SmartRack Side Panel with Key-Locking Latches
for Tripp Lite 48U Server Rack Cabinet, 1 Panel
MODEL NUMBER: SR48SIDE
Highlights
Pre-installed latches lock
securely with included keys to
protect equipment from theft
Ideal as replacement panel or
for expansion rack cabinets
Made from heavy-duty steel
engineered to stand up to busy
IT environments
Designed for use with 42 in.
(1050 mm) depth, 48U rack
enclosures
Fits models based on the
SR48UB frame design, including
SR48UBEXP and SR48UBWD
Package Includes
Locking steel panel attaches to the side of your SR48UB-based server rack enclosure.
Features
Single Steel Side Panel for Installation on Your Tripp Lite 48U Rack Cabinet
The SmartRack® SR48SIDE side panel features pre-installed key-locking latches for securing your rack
equipment against tampering and theft. Designed for Tripp Lite’s standard-depth SR48UB rack frame, this
panel can also be added to the side of an expansion cabinet (SR48UBEXP) when application needs have
changed or onto a wide cabinet (SR48UBWD) as the depth remains the same. They can also be used as
replacements for existing side panels.
Convert an Expansion Cabinet into a Cabinet with Side Panels
When needs change and you want to separate your expansion rack cabinets (such as Tripp Lite’s
SR48UBEXP), add four** SR48SIDE heavy-duty steel panels to the sides of them to convert the racks
into standard cabinets. Note: This package includes only one (1) singular panel. You will need to purchase
four SR48SIDE panels to completely populate an expandable rack.
Specifications
OVERVIEW
UPC Code
037332177148
Accessory Type
Side Panel
Accessory Class
Rack Accessories
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
5.08 x 97.79 x 97.79
Shipping Dimensions (hwd / in.)
2.00 x 38.50 x 38.50
1/2
Side panel with locking latches
(2) Keys
Shipping Weight (kg)
12.25
Shipping Weight (lbs.)
27.00
WARRANTY
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“SR48SIDE”相匹配的价格&库存,您可以联系我们找货
