Shelves (Fixed) - Internal Mount
(Two Pair of Panel Rails)
Path: Home > Rack Index > Shelves (Fixed) - Internal Mount - Two Pair of Panel Rails
Fixed Shelf (Unvented)
z
z
z
z
z
click to enlarge
z
z
z
z
z
z
z
Attach to the sides of both pair of rack combination
rails
Requires no front rail mounting
Front & rear lip folded for extra strength
Weight load tested (RFVS2426BK1) to 350 pounds!
Versatile design - can be used as shown (easy to
install) or upside down (front & rear lip become
equipment retainers)
Heavy duty, 14 Ga. steel construction
Sides folded up for easy hardware installation from
above
Sides are slotted for easy adjustment with most rail
depth locations
Rugged textured powder paint finish
Includes all mounting hardware
If used with our square hole rails you will need to
order P/N CPRSA rail adaptor for each shelf ordered.
Link here (below) to more information.
MOUNTS ON TWO PAIR OF PANEL RAILS
(FRONT & BACK)
UNVENTED - 19" Rack Mount
Part Number
3D
AutoCAD
Solid Model Shelf
Color Reader .dxf File
.stp files Depth
File (zipped) (zipped)
RFUS1918BK1 Black
RFUS1918CG1 Beige*
18"
63K
38K
19K
RFUS1921BK1 Black
RFUS1921CG1 Beige*
64K
41K
23K
RFUS1926BK1 Black
RFUS1926CG1 Beige*
63K
11K
23K
RFUS1931BK1 Black
RFUS1931CG1 Beige*
70K
42K
25K
21"
26"
31"
*Note: "CG2" (Beige color) is being phased out from stock
UNVENTED - 24" Rack Mount
Part Number
3D
AutoCAD
Solid Model Shelf
.stp files Depth
RFUS2418BK1 Black
RFUS2418CG1 Beige*
62K
38K
19K
RFUS2421BK1 Black
RFUS2421CG1 Beige*
63K
41K
23K
RFUS2426BK1 Black
RFUS2426CG1 Beige*
63K
41K
23K
RFUS2431BK1 Black
RFUS2431CG1 Beige*
63K
42K
25K
18"
21"
26"
31"
Note2: Weight load tested (RFUS2426BK1) to 350 pounds.
Fixed Shelf (Vented)
z
z
z
click to enlarge
z
z
z
z
z
z
z
z
z
z
rails
Provides a sturdy shelf without obstructing upward
heat movement
above
depth locations
(FRONT & BACK)
Part Number
3D
AutoCAD
Solid Model Shelf
.stp files Depth
RFVS1918BK1 Black
RFVS1918CG1 Beige*
133K
139K
250K
RFVS1921BK1 Black
RFVS1921CG1 Beige*
133K
141K
258K
RFVS1926BK1 Black
RFVS1926CG1 Beige*
239K
172K
329K
RFVS1931BK1 Black
RFVS1931CG1 Beige*
242K
173K
333K
18"
21"
26"
31"
VENTED - 24 " Rack Mount
Part Number
3D
AutoCAD
Solid Model Shelf
.stp files Depth
RFVS2418BK1 Black
RFVS2418CG1 Beige*
133K
144K
250K
RFVS2421BK1 Black
RFVS2421CG1 Beige*
135K
146K
255K
RFVS2426BK1 Black
RFVS2426CG1 Beige*
153K
179K
329K
RFVS2431BK1 Black
RFVS2431CG1 Beige*
152K
180K
333K
18"
21"
26"
31"
Note2: Weight load tested (RFVS2426BK1) to 350 pounds.
"Zero Space" - Fixed Shelf (Vented)
z
z
Attaches to the side of both pairs of rack combination
rails (see drawing)
No obstruction to front panel space or equipment
z
z
z
z
z
click to enlarge
z
z
z
z
z
z
click to enlarge
z
Requires no front rail mounting or front rack space
Vented to provide a sturdy shelf without obstructing
upward heat movement
Rear lip folded up for extra strength & acts as a rear
equipment retainer
Rear lip is covered with a rubber channel to avoid
equipment scratching and cable chaffing (see drawing
to the left)
Includes two equipment stops which can be fastened
anywhere on the shelf (#5 in drawing to the left)
above
depth locations
(FRONT & BACK)
Part Number
3D
AutoCAD
Solid Model Shelf
Color Reader .dxf Files
.stp files Depth
RZVS1918BK1 Black
18"
167K
119K
154K
124K
134K
184K
146K
175K
244K
162K
207K
304K
RZVS1921BK1 Black
21"
RZVS1926BK1 Black
26"
RZVS1931BK1 Black
31"
Adjustable Depth - Fixed Shelf - Light Duty
z
z
z
z
z
Uses 1U (1.75") of rack space
Adjustable mounting depth
Choice of unvented or vented versions
Finished in a rugged textured powder paint finish
click to enlarge
z
z
z
Weight load tested to 75 pounds.
