10828072
10828072
    SCHROFF.PENTAIR.
    Metal, Aluminum Chassis, Open 12.382" L x 17.559" W x 3.465" H (314.50mm x 446.00mm x 88.00mm) Natur...
10828072 数据手册
Electronic Cases 2009 Edition Perfect Combination Form and function for measurement, instrumentation and control technology in a wide range of industries • Medical instrumentation • Lab/data analysis • Communications diagnostics compacPRO Electronic Cases ■ High quality protection for sensitive electronics ■ Effective EMC shielding concepts ■ Flexible design emphasis multipacPRO ■ Ideal for all low profile rackmounted chassis applications ■ Available in sheet metal version for volume requirements ■ Perfect ‘pizza boxes’ slot in 1U and 2U sizes inpac ■ ■ ■ ■ ■ Ideal for heavy duty industrial 19" rack mount applications Top and bottom covers easily removed for access Rugged diecast and extruded framework Cost-effective solution ■ ■ ■ ■ ■ ■ Ideal for Medical, Test, or VME based applications Available in desktop or portable models Easily customized Rugged diecast and extruded framework Top and bottom covers easily removed for access Adjustable tip-up handle ratiopacPRO/-air ■ ■ ■ ■ Aesthetic, flexible design – perfect for instrumentation High Performance EMC option Available in rackmount, desktop, and tower models Efficient thermal management comptec ■ Ideal as the ‘desk top cabinet’ for applications where there is a need to house 19” rackmounted equipment ■ Applications: R & D Labs, demo equipment, table top cabinet requirements ■ Rugged diecast and extruded frame Test and Measurement Medical Schroff cases provide mounting for a wide variety of electronic equipment including: Schroff electronic cases are the perfect solution for a range of medical applications including: ■ ■ ■ ■ ■ ■ VME/CPCI boards Power supplies Motherboards Test panels Custom front/rear panels Cooling They can be configured to handle a wide range of applications in test measurement from photonics, to communications diagnostics, to chromatography to portable data acquisition. ■ ■ ■ ■ Electro-surgical equipment Embedded systems Portable diagnostic equipment Available in standard and EMC configurations The cases feature: Rugged construction Easy to clean surfaces Aesthetic design Easily customized Accommodates a range of board and component modules ■ Wide range of accessories ■ ■ ■ ■ ■ 1|2 compacPRO 3 2 1 6 4 5 ■ Cost effective, rugged case for desktop or portable applications ■ Pre-mounted, empty case for individual assembly ■ Flexible assemblies, prepared for 19" components or individual assembly, e.g. with chassis plate ■ Die-cast frame front and rear, highly stable through one-piece design and panel dimensioning ■ Wide range of accessories, coordinated for mobile applications ■ Non-sensitive, scratch-resistant surfaces through powder coating up-to-date color design ■ Top cover and base plate removable subsequently ■ Full-width front panel without visible screws ■ Individual mounting service from 1 case Ordering Information Height Usable Width width W U HP mm 2 42 257 257 2 42 2 42 257 2 84 471 2 84 471 2 84 471 3 28 186 3 28 186 3 42 257 257 3 42 3 42 257 3 63 364 3 63 364 3 63 364 471 84 3 3 84 471 3 84 471 84 471 3 3 84 471 4 42 257 257 42 4 4 63 364 4 63 364 4 63 364 4 84 471 4 84 471 4 84 471 84 471 4 Width w mm 219 219 219 432 432 432 148 148 219 219 219 326 326 326 432 432 432 432 432 219 219 326 326 326 432 432 432 432 Height H mm 102.6 102.6 102.6 102.6 102.6 102.6 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 191.6 191.6 191.6 191.6 191.6 191.6 191.6 191.6 20 191.6 Height h mm 84.4 84.4 84.4 84.4 84.4 84.4 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 Depth D mm 271 331 391 271 331 391 271 331 271 331 391 271 331 391 271 331 391 451 511 271 331 271 331 391 331 391 451 