RMASU1930CG1
RMASU1930CG1
    HAMMONDMANUFACTURING
    SHELF FIXED 30X17.4X1.72" BE/GY
RMASU1930CG1 数据手册
Shelves (Fixed) - Internal Mount (Two Pair of Panel Rails) Path: Home > Rack Index > Shelves (Fixed) - Internal Mount - Two Pair of Panel Rails Fixed Shelf (Unvented) z z z z z click to enlarge z z z z z z z Attach to the sides of both pair of rack combination rails Requires no front rail mounting Front & rear lip folded for extra strength Weight load tested (RFVS2426BK1) to 350 pounds! Versatile design - can be used as shown (easy to install) or upside down (front & rear lip become equipment retainers) Heavy duty, 14 Ga. steel construction Sides folded up for easy hardware installation from above Sides are slotted for easy adjustment with most rail depth locations Rugged textured powder paint finish Includes all mounting hardware If used with our square hole rails you will need to order P/N CPRSA rail adaptor for each shelf ordered. Link here (below) to more information. MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) UNVENTED - 19" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Color Reader .dxf File .stp files Depth File (zipped) (zipped) RFUS1918BK1 Black RFUS1918CG1 Beige* 18" 63K 38K 19K RFUS1921BK1 Black RFUS1921CG1 Beige* 64K 41K 23K RFUS1926BK1 Black RFUS1926CG1 Beige* 63K 11K 23K RFUS1931BK1 Black RFUS1931CG1 Beige* 70K 42K 25K 21" 26" 31" *Note: "CG2" (Beige color) is being phased out from stock UNVENTED - 24" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Color Reader .dxf File .stp files Depth File (zipped) (zipped) RFUS2418BK1 Black RFUS2418CG1 Beige* 62K 38K 19K RFUS2421BK1 Black RFUS2421CG1 Beige* 63K 41K 23K RFUS2426BK1 Black RFUS2426CG1 Beige* 63K 41K 23K RFUS2431BK1 Black RFUS2431CG1 Beige* 63K 42K 25K 18" 21" 26" 31" *Note: "CG2" (Beige color) is being phased out from stock Note2: Weight load tested (RFUS2426BK1) to 350 pounds. Fixed Shelf (Vented) z z z click to enlarge z z z z z z z z z z Attach to the sides of both pair of rack combination rails Requires no front rail mounting Provides a sturdy shelf without obstructing upward heat movement Front & rear lip folded for extra strength Weight load tested (RFVS2426BK1) to 350 pounds! Versatile design - can be used as shown (easy to install) or upside down (front & rear lip become equipment retainers) Heavy duty, 14 Ga. steel construction Sides folded up for easy hardware installation from above Sides are slotted for easy adjustment with most rail depth locations Rugged textured powder paint finish Includes all mounting hardware If used with our square hole rails you will need to order P/N CPRSA rail adaptor for each shelf ordered. Link here (below) to more information. MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) VENTED - 19" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Color Reader .dxf File .stp files Depth File (zipped) (zipped) RFVS1918BK1 Black RFVS1918CG1 Beige* 133K 139K 250K RFVS1921BK1 Black RFVS1921CG1 Beige* 133K 141K 258K RFVS1926BK1 Black RFVS1926CG1 Beige* 239K 172K 329K RFVS1931BK1 Black RFVS1931CG1 Beige* 242K 173K 333K 18" 21" 26" 31" *Note: "CG2" (Beige color) is being phased out from stock VENTED - 24 " Rack Mount Part Number 3D AutoCAD Solid Model Shelf Color Reader .dxf File .stp files Depth File (zipped) (zipped) RFVS2418BK1 Black RFVS2418CG1 Beige* 133K 144K 250K RFVS2421BK1 Black RFVS2421CG1 Beige* 135K 146K 255K RFVS2426BK1 Black RFVS2426CG1 Beige* 153K 179K 329K RFVS2431BK1 Black RFVS2431CG1 Beige* 152K 180K 333K 18" 21" 26" 31" *Note: "CG2" (Beige color) is being phased out from stock Note2: Weight load tested (RFVS2426BK1) to 350 pounds. "Zero Space" - Fixed Shelf (Vented) z z Attaches to the side of both pairs of rack combination rails (see drawing) No obstruction to front panel space or equipment z z z z z click to enlarge z z z z z z click to enlarge z Requires no front rail mounting or front rack space Vented to provide a sturdy shelf without obstructing upward heat movement Heavy duty, 14 Ga. steel construction Rear lip folded up for extra strength & acts as a rear equipment retainer Rear lip is covered with a rubber channel to avoid equipment scratching and cable chaffing (see drawing to the left) Includes two equipment stops which can be fastened anywhere on the shelf (#5 in drawing to the left) Sides folded