Hammond Mfg. - Welded "Contempra 4" Rack Frames (Series C4F)
Page 1 of 8
Welded - "Contempra 4" Rack Frames
(C4F Series)
Path: Home > Rack Index > Welded Cabinet Frames (C4F Series)
Features:
Create your own custom assembly using our C4
frame and choice of accessories below.
Allows standard 19" rack mounting of equipment
30" width provides wider internal cabling space
around rack mounted equipment
For a stock pre-assembled version see our C4RR
series.
Welded 14 gauge steel frame with reinforced
corners
Open bottom for cable access
4 - 3.5" cable entry holes in top for cable access
(includes covers)
An overall height of 83.5" allows for easy
movement through most doorways
The seismic loading of the C4 cabinet was
determined in accordance with the Uniform
Building Code 1997 (UBC 97) for Seismic Zone 4
when used with part number C4K-Z4 - floor bolt
down kit (see general accessories section below)
Finished in rugged textured powder paint
Check out our
http://www.hammondmfg.com/c4rack_cmpnt.htm
for this series!
3/18/2013
Page 2 of 8
30" Wide (External) - Frame Only
Part Number
AutoCAD Panel Height Overall Dimensions (Inches)
Color Reader .dxf File
A
B
Height Wt. lbs.
Inches
Units
(Width) (Depth) (Less Feet)
File (zipped)
19" Rack Mount
C4F307731BK1 Black
119K
50K
126K
58K
C4F307736BK1 Black
C4F307742BK1 Black
77
44
30
31.5
82.81
200
77
44
30
36
82.81
206
77
44
30
42
82.81
214
3/18/2013
122K
Page 3 of 8
52K
Accessories
30" Wide Rack Components:
C4 Doors
Solid Door
Plexi Door
Description
Perforated Door
Black Part Number
Plexi Door
C4DF3077SBK1
C4DF3077PBK1
Perforated Door
C4DF3077VBK1
Solid Door
C4 Side Panels
3/18/2013
Solid Side Panel
Page 4 of 8
Vented Side Panel
Description
Solid Side Panels - 31.5"
Deep
Solid Side Panels - 36"
Deep
Solid Side Panels - 42"
Deep
Vented Side Panels 31.5" Deep
Vented Side Panels - 36"
Deep
Vented Side Panels - 42"
Deep
Black Part Number
C4SP7731SBK1
C4SP7736SBK1
C4SP7742SBK1
C4SP7731VBK1
C4SP7736VBK1
C4SP7742VBK1
Fan Tops
Fan Top with 4 4.7" Fans
Description
Black Part Number Beige Part Number
Fan Top with 4 - 4.7" fans (30 x
C2T2423F4BK1 C2T2423F4CG1
31.5")
3/18/2013
36")
42")
Fan Top with 10" fan (30 x
31.5")
Fan Top with 10" fan (30 x 36")
Fan Top with 10" fan (30 x 42")
Page 5 of 8
C2T2431F4BK1 C2T2431F4CG1
C2T2436F4BK1 C2T2436F4CG1
C2T2423F10BK1 C2T2423F10CG1
C2T2431F10BK1 C2T2431F10CG1
C2T2436F10BK1 C2T2436F10CG1
C4 Tops
Description
Vented/Fan Cutout top - 31.5"
deep
Vented/Fan Cutout top - 36"
deep
Vented/Fan Cutout top - 42"
deep
31.5" Deep Vented Top
36" Deep Vented Top
42" Deep Vented Top
C2T2423VFBK1 C2T2423VFCG1
C2T2431VFBK1 C2T2431VFCG1
C2T2436VFBK1 C2T2436VFCG1
C2T2423VBK1
C2T2431VBK1
C2T2436VBK1
C2T2423VCG1
C2T2431VCG1
C2T2436VCG1
C4 Bottoms
Solid Bottom
Description
31.5" Deep Solid Bottom
Black Part Number
36" Deep Solid Bottom
C4B3031SBK1
C4B3036SBK1
42" Deep Solid Bottom
C4B3042SBK1
C4 19" Panel Mount Shelves
3/18/2013
Vented Shelf
Page 6 of 8
Solid Shelf
Description
Solid - Depth adjust from 25" to 35"
Black Part Number
RMASU1925BK1
RMASU1930BK1
Solid - Depth adjusts from 30" to 40"
Vented - Depth adjusts from 25" to 35"
Vented - Depth adjusts from 30" to 40"
RMASV1925BK1
RMASV1930BK1
General Accessories
Vertical Cable Manager
Panel Rail
Accessory Rail
Description
Part Number
19" Panel Rails with Square Holes (pair) with rack
C4PR77SZPL
U markings
19" Accessory Rail
C4AR77SZPL
Instructions
3/18/2013
Vertical Cable Manager with door
Ganging Kit
Caster Non-Locking (4)
Page 7 of 8
C4VCM77BK1
CGH01
1425BH
Floor Bolt Down Kit
(Required for Zone 4 compliance - see assembly C4K-Z4
instructions)
10-32 x 0.63" black pan head screw with nylon
washer
10-32 cage nuts
M6 Cage Nuts
12 - 24 Cage Nuts
1421ABK25* or
1421ABK100*
1421CNA25* or
1421CNA100*
1421CNB25* or
1421CNB100*
1421CNC25* or
1421CNC100*
* 25 - package quantity of 25, 100 - package quantity of 100
Accessory Links:
Aluminum rack panels (PBPA series)
Steel rack panels (PBPS series)
Formed steel rack panels (PBFS series)
Ventilated & Access Panels (Louvers, slots, baffles etc.)
Doors & Chassis - Panel Mount (Hinged & fixed)
Cable Organizing (Panel mount rings, "hook & loop" strap panels & guides)
Shelves - Panel Mount (Fixed, solid & vented)
Keyboard Shelves & Drawers (Vertical rail mount)
Rack mount power bars (1582 & 1583 series)
Fans (Fans, Fan Kits, Grills & Filters)
Cooling Panels (Ventilated Panels, Fan Panels & Baffles)
Blowers (HB series)
Fan Trays (FT series)
Mounting hardware (Hardware)
Check out our
for this series!
3/18/2013
Page 8 of 8
Exactly what you are looking for???
Link to our stocking distributors - most have "on-line" pricing, stock
check and ordering!!!
Order from your favorite distributor
Home | Products | Distributors | Technical | Contact Us | Other Options
Copyright; © 1998-2012 Hammond Mfg Co Inc
URL: http://www.hammondmfg.com/
3/18/2013
很抱歉,暂时无法提供与“C2T2436VFLG1”相匹配的价格&库存,您可以联系我们找货