511 D Order no. 14575-023 14575-025 14575-027 14575-063 14575-065 14575-067 14575-103 14575-105 14575-123 14575-125 14575-127 14575-143 14575-145 14575-147 14575-163 14575-165 14575-167 14575-169 14575-171 14575-223 14575-225 14575-243 14575-245 14575-247 14575-265 14575-267 14575-269 20 14575-271 5 h H ■ Full range of accessories including tip-up handles, filler panels and equipment mounting Delivery includes (kit, item 1 and 2 assembled) Item Qty Description 1 2 Side panel, Al extrusion, RAL 7016 2 2 Frame, Al die-cast, RAL 7016 3 1 Cover, Al, 1.5mm, RAL 9006, with GND/earthing connection 4 1 Base with perforation, Al, 1.5mm, RAL 9006, with GND/earthing connection 5 4 Case foot with anti-slip protection, PC, black 6 8 Mounting adapter cover plate, pre-mounted 7 1 The assembly kit allows to assemble a full-width front panel and a rear panel additionally 20 w W 20 D 5 h H For more product information visit us at www.schroff.us/oneclick Type Order No, into oneClick and click “search” w ratiopacPRO Delivery includes (in kit form) Item Qty Description 1 2 Side panel, Al passivated 2 2 Side trim, Al, visible surface powder coated, RAL 9006 3 2 Rear trim, Zn die-cast, powder coated, RAL 7016 3a 2 Front trim, Zn die-cast, powder coated, RAL 7016 3b 2 Front handle, Al die-cast, powder coated, RAL 7016 3c 2 19" mounting angle, Al die-cast, powder coated, RAL 7016 4 4 Horizontal rail, Al, visible surface powder coated, RAL 7016 11 2 Top cover and base cover, Al, internal surface conductive, visible surface powder coated, RAL 9006, with GND/earthing tag, base cover with vent slots 12 4 Case foot, PC, black, with anti-slip protection 13 1 Assembly kit ratiopacPRO/ratiopacPRO/air Width HP Depth mm 2U 3U 4U 5U 6U Order no. Order no. Order no. Order no. side Panel Classification (1U-3U-1U) (3U-2U) Order no. - - With Front Handle 84 255.5 84 315.5 84 375.5 84 435.5 84 495.5 - 24571-738 - - 24571-741 24571-789 24572-252 24572-396 24571-837 24571-742 24571-790 24572-253 24572-397 24571-838 24571-743 24571-791 24572-254 24572-398 24571-839 - 24571-744 - - - 24571-840 - - - With Bezel RatiopacPro construction 84 255.5 24572-530 24571-038 - 84 315.5 24572-533 24571-041 24571-089 24572-156 24572-300 24571-137 84 375.5 24572-534 24571-042 24571-090 24572-157 24572-301 24571-138 84 435.5 24572-535 24571-043 24571-091 24572-158 24572-302 24571-139 84 495.5 - 24571-044 - - - 24571-140 ■ Available in three versions: – with bezel – with front handle – with 19" brackets With 19” Mounting Bracket ■ EMC shielding upgrade available ■ Symmetrical design, identical front and rear 84 255.5 24572-570 24571-738 24571-486 - - - 84 315.5 24572-573 24571-741 24571-489 - - 24571-537 84 375.5 24572-574 24571-742 24571-490 24572-205 24572-349 24571-538 84 435.5 24572-575 24571-743 24571-491 24572-206 24572-350 24571-539 84 495.5 - - - - - 24571-540 For complete info on all specifications and accessories visit www.schroff.us 3|4 comptec 19" case 6-12U ■ Perfect desktop “cabinet” ■ Case to accommodate 19" equipment Delivery Comprises (kit) Item Qty Description 1 1 Front frame 2 1 Rear Frame 3 2 Side profile at top 4 2 Side profile at bottom 5 2 Side panel, St 6 2 Handle shell 7 1 Cover 8 1 Base 9 1 Rear Panel 10 4 Case foot 11 1 Assembly kit Ordering Information Height Height Height H h U mm mm 6 286 13 6 286 13 6 286 13 6 286 13 7 331 13 7 331 13 7 331 13 9 420 13 9 420 13 9 420 13 9 420 13 9 420 13 13 9 420 12 553 13 12 553 13 12 553 13 *Al covers Depth D mm 300 400 500 600 400 500 600 400 500 600 400 500 600 400 500 600 ■ Height from 1U up to 12U ■ Type of protection IP 20 ■ High stability ■ Front and rear panel identical, depth-symmetrical assembly ■ Factory assembled with protective GND/earthing connection ■ Cover, base and rear panel made out of steel