PHPF19005CG2
PHPF19005CG2
    HAMMONDMANUFACTURING
    DOOR STEEL 16.2X5.25" BE/GY
PHPF19005CG2 数据手册
ASSEMBLY INSTRUCTIONS FOR PHPF - SERIES HINGED FLAT DOOR PANEL BUL10367 REV. A PAGE 1 OF 1 6 6 1 1 2 2 B A 4 3 5 4 3 DETAIL A 1 2 DETAIL B ASSEMBLY INSTRUCTIONS: A) Select the height at which to mount the hinged flat door panel (items 1 & 2) on the combination rails (item 6). B) If mounting rails have square cutouts insert 2 cage nuts (item 5) per rail at desired height for the door panel. This can be done using a cage nut insertion tool. (Detail B) COMPLETE ASSEMBLY ITEM No. 1 2 3 4 5 6 PARTS LIST DESCRIPTION DOOR STOP ASSEMBLY HINGED DOOR PANEL SCREWS (NOT INCLUDED) WASHERS (NOT INCLUDED) CAGE NUTS (NOT INCLUDED) COMBINATION RAILS (NOT INCLUDED) TOOL BOX #2 Phillips Head Screw Driver QTY 1 1 4 4 4 2 C) Start with the doorstop assembly (item 1). Line up the mounting slots of the doorstop assembly with the holes on the combination rail (item 6). Secure with screws and washers (items 3 & 4) purchased for the combination rails (items 6). (Detail A & B) D) Once the doorstop assembly is secure. Mount and fasten the hinged door panel (item 2) by following instruction in step C. HAMMOND MANUFACTURING TM ELECTRONICS GROUP visit our website @ www.hammondmfg.com
PHPF19005CG2 价格&库存
很抱歉,暂时无法提供与“PHPF19005CG2”相匹配的价格&库存,您可以联系我们找货
