Shelves - Panel Mount
RAIL MOUNT - DUAL MODEM SHELVES
• Standard 19” rack mount - overall 19.5" deep, uses 3.5” (2U) of panel space
• Dual modem shelf permits front and rear access to modems on open relay racks
• Unvented version (pictured) available in either 19" or 23" rack panel width
• 16 gauge steel construction, weight load tested to 200 pounds
• The vented version provides a sturdy shelf without obstructing upward heat movement
• Powder paint finish
• Requires mounting hardware
Unvented
Par t Number
Black Textured
Grey Smooth
DNDMS19BK1
DNDMS19GY2
DNDMS23BK1
Panel
Width
19"
23"
Vented
Par t Number
Black Textured
Grey Smooth
DNDMV19BK1
DNDMV19GY2
Panel
Width
19"
RAIL MOUNT SHELVES
• Standard 19” rack mount - rail mount
• 17.25” wide and uses 5.25” (3U) of panel space, choice of two depths, either 15” or 20"
• 14 gauge steel construction, weight load tested to 200 pounds (unvented), 200 pounds (vented)
• Mounts to front rail either as an internal shelf or external shelf/work area
Unvented
Black Textured
RASU190515BK1
RASU190520BK1
RASU230515BK1
RASU230520BK1
Par t Number
Beige Textured
RASU190515CG1
RASU190520CG1
Grey Smooth
RASU190515GY2
Panel
Width
Shelf
Depth
Panel
Width
Shelf
Depth
Vented
Black Textured
RASV190515BK1
RASV190520BK1
RASV230515BK1
RASV230520BK1
Par t Number
Beige Textured
RASV190515CG1
RASV190520CG1
Grey Smooth
RASV190515GY2
Hammond Manufacturing Co. Ltd.
394 Edinburgh Rd. North
Guelph, Ontario N1H 1E5 CANADA
Phone: 519-822-2960 Fax: 519-822-0715
ww
w.h
am
mo
ndm
fg.c
om
Hammond Manufacturing Co. Inc.
256 Sonwil Dr.
Cheektowaga, NY 14225
USA
Phone: 716-651-0086 Fax: 716-651-0726
87
Shelves & Slides - Panel Mount
RAIL MOUNT KEYBOARD/MONITOR SHELF
• Mounts to panel rails using 5.25" (3U) of vertical panel space
• Extends 15" back from front panel
• Slanted keyboard section is 8.5"
• Rear lip to reduce chance of monitor being pushed off rear of shelf
• Available in either 19" or 23" rack panel width
• 14 Ga. steel construction
• Weight load tested to 160 pounds
• Finished in rugged black textured powder paint
Panel
Width
Par t Number
RKBM19BK1
RKBM23BK1
ADJUSTABLE SHELF
• Separate, reversible side brackets for maximum flexibility (allows shelf to
extend inside or outside the rack)
• 4 different depth settings (depending on location of side brackets)
• 14 Ga. steel construction, finished in rugged black textured powder paint
Pa r t Nu mb e r
DNRMA1916BK1
DNRMA1920BK1
DNRMA2316BK1
DNRMA2320BK1
Pa n e l
Wi dt h
19"
19"
23"
23"
Shelf
Depth
16"
20"
16"
20"
RAIL MOUNT EQUIPMENT SHELF
• A closed shelf with 1.5” dia. holes in each bottom corner for cord access
• Fabricated from 18 gauge steel
• Inside dimensions 17.2” wide x 15” deep
• Weight load tested to 75 pounds
• Opening height is only 1” less than panel height
• Finished in white (to aid visibility), powder paint
Par t Number
White Smooth
RASE1900815WH2
RASE1901015WH2
RASE1901215WH2
88
ww
w.h
am
mo
ndm
fg.c
om
Panel
Height
8.75"
10.50"
12.25"
256 Sonwil Dr.
USA
很抱歉,暂时无法提供与“DNDMS1922BK1”相匹配的价格&库存,您可以联系我们找货
