RASC2422WH2
RASC2422WH2
    HAMMONDMANUFACTURING
    SHELF FIXED 22X22.9X1.32" WHITE
RASC2422WH2 数据手册
Shelves & Slides - Dual Pair Rail Mount FIXED CHASSIS/SHELF • Shelf can be used as a permanently mounted support shelf or as a pull out chassis • Will also accept type "RSLIDE" equipment slides (see below) for pull out applications • If used with our square hole rails you will need to order P/N CPRSA rail adaptor for each shelf ordered • 18-gauge steel shelf and 14-gauge brackets • Weight load tested to 85 pounds • Shelf is 16.8” wide and 0.5” high • Finished in white powder paint for high visibility • MOUNTS ON TWO PAIR OF MOUNTING RAILS (FRONT & BACK) Par t Number RASC1912WH2 RASC1916WH2 RASC1922WH2 RASC2412WH2 RASC2416WH2 RASC2422WH2 Shelf Depth 19" Width 11.9" 15.9" 21.9" 24" Width 11.9" 15.9" 21.9" Bracket Depth 13.2" 14.9" 20.9" 13.2" 14.9" 20.9" EQUIPMENT SLIDES • SOLD IN PAIRS • Slide travel equals length plus 1” • Heavy duty - double rail, ball bearing type • Requires mounting hardware • MOUNTS ON TWO PAIR OF MOUNTING RAILS (FRONT & BACK) Par t Number Length RSLI DE12 RSLI DE16 RSLI DE22   $  Capacity (Pair)   !   EQUIPMENT SIDE SUPPORT ANGLES • SOLD IN PAIRS • Angles mount along side of rack to both front & rear rack mounting rails • Supplies side support for heavy equipment (relieving stress from the front panel) or as an aid in installation of deep equipment • Slots allow up/down and front/back adjustments • Made of 14 gauge steel, with dimensions of 1.75" x 1.75" • Finished in rugged textured black powder paint • Requires mounting hardware • If used with our square hole rails you will need to order P/N CPRSA rail adaptor for each support pair ordered • MOUNTS ON TWO PAIR OF MOUNTING RAILS (FRONT & BACK) Pa r t Nu mb e r RASA12BK3 RASA16BK3 RASA22BK3 RASA28BK3 90 © Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Length 9.97" 14.95" 20.95" 28.00" Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 Angles & Supports REAR SUPPORT BAR • Standard 19" rack mountable • Heavy duty 14 gauge steel support mounts to rear rack rails • Supports the rear of heavy or deep equipment (relieving stress from the front panel and/or as an aid for equipment mounting & removing) • Folded top edge for extra deep edge & extra strength • Uses only 1U (1.75") of panel space • Includes slots for easy installation of cable ties or velcro belts for cable organizing • Rugged textured black powder paint finish • Requires panel mounting hardware Pa r t Nu mb e r RASB19BK1 Length 19" EQUIPMENT HOLD DOWN BRACKETS • Standard 19" & 23" rack mountable • Designed mainly for our relay racks but can be used on any rack • Heavy duty 16 gauge steel bracket fastens between rails for support across equipment • Perfect for stabilizing shelf mounted P.C. towers & monitors • Uses only 1U (1.75") of panel space • Includes slots for easy installation of cable ties or velcro belts for cable organizing in between brackets • Includes four hold down brackets (enough for two side by side towers) • Includes rubber bracket feet to keep from marking equipment • Rugged textured black powder paint finish • Includes mounting hardware Pa r t Nu mb e r DNTB19BK1 DNTB23BK1 Pa n e l Wi d t h 19" 23" SQUARE HOLE PANEL RAIL ADAPTOR • Used in conjunction with square hole panel rails to allow use of dual rail mount accessories • Use with our RASA, RASC, RFUS, RFVS series accessories • Set of four • Includes mounting hardware • Rugged textured black powder paint finish Pa r t Nu mb e r CPRSA © Adapts 1 Shel f Hammond Manufacturing Co. Ltd. 394 Edinburgh Rd. North Guelph, Ontario N1H 1E5 CANADA Phone: 519-822-2960 Fax: 519-822-0715 ww w.h am mo ndm fg.c om Hammond Manufacturing Co. Inc. 256 Sonwil Dr. Cheektowaga, NY 14225 USA Phone: 716-651-0086 Fax: 716-651-0726 91
RASC2422WH2
物料型号: - 固定底盘/架子:RASC1912WH2, RASC1916WH2, RASC1922WH2, RASC2412WH2, RASC2416WH2, RASC2422WH2 - 设备滑轨:RSLIDE12, RSLIDE16, RSLIDE22 - 设备侧支撑角:RASA12BK3, RASA16BK3, RASA22BK3, RASA28BK3 - 后支撑杆:RASB19BK1 - 设备固定支架:DNTB19BK1, DNTB23BK1 - 方孔板轨适配器:CPRSA
器件简介: - 固定底盘/架子:可用作永久安装的支撑架或拉出式底盘,接受RSLIDE系列设备滑轨,采用18号钢架和14号钢支架,承重85磅,有白色粉末涂层。
- 设备滑轨:成对出售,滑轨行程等于长度加1英寸,重型双轨球轴承型,需要安装硬件。
- 设备侧支撑角:成对出售,安装在机架两侧,提供重型设备的侧面支撑,采用14号钢制成,有黑色粉末涂层。
- 后支撑杆:标准19英寸机架安装,重型14号钢支撑杆,支撑重型或深设备,使用1U(1.75英寸)面板空间。
- 设备固定支架:标准19英寸和23英寸机架安装,重型16号钢支架,用于稳定安装在架子上的PC塔和显示器。
- 方孔板轨适配器:与方孔板轨配合使用,允许使用双轨安装配件。
引脚分配参数特性功能详解应用信息封装信息:文档中未提供这些信息。
RASC2422WH2 价格&库存
很抱歉,暂时无法提供与“RASC2422WH2”相匹配的价格&库存,您可以联系我们找货
