide
mounts (2 pairs)
separately
RAL 7021
AlZn
AlZn
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
23117-017
22117-352
22117-389
22117-390
23117-018
22117-353
23117-019
22117-354
22117-835
22117-355
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
ERTP0045
Depth
Cabinet dimensions
Height
Reduced width
depth member
for 800 mm width
22117-389
22117-390
22117-389
22117-390
22117-389
22117-390
22117-391
22117-836
22117-356
22117-389
22117-390
22117-391
22117-836
22117-356
22117-837
22117-357
22117-390
22117-391
22117-837
22117-357
22117-839
22117-840
22117-389
22117-839
22117-840
22117-389
22117-838
22117-358
22117-390
22117-391
22117-838
22117-358
22117-840
1.309
eurorack Universal
Order Information
Cable panel
Width 150 mm
Cable panel
Width 250 mm
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
Width
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
23117-026
23117-020
23117-029
23117-023
23117-026
23117-020
23117-029
23117-023
23117-027
23117-021
23117-030
23117-024
23117-027
23117-021
23117-030
23117-024
23117-028
23117-022
23117-031
23117-025
23117-028
23117-022
23117-031
23117-025
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
1.310
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
PU 2 pieces
No. U
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
Depth
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
00108061
eurorack Universal
19" slide rails
Order Information
Dimensions
standard
assembly
Slide rail
Short slide rail
W
xf
c
D
25 kg
00205066
00108056
xf = distance from St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair, panel/
front
slide mounts (2 pairs), please order
c = pitch of
reduced widthdepth members
19" plane
separately
D = cabinet depth
see page
W = cabinet width
1.309
41003081
St, 1.5 mm, finish
40 kg/pair,
depth-adjustable
(c: 675-850 mm);
please order
panel/slide
mounts (2 pairs)
separately
see page
1.309
sc96xxxx
static load-carrying capacity 15 kg/
pair
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
SCHROFF.PENTAIR.CO.UK
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
110
110
60
60
60
110
110
60
60
60
110
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
380
580
480
680
780
380
580
480
680
780
580
PU 2 pieces
PU 10 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
enclosed loose
enclosed loose
enclosed loose
enclosed loose
enclosed loose
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-094
21127-197
20118-592
20118-593
22127-095
22127-094
21127-198
21127-197
28127-001
20118-592
20118-592
20118-593
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-096
21127-199
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-096
21127-199
28127-001
20118-592
20118-593
22127-094
25127-575
21127-197
20118-592
20118-592
20118-593
20118-593
22127-094
21127-197
20118-592
20118-593
22127-095
22127-096
21127-198
21127-197
28127-001
28127-001
20118-592
20118-592
20118-593
20118-593
22127-094
20118-593
21127-197
21127-197
20118-592
25127-575
22127-094
20118-592
20118-592
20118-593
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-197
21127-197
28127-001
20118-592
20118-592
20118-593
20118-593
1.311
eurorack Universal
Fixed 19" shelves
Order Information
Full depth
Depth member
Reduced width
Recessed by c - for 600 mm width depth member
for 800 mm width
100 mm
W
xf
c
D
Dimensions
standard
assembly
00205066
00105050
00105051
xf = distance from
with perforation, static load-carrying
front
capacity 75 kg, incl. GND/earthing;
c = pitch of 19"
panel/slide mounts (2 pairs),
plane
please order depth members or
D = cabinet depth
reduced width depth members
W = cabinet width
separately
see page
1.309
ERTP0045
ertp0044
19" plane at least
110 mm from
front edge of
cabi-net; please
order panel/slide
mounts (2 pairs)
separately
see page
1.309
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.312
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
110
110
60
60
60
110
110
60
60
60
110
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
380
580
480
680
780
380
580
480
680
780
580
SCHROFF PRODUCT CATALOG E 11/2017
1 piece
1 piece
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-842
22117-845
22117-389
22117-843
22117-842
22117-671
22117-845
22117-390
22117-389
22117-843
22117-671
22117-390
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-844
22117-843
22117-391
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-844
22117-843
22117-391
22117-842
22117-871
22117-839
22117-840
22117-842
22117-845
22117-389
22117-843
22117-844
22117-671
22117-843
22117-390
22117-391
22117-842
22117-839
22117-871
22117-842
22117-845
22117-389
22117-843
22117-671
22117-390
22117-844
22117-871
22117-843
22117-391
22117-840
22117-840
eurorack Universal
Order Information
Full depth
Shortened by
100 mm
T-bar lock
GND/earthing
c
D
Dimensions
standard
assembly
xf
W
00205066
00105069
