C2T2436VFCG1
C2T2436VFCG1
    HAMMONDMANUFACTURING
    RACK TOP
C2T2436VFCG1 数据手册
Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Page 1 of 8 Welded - "Contempra 4" Rack Frames (C4F Series) Path: Home > Rack Index > Welded Cabinet Frames (C4F Series) Features:           Create your own custom assembly using our C4 frame and choice of accessories below. Allows standard 19" rack mounting of equipment 30" width provides wider internal cabling space around rack mounted equipment For a stock pre-assembled version see our C4RR series. Welded 14 gauge steel frame with reinforced corners Open bottom for cable access 4 - 3.5" cable entry holes in top for cable access (includes covers) An overall height of 83.5" allows for easy movement through most doorways The seismic loading of the C4 cabinet was determined in accordance with the Uniform Building Code 1997 (UBC 97) for Seismic Zone 4 when used with part number C4K-Z4 - floor bolt down kit (see general accessories section below) Finished in rugged textured powder paint Check out our http://www.hammondmfg.com/c4rack_cmpnt.htm for this series! 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Page 2 of 8 30" Wide (External) - Frame Only Part Number AutoCAD Panel Height Overall Dimensions (Inches) Color Reader .dxf File A B Height Wt. lbs. Inches Units (Width) (Depth) (Less Feet) File (zipped) 19" Rack Mount C4F307731BK1 Black 119K 50K 126K 58K C4F307736BK1 Black C4F307742BK1 Black http://www.hammondmfg.com/c4rack_cmpnt.htm 77 44 30 31.5 82.81 200 77 44 30 36 82.81 206 77 44 30 42 82.81 214 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) 122K Page 3 of 8 52K Accessories 30" Wide Rack Components: C4 Doors Solid Door Plexi Door Description Perforated Door Black Part Number Plexi Door C4DF3077SBK1 C4DF3077PBK1 Perforated Door C4DF3077VBK1 Solid Door C4 Side Panels http://www.hammondmfg.com/c4rack_cmpnt.htm 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Solid Side Panel Page 4 of 8 Vented Side Panel Description Solid Side Panels - 31.5" Deep Solid Side Panels - 36" Deep Solid Side Panels - 42" Deep Vented Side Panels 31.5" Deep Vented Side Panels - 36" Deep Vented Side Panels - 42" Deep Black Part Number C4SP7731SBK1 C4SP7736SBK1 C4SP7742SBK1 C4SP7731VBK1 C4SP7736VBK1 C4SP7742VBK1 Fan Tops Fan Top with 4 4.7" Fans Description Black Part Number Beige Part Number Fan Top with 4 - 4.7" fans (30 x C2T2423F4BK1 C2T2423F4CG1 31.5") http://www.hammondmfg.com/c4rack_cmpnt.htm 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Fan Top with 4 - 4.7" fans (30 x 36") Fan Top with 4 - 4.7" fans (30 x 42") Fan Top with 10" fan (30 x 31.5") Fan Top with 10" fan (30 x 36") Fan Top with 10" fan (30 x 42") Page 5 of 8 C2T2431F4BK1 C2T2431F4CG1 C2T2436F4BK1 C2T2436F4CG1 C2T2423F10BK1 C2T2423F10CG1 C2T2431F10BK1 C2T2431F10CG1 C2T2436F10BK1 C2T2436F10CG1 C4 Tops Description Vented/Fan Cutout top - 31.5" deep Vented/Fan Cutout top - 36" deep Vented/Fan Cutout top - 42" deep 31.5" Deep Vented Top 36" Deep Vented Top 42" Deep Vented Top Black Part Number Beige Part Number C2T2423VFBK1 C2T2423VFCG1 C2T2431VFBK1 C2T2431VFCG1 C2T2436VFBK1 C2T2436VFCG1 C2T2423VBK1 C2T2431VBK1 C2T2436VBK1 C2T2423VCG1 C2T2431VCG1 C2T2436VCG1 C4 Bottoms Solid Bottom Description 31.5" Deep Solid Bottom Black Part Number 36" Deep Solid Bottom C4B3031SBK1 C4B3036SBK1 42" Deep Solid Bottom C4B3042SBK1 C4 19" Panel Mount Shelves http://www.hammondmfg.com/c4rack_cmpnt.htm 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Vented Shelf Page 6 of 8 Solid Shelf Description Solid - Depth adjust from 25" to 35" Black Part Number RMASU1925BK1 RMASU1930BK1 Solid - Depth adjusts from 30" to 40" Vented - Depth adjusts from 25" to 35" Vented - Depth adjusts from 30" to 40" RMASV1925BK1 RMASV1930BK1 General Accessories Vertical Cable Manager Panel Rail Accessory Rail Description Part Number 19" Panel Rails with Square Holes (pair) with rack C4PR77SZPL U markings 19" Accessory Rail http://www.hammondmfg.com/c4rack_cmpnt.htm C4AR77SZPL Instructions - 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Vertical Cable Manager with door Ganging Kit Caster Non-Locking (4) Page 7 of 8 C4VCM77BK1 CGH01 1425BH - Floor Bolt Down Kit (Required for Zone 4 compliance - see assembly C4K-Z4 instructions) 10-32 x 0.63" black pan head screw with nylon washer 10-32 cage nuts M6 Cage Nuts 12 - 24 Cage Nuts 1421ABK25* or 1421ABK100* 1421CNA25* or 1421CNA100* 1421CNB25* or 1421CNB100* 1421CNC25* or 1421CNC100* - * 25 - package quantity of 25, 100 - package quantity of 100 Accessory Links:               Aluminum rack panels (PBPA series) Steel rack panels (PBPS series) Formed steel rack panels (PBFS series) Ventilated & Access Panels (Louvers, slots, baffles etc.) Doors & Chassis - Panel Mount (Hinged & fixed) Cable Organizing (Panel mount rings, "hook & loop" strap panels & guides) Shelves - Panel Mount (Fixed, solid & vented) Keyboard Shelves & Drawers (Vertical rail mount) Rack mount power bars (1582 & 1583 series) Fans (Fans, Fan Kits, Grills & Filters) Cooling Panels (Ventilated Panels, Fan Panels & Baffles) Blowers (HB series) Fan Trays (FT series) Mounting hardware (Hardware) Check out our http://www.hammondmfg.com/c4rack_cmpnt.htm for this series! 3/18/2013 Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F) Page 8 of 8 Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor Home | Products | Distributors | Technical | Contact Us | Other Options Copyright; © 1998-2012 Hammond Mfg Co Inc URL: http://www.hammondmfg.com/ http://www.hammondmfg.com/c4rack_cmpnt.htm 3/18/2013
C2T2436VFCG1 价格&库存
很抱歉,暂时无法提供与“C2T2436VFCG1”相匹配的价格&库存,您可以联系我们找货
