DNDMS1916BK1
DNDMS1916BK1
    HAMMONDMANUFACTURING
    SHELF FIXED 16X19" BLACK
DNDMS1916BK1 数据手册
Shelves - Panel Mount RAIL MOUNT - DUAL MODEM SHELVES • Standard 19” rack mount - overall 19.5" deep, uses 3.5” (2U) of panel space • Dual modem shelf permits front and rear access to modems on open relay racks • Unvented version (pictured) available in either 19" or 23" rack panel width • 16 gauge steel construction, weight load tested to 200 pounds • The vented version provides a sturdy shelf without obstructing upward heat movement • Powder paint finish • Requires mounting hardware Unvented Par t Number Black Textured Grey Smooth DNDMS19BK1 DNDMS19GY2 DNDMS23BK1 - Panel Width 19" 23" Vented Par t Number Black Textured Grey Smooth DNDMV19BK1 DNDMV19GY2 Panel Width 19" RAIL MOUNT SHELVES • Standard 19” rack mount - rail mount • 17.25” wide and uses 5.25” (3U) of panel space, choice of two depths, either 15” or 20" • 14 gauge steel construction, weight load tested to 200 pounds (unvented), 200 pounds (vented) • Mounts to front rail either as an internal shelf or external shelf/work area • The vented version provides a sturdy shelf without obstructing upward heat movement • Powder paint finish • Requires mounting hardware Unvented Black Textured RASU190515BK1 RASU190520BK1 RASU230515BK1 RASU230520BK1 Par t Number Beige Textured RASU190515CG1 RASU190520CG1 - Grey Smooth RASU190515GY2 - Panel Width ' ' ! ! Shelf Depth #  #  Panel Width ' ' ! ! Shelf Depth #  #  Vented Black Textured RASV190515BK1 RASV190520BK1 RASV230515BK1 RASV230520BK1 © Par t Number Beige Textured RASV190515CG1 RASV190520CG1 - Grey Smooth RASV190515GY2 - Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 87 Shelves & Slides - Panel Mount RAIL MOUNT KEYBOARD/MONITOR SHELF • Standard 19” rack mount • Mounts to panel rails using 5.25" (3U) of vertical panel space • Extends 15" back from front panel • Slanted keyboard section is 8.5" • Rear lip to reduce chance of monitor being pushed off rear of shelf • Available in either 19" or 23" rack panel width • 14 Ga. steel construction • Weight load tested to 160 pounds • Finished in rugged black textured powder paint • Requires mounting hardware Panel Width ' ! Par t Number RKBM19BK1 RKBM23BK1 ADJUSTABLE SHELF • Standard 19” rack mount • Mounts to panel rails using 5.25" (3U) of vertical panel space • Separate, reversible side brackets for maximum flexibility (allows shelf to extend inside or outside the rack) • 4 different depth settings (depending on location of side brackets) • 14 Ga. steel construction, finished in rugged black textured powder paint • Requires mounting hardware Pa r t Nu mb e r DNRMA1916BK1 DNRMA1920BK1 DNRMA2316BK1 DNRMA2320BK1 Pa n e l Wi dt h 19" 19" 23" 23" Shelf Depth 16" 20" 16" 20" RAIL MOUNT EQUIPMENT SHELF • Standard 19” rack mount • A closed shelf with 1.5” dia. holes in each bottom corner for cord access • Fabricated from 18 gauge steel • Inside dimensions 17.2” wide x 15” deep • Weight load tested to 75 pounds • Opening height is only 1” less than panel height • Finished in white (to aid visibility), powder paint • Requires mounting hardware Par t Number White Smooth RASE1900815WH2 RASE1901015WH2 RASE1901215WH2 88 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Panel Height 8.75" 10.50" 12.25" Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726
DNDMS1916BK1 价格&库存
很抱歉,暂时无法提供与“DNDMS1916BK1”相匹配的价格&库存,您可以联系我们找货