00105070
St, 1.5 mm, static load-carrying
xf = distance from
front
c = pitch of 19"
earthing separately
plane
D = cabinet depth
W = cabinet width
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
c
mm
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
21130-353
21130-352
23130-092
21120-189
21130-355
21130-353
21130-354
21130-352
23130-092
23130-092
21120-189
21120-189
21130-355
21130-354
23130-092
21120-189
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
450 - 550
650 - 750
21130-353
21130-352
23130-092
21120-189
21130-355
21130-354
23130-092
21120-189
450 - 550
450 - 550
21130-353
21130-352
23130-092
21120-189
21130-355
21130-354
23130-092
21120-189
Part number in normal type: ready for despatch within 10 working days
1.313
eurorack Universal
Fixed shelves on universalcabinet uprights
Order Information
Fixed shelf
Full depth
Shortened by
100 mm
00106053
00106054
St 1.5 mm,
St 1.5 mm,
RAL 7021, load- RAL 7021, loadcarrying
carrying
capacity 75 kg,
capacity 75 kg,
incl. GND/
incl. GND/
earthing,
earthing
depth member
required,
please order
separately
Depth member
ERTP0045
St, 1.5 mm, AIZn
Cabinet dimensions
Width
Depth
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
22117-846
22117-851
22117-389
22117-847
22117-846
22117-852
22117-851
22117-390
22117-389
22117-847
22117-852
22117-390
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
22117-848
22117-847
22117-391
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.314
PU 2 pieces
22117-848
22117-847
22117-391
22117-849
22117-850
22117-853
22117-854
22117-389
22117-390
22117-846
22117-851
22117-389
22117-847
22117-848
22117-852
22117-847
22117-390
22117-391
22117-849
22117-853
22117-389
22117-850
22117-846
22117-854
22117-851
22117-390
22117-389
22117-847
22117-852
22117-390
22117-848
22117-850
22117-847
22117-854
22117-391
22117-390
eurorack Universal
Telescopic shelves on universal cabinet uprights
Order Information
Telescopic shelf, Universal eurorack
Full depth
Shortened by
100 mm
Telescopic slides
T-bar lock
GND/earthing
General
components
Mechanics
00105072
00105073
ERA46351
01004125
to lock the
telescopic shelf
aza43284
St, 1.5 mm,
RAL 7021,
please order
telescopic slides
and T-bar lock
separately
St, 1.5 mm,
RAL 7021,
please order
telescopic slides
and T-bar lock
separately
St, zinc-plated
for telescopic
shelf
1 piece
1 piece
PU 2 pieces
1 piece
PU 1 kit
assembled
assembled
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
Electrics
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
22117-855
22117-856
22117-860
22117-861
22114-340
22114-342
22117-855
22117-860
22114-340
22117-856
22117-855
22117-861
22117-860
22114-342
22114-340
22117-856
22117-861
22114-342
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
from page
4.0
22117-858
22117-862
22114-340
22117-859
22117-863
22114-342
22117-855
22117-856
22117-860
22117-861
22114-340
22114-342
22117-858
22117-859
22117-862
22117-863
22114-340
22114-342
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
22117-859
22117-863
22114-342
21101-132
21101-178
21101-132
21101-178
from page
3.29
Power
distribution
from page
3.50
Climate control
from page
4.0
1.315
OutdoorMain Catalogue
Cabinets – Outdoor
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
41602001
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
41603009
The dual wall concept provides a
natural airflow between the outer
and inner wall, substantially
reducing the requirement for
additional heat removal.
41603010
Optimal protection from vandalism
thanks to a fixing accessible only
from within. Easily exchangeable
exterior cladding components.
41603005
The gasketing material can be
selected to suit the requirements
(IP protection, EMC shielding) and
may be exchanged subsequently.
Power supply
units . . . . . . . . . . 9
Standard / Certifications
Backplanes . . . 10
쮿 External dimensions in accordance with IEC 619691/2, IEC 6091721
쮿 Internal dimensions in accordance with ETS 300119, part 2
쮿 Type of protection IP 55 in accordance with IEC 60529
쮿 Protective GND/earthing connections in accordance with DIN EN 50178 / VDE 0160
Connectors, front
panel component
system . . . . . . . 11
쮿 Vibration in accordance with IEC 619693 class 2
Appendix . . . . . 12
1.316
SCHROFF PRODUCT CATALOG E 05/2016
Cabinets – Outdoor
Overview . . . . . . 1.316
O utdoorMain Catalogue
Outdoor cabinet for the most challenging operating conditions
쮿 High stability up to earthquake resistance
쮿 Weight-saving aluminium construction
쮿 Assembly possibilities with 19", ETSI or other accessories
쮿 Tested thermal concepts available
쮿 IP 55 and security against vandalism
COMLINE: single wall
Weight-saving aluminium construction. Single wall cabinet
ready for wall, pole or ground installation. Optimal for diverse
applications in industry, transportation and communication.