Typical modifications: ■ Special colors ■ Customized cut-outs in rear panels, front panels, cover and base plates h H HE ■ Special depths For more product information visit us at www.schroff.us/oneclick Type Order No, into oneClick and click “search” b B Usable Depth d mm 276 376 476 576 376 476 576 376 476 576 376 476 576 376 476 576 Order no. 10225-604 10225-615 10225-626 10225-637 10225-616 10225-627 10225-638 10225-618 10225-629 10225-640 *10225-667 *10225-682 *10225-693 *10225-670 *10225-685 *10225-696 inpac ■ Rugged 19" chassis with high mechanical stability ■ Front and rear frame Al-diecast ■ Modular design ■ Easily accommodates electronic components Delivery includes (kit) Item Qty Description 1 2 Side panel, Al extrusion 2 1 Front frame, Al die-cast 3 1 Rear frame, Al die-cast 4 1 Cover, St 5 1 Base, St 6 4 Case foot 7 1 Assembly kit Ordering Height H U 2 2 2 3 3 3 3 4 4 4 4 6 6 Information Height h H mm mm 88 86 88 86 88 86 132.5 130.5 132.5 130.5 132.5 130.5 132.5 130.5 177 174.5 177 174.5 174.5 177 177 174.5 265.9 263.5 265.9 263.5 h1 h2 mm 57.5 57.5 57.5 102 102 102 102 146.5 146.5 146.5 146.5 235.4 235.4 mm 76.2 76.2 76.2 57.15 57.15 57.15 57.15 101.6 101.6 101.6 101.6 190.5 190.5 Depth D mm 254.5 314.5 374.5 254.5 314.5 374.5 434.5 254.5 314.5 374.5 434.5 374.5 434.5 Order no. 10828-071 10828-072 10828-073 10828-051 10828-052 10828-053 10828-054 10828-056 10828-057 10828-058 10828-059 10828-068 10828-069 multipacPRO Delivery includes (kit) Item Qty Description 1 Front panel, Al extrusion, 2 mm, front anodized, rear 1 etched (at 1U), colorless chromated front and rear side of front panel, from 2 U clear chromate Base body plain, St, 1 mm, (AIZn coated) 1 2 3 1 Rear panel, St, 1 mm, (AIZn coated) 4 1 Cover, St, 1 mm, (AIZn coated) Assembly kit 1 7 ■ 19" rackmount modular 1U & 2U cases ■ Perfect alternative for “pizza box” applications for low volume requirements ■ Sheet metal version for volume opportunities ■ EMC option Ordering Information Height Height mm U 1 43.7 1 43.7 1 43.7 2 88.1 2 88.1 Depth mm 220 280 340 280 340 Order no. 20860-120 20860-121 20860-122 20860-126 20860-127 Front handles For 1 U, AI extrusion, anodized, U 2 pieces 20860-256 Front handles For 2 U, AI extrusion, anodized, U 2 piece 20860-257 5|6 We are where you are www.schroff.us Pentair Technical Products Groups USA Pentair Electronic Packaging 170 Commerce Drive Warwick RI 02817 USA Tel. +1 (401) 732-3770 14100 Danielson Street Poway, CA 92064 Tel.: +1 (858) 679-4550 Fax: +1 (858) 679-4555 Toll free (888) 957-8291 www.schroff.us EUROPE Schroff GmbH Langenalber Straße 96-100 75334 Straubenhardt Deutschland Tel. +49 (0)7082 794-0 www.schroff.de Schroff UK Ltd. Maylands Avenue Hemel Hempstead Herts HP2 7DE Great Britain Tel. +44 (0)1442 240 471 www.schroff.biz Schroff SAS Z.I. 4, rue du Marais Boîte Postale 16 67660 Betschdorf France Tel. +33 (0)3 88 90 64 90 www.schroff.biz Schroff Scandinavia AB Flygfältsgatan 11 P.O. Box 2003 12821 Skarpnäck Sweden Tel. +46 (0) 8 683 61 00 www.schroff.se © Pentair Electronic Packaging 2008 12.08.5000 Schroff Scandinavia AB Peräsimentie 8 FIN-03100 Nummela Finland Tel. +358 9 222 68 00 www.schroff.fi Schroff S.r.l. Via Brughiera 1 20010 Pregnana Milanese (MI) Italy Tel. +39 02 932 714-1 www.schroff.biz Schroff GmbH/ Sp.z.o.o./-oddzial w Polsce ul. Marynarska 19A PL-02-674 Warszawa Poland Tel. +48 (0) 22 607 06 16 www.schroff.pl ASIA Schroff K.K. Nisso No.13 Bldg. 4F 2-5-1 Shinyokohama, Kohoku-ku Yokohama-shi Kanagawa 222-0033 Japan Tel. +81 (0)45 476 02 81 www.schroff.co.jp Pentair Technical Products China Shuangyuan Rd. South, Liuting, Chengyang District (Airport Ind. Zone) Qingdao, PC 266108 PR China Tel. +86 532-8771 6101 www.schroff.biz
10828072 价格&库存
很抱歉,暂时无法提供与“10828072”相匹配的价格&库存,您可以联系我们找货