(FRONT & BACK)
Part Number
3D
AutoCAD
Adjustable
Solid Model
Depth
.stp file
Range
RMASU1917BK1 Black
17" to 27"
182K
76K
68K
190K
76K
69K
180K
76K
69K
RMASU1925BK1 Black
25" to 35"
RMASU1930BK1 Black
30" to 40"
Part Number
3D
AutoCAD
Adjustable
Solid Model
Depth
.stp file
(zipped)
Range
File
(zipped)
RMASV1917BK1 Black
17" to 27"
233K
151K
177K
RMASV1925BK1 Black
25" to 35"
248K
169K
211K
263K
177K
227K
RMASV1930BK1 Black
30" to 40"
Note: Weight load tested to 75 pounds.
Adjustable Depth - Fixed Shelf - HEAVY DUTY
z
z
z
z
Uses 2U (3.5") of rack space
z
z
z
z
Weight load tested to 200 pounds.
(FRONT & BACK)
Part Number
3D
AutoCAD
Adjustable
Solid Model
Depth
.stp file
(zipped)
Range
File
(zipped)
RMASUHD1917BK1 Black
17" to 27"
196K
79K
75K
195K
79K
75K
194K
79K
77K
RMASUHD1925BK1 Black
25" to 35"
RMASUHD1936BK1 Black
36" to 48"
Part Number
3D
AutoCAD
Adjustable
Solid Model
Depth
.stp file
Range
RMASVHD1917BK1 Black
17" to 27"
283K
140K
166K
322K
165K
218K
363K
198K
287K
RMASVHD1925BK1 Black
25" to 35"
RMASVHD1936BK1 Black
36" to 48"
Note: Weight load tested to 200 pounds.
Fixed Chassis/Shelf
z
z
z
z
z
z
z
z
Shelf can be used as a permanently
mounted support shelf or as a pull out
chassis
Will also accept type "RSLIDE"
equipment slides (see below) for pull
out applications
18-gauge steel shelf and 14-gauge
brackets
Weight load tested (RASC1922WH2) to
85 pounds.
Shelf is 16.8” wide and 0.5” high
Finished in a smooth white powder paint
for high visability
PANEL RAILS (FRONT & BACK)
19" Rack Mount
Part Number
3D
AutoCAD
Solid Model Shelf Depth Bracket Depth
Reader .dxf file
.stp file
Inches
Inches
RASC1912WH2
153K
70K
RASC1916WH2
159K
68K
68K
13.2
15.9
14.9
21.9
20.9
63K
RASC1922WH2
160K
11.9
63K
63K
24" Rack Mount
Part Number
3D
AutoCAD
Reader .dxf file
.stp file
Inches
Inches
RASC2412WH2
152K
70K
63K
155K
68K
63K
152K
68K
63K
RASC2416WH2
RASC2422WH2
11.9
13.2
15.9
14.9
21.9
20.9
Note: Weight load tested (RASC1922WH2) to 85 pounds.
RAIL ACCESSORIES
Square Hole Panel Rail Adaptor
Part Number CPRSA
z
z
z
z
click to enlarge
REQUIRED ONLY
when using square
hole panel rails with
dual rail pair
mounted shelves
works with RFVS,
RFUS, RZVS and
RASC shelves
set of 4
includes mounting
hardware
AutoCAD
3D
.dxf
Solid
Reader & .dwg Model
Files
.stp file
File
(zipped) (zipped)
71K
32K
9K
Shelves & Slides - catalog pages (5) - Adobe Reader .pdf format (198K)
all accessories - catalog pages (44) - Adobe Reader .pdf format (1,495K)
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock check
and ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 1998-2011 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com
很抱歉,暂时无法提供与“RMASUHD1925BK1”相匹配的价格&库存,您可以联系我们找货