Versions
COMLINE
ECL - single
access . . . . . . . . . . 1.328
FTTX - single
and dual
access . . . . . . . . . 1.329
쮿 ECL - single access (front door)
쮿 FTTX - single access (front door) and dual access
(front and rear door)
41612054
Unibody
Cost-effective inner case with removable outer cladding.
This version has advantages especially for small cabinets.
If accessed through the front door, it meets the installation
requirements.
Outdoor Unibody
Unibody . . . . . . . . .
Unibody VENT . . . .
Unibody HEX . . . . .
Wall mounting kit
1.322
1.323
1.324
1.325
Versions
쮿 With natural convection
쮿 With fan
쮿 With heat exchanger
41603054
Modular
Aluminium profile frame with removable, double-walled
cladding.
This version has advantages especially for large cabinets and if
access from all sides is needed.
Outdoor Modular
Modular VENT . . . 1.326
Modular HEX . . . . . 1.327
Versions
Accessories
쮿 With fan
Metric panel/slide
mounts . . . . . . . . . . 1.328
19" panel/slide
mounts . . . . . . . . . 1.329
41603051
ServicePLUS from page 1.330
e. g. individual configurations also with air
conditioners
e. g. custom solutions (electrical, thermal,
backup power supplies, special sizes)
ServicePLUS . . . 1.330
www.schroff.biz/ServicePLUS
30407004
1.317
Cabinets – Outdoor - COMLINE
Outdoor COMLINE ECL
Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Single wall, lightweight aluminium cabinet
쮿 Heat dissipation through natural convection
쮿 IP 55
쮿 2 versions
– With plinth
– Without plinth
Delivery comprises
41612001
Drawing shows version with with plinth
Item
1
2
Qty
1
1
3
4
1
1
5
6
2
1
Description
Body, single wall, Al, 2.5 mm, RAL 7035
Front door, Al, 2.5 mm, RAL 7035, 3-point locking,
lever handle with DIN profile half cylinder,
door opening angle 135°, door retainer at 110°,
door hinged on left hand side;
electrical door switch
Solar shield top cover, Al, 2 mm, RAL 7035
Plinth, Al, 3 mm, height 120 mm (only for version with
plinth)
19"/23" panel/slide mounts, St, galvanised, 2.5 mm
GND/earthing kit, assembled
Order Information
Height H
Height H
Width W
Depth D
U
mm
mm
mm
12
600
600
500
18
900
600
500
18
900
700
500
25
1200
700
600
Height dimensions without plinth (120 mm)
41612052
45
W + 51
D + 24
Part no.
Without
plinth
Part no.
12349-001
12349-009
12349-002
12349-003
12349-010
12349-011
12349-004
12349-012
Note
쮿 19"/23" panel/slide mount kit see page 1.319
64
Drawing shows version with plinth
With plinth
465
D - 37
H
451
Z
120
Z
W
D
Z-Z
Door opening height = H - 75 mm;
door opening width = W - 75 mm
1.318
41612050
19"/23" panel/slide mount kit for
COMLINE ECL
Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
쮿 For fitting to depth member (25 mm grid)
쮿 For recessed installation of 19"/23" components
쮿 Slide rails can be fitted
쮿 Load-carrying capacity 400 kg
Delivery comprises
Item
1
2
Qty
2
1
Description
19"/23" panel/slide mount, St, galvanised, 2.5 mm
Assembly kit
Order Information
For cabinet height
U
mm
12
600
18
900
18
900
25
1200
For cabinet width
mm
600
600
700
700
Part no.
22349-024
22349-025
22349-026
22349-027
41612057
1.319
Outdoor COMLINE FTTX
쮿 Insulated cabinet
쮿 IP 55
쮿 2 versions with plinth
– Single access (front door)
– Dual access (front and rear door)
Delivery comprises
41612003
Order Information
Single access
41612053
41612054
Dual access
Note
쮿 19"/23" panel/slide mount kit see page 1.321
쮿 Cable entry see page 1.321
쮿 Spool for fibre optic cables see page 1.321
Dual access
Height of door opening = H - 270 mm;
width of door opening = W - 100 mm
1.320
41612055
Single access
41612056