up for easy hardware installation from above Sides are slotted for easy adjustment with most rail depth locations Rugged textured powder paint finish Includes all mounting hardware If used with our square hole rails you will need to order P/N CPRSA rail adaptor for each shelf ordered. Link here (below) to more information. MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) VENTED - 19" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Color Reader .dxf Files .stp files Depth File (zipped) (zipped) RZVS1918BK1 Black 18" 167K 119K 154K 124K 134K 184K 146K 175K 244K 162K 207K 304K RZVS1921BK1 Black 21" RZVS1926BK1 Black 26" RZVS1931BK1 Black 31" Adjustable Depth - Fixed Shelf - Light Duty z z z z z Uses 1U (1.75") of rack space Adjustable mounting depth Choice of unvented or vented versions 14 Ga. steel construction Finished in a rugged textured powder paint finish click to enlarge z z z Weight load tested to 75 pounds. Includes all mounting hardware MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) UNVENTED - 19" Rack Mount Part Number 3D AutoCAD Adjustable Solid Model Depth Color Reader .dxf Files .stp file Range File (zipped) (zipped) RMASU1917BK1 Black 17" to 27" 182K 76K 68K 190K 76K 69K 180K 76K 69K RMASU1925BK1 Black 25" to 35" RMASU1930BK1 Black 30" to 40" VENTED - 19" Rack Mount Part Number 3D AutoCAD Adjustable Solid Model Depth Color Reader .dxf Files .stp file (zipped) Range File (zipped) RMASV1917BK1 Black 17" to 27" 233K 151K 177K RMASV1925BK1 Black 25" to 35" 248K 169K 211K 263K 177K 227K RMASV1930BK1 Black 30" to 40" Note: Weight load tested to 75 pounds. Adjustable Depth - Fixed Shelf - HEAVY DUTY z z z z Uses 2U (3.5") of rack space Adjustable mounting depth Choice of unvented or vented versions Heavy duty, 14 Ga. steel construction z z z z Finished in a rugged textured powder paint finish Weight load tested to 200 pounds. Includes all mounting hardware MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) UNVENTED - 19" Rack Mount Part Number 3D AutoCAD Adjustable Solid Model Color Reader .dxf Files Depth .stp file (zipped) Range File (zipped) RMASUHD1917BK1 Black 17" to 27" 196K 79K 75K 195K 79K 75K 194K 79K 77K RMASUHD1925BK1 Black 25" to 35" RMASUHD1936BK1 Black 36" to 48" VENTED - 19" Rack Mount Part Number 3D AutoCAD Adjustable Solid Model Color Reader .dxf Files Depth .stp file Range File (zipped) (zipped) RMASVHD1917BK1 Black 17" to 27" 283K 140K 166K 322K 165K 218K 363K 198K 287K RMASVHD1925BK1 Black 25" to 35" RMASVHD1936BK1 Black 36" to 48" Note: Weight load tested to 200 pounds. Fixed Chassis/Shelf z z z z z z z z Shelf can be used as a permanently mounted support shelf or as a pull out chassis Will also accept type "RSLIDE" equipment slides (see below) for pull out applications 18-gauge steel shelf and 14-gauge brackets Weight load tested (RASC1922WH2) to 85 pounds. Shelf is 16.8” wide and 0.5” high Finished in a smooth white powder paint for high visability Includes all mounting hardware MOUNTS ON TWO PAIR OF PANEL RAILS (FRONT & BACK) 19" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Depth Bracket Depth Reader .dxf file .stp file Inches Inches File (zipped) (zipped) RASC1912WH2 153K 70K RASC1916WH2 159K 68K 68K 13.2 15.9 14.9 21.9 20.9 63K RASC1922WH2 160K 11.9 63K 63K 24" Rack Mount Part Number 3D AutoCAD Solid Model Shelf Depth Bracket Depth Reader .dxf file .stp file Inches Inches File (zipped) (zipped) RASC2412WH2 152K 70K 63K 155K 68K 63K 152K 68K 63K RASC2416WH2 RASC2422WH2 11.9 13.2 15.9 14.9 21.9 20.9 Note: Weight load tested (RASC1922WH2) to 85 pounds. RAIL ACCESSORIES Square Hole Panel Rail Adaptor Part Number CPRSA z z z z click to enlarge REQUIRED ONLY when using square hole panel rails with dual rail pair mounted shelves works with RFVS, RFUS, RZVS and RASC shelves set of 4 includes mounting hardware AutoCAD 3D .dxf Solid Reader & .dwg Model Files .stp file File (zipped) (zipped) 71K 32K 9K Shelves & Slides - catalog pages (5) - Adobe Reader .pdf format (198K) all accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K) Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor Home | Products | Distributors | Technical | Contact Us | Other Options Copyright; © 1998-2011 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RMASU1930CG1 价格&库存
很抱歉,暂时无法提供与“RMASU1930CG1”相匹配的价格&库存,您可以联系我们找货
