Shelves (Fixed) - Panel Mount
(Single Pair of Panel Rails)
Path: Home > Rack Index > Shelves (Fixed) - Panel Mount
Panel Rail Mounted
Light Duty (Maximum 40 - 80 pound loads)
Fixed Chassis/Shelf (Vented or Unvented)
z
z
z
Vented
(7" Deep - 1U Shown)
z
z
z
z
z
z
Unvented
z
z
z
Allows easy rack mounting of narrow equipment or
items that do not have rack mounting capabilities.
Shelves feature formed 16-gauge steel construction
Choice of three heights - 1.75"(1U), 3.5"(2U) or
5.25"(3U) of panel space
Front & back edge folded - acting as both stiffeners
and equipment retainers..
Weight load tested: (1U-40 pounds, 2U-65 pounds,
3U-80 pounds)
Mounts to rack rails either as an internal shelf or
external shelf/work area
Choice of two depths - 7" or 14.5"
Available in either vented or unvented versions
Shelves include tie down slots on each side & four tie
down holes.
Perfect for our smaller desk top racks (ex: RCBS,
RCHS, RCHV, RRTT, 1459 series)
Rugged textured - black powder paint finish
Requires mounting hardware
A few other installation ideas...
RASU190107DBK1 mounted
RASU190107DBK1 front
mounted on a "DNRR"
series relay rack
RASVL190314BK1 mounted
in a 17" deep - "RCHS" series
desktop rack cabinet
upside down on a "DNRR"
series
relay rack (keyboard not
included)
VENTED
Part Number
3D
Panel
Thumbnail
Weight
AutoCAD Solid
Height
Shelf
Load
.dxf File Model
Reader
(Click to
Depth Rating
(zipped) .stp files
enlarge) Inches Units File
(Pounds)
(zipped)
Stiffener
Lip(s)
Folded
19" Rack Mount
RASV190107UBK1
RASV190107DBK1
RASVL190314BK1
1.75" 1U
147K
116K
177K
143K
103K
156K
1.75" 1U
3.50" 2U
163K
RASVL190514BK1
124K
164K
119K
40
7"
40
14.5"
65
Up
(back only)
14.5"
80
Up
(back only)
197K
5.25" 3U
Up
(front &
back)
Down
(front &
back)
7"
197K
UNVENTED
Part Number
3D
Panel
Thumbnail
Weight
AutoCAD
Solid
Height
Load
Shelf
Reader .dxf File Model Depth Rating
(Click to
(zipped) .stp files
(Pounds)
(zipped)
Stiffener
Lip(s)
Folded
19" Rack Mount
RASU190107UBK1
RASU190107DBK1
RASUL190314BK1
1.75" 1U
77K
50K
49K
74K
43K
38K
1.75" 1U
3.50" 2U
80K
RASUL190514BK1
46K
84K
46K
40
7"
40
14.5"
65
Up
(back only)
14.5"
80
Up
(back only)
42K
5.25" 3U
42K
Up
(front &
back)
Down
(front &
back)
7"
Panel Rail Mounted
HEAVY DUTY (Maximum 40 - 200 pound loads)
z
z
z
z
Vented
(20" Deep - 3U Shown)
z
z
z
z
z
z
Shelves feature formed 14-gauge steel construction
Choice of four heights - 1.75"(1U), 3.5"(2U),
5.25"(3U) or 7"(4U) of panel space
Rear lip stiffener folded up for extra strength & acts as
a rear equipment retainer
Weight load tested: (1U-40 pounds, 2U-100 pounds,
3U & 4U-200 pounds)
Choice of two depths - 15" or 20"
Rugged textured - powder paint finish
Unvented
(15" Deep - 3U Shown)
VENTED
3D
AutoCAD
Weight Load
Solid Model Panel Shelf
Color
.dxf
File
Rating
Reader
.stp files Width Depth
(Pounds)
Inches Units File (zipped) (zipped)
Panel Height
Part Number
19" Rack Mount
RASV190115BK1 Black 1.75" 1U
162K
122K
150K
122K
139K
179K
RASV190120BK1 Black 1.75" 1U
RASV190315BK1 Black 3.50" 2U
470K
122K
19"
15"
40
19"
20"
40
19"
15"
100
19"
20"
100
19"
15"
200
155K
RASV190320BK1 Black 3.50" 2U
124K
139K
185K
163K
119K
155K
RASV190515BK1 Black 5.25" 3U
RASV190520BK1 Black 5.25" 3U
155K
134K
185K
164K
113K
155K
130K
129K
184K
RASV190715BK1 Black 7.00" 4U
RASV190720BK1 Black 7.00" 4U
19"
20"
200
19"
15"
200
19"
20"
200
23"
15"
200
23"
20"
200
24"
15"
200
24"
20"
200
23" Rack Mount
RASV230515BK1 Black 5.25" 3U
124K
139K
189K
136K
159K
231K
RASV230520BK1 Black 5.25" 3U
24" Rack Mount
RASV240515BK1 Black 5.25" 3U
125K
141K
189K
134K
161K
229K
RASV240520BK1 Black 5.25" 3U
UNVENTED
3D
AutoCAD
Weight Load
Color
.dxf
File
Rating
Reader
(zipped)
(Pounds)
Inches Units File
(zipped)
Panel Height
Part Number
19" Rack Mount
RASU190115BK1 Black 1.75" 1U
75K
43K
31K
70K
43K
31K
79K
46K
35K
72K
46K
35K
79K
46K
35K
82K
46K
35K
RASU190120BK1 Black 1.75" 1U
RASU190315BK1 Black 3.50" 2U
RASU190320BK1 Black 3.50" 2U
RASU190515BK1 Black 5.25" 3U
RASU190520BK1 Black 5.25" 3U
19"
15"
40
19"
20"
40
19"
15"
100
19"
20"
100
19"
15"
200
19"
20"
200
RASU190715BK1 Black 7.00" 4U
81K
45K
35K
73K
45K
35K
RASU190720BK1 Black 7.00" 4U
19"
15"
200
19"
20"
200
23"
15"
200
23"
20"
200
24"
15"
200
24"
20"
200
23" Rack Mount
RASU230515BK1 Black 5.25" 3U
71K
45K
35K
72K
46K
35K
RASU230520BK1 Black 5.25" 3U
24" Rack Mount
RASU240515BK1 Black 5.25" 3U
70K
45K
35K
72K
45K
35K
RASU240520BK1 Black 5.25" 3U
Panel Rail Mounted
Dual Modem Shelves
z
z
z
Vented
z
z
z
z
z
z
z
Unvented
Dual modem shelf permits front and rear access to
modems on open relay racks
Unvented version available in either 19" or 23" rack
panel width
Uses 3.5" (2U) of vertical panel space
Overall 19.5" deep
The vented version provides a sturdy shelf without
obstructing upward heat movement
Front & rear lip folded for extra strength & become
equipment retainers
Weight load tested (DNDMS23BK1) to 200 pounds
VENTED
Part Number
3D
AutoCAD
Solid Model
Reader .dxf File .stp files Panel Width
19" Rack Mount
DNDMV19BK1
19"
164K
153K
277K
UNVENTED
Part Number
3D
AutoCAD
Solid Model
19" Rack Mount
DNDMS19BK1
19"
51K
97K
43K
23" Rack Mount
DNDMS23BK1
23"
51K
97K
43K
Note: Weight load tested (DNDMS23BK1) to 200 pounds.
Adjustable Shelf
z
z
z
z
z
z
z
z
z
Mounts to panel rails using 5.25" (3U) of vertical
panel space
Movable side brackets allow mounting inside or
outside rack at 4 different depths
Designed mainly for open relay racks - works panel
mounted on any rack
Choice of 16" or 20" deep
Available in either 19" or 23" rack panel width
14 Ga. steel construction
Weight load tested (DNRMA2320BK1) to 275
pounds
Finished in rugged textured - black powder paint
Part Number
3D
AutoCAD
Solid Model
Shelf
Reader .dxf File .stp files Panel Width Depth
19" Rack Mount
DNRMA1916BK1
186K
57K
41K
192K
58K
42K
DNRMA1920BK1
19"
16"
19"
20"
23"
16"
23"
20"
23" Rack Mount
DNRMA2316BK1
182K
58K
41K
185K
59K
42K
DNRMA2320BK1
Note: Weight load tested (DNRMA2320BK1) to 275 pounds.
Panel Rail Mounted
Clamping Shelves
(Vented)
z
z
z
z
z
z
z
z
z
Example of clamped equipment
(in this case 10.5" wide)
z
z
Includes two adjustable - gasketed (to protect from
scratching the clamped equipment) horizontal clamps.
Designed for equipment requiring front adjustment
without sliding around the shelf (ie...pushbuttons,
jacks, plugs, dials etc.)
Choice of four clamp locations depending on depth of
equipment
Choice of three shelf heights (see table below)
Mounted equipment height should be at least 1/2"
shorter than shelf "panel height" to allow clearance for
the gasketed clamps (see table below).
Provides a sturdy shelf without obstructing upward
heat movement
Rear lip folded up for extra strength & doubles as an
equipment retainer
VENTED
Part Number
3D
Shelf Panel Height Maximum
AutoCAD
Equipment
Solid Model Shelf
.dxf File
Height Reader
.stp files Depth
Inches
Units
(zipped)
File
(Inches)
(zipped)
19" Rack Mount
RACSV190315BK1 3.50"
2U
3"
15"
274K
RACSV190515BK1 5.25"
RACSV190715BK1 7.00"
3U
4U
119K
257K
4.75"
15"
290K
124K
293K
300K
131K
319K
6.5"
15"
Panel Rail Mounted
Keyboard/Monitor Shelf
z
z
z
z
z
z
z
z
z
Extends 15" back from front panel
Slanted keyboard section is 8.5"
Rear lip to reduce chance of monitor being
pushed off rear of shelf
width
Weight load tested (RKBM23BK1) to 160
pounds
paint
3D
AutoCAD
Solid Model
Part Number Reader .dxf File
Panel Width
.stp files
(zipped)
File
(zipped)
19" Rack Mount
RKBM19BK1
19"
50K
155K
40K
23" Rack Mount
RKBM23BK1
23"
50K
121K
40K
Note: Weight load tested (RKBM23BK1) to 160 pounds.
Shelf mounted to open aluminum Relay Rack
(keyboard not included)
Panel Rail Mounted
Equipment Shelf
z
z
z
z
z
z
z
Part Number
Standard 19" rack mount
A closed shelf with 1.5" dia. holes in each bottom
corner for cord access
Fabricated from 18 gauge steel
Inside dimensions 17.2" wide x 15" deep
Opening height is only 1" less than panel height
Finished in smooth white (to aid visibility), powder
paint
3D
AutoCAD Solid Model
Panel
Height
File
(zipped)
(zipped)
Inches Units
19" Rack Mount
RASE1900815WH2
8.75" 5U
88K
40K
31K
81K
40K
31K
80K
40K
31K
RASE1901015WH2
10.50" 6U
RASE1901215WH2
12.25" 7U
Note: Weight load tested (RASE191215WH2) to 75 pounds.
Panel Mount Shelves - catalog pages (2) - Adobe Reader .pdf format (111K)
all accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K)
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check
and ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 1998-2011 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
很抱歉,暂时无法提供与“RASU190720BK1”相匹配的价格&库存,您可以联系我们找货
